7.1 Release
infer_grpc_context.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2021-2022 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
22 #ifndef __NVDSINFERSERVER_GRPC_CONTEXT_H__
23 #define __NVDSINFERSERVER_GRPC_CONTEXT_H__
24
25 #include "infer_base_backend.h"
26 #include "infer_cuda_context.h"
27 #include "infer_cuda_utils.h"
28 #include "infer_datatypes.h"
29 #include "infer_utils.h"
30
31 namespace nvdsinferserver {
32
38 public:
43
47  ~InferGrpcContext() override;
48
49 protected:
58  const ic::BackendParams& params, int maxBatchSize,
60
64  NvDsInferStatus deinit() override;
65
70  {
71  assert(m_Stream);
72  return m_Stream;
73  }
74
75 private:
85  NvDsInferStatus allocateResource(
86  const ic::InferenceConfig& config) override;
87
96  NvDsInferStatus specifyBackendDims(
97  BaseBackend* be, const std::string& model,
98  const ic::BackendParams& params);
99
108  NvDsInferStatus getConfigInOutMap(
109  const ic::BackendParams& params,
110  std::unordered_map<std::string, InferDims>& inputs,
111  std::set<std::string>& outputs);
112
113 private:
117  SharedCuStream m_Stream;
121  TrtISBackend* m_Backend{nullptr};
122 };
123
124 } // namespace nvdsinferserver
125
126 #endif //__NVDSINFERSERVER_GRPC_CONTEXT_H__
nvdsinferserver
Definition: infer_custom_process.h:24
nvdsinferserver::InferGrpcContext::deinit
Synchronize on the CUDA stream and call InferCudaContext::deinit().
nvdsinferserver::InferBaseContext::maxBatchSize
int maxBatchSize() const
Definition: infer_base_context.h:99
infer_datatypes.h
Header file for the data types used in the inference processing.
nvdsinferserver::TrtISBackend
Triton backend processing class.
Definition: infer_trtis_backend.h:39
infer_utils.h
Header file for the CUDA inference context class.
nvdsinferserver::UniqBackend
std::unique_ptr< BaseBackend > UniqBackend
Definition: infer_base_backend.h:212
infer_cuda_utils.h
Header file declaring utility classes for CUDA memory management, CIDA streams and events.
nvdsinferserver::InferGrpcContext::createNNBackend
NvDsInferStatus createNNBackend(const ic::BackendParams &params, int maxBatchSize, UniqBackend &backend)
Create the Triton gRPC mode inference processing backend.
nvdsinferserver::SharedCuStream
std::shared_ptr< CudaStream > SharedCuStream
Cuda based pointers.
Definition: infer_common.h:84
nvdsinferserver::InferBaseContext::backend
BaseBackend * backend()
Definition: infer_base_context.h:101
nvdsinferserver::InferBaseContext::config
const ic::InferenceConfig & config() const
Definition: infer_base_context.h:98
nvdsinferserver::InferGrpcContext::~InferGrpcContext
Destructor, default.
Inference context class accessing Triton Inference Server in gRPC mode.
Definition: infer_grpc_context.h:37
nvdsinferserver::InferGrpcContext::mainStream
SharedCuStream & mainStream() override
Get the main processing CUDA event.
Definition: infer_grpc_context.h:69
nvdsinferserver::BaseBackend
Base class of inference backend processing.
Definition: infer_base_backend.h:40
Header file for inference processing backend base class.
nvdsinferserver::InferGrpcContext::InferGrpcContext
InferGrpcContext()
Constructor, default.
NvDsInferStatus
NvDsInferStatus
Definition: nvdsinfer.h:220
nvdsinferserver::InferCudaContext
Class for inference context CUDA processing.
Definition: infer_cuda_context.h:44
