8. Double Precision Mathematical Functions
This section describes double precision mathematical functions.
To use these functions, you do not need to include any additional header file in your program.
Functions
- __device__ double acos(double x)
Calculate the arc cosine of the input argument.
- __device__ double acosh(double x)
Calculate the nonnegative inverse hyperbolic cosine of the input argument.
- __device__ double asin(double x)
Calculate the arc sine of the input argument.
- __device__ double asinh(double x)
Calculate the inverse hyperbolic sine of the input argument.
- __device__ double atan(double x)
Calculate the arc tangent of the input argument.
- __device__ double atan2(double y, double x)
Calculate the arc tangent of the ratio of first and second input arguments.
- __device__ double atanh(double x)
Calculate the inverse hyperbolic tangent of the input argument.
- __device__ double cbrt(double x)
Calculate the cube root of the input argument.
- __device__ double ceil(double x)
Calculate ceiling of the input argument.
- __device__ double copysign(double x, double y)
Create value with given magnitude, copying sign of second value.
- __device__ double cos(double x)
Calculate the cosine of the input argument.
- __device__ double cosh(double x)
Calculate the hyperbolic cosine of the input argument.
- __device__ double cospi(double x)
Calculate the cosine of the input argument \(\times \pi\) .
- __device__ double cyl_bessel_i0(double x)
Calculate the value of the regular modified cylindrical Bessel function of order 0 for the input argument.
- __device__ double cyl_bessel_i1(double x)
Calculate the value of the regular modified cylindrical Bessel function of order 1 for the input argument.
- __device__ double erf(double x)
Calculate the error function of the input argument.
- __device__ double erfc(double x)
Calculate the complementary error function of the input argument.
- __device__ double erfcinv(double x)
Calculate the inverse complementary error function of the input argument.
- __device__ double erfcx(double x)
Calculate the scaled complementary error function of the input argument.
- __device__ double erfinv(double x)
Calculate the inverse error function of the input argument.
- __device__ double exp(double x)
Calculate the base \(e\) exponential of the input argument.
- __device__ double exp10(double x)
Calculate the base 10 exponential of the input argument.
- __device__ double exp2(double x)
Calculate the base 2 exponential of the input argument.
- __device__ double expm1(double x)
Calculate the base \(e\) exponential of the input argument, minus 1.
- __device__ double fabs(double x)
Calculate the absolute value of the input argument.
- __device__ double fdim(double x, double y)
Compute the positive difference between
x
andy
.- __device__ double floor(double x)
Calculate the largest integer less than or equal to
x
.- __device__ double fma(double x, double y, double z)
Compute \(x \times y + z\) as a single operation.
- __device__ double fmax(double, double)
Determine the maximum numeric value of the arguments.
- __device__ double fmin(double x, double y)
Determine the minimum numeric value of the arguments.
- __device__ double fmod(double x, double y)
Calculate the double-precision floating-point remainder of
x
/y
.- __device__ double frexp(double x, int *nptr)
Extract mantissa and exponent of a floating-point value.
- __device__ double hypot(double x, double y)
Calculate the square root of the sum of squares of two arguments.
- __device__ int ilogb(double x)
Compute the unbiased integer exponent of the argument.
- __device__ __RETURN_TYPE isfinite(double a)
Determine whether argument is finite.
- __device__ __RETURN_TYPE isinf(double a)
Determine whether argument is infinite.
- __device__ __RETURN_TYPE isnan(double a)
Determine whether argument is a NaN.
- __device__ double j0(double x)
Calculate the value of the Bessel function of the first kind of order 0 for the input argument.
- __device__ double j1(double x)
Calculate the value of the Bessel function of the first kind of order 1 for the input argument.
- __device__ double jn(int n, double x)
Calculate the value of the Bessel function of the first kind of order n for the input argument.
- __device__ double ldexp(double x, int exp)
Calculate the value of \(x\cdot 2^{exp}\) .
- __device__ double lgamma(double x)
Calculate the natural logarithm of the absolute value of the gamma function of the input argument.
- __device__ long long int llrint(double x)
Round input to nearest integer value.
- __device__ long long int llround(double x)
Round to nearest integer value.
- __device__ double log(double x)
Calculate the base \(e\) logarithm of the input argument.
- __device__ double log10(double x)
Calculate the base 10 logarithm of the input argument.
- __device__ double log1p(double x)
Calculate the value of \(\log_{e}(1+x)\) .
- __device__ double log2(double x)
Calculate the base 2 logarithm of the input argument.
- __device__ double logb(double x)
Calculate the floating-point representation of the exponent of the input argument.
- __device__ long int lrint(double x)
- __device__ long int lround(double x)
- __device__ double max(const float a, const double b)
Calculate the maximum value of the input
float
anddouble
arguments.- __device__ double max(const double a, const float b)
double
andfloat
arguments.- __device__ double max(const double a, const double b)
float
arguments.- __device__ double min(const float a, const double b)
Calculate the minimum value of the input
float
anddouble
arguments.- __device__ double min(const double a, const double b)
float
arguments.- __device__ double min(const double a, const float b)
double
andfloat
arguments.- __device__ double modf(double x, double *iptr)
Break down the input argument into fractional and integral parts.
- __device__ double nan(const char *tagp)
Returns "Not a Number" value.
- __device__ double nearbyint(double x)
Round the input argument to the nearest integer.
- __device__ double nextafter(double x, double y)
Return next representable double-precision floating-point value after argument
x
in the direction ofy
.- __device__ double norm(int dim, double const *p)
Calculate the square root of the sum of squares of any number of coordinates.
- __device__ double norm3d(double a, double b, double c)
Calculate the square root of the sum of squares of three coordinates of the argument.
- __device__ double norm4d(double a, double b, double c, double d)
Calculate the square root of the sum of squares of four coordinates of the argument.
- __device__ double normcdf(double x)
Calculate the standard normal cumulative distribution function.
- __device__ double normcdfinv(double x)
Calculate the inverse of the standard normal cumulative distribution function.
- __device__ double pow(double x, double y)
Calculate the value of first argument to the power of second argument.
- __device__ double rcbrt(double x)
Calculate reciprocal cube root function.
- __device__ double remainder(double x, double y)
Compute double-precision floating-point remainder.
- __device__ double remquo(double x, double y, int *quo)
Compute double-precision floating-point remainder and part of quotient.
- __device__ double rhypot(double x, double y)
Calculate one over the square root of the sum of squares of two arguments.
- __device__ double rint(double x)
Round to nearest integer value in floating-point.
- __device__ double rnorm(int dim, double const *p)
Calculate the reciprocal of square root of the sum of squares of any number of coordinates.
- __device__ double rnorm3d(double a, double b, double c)
Calculate one over the square root of the sum of squares of three coordinates.
- __device__ double rnorm4d(double a, double b, double c, double d)
Calculate one over the square root of the sum of squares of four coordinates.
- __device__ double round(double x)
- __device__ double rsqrt(double x)
Calculate the reciprocal of the square root of the input argument.
- __device__ double scalbln(double x, long int n)
Scale floating-point input by integer power of two.
- __device__ double scalbn(double x, int n)
- __device__ __RETURN_TYPE signbit(double a)
Return the sign bit of the input.
- __device__ double sin(double x)
Calculate the sine of the input argument.
- __device__ void sincos(double x, double *sptr, double *cptr)
Calculate the sine and cosine of the first input argument.
- __device__ void sincospi(double x, double *sptr, double *cptr)
Calculate the sine and cosine of the first input argument \(\times \pi\) .
- __device__ double sinh(double x)
Calculate the hyperbolic sine of the input argument.
- __device__ double sinpi(double x)
Calculate the sine of the input argument \(\times \pi\) .
- __device__ double sqrt(double x)
Calculate the square root of the input argument.
- __device__ double tan(double x)
Calculate the tangent of the input argument.
- __device__ double tanh(double x)
Calculate the hyperbolic tangent of the input argument.
- __device__ double tgamma(double x)
Calculate the gamma function of the input argument.
- __device__ double trunc(double x)
Truncate input argument to the integral part.
- __device__ double y0(double x)
Calculate the value of the Bessel function of the second kind of order 0 for the input argument.
- __device__ double y1(double x)
Calculate the value of the Bessel function of the second kind of order 1 for the input argument.
- __device__ double yn(int n, double x)
Calculate the value of the Bessel function of the second kind of order n for the input argument.
8.1. Functions
Calculate the principal value of the arc cosine of the input argument
x
.Note
For accuracy information, see the CUDA C++ Programming Guide, Mathematical Functions Appendix, Double-Precision Floating-Point Functions section.
- Returns
Result will be in radians, in the interval [0, \( \pi \) ] for
x
inside [-1, +1].acos(1) returns +0.
acos(
x
) returns NaN forx
outside [-1, +1].acos(NaN) returns NaN.
x
.Note
- Returns
Result will be in the interval [0, \( +\infty \) ].
acosh(1) returns 0.
acosh(
x
) returns NaN forx
in the interval [ \( -\infty \) , 1).acosh( \( +\infty \) ) returns \( +\infty \).
acosh(NaN) returns NaN.
Calculate the principal value of the arc sine of the input argument
x
.Note
- Returns
Result will be in radians, in the interval [- \( \pi \) /2, + \( \pi \) /2] for
x
inside [-1, +1].asin( \( \pm 0 \) ) returns \( \pm 0 \).
asin(
x
) returns NaN forx
outside [-1, +1].asin(NaN) returns NaN.
x
.Note
- Returns
asinh( \( \pm 0 \) ) returns \( \pm 0 \).
asinh( \( \pm \infty \) ) returns \( \pm \infty \).
asinh(NaN) returns NaN.
Calculate the principal value of the arc tangent of the input argument
x
.Note
- Returns
Result will be in radians, in the interval [- \( \pi \) /2, + \( \pi \) /2].
atan( \( \pm 0 \) ) returns \( \pm 0 \).
atan( \( \pm \infty \) ) returns \( \pm \pi \) /2.
atan(NaN) returns NaN.
Calculate the principal value of the arc tangent of the ratio of first and second input arguments
y
/x
. The quadrant of the result is determined by the signs of inputsy
andx
.Note
- Returns
Result will be in radians, in the interval [- \( \pi \) , + \( \pi \) ].
atan2( \( \pm 0 \) , -0) returns \( \pm \pi \).
atan2( \( \pm 0 \) , +0) returns \( \pm 0 \).
x
) returns \( \pm \pi \) forx
< 0.atan2( \( \pm 0 \) ,
x
) returns \( \pm 0 \) forx
> 0.atan2(
y
, \( \pm 0 \) ) returns \( -\pi \) /2 fory
< 0.atan2(
y
, \( \pm 0 \) ) returns \( \pi \) /2 fory
> 0.atan2( \( \pm y \) , \( -\infty \) ) returns \( \pm \pi \) for finite
y
> 0.atan2( \( \pm y \) , \( +\infty \) ) returns \( \pm 0 \) for finite
y
> 0.atan2( \( \pm \infty \) ,
x
) returns \( \pm \pi \) /2 for finitex
.atan2( \( \pm \infty \) , \( -\infty \) ) returns \( \pm 3\pi \) /4.
atan2( \( \pm \infty \) , \( +\infty \) ) returns \( \pm \pi \) /4.
If either argument is NaN, NaN is returned.
x
.Note
- Returns
atanh( \( \pm 0 \) ) returns \( \pm 0 \).
atanh( \( \pm 1 \) ) returns \( \pm \infty \).
atanh(
x
) returns NaN forx
outside interval [-1, 1].atanh(NaN) returns NaN.
x
, \( x^{1/3} \).Note
- Returns
Returns \( x^{1/3} \).
cbrt( \( \pm 0 \) ) returns \( \pm 0 \).
cbrt( \( \pm \infty \) ) returns \( \pm \infty \).
cbrt(NaN) returns NaN.
Compute the smallest integer value not less than
x
.- Returns
Returns \( \lceil x \rceil \) expressed as a floating-point number.
ceil( \( \pm 0 \) ) returns \( \pm 0 \).
ceil( \( \pm \infty \) ) returns \( \pm \infty \).
ceil(NaN) returns NaN.
Create a floating-point value with the magnitude
x
and the sign ofy
.- Returns
a value with the magnitude of
x
and the sign ofy
.copysign(
NaN
,y
) returns aNaN
with the sign ofy
x
(measured in radians).Note
- Returns
cos( \( \pm 0 \) ) returns 1.
cos( \( \pm \infty \) ) returns NaN.
x
.Note
- Returns
cosh( \( \pm 0 \) ) returns 1.
cosh( \( \pm \infty \) ) returns \( +\infty \).
Calculate the cosine of the input argument \( \times \pi \).
x
\( \times \pi \) (measured in radians), wherex
is the input argument.Note
- Returns
cospi( \( \pm 0 \) ) returns 1.
cospi( \( \pm \infty \) ) returns NaN.
cospi(NaN) returns NaN.
x
, \( I_0(x) \).Note
- Returns
Returns the value of the regular modified cylindrical Bessel function of order 0.
cyl_bessel_i0( \( \pm 0 \)) returns +1.
cyl_bessel_i0( \( \pm\infty \)) returns \( +\infty \).
cyl_bessel_i0(NaN) returns NaN.
x
, \( I_1(x) \).Note
- Returns
Returns the value of the regular modified cylindrical Bessel function of order 1.
cyl_bessel_i1( \( \pm 0 \)) returns \( \pm 0 \).
cyl_bessel_i1( \( \pm\infty \)) returns \( \pm\infty \).
cyl_bessel_i1(NaN) returns NaN.
Calculate the value of the error function for the input argument
x
, \( \frac{2}{\sqrt \pi} \int_0^x e^{-t^2} dt \).Note
- Returns
erf( \( \pm 0 \) ) returns \( \pm 0 \).
erf( \( \pm \infty \) ) returns \( \pm 1 \).
erf(NaN) returns NaN.
x
, 1 - erf(x
).Note
- Returns
erfc( \( -\infty \) ) returns 2.
erfc( \( +\infty \) ) returns +0.
erfc(NaN) returns NaN.
Calculate the inverse complementary error function \( \operatorname{erfc}^{-1} \) (
x
), of the input argumentx
in the interval [0, 2].Note
- Returns
erfcinv( \( \pm 0 \) ) returns \( +\infty \).
erfcinv(2) returns \( -\infty \).
erfcinv(
x
) returns NaN forx
outside [0, 2].erfcinv(NaN) returns NaN.
x
, \( e^{x^2}\cdot \operatorname{erfc}(x) \).Note
- Returns
erfcx( \( -\infty \) ) returns \( +\infty \).
erfcx( \( +\infty \) ) returns +0.
erfcx(NaN) returns NaN.
Calculate the inverse error function \( \operatorname{erf}^{-1} \) (
x
in the interval [-1, 1].Note
- Returns
erfinv( \( \pm 0 \) ) returns \( \pm 0 \).
erfinv(1) returns \( +\infty \).
erfinv(-1) returns \( -\infty \).
erfinv(
x
) returns NaN forx
outside [-1, +1].erfinv(NaN) returns NaN.
Calculate the base \( e \) exponential of the input argument.
Calculate \( e^x \) , the base \( e \) exponential of the input argument
x
.Note
- Returns
exp( \( \pm 0 \) ) returns 1.
exp( \( -\infty \) ) returns +0.
exp( \( +\infty \) ) returns \( +\infty \).
exp(NaN) returns NaN.
Calculate \( 10^x \) , the base 10 exponential of the input argument
x
.Note
- Returns
exp10( \( \pm 0 \) ) returns 1.
exp10( \( -\infty \) ) returns +0.
exp10( \( +\infty \) ) returns \( +\infty \).
exp10(NaN) returns NaN.
Calculate \( 2^x \) , the base 2 exponential of the input argument
x
.Note
- Returns
exp2( \( \pm 0 \) ) returns 1.
exp2( \( -\infty \) ) returns +0.
exp2( \( +\infty \) ) returns \( +\infty \).
exp2(NaN) returns NaN.
Calculate the base \( e \) exponential of the input argument, minus 1.
Calculate \( e^x \) -1, the base \( e \) exponential of the input argument
x
, minus 1.Note
- Returns
expm1( \( \pm 0 \) ) returns \( \pm 0 \).
expm1( \( -\infty \) ) returns -1.
expm1( \( +\infty \) ) returns \( +\infty \).
expm1(NaN) returns NaN.
x
.Note
- Returns
Returns the absolute value of the input argument.
fabs( \( \pm \infty \) ) returns \( +\infty \).
fabs( \( \pm 0 \) ) returns +0.
fabs(NaN) returns an unspecified NaN.
x
andy
.Compute the positive difference between
x
andy
. The positive difference isx
-y
whenx
>y
and +0 otherwise.Note
- Returns
Returns the positive difference between
x
andy
.fdim(
x
,y
) returnsx
-y
ifx
>y
.fdim(
x
,y
) returns +0 ifx
\( \leq \)y
.If either argument is NaN, NaN is returned.
x
.Calculates the largest integer value which is less than or equal to
x
.Note
- Returns
Returns \( \lfloor x \rfloor \) expressed as a floating-point number.
floor( \( \pm \infty \) ) returns \( \pm \infty \).
floor( \( \pm 0 \) ) returns \( \pm 0 \).
floor(NaN) returns NaN.
Compute \( x \times y + z \) as a single operation.
Compute the value of \( x \times y + z \) as a single ternary operation. After computing the value to infinite precision, the value is rounded once using round-to-nearest, ties-to-even rounding mode.
Note
- Returns
Returns the rounded value of \( x \times y + z \) as a single operation.
fma( \( \pm \infty \) , \( \pm 0 \) ,
z
) returns NaN.fma( \( \pm 0 \) , \( \pm \infty \) ,
z
) returns NaN.fma(
x
,y
, \( -\infty \) ) returns NaN if \( x \times y \) is an exact \( +\infty \).fma(
x
,y
, \( +\infty \) ) returns NaN if \( x \times y \) is an exact \( -\infty \).fma(
x
,y
, \( \pm 0 \)) returns \( \pm 0 \) if \( x \times y \) is exact \( \pm 0 \).fma(
x
,y
, \( \mp 0 \)) returns \( +0 \) if \( x \times y \) is exact \( \pm 0 \).fma(
x
,y
,z
) returns \( +0 \) if \( x \times y + z \) is exactly zero and \( z \neq 0 \).If either argument is NaN, NaN is returned.
Determines the maximum numeric value of the arguments
x
andy
. Treats NaN arguments as missing data. If one argument is a NaN and the other is legitimate numeric value, the numeric value is chosen.Note
- Returns
Returns the maximum numeric values of the arguments
x
andy
.If both arguments are NaN, returns NaN.
If one argument is NaN, returns the numeric argument.
Determines the minimum numeric value of the arguments
x
andy
- Returns
Returns the minimum numeric value of the arguments
x
andy
x
/y
.Calculate the double-precision floating-point remainder of
x
/y
. The floating-point remainder of the division operationx
/y
calculated by this function is exactly the valuex - n*y
, wheren
isx
/y
with its fractional part truncated. The computed value will have the same sign asx
, and its magnitude will be less than the magnitude ofy
.Note
- Returns
Returns the floating-point remainder of
x
/y
.fmod( \( \pm 0 \) ,
y
) returns \( \pm 0 \) ify
is not zero.fmod(
x
, \( \pm \infty \) ) returnsx
ifx
is finite.fmod(
x
,y
) returns NaN ifx
is \( \pm\infty \) ory
is zero.If either argument is NaN, NaN is returned.
Decompose the floating-point value
x
into a componentm
for the normalized fraction element and another termn
for the exponent. The absolute value ofm
will be greater than or equal to 0.5 and less than 1.0 or it will be equal to 0; \( x = m\cdot 2^n \). The integer exponentn
will be stored in the location to whichnptr
points.Note
- Returns
Returns the fractional component
m
.frexp( \( \pm 0 \) ,
nptr
) returns \( \pm 0 \) and stores zero in the location pointed to bynptr
.frexp( \( \pm \infty \) ,
nptr
) returns \( \pm \infty \) and stores an unspecified value in the location to whichnptr
points.frexp(NaN,
y
) returns a NaN and stores an unspecified value in the location to whichnptr
points.
Calculate the length of the hypotenuse of a right triangle whose two sides have lengths
x
andy
without undue overflow or underflow.Note
- Returns
Returns the length of the hypotenuse \( \sqrt{x^2+y^2} \).
hypot(
x
,y
), hypot(y
,x
), and hypot(x
,-y
) are equivalent.hypot(
x
, \( \pm 0 \) ) is equivalent to fabs(x
).hypot( \( \pm \infty \) ,
y
) returns \( +\infty \) , even ify
is a NaN.hypot(NaN,
y
) returns NaN, wheny
is not \( \pm\infty \).
Calculates the unbiased integer exponent of the input argument
x
.Note
- Returns
If successful, returns the unbiased exponent of the argument.
ilogb( \( \pm 0 \) ) returns
INT_MIN
.ilogb(NaN) returns
INT_MIN
.ilogb( \( \pm \infty \) ) returns
INT_MAX
.Note: above behavior does not take into account
FP_ILOGB0
norFP_ILOGBNAN
Determine whether the floating-point value
a
is a finite value (zero, subnormal, or normal and not infinity or NaN).- Returns
With Visual Studio 2013 host compiler: __RETURN_TYPE is ‘bool’. Returns true if and only if
a
is a finite value.With other host compilers: __RETURN_TYPE is ‘int’. Returns a nonzero value if and only if
a
is a finite value.
a
is an infinite value (positive or negative).- Returns
With Visual Studio 2013 host compiler: Returns true if and only if
a
is an infinite value.With other host compilers: Returns a nonzero value if and only if
a
a
is a NaN.- Returns
a
is a NaN value.With other host compilers: __RETURN_TYPE is ‘int’. Returns a nonzero value if and only if
a
is a NaN value.
x
, \( J_0(x) \).Note
- Returns
Returns the value of the Bessel function of the first kind of order 0.
j0( \( \pm \infty \) ) returns +0.
j0(NaN) returns NaN.
x
, \( J_1(x) \).Note
- Returns
Returns the value of the Bessel function of the first kind of order 1.
j1( \( \pm 0 \) ) returns \( \pm 0 \).
j1( \( \pm \infty \) ) returns \( \pm 0 \).
j1(NaN) returns NaN.
n
for the input argumentx
, \( J_n(x) \).Note
- Returns
n
.jn(
n
, NaN) returns NaN.jn(
n
,x
) returns NaN forn
< 0.jn(
n
, \( +\infty \) ) returns +0.
Calculate the value of \( x\cdot 2^{exp} \).
Calculate the value of \( x\cdot 2^{exp} \) of the input arguments
x
andexp
.Note
- Returns
ldexp(
x
,exp
) is equivalent to scalbn(x
,exp
x
, namely the value of \( \log_{e}\left|\Gamma(x)\right| \)Note
- Returns
lgamma(1) returns +0.
lgamma(2) returns +0.
lgamma(
x
) returns \( +\infty \) ifx
\( \leq \) 0 andx
is an integer.lgamma( \( -\infty \) ) returns \( +\infty \).
lgamma( \( +\infty \) ) returns \( +\infty \).
lgamma(NaN) returns NaN.
Round
x
to the nearest integer value, with halfway cases rounded to the nearest even integer value. If the result is outside the range of the return type, the behavior is undefined.- Returns
Returns rounded integer value.
Round
x
to the nearest integer value, with halfway cases rounded away from zero. If the result is outside the range of the return type, the behavior is undefined.Note
This function may be slower than alternate rounding methods. See llrint().
- Returns
Calculate the base \( e \) logarithm of the input argument.
x
.Note
- Returns
log( \( \pm 0 \) ) returns \( -\infty \).
log(1) returns +0.
log(
x
) returns NaN forx
< 0.log( \( +\infty \) ) returns \( +\infty \).
log(NaN) returns NaN.
x
.Note
- Returns
log10( \( \pm 0 \) ) returns \( -\infty \).
log10(1) returns +0.
log10(
x
) returns NaN forx
< 0.log10( \( +\infty \) ) returns \( +\infty \).
log10(NaN) returns NaN.
Calculate the value of \( \log_{e}(1+x) \).
Calculate the value of \( \log_{e}(1+x) \) of the input argument
x
.Note
- Returns
log1p( \( \pm 0 \) ) returns \( \pm 0 \).
log1p(-1) returns \( -\infty \).
log1p(
x
) returns NaN forx
< -1.log1p( \( +\infty \) ) returns \( +\infty \).
log1p(NaN) returns NaN.
x
.Note
- Returns
log2( \( \pm 0 \) ) returns \( -\infty \).
log2(1) returns +0.
log2(
x
) returns NaN forx
< 0.log2( \( +\infty \) ) returns \( +\infty \).
log2(NaN) returns NaN.
x
.Note
- Returns
logb( \( \pm 0 \) ) returns \( -\infty \).
logb( \( \pm \infty \) ) returns \( +\infty \).
logb(NaN) returns NaN.
Round
x
Round
x
This function may be slower than alternate rounding methods. See lrint().
- Returns
float
anddouble
arguments.Convert
float
argumenta
todouble
, followed by fmax().Note, this is different from
std:
: specification
double
andfloat
arguments.Convert
float
argumentb
todouble
std:
: specification
float
arguments.Calculate the maximum value of the arguments
a
andb
. Behavior is equivalent to fmax() function.Note, this is different from
std:
: specification
float
anddouble
arguments.Convert
float
argumenta
todouble
, followed by fmin().Note, this is different from
std:
: specification
float
arguments.Calculate the minimum value of the arguments
a
andb
. Behavior is equivalent to fmin() function.Note, this is different from
std:
: specification
double
andfloat
arguments.Convert
float
argumentb
todouble
std:
: specification
Break down the argument
x
into fractional and integral parts. The integral part is stored in the argumentiptr
. Fractional and integral parts are given the same sign as the argumentx
.Note
- Returns
modf( \( \pm x \) ,
iptr
) returns a result with the same sign asx
.modf( \( \pm \infty \) ,
iptr
) returns \( \pm 0 \) and stores \( \pm \infty \) in the object pointed to byiptr
.modf(NaN,
iptr
) stores a NaN in the object pointed to byiptr
and returns a NaN.
Returns “Not a Number” value.
Return a representation of a quiet NaN. Argument
tagp
selects one of the possible representations.Note
- Returns
nan(
tagp
) returns NaN.
Round argument
x
to an integer value in double precision floating-point format. Uses round to nearest rounding, with ties rounding to even.Note
- Returns
nearbyint( \( \pm 0 \) ) returns \( \pm 0 \).
nearbyint( \( \pm \infty \) ) returns \( \pm \infty \).
nearbyint(NaN) returns NaN.
x
.Calculate the next representable double-precision floating-point value following
x
. For example, ify
is greater thanx
, nextafter() returns the smallest representable number greater thanx
Note
- Returns
nextafter(
x
,y
) =y
ifx
equalsy
.nextafter(
x
,y
) =NaN
if eitherx
ory
areNaN
Calculate the length of a vector p, dimension of which is passed as an argument
without
- Returns
Returns the length of the dim-D vector \( \sqrt{\sum_{i=0}^{dim-1} p_i^2} \).
In the presence of an exactly infinite coordinate \( +\infty \) is returned, even if there are NaNs.
returns +0, when all coordinates are \( \pm 0 \).
returns NaN, when at least one of the coordinates is NaN and none are infinite.
Calculate the length of three dimensional vector in Euclidean space without undue overflow or underflow.
Note
- Returns
Returns the length of 3D vector \( \sqrt{a^2+b^2+c^2} \).
Calculate the length of four dimensional vector in Euclidean space without undue overflow or underflow.
Note
- Returns
Returns the length of 4D vector \( \sqrt{a^2+b^2+c^2+d^2} \).
Calculate the cumulative distribution function of the standard normal distribution for input argument
x
, \( \Phi(x) \).Note
- Returns
normcdf( \( +\infty \) ) returns 1.
normcdf( \( -\infty \) ) returns +0.
normcdf(NaN) returns NaN.
Calculate the inverse of the standard normal cumulative distribution function for input argument
x
, \( \Phi^{-1}(x) \). The function is defined for input values in the interval \( (0, 1) \).Note
- Returns
normcdfinv( \( \pm 0 \) ) returns \( -\infty \).
normcdfinv(1) returns \( +\infty \).
normcdfinv(
x
) returns NaN ifx
is not in the interval [0,1].normcdfinv(NaN) returns NaN.
x
to the power ofy
.Note
- Returns
pow( \( \pm 0 \) ,
y
) returns \( \pm \infty \) fory
an odd integer less than 0.pow( \( \pm 0 \) ,
y
) returns \( +\infty \) fory
less than 0 and not an odd integer.pow( \( \pm 0 \) ,
y
) returns \( \pm 0 \) fory
an odd integer greater than 0.pow( \( \pm 0 \) ,
y
) returns +0 fory
> 0 and not an odd integer.pow(-1, \( \pm \infty \) ) returns 1.
pow(+1,
y
) returns 1 for anyy
, even a NaN.pow(
x
, \( \pm 0 \) ) returns 1 for anyx
, even a NaN.pow(
x
,y
) returns a NaN for finitex
< 0 and finite non-integery
.pow(
x
, \( -\infty \) ) returns \( +\infty \) for \( | x | < 1 \).pow(
x
, \( -\infty \) ) returns +0 for \( | x | > 1 \).pow(
x
, \( +\infty \) ) returns +0 for \( | x | < 1 \).pow(
x
, \( +\infty \) ) returns \( +\infty \) for \( | x | > 1 \).pow( \( -\infty \) ,
y
) returns -0 fory
an odd integer less than 0.pow( \( -\infty \) ,
y
) returns +0 fory
< 0 and not an odd integer.pow( \( -\infty \) ,
y
) returns \( -\infty \) fory
an odd integer greater than 0.pow( \( -\infty \) ,
y
> 0 and not an odd integer.pow( \( +\infty \) ,
y
) returns +0 fory
< 0.pow( \( +\infty \) ,
y
> 0.pow(
x
,y
) returns NaN if eitherx
ory
or both are NaN andx
\( \neq \) +1 andy
\( \neq\pm 0 \).
Calculate reciprocal cube root function of
x
.Note
- Returns
rcbrt( \( \pm 0 \) ) returns \( \pm \infty \).
rcbrt( \( \pm \infty \) ) returns \( \pm 0 \).
rcbrt(NaN) returns NaN.
r
of dividingx
byy
for nonzeroy
. Thus \( r = x - n y \). The valuen
is the integer value nearest \( \frac{x}{y} \). In the case when \( | n -\frac{x}{y} | = \frac{1}{2} \) , the evenn
- Returns
remainder(
x
, \( \pm 0 \) ) returns NaN.remainder( \( \pm \infty \) ,
y
x
for finitex
Compute a double-precision floating-point remainder in the same way as the remainder() function. Argument
quo
returns part of quotient upon division ofx
byy
. Valuequo
has the same sign as \( \frac{x}{y} \) and may not be the exact quotient but agrees with the exact quotient in the low order 3 bits.Note
- Returns
Returns the remainder.
remquo(
x
, \( \pm 0 \) ,quo
) returns NaN and stores an unspecified value in the location to whichquo
points.remquo( \( \pm \infty \) ,
y
,quo
points.remquo(
x
,y
,quo
points if either ofx
ory
is NaN.remquo(
x
, \( \pm \infty \) ,quo
) returnsx
and stores zero in the location to whichquo
points for finitex
Calculate one over the length of the hypotenuse of a right triangle whose two sides have lengths
x
andy
- Returns
Returns one over the length of the hypotenuse \( \frac{1}{\sqrt{x^2+y^2}} \).
rhypot(
x
,y
), rhypot(y
,x
), and rhypot(x
,-y
) are equivalent.rhypot( \( \pm \infty \) ,
y
) returns +0, even ify
is a NaN.rhypot( \( \pm 0, \pm 0 \)) returns \( +\infty \).
rhypot(NaN,
y
Round
x
to the nearest integer value in floating-point format, with halfway cases rounded to the nearest even integer value.- Returns
rint( \( \pm 0 \) ) returns \( \pm 0 \).
rint( \( \pm \infty \) ) returns \( \pm \infty \).
rint(NaN) returns NaN.
Calculates one over the length of vector
p
, dimension of which is passed as an argument, in Euclidean space without undue overflow or underflow.Note
- Returns
Returns one over the length of the vector \( \frac{1}{\sqrt{\sum_{i=0}^{dim-1} p_i^2}} \).
In the presence of an exactly infinite coordinate \( +0 \) is returned, even if there are NaNs.
returns \( +\infty \), when all coordinates are \( \pm 0 \).
Calculate one over the length of three dimensional vector in Euclidean space without undue overflow or underflow.
Note
- Returns
Returns one over the length of the 3D vector \( \frac{1}{\sqrt{a^2+b^2+c^2}} \).
Calculate one over the length of four dimensional vector in Euclidean space without undue overflow or underflow.
Note
- Returns
Returns one over the length of the 3D vector \( \frac{1}{\sqrt{a^2+b^2+c^2+d^2}} \).
Round
x
to the nearest integer value in floating-point format, with halfway cases rounded away from zero.Note
This function may be slower than alternate rounding methods. See rint().
- Returns
round( \( \pm 0 \) ) returns \( \pm 0 \).
round( \( \pm \infty \) ) returns \( \pm \infty \).
round(NaN) returns NaN.
Calculate the reciprocal of the nonnegative square root of
x
, \( 1/\sqrt{x} \).Note
- Returns
Returns \( 1/\sqrt{x} \).
rsqrt( \( +\infty \) ) returns +0.
rsqrt( \( \pm 0 \) ) returns \( \pm \infty \).
rsqrt(
x
) returns NaN ifx
is less than 0.rsqrt(NaN) returns NaN.
Scale
x
by \( 2^n \) by efficient manipulation of the floating-point exponent.- Returns
Returns
x
* \( 2^n \).scalbln( \( \pm 0 \) ,
n
) returns \( \pm 0 \).scalbln(
x
, 0) returnsx
.scalbln( \( \pm \infty \) ,
n
) returns \( \pm \infty \).scalbln(NaN,
n
) returns NaN.
Scale
x
Returns
x
* \( 2^n \).scalbn( \( \pm 0 \) ,
n
) returns \( \pm 0 \).scalbn(
x
, 0) returnsx
.scalbn( \( \pm \infty \) ,
n
) returns \( \pm \infty \).scalbn(NaN,
n
) returns NaN.
a
is negative.- Returns
Reports the sign bit of all values including infinities, zeros, and NaNs.
a
is negative.With other host compilers: __RETURN_TYPE is ‘int’. Returns a nonzero value if and only if
a
is negative.
x
- Returns
sin( \( \pm \infty \) ) returns NaN.
x
(measured in radians). The results for sine and cosine are written into the second argument,sptr
, and, respectively, third argument,cptr
.Note
Calculate the sine and cosine of the first input argument \( \times \pi \).
Calculate the sine and cosine of the first input argument,
x
(measured in radians), \( \times \pi \). The results for sine and cosine are written into the second argument,sptr
.Note
x
.Note
- Returns
Calculate the sine of the input argument \( \times \pi \).
x
- Returns
sinpi( \( \pm 0 \) ) returns \( \pm 0 \).
sinpi( \( \pm \infty \) ) returns NaN.
sinpi(NaN) returns NaN.
Calculate the nonnegative square root of
x
, \( \sqrt{x} \).Note
- Returns
Returns \( \sqrt{x} \).
sqrt( \( \pm 0 \) ) returns \( \pm 0 \).
sqrt( \( +\infty \) ) returns \( +\infty \).
sqrt(
x
) returns NaN ifx
is less than 0.sqrt(NaN) returns NaN.
x
- Returns
tan( \( \pm \infty \) ) returns NaN.
x
.Note
- Returns
tanh( \( \pm \infty \) ) returns \( \pm 1 \).
x
, namely the value of \( \Gamma(x) \).Note
- Returns
tgamma( \( \pm 0 \) ) returns \( \pm \infty \).
tgamma(
x
) returns NaN ifx
< 0 andx
is an integer.tgamma( \( -\infty \) ) returns NaN.
tgamma( \( +\infty \) ) returns \( +\infty \).
tgamma(NaN) returns NaN.
Round
x
to the nearest integer value that does not exceedx
in magnitude.Note
- Returns
Returns truncated integer value.
trunc( \( \pm 0 \) ) returns \( \pm 0 \).
trunc( \( \pm \infty \) ) returns \( \pm \infty \).
trunc(NaN) returns NaN.
x
, \( Y_0(x) \).Note
- Returns
Returns the value of the Bessel function of the second kind of order 0.
y0( \( \pm 0 \) ) returns \( -\infty \).
y0(
x
) returns NaN forx
< 0.y0( \( +\infty \) ) returns +0.
y0(NaN) returns NaN.
x
, \( Y_1(x) \).Note
- Returns
Returns the value of the Bessel function of the second kind of order 1.
y1( \( \pm 0 \) ) returns \( -\infty \).
y1(
x
) returns NaN forx
< 0.y1( \( +\infty \) ) returns +0.
y1(NaN) returns NaN.
n
, \( Y_n(x) \).Note
- Returns
n
.yn(
n
,x
) returns NaN forn
< 0.yn(
n
, \( \pm 0 \) ) returns \( -\infty \).yn(
n
,x
) returns NaN forx
< 0.yn(
n
, \( +\infty \) ) returns +0.yn(
n
, NaN) returns NaN.
