7.1 Release
nvds_tracker_meta.h File Reference
Defines Tracker Metadata
Definition in file nvds_tracker_meta.h.
Data Structures
struct  _NvDsTargetMiscDataFrame
 A single frame of misc data for a given Target. More...
struct  _NvDsTargetMiscDataObject
 All misc data output for a single target. More...
struct  _NvDsTargetMiscDataStream
 All misc targets data for a given stream. More...
struct  _NvDsTargetMiscDataBatch
 Batch of all streams of a given target misc output. More...
struct  _NvDsReidTensorBatch
 ReID tensor of the batch. More...
struct  _NvDsObjConvexHull
 Holds convex hull information. More...
struct  _NvDsObjReid
 Holds Reid Vector information for an object. More...
Macros
#define MAX_LABEL_SIZE   128
Typedefs
typedef struct _NvDsTargetMiscDataFrame NvDsTargetMiscDataFrame
typedef struct _NvDsTargetMiscDataObject NvDsTargetMiscDataObject
typedef struct _NvDsTargetMiscDataStream NvDsTargetMiscDataStream
typedef struct _NvDsTargetMiscDataBatch NvDsTargetMiscDataBatch
typedef struct _NvDsReidTensorBatch NvDsReidTensorBatch
typedef NvDsTargetMiscDataBatch NvDsTrajectoryBatch
 Batch of trajectory data in all streams. More...
typedef struct _NvDsObjConvexHull NvDsObjConvexHull
typedef struct _NvDsObjReid NvDsObjReid
Enumerations
enum  TRACKER_STATE {
  EMPTY = 0,
  ACTIVE = 1,
  INACTIVE = 2,
  TENTATIVE = 3,
  PROJECTED = 4
