Here is a list of all functions, variables, defines, enums, and typedefs with links to the files they belong to:
- m -
- MAX_BG_CLR
: gstnvdsosd.h
- MAX_BORDER_WIDTH
: nvll_osd_api.h
- MAX_BUFFER_POOL_SIZE
: convbufmanager.h
- MAX_COMPONENT_LEN
: nvds_latency_meta.h
- MAX_DEWARPED_VIEWS
: nvds_dewarper_meta.h
- MAX_DISPLAY_LEN
: sample_video_probe.hpp
- MAX_ELEMENTS_IN_DISPLAY_META
: nvdsmeta.h
- MAX_ENCODED_SIZE
: gstnvimageenc.h
- MAX_ENTRIES
: nvdsmeta_schema.h
- MAX_FIELD_LEN
: includes/nvds_mqtt_proto.h
, kafka_client.h
, libs/mqtt_protocol_adaptor/nvds_mqtt_proto.h
- MAX_FILENAME_LENGTH
: deepstream_asr_tts_app.h
- MAX_FONT_SIZE
: backend.hpp
- MAX_IN_BUF
: nvll_osd_api.h
- MAX_LABEL_SIZE
: dsexample_lib/dsexample_lib.h
, cuda/dsexample_lib/dsexample_lib.h
, nvdsmeta.h
, nvds_tracker_meta.h
- MAX_LATENCY
: includes/nvds_rest_server.h
, libs/nvds_rest_server/nvds_rest_server.h
- MAX_LATENCY_UPDATE_FAIL
- MAX_LATENCY_UPDATE_SUCCESS
- MAX_MESSAGE_CONSUMERS
: deepstream_config.h
- MAX_NUM_OBJECTS
: nvdsmeta_schema.h
- MAX_RESERVED_FIELDS
: nvdsmeta.h
- max_retry_limit
: nvmsgbroker_internal.h
- MAX_SECONDARY_GIE_BINS
- MAX_SECONDARY_PREPROCESS_BINS
- MAX_SINK_BINS
- MAX_SINK_NUM
: deepstream_nmos_app.h
- MAX_SOURCE_BINS
- MAX_SOURCE_ID_LEN
: nvdsmeta_schema.h
- MAX_SOURCE_NUM
- MAX_ST2022_7_STREAMS
: gstnvdsudpcommon.h
- MAX_TOPIC_LEN
: kafka_client.h
- MAX_USER_FIELDS
: nvdsmeta.h
- MED_FILT_MSEC
: gst-plugins/gst-nvdsanalytics/nvds_analytics.h
, libs/nvds_analytics/nvds_analytics.h
- mem_buf_unref_callback()
: gstnvstreammux_impl.h
- MEM_TYPE_DEVICE
- MEM_TYPE_HOST
- MEM_TYPE_SYSTEM
- MEM_TYPE_UNKNOWN
- MEMORY_FEATURES
- MemoryType
- merge_classification_output()
: gstnvinfer_meta_utils.h
- mg_authorization_handler
: civetweb.h
- mg_base64_decode()
: civetweb.h
- mg_base64_encode()
: civetweb.h
- mg_check_digest_access_authentication()
: civetweb.h
- mg_check_feature()
: civetweb.h
- mg_close_connection()
: civetweb.h
- MG_CONFIG_TYPE_BOOLEAN
: civetweb.h
- MG_CONFIG_TYPE_DIRECTORY
: civetweb.h
- MG_CONFIG_TYPE_EXT_PATTERN
: civetweb.h
- MG_CONFIG_TYPE_FILE
: civetweb.h
- MG_CONFIG_TYPE_NUMBER
: civetweb.h
- MG_CONFIG_TYPE_STRING
: civetweb.h
- MG_CONFIG_TYPE_STRING_LIST
: civetweb.h
- MG_CONFIG_TYPE_STRING_MULTILINE
: civetweb.h
- MG_CONFIG_TYPE_UNKNOWN
: civetweb.h
- MG_CONFIG_TYPE_YES_NO_OPTIONAL
: civetweb.h
- mg_connect_client()
: civetweb.h
- mg_connect_client_secure()
: civetweb.h
- mg_connect_websocket_client()
: civetweb.h
- mg_connect_websocket_client_extensions()
: civetweb.h
- mg_connect_websocket_client_secure()
: civetweb.h
- mg_connect_websocket_client_secure_extensions()
: civetweb.h
- mg_cry()
: civetweb.h
- mg_disable_connection_keep_alive()
: civetweb.h
- mg_download()
: civetweb.h
- MG_ERROR_DATA_CODE_CONNECT_FAILED
: civetweb.h
- MG_ERROR_DATA_CODE_CONNECT_TIMEOUT
: civetweb.h
- MG_ERROR_DATA_CODE_DUPLICATE_DOMAIN
: civetweb.h
- MG_ERROR_DATA_CODE_HOST_NOT_FOUND
: civetweb.h
- MG_ERROR_DATA_CODE_INIT_ACL_FAILED
: civetweb.h
- MG_ERROR_DATA_CODE_INIT_LIBRARY_FAILED
: civetweb.h
- MG_ERROR_DATA_CODE_INIT_PORTS_FAILED
: civetweb.h
- MG_ERROR_DATA_CODE_INIT_TLS_FAILED
: civetweb.h
- MG_ERROR_DATA_CODE_INIT_USER_FAILED
: civetweb.h
- MG_ERROR_DATA_CODE_INVALID_OPTION
: civetweb.h
- MG_ERROR_DATA_CODE_INVALID_PARAM
: civetweb.h
- MG_ERROR_DATA_CODE_INVALID_PASS_FILE
: civetweb.h
- MG_ERROR_DATA_CODE_MISSING_OPTION
: civetweb.h
- MG_ERROR_DATA_CODE_OK
: civetweb.h
- MG_ERROR_DATA_CODE_OS_ERROR
: civetweb.h
- MG_ERROR_DATA_CODE_OUT_OF_MEMORY
: civetweb.h
- MG_ERROR_DATA_CODE_SCRIPT_ERROR
: civetweb.h
- MG_ERROR_DATA_CODE_SERVER_STOPPED
: civetweb.h
- MG_ERROR_DATA_CODE_TLS_CLIENT_CERT_ERROR
: civetweb.h
- MG_ERROR_DATA_CODE_TLS_CONNECT_ERROR
: civetweb.h
- MG_ERROR_DATA_CODE_TLS_SERVER_CERT_ERROR
: civetweb.h
- mg_exit_library()
: civetweb.h
- MG_FEATURES_ALL
: civetweb.h
- MG_FEATURES_CACHE
: civetweb.h
- MG_FEATURES_CGI
: civetweb.h
- MG_FEATURES_COMPRESSION
: civetweb.h
- MG_FEATURES_DEFAULT
: civetweb.h
- MG_FEATURES_FILES
: civetweb.h
- MG_FEATURES_HTTP2
: civetweb.h
- MG_FEATURES_IPV6
: civetweb.h
- MG_FEATURES_LUA
: civetweb.h
- MG_FEATURES_SSJS
: civetweb.h
- MG_FEATURES_SSL
: civetweb.h
- MG_FEATURES_STATS
: civetweb.h
- MG_FEATURES_TLS
: civetweb.h
- MG_FEATURES_WEBSOCKET
: civetweb.h
- MG_FEATURES_X_DOMAIN_SOCKET
: civetweb.h
- MG_FORM_FIELD_HANDLE_ABORT
: civetweb.h
- MG_FORM_FIELD_HANDLE_GET
: civetweb.h
- MG_FORM_FIELD_HANDLE_NEXT
: civetweb.h
- MG_FORM_FIELD_STORAGE_ABORT
: civetweb.h
- MG_FORM_FIELD_STORAGE_GET
: civetweb.h
- MG_FORM_FIELD_STORAGE_SKIP
: civetweb.h
- MG_FORM_FIELD_STORAGE_STORE
: civetweb.h
- mg_get_builtin_mime_type()
: civetweb.h
- mg_get_context()
: civetweb.h
- mg_get_context_info()
: civetweb.h
- mg_get_cookie()
: civetweb.h
- mg_get_header()
: civetweb.h
- mg_get_option()
: civetweb.h
- mg_get_request_info()
: civetweb.h
- mg_get_request_link()
: civetweb.h
- mg_get_response()
: civetweb.h
- mg_get_response_code_text()
: civetweb.h
- mg_get_response_info()
: civetweb.h
- mg_get_server_ports()
: civetweb.h
- mg_get_system_info()
: civetweb.h
- mg_get_thread_pointer()
: civetweb.h
- mg_get_user_connection_data()
: civetweb.h
- mg_get_user_context_data()
: civetweb.h
- mg_get_user_data()
: civetweb.h
- mg_get_valid_options()
: civetweb.h
- mg_get_var()
: civetweb.h
- mg_get_var2()
: civetweb.h
- mg_handle_form_request()
: civetweb.h
- mg_init_library()
: civetweb.h
- mg_lock_connection()
: civetweb.h
- mg_lock_context()
: civetweb.h
- MG_MATCH_CONTEXT_MAX_MATCHES
: civetweb.h
- MG_MAX_HEADERS
: civetweb.h
- mg_md5()
: civetweb.h
- mg_modify_passwords_file()
: civetweb.h
- mg_modify_passwords_file_ha1()
: civetweb.h
- mg_printf()
: civetweb.h
- mg_read()
: civetweb.h
- mg_request_handler
: civetweb.h
- mg_response_header_add()
: civetweb.h
- mg_response_header_add_lines()
: civetweb.h
- mg_response_header_send()
: civetweb.h
- mg_response_header_start()
: civetweb.h
- mg_send_chunk()
: civetweb.h
- mg_send_digest_access_authentication_request()
: civetweb.h
- mg_send_file()
: civetweb.h
- mg_send_file_body()
: civetweb.h
- mg_send_http_error()
: civetweb.h
- mg_send_http_ok()
: civetweb.h
- mg_send_http_redirect()
: civetweb.h
- mg_send_mime_file()
: civetweb.h
- mg_send_mime_file2()
: civetweb.h
- mg_server_ports
: civetweb.h
- mg_set_auth_handler()
: civetweb.h
- mg_set_request_handler()
: civetweb.h
- mg_set_user_connection_data()
: civetweb.h
- mg_set_websocket_handler()
: civetweb.h
- mg_set_websocket_handler_with_subprotocols()
: civetweb.h
- mg_split_form_urlencoded()
: civetweb.h
- mg_start()
: civetweb.h
- mg_start2()
: civetweb.h
- mg_start_domain()
: civetweb.h
- mg_start_domain2()
: civetweb.h
- mg_start_thread()
: civetweb.h
- mg_stop()
: civetweb.h
- mg_store_body()
: civetweb.h
- mg_strcasecmp()
: civetweb.h
- mg_strncasecmp()
: civetweb.h
- mg_thread_func_t
: civetweb.h
- MG_TIMEOUT_INFINITE
: civetweb.h
- mg_unlock_connection()
: civetweb.h
- mg_unlock_context()
: civetweb.h
- mg_url_decode()
: civetweb.h
- mg_url_encode()
: civetweb.h
- mg_version()
: civetweb.h
- mg_websocket_client_write()
: civetweb.h
- mg_websocket_close_handler
: civetweb.h
- mg_websocket_connect_handler
: civetweb.h
- mg_websocket_data_handler
: civetweb.h
- MG_WEBSOCKET_OPCODE_BINARY
: civetweb.h
- MG_WEBSOCKET_OPCODE_CONNECTION_CLOSE
: civetweb.h
- MG_WEBSOCKET_OPCODE_CONTINUATION
: civetweb.h
- MG_WEBSOCKET_OPCODE_PING
: civetweb.h
- MG_WEBSOCKET_OPCODE_PONG
: civetweb.h
- MG_WEBSOCKET_OPCODE_TEXT
: civetweb.h
- mg_websocket_ready_handler
: civetweb.h
- mg_websocket_write()
: civetweb.h
- mg_write()
: civetweb.h
- MODE_CPU
: nvll_osd_struct.h
- MODE_GPU
: nvll_osd_struct.h
- MODE_NONE
: nvll_osd_struct.h
- mosq_mqtt_log_callback()
- MULTIURIBIN_PROP_0
: gstdsnvmultiurisrcbin.h
- MULTIURIBIN_PROP_BUFFER_MODE
- MULTIURIBIN_PROP_CUDADEC_MEM_TYPE
- MULTIURIBIN_PROP_DEC_SKIP_FRAMES
- MULTIURIBIN_PROP_DISABLE_AUDIO
- MULTIURIBIN_PROP_DISABLE_PASSTHROUGH
- MULTIURIBIN_PROP_DROP_FRAME_INTERVAL
- MULTIURIBIN_PROP_DROP_ON_LATENCY
- MULTIURIBIN_PROP_EXTRACT_SEI_TYPE5_DATA_DEC
- MULTIURIBIN_PROP_FILE_LOOP
- MULTIURIBIN_PROP_GPU_DEVICE_ID
- MULTIURIBIN_PROP_HTTP_IP
- MULTIURIBIN_PROP_HTTP_PORT
- MULTIURIBIN_PROP_IPC_BUFFER_TIMESTAMP_COPY
- MULTIURIBIN_PROP_IPC_CONNECTION_ATTEMPTS
- MULTIURIBIN_PROP_IPC_CONNECTION_INTERVAL
- MULTIURIBIN_PROP_IPC_SOCKET_PATH
- MULTIURIBIN_PROP_LAST
- MULTIURIBIN_PROP_LATENCY
- MULTIURIBIN_PROP_LEAKY
- MULTIURIBIN_PROP_LOW_LATENCY_MODE
- MULTIURIBIN_PROP_MAX_BATCH_SIZE
- MULTIURIBIN_PROP_MAX_SIZE_BUFFERS
- MULTIURIBIN_PROP_MODE
- MULTIURIBIN_PROP_NUM_EXTRA_SURF
- MULTIURIBIN_PROP_RTP_PROTOCOL
- MULTIURIBIN_PROP_RTSP_INIT_RECONNECT_INTERVAL
- MULTIURIBIN_PROP_RTSP_RECONNECT_ATTEMPTS
- MULTIURIBIN_PROP_RTSP_RECONNECT_INTERVAL
- MULTIURIBIN_PROP_SEI_UUID
- MULTIURIBIN_PROP_SENSOR_ID_LIST
- MULTIURIBIN_PROP_SENSOR_NAME_LIST
- MULTIURIBIN_PROP_SENSORID_PADID_MAPPING
- MULTIURIBIN_PROP_SMART_RECORD
- MULTIURIBIN_PROP_SMART_RECORD_CACHE
- MULTIURIBIN_PROP_SMART_RECORD_CONTAINER
- MULTIURIBIN_PROP_SMART_RECORD_DEFAULT_DURATION
- MULTIURIBIN_PROP_SMART_RECORD_DIR_PATH
- MULTIURIBIN_PROP_SMART_RECORD_FILE_PREFIX
- MULTIURIBIN_PROP_SMART_RECORD_MODE
- MULTIURIBIN_PROP_SMART_RECORD_STATUS
- MULTIURIBIN_PROP_SMART_RECORD_VIDEO_CACHE
- MULTIURIBIN_PROP_SOURCE_ID
- MULTIURIBIN_PROP_SOURCE_TYPE
- MULTIURIBIN_PROP_UDP_BUFFER_SIZE
- MULTIURIBIN_PROP_URI_LIST
- MUX_AUDIO_VIDEO_OUT
- MUXER_BATCH_TIMEOUT_USEC
: deepstream_ucx_test_app.h
- MUXER_OUTPUT_HEIGHT
- MUXER_OUTPUT_WIDTH
- my_connect_callback()
- my_disconnect_callback()
: libs/mqtt_protocol_adaptor/nvds_mqtt_proto.h
, includes/nvds_mqtt_proto.h
- my_publish_callback()
