7.1 Release
nvdsinferserver::OtherPostprocessor Class Reference
Post processor class for tensor output for custom post processing.
Definition at line 270 of file infer_postprocess.h.
Inheritance diagram for nvdsinferserver::OtherPostprocessor:
Collaboration diagram for nvdsinferserver::OtherPostprocessor:
Public Types
using TensorAllocator = std::function< SharedSysMem(const std::string &name, size_t bytes)>
using EventAllocator = std::function< SharedCuEvent()>
using PostprocessDone = std::function< void(NvDsInferStatus, SharedBatchArray)>
Public Member Functions
 OtherPostprocessor (int uid, const ic::OtherNetworkParams &params)
void setDllHandle (const SharedDllHandle &dlHandle)
void setLabelPath (const std::string &path)
void setNetworkInfo (const NvDsInferNetworkInfo &info)
void setOutputLayerCount (uint32_t num)
void setInputCopy (bool enable)
const std::vector< std::vector< std::string > > & getLabels () const
void setAllocator (TensorAllocator cpuAlloc, EventAllocator event)
bool needInputCopy () const
virtual NvDsInferStatus allocateResource (const std::vector< int > &devIds) override
NvDsInferStatus postCudaProcess (SharedBatchArray inBuf, SharedCuStream mainStream, PostprocessDone done) override
 Acquire an output buffer array and call CUDA post processing steps. More...
NvDsInferStatus postHostProcess (SharedBatchArray inBuf, SharedCuStream mainStream, PostprocessDone done) override
 Acquire an output buffer array and call host side processing steps. More...
Protected Member Functions
NvDsInferStatus postCudaImpl (SharedBatchArray &inBuf, SharedBatchArray &outbuf, SharedCuStream &mainStream) override
NvDsInferStatus postHostImpl (SharedBatchArray &inBuf, SharedBatchArray &outbuf, SharedCuStream &mainStream) override
SharedBatchArray requestCudaOutBufs (const SharedBatchArray &inBuf) override
SharedBatchArray requestHostOutBufs (const SharedBatchArray &inBuf) override
NvDsInferStatus parseLabelsFile (const std::string &path)
Protected Attributes
SharedDllHandle m_CustomLibHandle
 Custom library implementation. More...
bool m_CopyInputToHostBuffers = false
NvDsInferNetworkInfo m_NetworkInfo = {0}
 Network input information. More...
uint32_t m_OutputLayerCount = 0
std::string m_LabelPath
std::vector< std::vector< std::string > > m_Labels
 Holds the string labels for classes. More...
TensorAllocator m_CpuAllocator
EventAllocator m_EventAllocator
Member Typedef Documentation
◆ EventAllocator
Definition at line 57 of file infer_postprocess.h.
◆ PostprocessDone
Definition at line 62 of file infer_iprocess.h.
◆ TensorAllocator
using nvdsinferserver::Postprocessor::TensorAllocator = std::function<SharedSysMem(const std::string& name, size_t bytes)>
inherited
Definition at line 56 of file infer_postprocess.h.
◆ OtherPostprocessor()
nvdsinferserver::OtherPostprocessor::OtherPostprocessor ( int  uid,
const ic::OtherNetworkParams &  params
Member Function Documentation
◆ allocateResource()
virtual NvDsInferStatus nvdsinferserver::Postprocessor::allocateResource ( const std::vector< int > &  devIds)
overridevirtualinherited
◆ getLabels()
const std::vector<std::vector<std::string> >& nvdsinferserver::Postprocessor::getLabels ( ) const
inlineinherited
Definition at line 74 of file infer_postprocess.h.
References nvdsinferserver::Postprocessor::m_Labels.
◆ needInputCopy()
bool nvdsinferserver::Postprocessor::needInputCopy ( ) const
inlineinherited
◆ networkType()
InferPostprocessType nvdsinferserver::BasePostprocessor::networkType ( ) const
inlineinherited
Definition at line 180 of file infer_iprocess.h.
◆ parseLabelsFile()
NvDsInferStatus nvdsinferserver::Postprocessor::parseLabelsFile ( const std::string &  path)
protectedinherited
◆ postCudaImpl()
NvDsInferStatus nvdsinferserver::Postprocessor::postCudaImpl ( SharedBatchArray inBuf,
SharedBatchArray outbuf,
overrideprotectedvirtualinherited
◆ postCudaProcess()
NvDsInferStatus nvdsinferserver::BasePostprocessor::postCudaProcess ( SharedBatchArray  inBuf,
inlineoverridevirtualinherited
Parameters
[in]inBufPointer to the input batch array.
[in]mainStreamThe main CUDA stream to synchronize with.
[in]doneCallback function to be executed.
Returns
Error status.
Implements nvdsinferserver::IPostprocessor.
Definition at line 190 of file infer_iprocess.h.
◆ postHostImpl()
NvDsInferStatus nvdsinferserver::Postprocessor::postHostImpl ( SharedBatchArray inBuf,
◆ postHostProcess()
NvDsInferStatus nvdsinferserver::BasePostprocessor::postHostProcess ( SharedBatchArray  inBuf,
Parameters
Returns
Error status.
Definition at line 204 of file infer_iprocess.h.
◆ requestCudaOutBufs()
SharedBatchArray nvdsinferserver::Postprocessor::requestCudaOutBufs ( const SharedBatchArray inBuf)
◆ requestHostOutBufs()
SharedBatchArray nvdsinferserver::Postprocessor::requestHostOutBufs ( const SharedBatchArray inBuf)
◆ setAllocator()
void nvdsinferserver::Postprocessor::setAllocator ( TensorAllocator  cpuAlloc,
inlineinherited
◆ setDllHandle()
void nvdsinferserver::Postprocessor::setDllHandle ( const SharedDllHandle dlHandle)
inlineinherited
◆ setInputCopy()
void nvdsinferserver::Postprocessor::setInputCopy ( bool  enable)
inlineinherited
◆ setLabelPath()
void nvdsinferserver::Postprocessor::setLabelPath ( const std::string &  path)
inlineinherited
Definition at line 68 of file infer_postprocess.h.
References nvdsinferserver::Postprocessor::m_LabelPath.
◆ setNetworkInfo()
void nvdsinferserver::Postprocessor::setNetworkInfo ( const NvDsInferNetworkInfo info)
inlineinherited
Definition at line 69 of file infer_postprocess.h.
References nvdsinferserver::Postprocessor::m_NetworkInfo.
◆ setOutputLayerCount()
void nvdsinferserver::Postprocessor::setOutputLayerCount ( uint32_t  num)
inlineinherited
◆ setUniqueId()
void nvdsinferserver::BasePostprocessor::setUniqueId ( int  id)
inlineinherited
Definition at line 178 of file infer_iprocess.h.
◆ uniqueId()
int nvdsinferserver::BasePostprocessor::uniqueId ( ) const
inlineinherited
Definition at line 179 of file infer_iprocess.h.
Field Documentation
◆ m_CopyInputToHostBuffers
bool nvdsinferserver::Postprocessor::m_CopyInputToHostBuffers = false
protectedinherited
◆ m_CpuAllocator
TensorAllocator nvdsinferserver::Postprocessor::m_CpuAllocator
protectedinherited
Definition at line 121 of file infer_postprocess.h.
Referenced by nvdsinferserver::Postprocessor::setAllocator().
◆ m_CustomLibHandle
SharedDllHandle nvdsinferserver::Postprocessor::m_CustomLibHandle
protectedinherited
Definition at line 111 of file infer_postprocess.h.
Referenced by nvdsinferserver::Postprocessor::setDllHandle().
◆ m_EventAllocator
EventAllocator nvdsinferserver::Postprocessor::m_EventAllocator
protectedinherited
Definition at line 122 of file infer_postprocess.h.
◆ m_LabelPath
std::string nvdsinferserver::Postprocessor::m_LabelPath
protectedinherited
Definition at line 116 of file infer_postprocess.h.
Referenced by nvdsinferserver::Postprocessor::setLabelPath().
◆ m_Labels
std::vector<std::vector<std::string> > nvdsinferserver::Postprocessor::m_Labels
protectedinherited
Definition at line 119 of file infer_postprocess.h.
Referenced by nvdsinferserver::Postprocessor::getLabels().
◆ m_NetworkInfo
NvDsInferNetworkInfo nvdsinferserver::Postprocessor::m_NetworkInfo = {0}
protectedinherited
Definition at line 114 of file infer_postprocess.h.
Referenced by nvdsinferserver::Postprocessor::setNetworkInfo().
◆ m_OutputLayerCount
uint32_t nvdsinferserver::Postprocessor::m_OutputLayerCount = 0
protectedinherited
