8.0 Release
post_processor_custom_impl.h File Reference
Macros
#define CHECK_CUSTOM_PARSE_FUNC_PROTOTYPE(customParseFunc)
 Validates a custom parser function definition. More...
#define CHECK_CUSTOM_INSTANCE_MASK_PARSE_FUNC_PROTOTYPE(customParseFunc)
#define CHECK_CUSTOM_CLASSIFIER_PARSE_FUNC_PROTOTYPE(customParseFunc)
 Validates the classifier custom parser function definition. More...
Typedefs
typedef bool(* NvDsPostProcessParseCustomFunc) (std::vector< NvDsInferLayerInfo > const &outputLayersInfo, NvDsInferNetworkInfo const &networkInfo, NvDsPostProcessParseDetectionParams const &detectionParams, std::vector< NvDsPostProcessObjectDetectionInfo > &objectList)
 Type definition for the custom bounding box parsing function. More...
typedef bool(* NvDsPostProcessInstanceMaskParseCustomFunc) (std::vector< NvDsInferLayerInfo > const &outputLayersInfo, NvDsInferNetworkInfo const &networkInfo, NvDsPostProcessParseDetectionParams const &detectionParams, std::vector< NvDsPostProcessInstanceMaskInfo > &objectList)
 Type definition for the custom bounding box and instance mask parsing function. More...
typedef bool(* NvDsPostProcessClassiferParseCustomFunc) (std::vector< NvDsInferLayerInfo > const &outputLayersInfo, NvDsInferNetworkInfo const &networkInfo, float classifierThreshold, std::vector< NvDsPostProcessAttribute > &attrList, std::string &descString)
 Type definition for the custom classifier output parsing function. More...
◆ CHECK_CUSTOM_CLASSIFIER_PARSE_FUNC_PROTOTYPE
#define CHECK_CUSTOM_CLASSIFIER_PARSE_FUNC_PROTOTYPE (   customParseFunc)
Value:
static void checkFunc_ ## customParseFunc (NvDsPostProcessClassiferParseCustomFunc func = customParseFunc) \
{ checkFunc_ ## customParseFunc (); }; \
extern "C" bool customParseFunc (std::vector<NvDsInferLayerInfo> const &outputLayersInfo, \
NvDsInferNetworkInfo const &networkInfo, \
float classifierThreshold, \
std::vector<NvDsPostProcessAttribute> &attrList, \
std::string &descString);
Must be called after defining the function.
Definition at line 119 of file post_processor_custom_impl.h.
◆ CHECK_CUSTOM_INSTANCE_MASK_PARSE_FUNC_PROTOTYPE
#define CHECK_CUSTOM_INSTANCE_MASK_PARSE_FUNC_PROTOTYPE (   customParseFunc)
Value:
static void checkFunc_ ## customParseFunc (NvDsPostProcessInstanceMaskParseCustomFunc func = customParseFunc) \
NvDsPostProcessParseDetectionParams const &detectionParams, \
std::vector<NvDsPostProcessInstanceMaskInfo> &objectList);
Definition at line 87 of file post_processor_custom_impl.h.
◆ CHECK_CUSTOM_PARSE_FUNC_PROTOTYPE
#define CHECK_CUSTOM_PARSE_FUNC_PROTOTYPE (   customParseFunc)
Value:
static void checkFunc_ ## customParseFunc (NvDsPostProcessParseCustomFunc func = customParseFunc) \
std::vector<NvDsPostProcessObjectDetectionInfo> &objectList);
Definition at line 58 of file post_processor_custom_impl.h.
Typedef Documentation
◆ NvDsPostProcessClassiferParseCustomFunc
Parameters
[in]outputLayersInfoA vector containing information on the output layers of the model.
[in]networkInfoNetwork information.
[in]classifierThresholdClassification confidence threshold.
[out]attrListA reference to a vector in which the function is to add the parsed attributes.
[out]descStringA reference to a string object in which the function may place a description string.
Definition at line 108 of file post_processor_custom_impl.h.
◆ NvDsPostProcessInstanceMaskParseCustomFunc
Parameters
[in]detectionParamsDetection parameters required for parsing objects.
[out]objectListA reference to a vector in which the function is to add parsed objects and instance mask.
Definition at line 77 of file post_processor_custom_impl.h.
◆ NvDsPostProcessParseCustomFunc
Parameters
[out]objectListA reference to a vector in which the function is to add parsed objects.
Definition at line 48 of file post_processor_custom_impl.h.
bool(* NvDsPostProcessClassiferParseCustomFunc)(std::vector< NvDsInferLayerInfo > const &outputLayersInfo, NvDsInferNetworkInfo const &networkInfo, float classifierThreshold, std::vector< NvDsPostProcessAttribute > &attrList, std::string &descString)
Definition: post_processor_custom_impl.h:108
Definition: nvdsinfer.h:114
bool(* NvDsPostProcessParseCustomFunc)(std::vector< NvDsInferLayerInfo > const &outputLayersInfo, NvDsInferNetworkInfo const &networkInfo, NvDsPostProcessParseDetectionParams const &detectionParams, std::vector< NvDsPostProcessObjectDetectionInfo > &objectList)
Definition: post_processor_custom_impl.h:48
bool(* NvDsPostProcessInstanceMaskParseCustomFunc)(std::vector< NvDsInferLayerInfo > const &outputLayersInfo, NvDsInferNetworkInfo const &networkInfo, NvDsPostProcessParseDetectionParams const &detectionParams, std::vector< NvDsPostProcessInstanceMaskInfo > &objectList)
Definition: post_processor_custom_impl.h:77
Holds the detection parameters required for parsing objects.
Definition: post_processor_struct.h:567
