7.1 Release
nvdsinferserver::InferBaseContext Class Referenceabstract
The base class for handling the inference context.
It creates the NN backend, pre-processors, post-processors and calls these for the inference processing.
Definition at line 52 of file infer_base_context.h.
Inheritance diagram for nvdsinferserver::InferBaseContext:
Collaboration diagram for nvdsinferserver::InferBaseContext:
Public Member Functions
 InferBaseContext ()
 ~InferBaseContext () override
NvDsInferStatus initialize (const std::string &prototxt, InferLoggingFunc logFunc) final
NvDsInferStatus run (SharedIBatchArray input, InferOutputCb outputCb) final
NvDsInferStatus deinit () override
Protected Member Functions
virtual void backendConsumedInputs (SharedBatchArray inputs)
virtual SharedCuStreammainStream ()=0
const ic::InferenceConfig & config () const
int maxBatchSize () const
int uniqueId () const
BaseBackendbackend ()
const SharedDllHandlecustomLib () const
bool needCopyInputToHost () const
void print (NvDsInferLogLevel l, const char *msg)
bool needPreprocess () const
◆ InferBaseContext()
nvdsinferserver::InferBaseContext::InferBaseContext ( )
◆ ~InferBaseContext()
nvdsinferserver::InferBaseContext::~InferBaseContext ( )
override
Member Function Documentation
◆ backend()
BaseBackend* nvdsinferserver::InferBaseContext::backend ( )
inlineprotected
Definition at line 101 of file infer_base_context.h.
◆ backendConsumedInputs()
virtual void nvdsinferserver::InferBaseContext::backendConsumedInputs ( SharedBatchArray  inputs)
inlineprotectedvirtual
Definition at line 93 of file infer_base_context.h.
◆ config()
const ic::InferenceConfig& nvdsinferserver::InferBaseContext::config ( ) const
inlineprotected
Definition at line 98 of file infer_base_context.h.
◆ customLib()
const SharedDllHandle& nvdsinferserver::InferBaseContext::customLib ( ) const
inlineprotected
Definition at line 102 of file infer_base_context.h.
◆ deinit()
NvDsInferStatus nvdsinferserver::InferBaseContext::deinit ( )
override
◆ initialize()
NvDsInferStatus nvdsinferserver::InferBaseContext::initialize ( const std::string &  prototxt,
final
◆ mainStream()
virtual SharedCuStream& nvdsinferserver::InferBaseContext::mainStream ( )
protectedpure virtual
◆ maxBatchSize()
int nvdsinferserver::InferBaseContext::maxBatchSize ( ) const
inlineprotected
Definition at line 99 of file infer_base_context.h.
◆ needCopyInputToHost()
bool nvdsinferserver::InferBaseContext::needCopyInputToHost ( ) const
protected
◆ needPreprocess()
bool nvdsinferserver::InferBaseContext::needPreprocess ( ) const
protected
◆ print()
void nvdsinferserver::InferBaseContext::print ( NvDsInferLogLevel  l,
const char *  msg
protected
◆ run()
NvDsInferStatus nvdsinferserver::InferBaseContext::run ( SharedIBatchArray  input,
final
◆ uniqueId()
int nvdsinferserver::InferBaseContext::uniqueId ( ) const
inlineprotected
Definition at line 100 of file infer_base_context.h.
