7.1 Release
nvdsinferserver::InferTrtISContext Class Reference
Inference context accessing Triton Inference Server in C-API mode.
Definition at line 33 of file infer_trtis_context.h.
Inheritance diagram for nvdsinferserver::InferTrtISContext:
Collaboration diagram for nvdsinferserver::InferTrtISContext:
Public Member Functions
 InferTrtISContext ()
 Constructor, default. More...
 ~InferTrtISContext () override
 Destructor, default. More...
NvDsInferStatus deinit () override
 Synchronize on the CUDA stream and call InferCudaContext::deinit(). More...
SharedCuStreammainStream () override
 Get the main processing CUDA event. More...
SharedSysMem acquireTensorHostBuf (const std::string &name, size_t bytes)
 Allocator. More...
SharedCuEvent acquireTensorHostEvent ()
 Acquire a CUDA event from the events pool. More...
NvDsInferStatus initialize (const std::string &prototxt, InferLoggingFunc logFunc) final
NvDsInferStatus run (SharedIBatchArray input, InferOutputCb outputCb) final
Protected Member Functions
NvDsInferStatus fixateInferenceInfo (const ic::InferenceConfig &config, BaseBackend &backend) override
 Check the tensor order, media format, and datatype for the input tensor. More...
NvDsInferStatus createPreprocessor (const ic::PreProcessParams &params, std::vector< UniqPreprocessor > &processors) override
 Create the surface converter and network preprocessor. More...
NvDsInferStatus createPostprocessor (const ic::PostProcessParams &params, UniqPostprocessor &processor) override
 Create the post-processor as per the network output type. More...
NvDsInferStatus preInference (SharedBatchArray &inputs, const ic::InferenceConfig &config) override
 Initialize non-image input layers if the custom library has implemented the interface. More...
NvDsInferStatus extraOutputTensorCheck (SharedBatchArray &outputs, SharedOptions inOptions) override
 Post inference steps for the custom processor and LSTM controller. More...
void notifyError (NvDsInferStatus status) override
 In case of error, notify the waiting threads. More...
void getNetworkInputInfo (NvDsInferNetworkInfo &networkInfo) override
 Get the network input layer information. More...
int tensorPoolSize () const
 Get the size of the tensor pool. More...
virtual void backendConsumedInputs (SharedBatchArray inputs)
const ic::InferenceConfig & config () const
int maxBatchSize () const
int uniqueId () const
BaseBackendbackend ()
const SharedDllHandlecustomLib () const
bool needCopyInputToHost () const
void print (NvDsInferLogLevel l, const char *msg)
bool needPreprocess () const
Protected Attributes
NvDsInferNetworkInfo m_NetworkImageInfo {0, 0, 0}
 Network input height, width, channels for preprocessing. More...
InferMediaFormat m_NetworkImageFormat = InferMediaFormat::kRGB
 The input layer media format. More...
std::string m_NetworkImageName
 The input layer name. More...
InferTensorOrder m_InputTensorOrder = InferTensorOrder::kNone
 The input layer tensor order. More...
InferDataType m_InputDataType = InferDataType::kFp32
 The input layer datatype. More...
std::vector< SharedCudaTensorBufm_ExtraInputs
 Array of buffers of the additional inputs. More...
MapBufferPool< std::string, UniqSysMemm_HostTensorPool
 Map of pools for the output tensors. More...
SharedBufPool< std::unique_ptr< CudaEventInPool > > m_HostTensorEvents
 Pool of CUDA events for host tensor copy. More...
UniqLstmController m_LstmController
UniqStreamManager m_MultiStreamManager
 stream-id based management. More...
UniqInferExtraProcessor m_ExtraProcessor
 Extra and custom processing pre/post inference. More...
CropSurfaceConverterm_SurfaceConverter = nullptr
 Preprocessor and post-processor handles. More...
NetworkPreprocessorm_NetworkPreprocessor = nullptr
Postprocessorm_FinalProcessor = nullptr
◆ InferTrtISContext()
nvdsinferserver::InferTrtISContext::InferTrtISContext ( )
◆ ~InferTrtISContext()
nvdsinferserver::InferTrtISContext::~InferTrtISContext ( )
override
Member Function Documentation
◆ acquireTensorHostBuf()
SharedSysMem nvdsinferserver::InferCudaContext::acquireTensorHostBuf ( const std::string &  name,
size_t  bytes
inherited
Allocator.
Acquire a host buffer for the inference output.
Parameters
[in]nameName of the output layer.
[in]bytesSize of the buffer.
Returns
Pointer to the memory buffer.
◆ acquireTensorHostEvent()
SharedCuEvent nvdsinferserver::InferCudaContext::acquireTensorHostEvent ( )
inherited
◆ backend()
BaseBackend* nvdsinferserver::InferBaseContext::backend ( )
inlineprotectedinherited
Definition at line 101 of file infer_base_context.h.
◆ backendConsumedInputs()
virtual void nvdsinferserver::InferBaseContext::backendConsumedInputs ( SharedBatchArray  inputs)
inlineprotectedvirtualinherited
Definition at line 93 of file infer_base_context.h.
◆ config()
const ic::InferenceConfig& nvdsinferserver::InferBaseContext::config ( ) const
Definition at line 98 of file infer_base_context.h.
◆ createPostprocessor()
NvDsInferStatus nvdsinferserver::InferCudaContext::createPostprocessor ( const ic::PostProcessParams &  params,
UniqPostprocessor processor
overrideprotectedvirtualinherited
Parameters
[in]paramsThe post processing configuration parameters.
[out]processorThe handle to the created post processor.
Returns
Status code.
Implements nvdsinferserver::InferBaseContext.
◆ createPreprocessor()
NvDsInferStatus nvdsinferserver::InferCudaContext::createPreprocessor ( const ic::PreProcessParams &  params,
std::vector< UniqPreprocessor > &  processors
Parameters
paramsThe preprocessor configuration.
processorsList of the created preprocessor handles.
Returns
Status code.
◆ customLib()
const SharedDllHandle& nvdsinferserver::InferBaseContext::customLib ( ) const
Definition at line 102 of file infer_base_context.h.
◆ deinit()
NvDsInferStatus nvdsinferserver::InferTrtISContext::deinit ( )
override
◆ extraOutputTensorCheck()
NvDsInferStatus nvdsinferserver::InferCudaContext::extraOutputTensorCheck ( SharedBatchArray outputs,
Parameters
[in,out]outputsThe output batch buffers array.
[in]inOptionsThe configuration options for the buffers.
Returns
Status code.
Reimplemented from nvdsinferserver::InferBaseContext.
◆ fixateInferenceInfo()
NvDsInferStatus nvdsinferserver::InferCudaContext::fixateInferenceInfo ( const ic::InferenceConfig &  config,
BaseBackend backend
Initiate the extra processor and lstm controller if configured.
Parameters
[in]configThe inference configuration protobuf message.
[in]backendThe inference backend instance.
Returns
Status code.
◆ getNetworkInputInfo()
void nvdsinferserver::InferCudaContext::getNetworkInputInfo ( NvDsInferNetworkInfo networkInfo)
inlineoverrideprotectedinherited
Definition at line 132 of file infer_cuda_context.h.
References nvdsinferserver::InferCudaContext::m_NetworkImageInfo.
◆ initialize()
NvDsInferStatus nvdsinferserver::InferBaseContext::initialize ( const std::string &  prototxt,
finalinherited
◆ mainStream()
SharedCuStream& nvdsinferserver::InferTrtISContext::mainStream ( )
inlineoverridevirtual
Definition at line 53 of file infer_trtis_context.h.
◆ maxBatchSize()
int nvdsinferserver::InferBaseContext::maxBatchSize ( ) const
Definition at line 99 of file infer_base_context.h.
◆ needCopyInputToHost()
bool nvdsinferserver::InferBaseContext::needCopyInputToHost ( ) const
protectedinherited
◆ needPreprocess()
bool nvdsinferserver::InferBaseContext::needPreprocess ( ) const
protectedinherited
◆ notifyError()
void nvdsinferserver::InferCudaContext::notifyError ( NvDsInferStatus  status)
◆ preInference()
NvDsInferStatus nvdsinferserver::InferCudaContext::preInference ( SharedBatchArray inputs,
Parameters
[in,out]inputsArray of the input batch buffers.
[in]configThe inference configuration settings.
Returns
Status code.
◆ print()
void nvdsinferserver::InferBaseContext::print ( NvDsInferLogLevel  l,
const char *  msg
protectedinherited
◆ run()
NvDsInferStatus nvdsinferserver::InferBaseContext::run ( SharedIBatchArray  input,
finalinherited
◆ tensorPoolSize()
int nvdsinferserver::InferCudaContext::tensorPoolSize ( ) const
protectedinherited
◆ uniqueId()
int nvdsinferserver::InferBaseContext::uniqueId ( ) const
Definition at line 100 of file infer_base_context.h.
Field Documentation
◆ m_ExtraInputs
std::vector<SharedCudaTensorBuf> nvdsinferserver::InferCudaContext::m_ExtraInputs
protectedinherited
Definition at line 213 of file infer_cuda_context.h.
◆ m_ExtraProcessor
UniqInferExtraProcessor nvdsinferserver::InferCudaContext::m_ExtraProcessor
protectedinherited
Definition at line 228 of file infer_cuda_context.h.
◆ m_FinalProcessor
Postprocessor* nvdsinferserver::InferCudaContext::m_FinalProcessor = nullptr
protectedinherited
Definition at line 234 of file infer_cuda_context.h.
◆ m_HostTensorEvents
SharedBufPool<std::unique_ptr<CudaEventInPool> > nvdsinferserver::InferCudaContext::m_HostTensorEvents
protectedinherited
Definition at line 221 of file infer_cuda_context.h.
◆ m_HostTensorPool
MapBufferPool<std::string, UniqSysMem> nvdsinferserver::InferCudaContext::m_HostTensorPool
protectedinherited
Definition at line 217 of file infer_cuda_context.h.
◆ m_InputDataType
InferDataType nvdsinferserver::InferCudaContext::m_InputDataType = InferDataType::kFp32
protectedinherited
Definition at line 208 of file infer_cuda_context.h.
◆ m_InputTensorOrder
InferTensorOrder nvdsinferserver::InferCudaContext::m_InputTensorOrder = InferTensorOrder::kNone
protectedinherited
Definition at line 204 of file infer_cuda_context.h.
◆ m_LstmController
UniqLstmController nvdsinferserver::InferCudaContext::m_LstmController
protectedinherited
LSTM controller.
Definition at line 224 of file infer_cuda_context.h.
◆ m_MultiStreamManager
UniqStreamManager nvdsinferserver::InferCudaContext::m_MultiStreamManager
protectedinherited
Definition at line 226 of file infer_cuda_context.h.
◆ m_NetworkImageFormat
InferMediaFormat nvdsinferserver::InferCudaContext::m_NetworkImageFormat = InferMediaFormat::kRGB
protectedinherited
Definition at line 196 of file infer_cuda_context.h.
◆ m_NetworkImageInfo
NvDsInferNetworkInfo nvdsinferserver::InferCudaContext::m_NetworkImageInfo {0, 0, 0}
protectedinherited
Definition at line 192 of file infer_cuda_context.h.
Referenced by nvdsinferserver::InferCudaContext::getNetworkInputInfo().
◆ m_NetworkImageName
std::string nvdsinferserver::InferCudaContext::m_NetworkImageName
protectedinherited
Definition at line 200 of file infer_cuda_context.h.
◆ m_NetworkPreprocessor
NetworkPreprocessor* nvdsinferserver::InferCudaContext::m_NetworkPreprocessor = nullptr
protectedinherited
Definition at line 233 of file infer_cuda_context.h.
◆ m_SurfaceConverter
CropSurfaceConverter* nvdsinferserver::InferCudaContext::m_SurfaceConverter = nullptr
protectedinherited
Definition at line 232 of file infer_cuda_context.h.
