7.1 Release
nvdsinferserver::InferSimpleContext Class Reference
Definition at line 25 of file infer_simple_context.h.
Inheritance diagram for nvdsinferserver::InferSimpleContext:
Collaboration diagram for nvdsinferserver::InferSimpleContext:
Public Member Functions
 InferSimpleContext ()
 ~InferSimpleContext () override
NvDsInferStatus initialize (const std::string &prototxt, InferLoggingFunc logFunc) final
NvDsInferStatus run (SharedIBatchArray input, InferOutputCb outputCb) final
Protected Member Functions
NvDsInferStatus createNNBackend (const ic::BackendParams &params, int maxBatchSize, UniqBackend &backend)
NvDsInferStatus fixateInferenceInfo (const ic::InferenceConfig &config, BaseBackend &backend) override
NvDsInferStatus deinit () override
virtual void backendConsumedInputs (SharedBatchArray inputs)
const ic::InferenceConfig & config () const
int maxBatchSize () const
int uniqueId () const
BaseBackendbackend ()
const SharedDllHandlecustomLib () const
bool needCopyInputToHost () const
void print (NvDsInferLogLevel l, const char *msg)
bool needPreprocess () const
◆ InferSimpleContext()
nvdsinferserver::InferSimpleContext::InferSimpleContext ( )
◆ ~InferSimpleContext()
nvdsinferserver::InferSimpleContext::~InferSimpleContext ( )
override
Member Function Documentation
◆ backend()
BaseBackend* nvdsinferserver::InferBaseContext::backend ( )
inlineprotectedinherited
Definition at line 101 of file infer_base_context.h.
◆ backendConsumedInputs()
virtual void nvdsinferserver::InferBaseContext::backendConsumedInputs ( SharedBatchArray  inputs)
inlineprotectedvirtualinherited
Definition at line 93 of file infer_base_context.h.
◆ config()
const ic::InferenceConfig& nvdsinferserver::InferBaseContext::config ( ) const
Definition at line 98 of file infer_base_context.h.
◆ createNNBackend()
NvDsInferStatus nvdsinferserver::InferSimpleContext::createNNBackend ( const ic::BackendParams &  params,
int  maxBatchSize,
UniqBackend backend
protectedvirtual
◆ customLib()
const SharedDllHandle& nvdsinferserver::InferBaseContext::customLib ( ) const
Definition at line 102 of file infer_base_context.h.
◆ deinit()
NvDsInferStatus nvdsinferserver::InferSimpleContext::deinit ( )
overrideprotected
◆ fixateInferenceInfo()
NvDsInferStatus nvdsinferserver::InferSimpleContext::fixateInferenceInfo ( const ic::InferenceConfig &  config,
BaseBackend backend
overrideprotectedvirtual
◆ initialize()
NvDsInferStatus nvdsinferserver::InferBaseContext::initialize ( const std::string &  prototxt,
finalinherited
◆ maxBatchSize()
int nvdsinferserver::InferBaseContext::maxBatchSize ( ) const
Definition at line 99 of file infer_base_context.h.
◆ needCopyInputToHost()
bool nvdsinferserver::InferBaseContext::needCopyInputToHost ( ) const
protectedinherited
◆ needPreprocess()
bool nvdsinferserver::InferBaseContext::needPreprocess ( ) const
protectedinherited
◆ print()
void nvdsinferserver::InferBaseContext::print ( NvDsInferLogLevel  l,
const char *  msg
protectedinherited
◆ run()
NvDsInferStatus nvdsinferserver::InferBaseContext::run ( SharedIBatchArray  input,
finalinherited
◆ uniqueId()
int nvdsinferserver::InferBaseContext::uniqueId ( ) const
Definition at line 100 of file infer_base_context.h.
