7.1 Release
infer_simple_context.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2020-2021 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
13 #ifndef __NVDSINFERSERVER_SIMPLE_CONTEXT_H__
14 #define __NVDSINFERSERVER_SIMPLE_CONTEXT_H__
15
16 #include "infer_base_backend.h"
17 #include "infer_base_context.h"
18 #include "infer_cuda_utils.h"
19 #include "infer_datatypes.h"
20 #include "infer_utils.h"
21
22 namespace nvdsinferserver {
23
24
26 public:
28  ~InferSimpleContext() override;
29
30 protected:
32  const ic::BackendParams& params, int maxBatchSize,
35  const ic::InferenceConfig& config, BaseBackend& backend) override;
36  NvDsInferStatus deinit() override;
37
38 private:
39  // should not called
40  NvDsInferStatus createPreprocessor(
41  const ic::PreProcessParams& params,
42  std::vector<UniqPreprocessor>& processors) override;
43  NvDsInferStatus createPostprocessor(
44  const ic::PostProcessParams& params,
45  UniqPostprocessor& processor) override;
46  NvDsInferStatus allocateResource(
47  const ic::InferenceConfig& config) override;
48
49  void getNetworkInputInfo(NvDsInferNetworkInfo& networkInfo) override
50  {
51  networkInfo = m_NetworkImageInfo;
52  }
53  void notifyError(NvDsInferStatus status) override {}
54  SharedCuStream& mainStream() override { return m_Stream; }
55
56 private:
57  // Optional, not needed
58  NvDsInferNetworkInfo m_NetworkImageInfo{0, 0, 0};
59
60  SharedCuStream m_Stream{nullptr};
61 };
62
63 } // namespace nvdsinferserver
64
65 #endif //__NVDSINFERSERVER_SIMPLE_CONTEXT_H__
nvdsinferserver
Definition: infer_custom_process.h:24
nvdsinferserver::InferSimpleContext::InferSimpleContext
nvdsinferserver::InferBaseContext::maxBatchSize
int maxBatchSize() const
Definition: infer_base_context.h:99
nvdsinferserver::InferSimpleContext::fixateInferenceInfo
NvDsInferStatus fixateInferenceInfo(const ic::InferenceConfig &config, BaseBackend &backend) override
infer_datatypes.h
Header file for the data types used in the inference processing.
nvdsinferserver::InferSimpleContext::~InferSimpleContext
nvdsinferserver::InferSimpleContext::deinit
nvdsinferserver::InferSimpleContext::createNNBackend
NvDsInferStatus createNNBackend(const ic::BackendParams &params, int maxBatchSize, UniqBackend &backend)
infer_utils.h
nvdsinferserver::UniqBackend
std::unique_ptr< BaseBackend > UniqBackend
Definition: infer_base_backend.h:212
Definition: nvdsinfer.h:112
infer_cuda_utils.h
Header file declaring utility classes for CUDA memory management, CIDA streams and events.
nvdsinferserver::SharedCuStream
std::shared_ptr< CudaStream > SharedCuStream
Cuda based pointers.
Definition: infer_common.h:84
nvdsinferserver::InferBaseContext::backend
BaseBackend * backend()
Definition: infer_base_context.h:101
The base class for handling the inference context.
Definition: infer_base_context.h:52
nvdsinferserver::InferBaseContext::config
const ic::InferenceConfig & config() const
Definition: infer_base_context.h:98
Definition: infer_simple_context.h:25
nvdsinferserver::UniqPostprocessor
std::unique_ptr< BasePostprocessor > UniqPostprocessor
Processor interfaces.
Definition: infer_common.h:98
nvdsinferserver::BaseBackend
Base class of inference backend processing.
Definition: infer_base_backend.h:40
Header file for inference processing backend base class.
Header file of the base class for inference context.
NvDsInferStatus
NvDsInferStatus
Definition: nvdsinfer.h:220
