23 #ifndef __INFER_BASE_CONTEXT_H__
24 #define __INFER_BASE_CONTEXT_H__
27 #include <condition_variable>
36 #include "infer_icontext.h"
37 #include "nvdsinferserver_config.pb.h"
39 namespace ic = nvdsinferserver::config;
58 const std::string& prototxt, InferLoggingFunc logFunc)
final;
63 virtual NvDsInferStatus createNNBackend(
const ic::BackendParams& params,
68 const ic::PreProcessParams& params,
69 std::vector<UniqPreprocessor>& processors) = 0;
73 const ic::InferenceConfig&
config) = 0;
88 void rawDataInferDone(
98 const ic::InferenceConfig&
config()
const {
return m_Config; }
118 InferLoggingFunc m_LoggingFunc;
119 uint32_t m_UniqueID = 0;
123 uint32_t m_MaxBatchSize = 1;
124 bool m_Initialized =
false;
131 std::vector<UniqPreprocessor> m_Preprocessors;
132 std::unordered_map<IPreprocessor*, IPreprocessor*> m_NextPreprocMap;
138 ic::InferenceConfig m_Config;
143 #define _MAX_LOG_LENGTH 4096
144 #define printMsg(level, tag_str, fmt, ...) \
146 char* baseName = strrchr((char*)__FILE__, '/'); \
147 baseName = (baseName) ? (baseName + 1) : (char*)__FILE__; \
148 std::vector<char> logMsgBuffer(_MAX_LOG_LENGTH, 0); \
149 snprintf(logMsgBuffer.data(), _MAX_LOG_LENGTH - 1, \
150 tag_str " %s() <%s:%d> [UID = %d]: " fmt, \
151 __func__, baseName, __LINE__, uniqueId(), ##__VA_ARGS__); \
152 this->print(level, logMsgBuffer.data()); \
155 #define printError(fmt, ...) \
157 printMsg(NVDSINFER_LOG_ERROR, "Error in", fmt, ##__VA_ARGS__); \
160 #define printWarning(fmt, ...) \
162 printMsg(NVDSINFER_LOG_WARNING, "Warning from", fmt, ##__VA_ARGS__); \
165 #define printInfo(fmt, ...) \
167 printMsg(NVDSINFER_LOG_INFO, "Info from", fmt, ##__VA_ARGS__); \
170 #define printDebug(fmt, ...) \
172 printMsg(NVDSINFER_LOG_DEBUG, "DEBUG", fmt, ##__VA_ARGS__); \
175 #define CTX_RETURN_NVINFER_ERROR(err, fmt, ...) \
176 CHECK_NVINFER_ERROR_PRINT( \
177 err, return ifStatus, printError, fmt, ##__VA_ARGS__)
179 #define CTX_RETURN_CUDA_ERR(err, fmt, ...) \
180 CHECK_CUDA_ERR_W_ACTION( \
181 err, return NVDSINFER_CUDA_ERROR, printError, fmt, ##__VA_ARGS__)
NvDsInferStatus initialize(const std::string &prototxt, InferLoggingFunc logFunc) final
std::shared_ptr< DlLibHandle > SharedDllHandle
const SharedDllHandle & customLib() const
@ NVDSINFER_SUCCESS
NvDsInferLogLevel
Enum for the log levels of NvDsInferContext.
bool needPreprocess() const
std::unique_ptr< BasePostprocessor > UniqPostprocessor
Processor interfaces.
std::shared_ptr< CudaStream > SharedCuStream
Cuda based pointers.
std::shared_ptr< IOptions > SharedOptions
NvDsInferStatus deinit() override
std::unique_ptr< BaseBackend > UniqBackend
The base class for handling the inference context.
void print(NvDsInferLogLevel l, const char *msg)
const ic::InferenceConfig & config() const
~InferBaseContext() override
std::function< void(NvDsInferStatus, SharedBatchArray)> InferCompleted
std::shared_ptr< IBatchArray > SharedIBatchArray
Base class of inference backend processing.
Header file for inference processing backend base class.
NvDsInferStatus run(SharedIBatchArray input, InferOutputCb outputCb) final
Preprocessor interface class.
virtual SharedCuStream & mainStream()=0
bool needCopyInputToHost() const
virtual void backendConsumedInputs(SharedBatchArray inputs)
NvDsInferStatus
