7. Single Precision Intrinsics
This section describes single precision intrinsic functions that are only supported in device code.
To use these functions, you do not need to include any additional header file in your program.
Functions
- __device__ float __cosf(float x)
Calculate the fast approximate cosine of the input argument.
- __device__ float __exp10f(float x)
Calculate the fast approximate base 10 exponential of the input argument.
- __device__ float __expf(float x)
Calculate the fast approximate base \(e\) exponential of the input argument.
- __device__ float2 __fadd2_rd(float2 x, float2 y)
Compute vector add operation \(x + y\) in round-down mode.
- __device__ float2 __fadd2_rn(float2 x, float2 y)
Compute vector add operation \(x + y\) in round-to-nearest-even mode.
- __device__ float2 __fadd2_ru(float2 x, float2 y)
Compute vector add operation \(x + y\) in round-up mode.
- __device__ float2 __fadd2_rz(float2 x, float2 y)
Compute vector add operation \(x + y\) in round-towards-zero mode.
- __device__ float __fadd_rd(float x, float y)
Add two floating-point values in round-down mode.
- __device__ float __fadd_rn(float x, float y)
Add two floating-point values in round-to-nearest-even mode.
- __device__ float __fadd_ru(float x, float y)
Add two floating-point values in round-up mode.
- __device__ float __fadd_rz(float x, float y)
Add two floating-point values in round-towards-zero mode.
- __device__ float __fdiv_rd(float x, float y)
Divide two floating-point values in round-down mode.
- __device__ float __fdiv_rn(float x, float y)
Divide two floating-point values in round-to-nearest-even mode.
- __device__ float __fdiv_ru(float x, float y)
Divide two floating-point values in round-up mode.
- __device__ float __fdiv_rz(float x, float y)
Divide two floating-point values in round-towards-zero mode.
- __device__ float __fdividef(float x, float y)
Calculate the fast approximate division of the input arguments.
- __device__ float2 __ffma2_rd(float2 x, float2 y, float2 z)
Compute vector fused multiply-add operation \(x \times y + z\) in round-down mode.
- __device__ float2 __ffma2_rn(float2 x, float2 y, float2 z)
Compute vector fused multiply-add operation \(x \times y + z\) in round-to-nearest-even mode.
- __device__ float2 __ffma2_ru(float2 x, float2 y, float2 z)
Compute vector fused multiply-add operation \(x \times y + z\) in round-up mode.
- __device__ float2 __ffma2_rz(float2 x, float2 y, float2 z)
Compute vector fused multiply-add operation \(x \times y + z\) in round-towards-zero mode.
- __device__ float __fmaf_ieee_rd(float x, float y, float z)
Compute fused multiply-add operation in round-down mode, ignore
-ftz=true
compiler flag.- __device__ float __fmaf_ieee_rn(float x, float y, float z)
Compute fused multiply-add operation in round-to-nearest-even mode, ignore
-ftz=true
compiler flag.- __device__ float __fmaf_ieee_ru(float x, float y, float z)
Compute fused multiply-add operation in round-up mode, ignore
-ftz=true
compiler flag.- __device__ float __fmaf_ieee_rz(float x, float y, float z)
Compute fused multiply-add operation in round-towards-zero mode, ignore
-ftz=true
compiler flag.- __device__ float __fmaf_rd(float x, float y, float z)
Compute \(x \times y + z\) as a single operation, in round-down mode.
- __device__ float __fmaf_rn(float x, float y, float z)
Compute \(x \times y + z\) as a single operation, in round-to-nearest-even mode.
- __device__ float __fmaf_ru(float x, float y, float z)
Compute \(x \times y + z\) as a single operation, in round-up mode.
- __device__ float __fmaf_rz(float x, float y, float z)
Compute \(x \times y + z\) as a single operation, in round-towards-zero mode.
- __device__ float2 __fmul2_rd(float2 x, float2 y)
Compute vector multiply operation \(x \times y\) in round-down mode.
- __device__ float2 __fmul2_rn(float2 x, float2 y)
Compute vector multiply operation \(x \times y\) in round-to-nearest-even mode.
- __device__ float2 __fmul2_ru(float2 x, float2 y)
Compute vector multiply operation \(x \times y\) in round-up mode.
- __device__ float2 __fmul2_rz(float2 x, float2 y)
Compute vector multiply operation \(x \times y\) in round-towards-zero mode.
- __device__ float __fmul_rd(float x, float y)
Multiply two floating-point values in round-down mode.
- __device__ float __fmul_rn(float x, float y)
Multiply two floating-point values in round-to-nearest-even mode.
- __device__ float __fmul_ru(float x, float y)
Multiply two floating-point values in round-up mode.
- __device__ float __fmul_rz(float x, float y)
Multiply two floating-point values in round-towards-zero mode.
- __device__ float __frcp_rd(float x)
Compute \(\frac{1}{x}\) in round-down mode.
- __device__ float __frcp_rn(float x)
Compute \(\frac{1}{x}\) in round-to-nearest-even mode.
- __device__ float __frcp_ru(float x)
Compute \(\frac{1}{x}\) in round-up mode.
- __device__ float __frcp_rz(float x)
Compute \(\frac{1}{x}\) in round-towards-zero mode.
- __device__ float __frsqrt_rn(float x)
Compute \(1/\sqrt{x}\) in round-to-nearest-even mode.
- __device__ float __fsqrt_rd(float x)
Compute \(\sqrt{x}\) in round-down mode.
- __device__ float __fsqrt_rn(float x)
Compute \(\sqrt{x}\) in round-to-nearest-even mode.
- __device__ float __fsqrt_ru(float x)
Compute \(\sqrt{x}\) in round-up mode.
- __device__ float __fsqrt_rz(float x)
Compute \(\sqrt{x}\) in round-towards-zero mode.
- __device__ float __fsub_rd(float x, float y)
Subtract two floating-point values in round-down mode.
- __device__ float __fsub_rn(float x, float y)
Subtract two floating-point values in round-to-nearest-even mode.
- __device__ float __fsub_ru(float x, float y)
Subtract two floating-point values in round-up mode.
- __device__ float __fsub_rz(float x, float y)
Subtract two floating-point values in round-towards-zero mode.
- __device__ float __log10f(float x)
Calculate the fast approximate base 10 logarithm of the input argument.
- __device__ float __log2f(float x)
Calculate the fast approximate base 2 logarithm of the input argument.
- __device__ float __logf(float x)
Calculate the fast approximate base \(e\) logarithm of the input argument.
- __device__ float __powf(float x, float y)
Calculate the fast approximate of \(x^y\) .
- __device__ float __saturatef(float x)
Clamp the input argument to [+0.0, 1.0].
- __device__ void __sincosf(float x, float *sptr, float *cptr)
Calculate the fast approximate of sine and cosine of the first input argument.
- __device__ float __sinf(float x)
Calculate the fast approximate sine of the input argument.
- __device__ float __tanf(float x)
Calculate the fast approximate tangent of the input argument.
- __device__ float __tanhf(float x)
Calculate the fast approximate hyperbolic tangent of the input argument.
7.1. Functions
x
, measured in radians.See also
cosf() for further special case behavior specification.
Note
For accuracy information, see the CUDA C++ Programming Guide, Mathematical Functions Appendix, Intrinsic Functions section.
- Returns
Returns the approximate cosine of
x
x
, \( 10^x \).See also
exp10f() for further special case behavior specification.
Note
- Returns
Returns an approximation to \( 10^x \).
Calculate the fast approximate base \( e \) exponential of the input argument.
x
, \( e^x \).See also
expf() for further special case behavior specification.
Note
- Returns
Returns an approximation to \( e^x \).
Compute vector add operation \( x + y \) in round-down mode.
Numeric behavior per component is the same as __fadd_rd().
Note
This intrinsic requires compute capability >= 10.0.
Note
The vector variants may not always provide better performance.
Compute vector add operation \( x + y \) in round-to-nearest-even mode.
Numeric behavior per component is the same as __fadd_rn().
Note
Note
Compute vector add operation \( x + y \) in round-up mode.
Numeric behavior per component is the same as __fadd_ru().
Note
Note
Compute vector add operation \( x + y \) in round-towards-zero mode.
Numeric behavior per component is the same as __fadd_rz().
Note
Note
Compute the sum of
x
andy
in round-down (to negative infinity) mode.Note
Note
This operation will never be merged into a single multiply-add instruction.
- Returns
Returns
x
+y
.__fadd_rd(
x
,y
) is equivalent to __fadd_rd(y
,x
).__fadd_rd(
x
, \( \pm\infty \)) returns \( \pm\infty \) for finitex
.__fadd_rd( \( \pm\infty \), \( \pm\infty \)) returns \( \pm\infty \).
__fadd_rd( \( \pm\infty \), \( \mp\infty \)) returns NaN.
__fadd_rd( \( \pm 0 \), \( \pm 0 \)) returns \( \pm 0 \).
__fadd_rd(
x
,-x
) returns \( -0 \) for finitex
, including \( \pm 0 \).If either argument is NaN, NaN is returned.
Compute the sum of
x
andy
in round-to-nearest-even rounding mode.Note
Note
- Returns
Returns
x
+y
.__fadd_rn(
x
,y
) is equivalent to __fadd_rn(y
,x
).__fadd_rn(
x
.__fadd_rn( \( \pm\infty \), \( \pm\infty \)) returns \( \pm\infty \).
__fadd_rn( \( \pm\infty \), \( \mp\infty \)) returns NaN.
__fadd_rn( \( \pm 0 \), \( \pm 0 \)) returns \( \pm 0 \).
__fadd_rn(
x
,-x
) returns \( +0 \) for finitex
Compute the sum of
x
andy
in round-up (to positive infinity) mode.Note
Note
- Returns
Returns
x
+y
.__fadd_ru(
x
,y
) is equivalent to __fadd_ru(y
,x
).__fadd_ru(
x
.__fadd_ru( \( \pm\infty \), \( \pm\infty \)) returns \( \pm\infty \).
__fadd_ru( \( \pm\infty \), \( \mp\infty \)) returns NaN.
__fadd_ru( \( \pm 0 \), \( \pm 0 \)) returns \( \pm 0 \).
__fadd_ru(
x
,-x
Compute the sum of
x
andy
in round-towards-zero mode.Note
Note
- Returns
Returns
x
+y
.__fadd_rz(
x
,y
) is equivalent to __fadd_rz(y
,x
).__fadd_rz(
x
.__fadd_rz( \( \pm\infty \), \( \pm\infty \)) returns \( \pm\infty \).
__fadd_rz( \( \pm\infty \), \( \mp\infty \)) returns NaN.
__fadd_rz( \( \pm 0 \), \( \pm 0 \)) returns \( \pm 0 \).
__fadd_rz(
x
,-x
x
byy
- Returns
Returns
x
/y
.sign of the quotient
x
/y
is XOR of the signs ofx
andy
when neither inputs nor result are NaN.__fdiv_rd( \( \pm 0 \), \( \pm 0 \)) returns NaN.
__fdiv_rd( \( \pm\infty \), \( \pm\infty \)) returns NaN.
__fdiv_rd(
x
, \( \pm\infty \)) returns \( 0 \) of appropriate sign for finitex
.__fdiv_rd( \( \pm\infty \),
y
) returns \( \infty \) of appropriate sign for finitey
.__fdiv_rd(
x
, \( \pm 0 \)) returns \( \infty \) of appropriate sign forx
\( \neq 0 \).__fdiv_rd( \( \pm 0 \),
y
) returns \( 0 \) of appropriate sign fory
\( \neq 0 \).If either argument is NaN, NaN is returned.
x
byy
in round-to-nearest-even mode.Note
- Returns
Returns
x
/y
x
/y
andy
when neither inputs nor result are NaN.__fdiv_rn( \( \pm 0 \), \( \pm 0 \)) returns NaN.
__fdiv_rn( \( \pm\infty \), \( \pm\infty \)) returns NaN.
__fdiv_rn(
x
.__fdiv_rn( \( \pm\infty \),
y
.__fdiv_rn(
x
\( \neq 0 \).__fdiv_rn( \( \pm 0 \),
y
x
byy
- Returns
Returns
x
/y
x
/y
andy
when neither inputs nor result are NaN.__fdiv_ru( \( \pm 0 \), \( \pm 0 \)) returns NaN.
__fdiv_ru( \( \pm\infty \), \( \pm\infty \)) returns NaN.
__fdiv_ru(
x
.__fdiv_ru( \( \pm\infty \),
y
.__fdiv_ru(
x
\( \neq 0 \).__fdiv_ru( \( \pm 0 \),
y
x
byy
- Returns
Returns
x
/y
x
/y
andy
when neither inputs nor result are NaN.__fdiv_rz( \( \pm 0 \), \( \pm 0 \)) returns NaN.
__fdiv_rz( \( \pm\infty \), \( \pm\infty \)) returns NaN.
__fdiv_rz(
x
.__fdiv_rz( \( \pm\infty \),
y
.__fdiv_rz(
x
\( \neq 0 \).__fdiv_rz( \( \pm 0 \),
y
x
byy
.See also
__fdiv_rn() for further special case behavior specification.
Note
- Returns
Returns
x
/y
.__fdividef( \( \infty \) ,
y
) returns NaN for \( 2^{126} < |y| < 2^{128} \).__fdividef(
x
,y
) returns 0 for \( 2^{126} < |y| < 2^{128} \) and finite \( x \).
Compute vector fused multiply-add operation \( x \times y + z \) in round-down mode.
Numeric behavior per component is the same as __fmaf_rd().
Note
Note
Compute vector fused multiply-add operation \( x \times y + z \) in round-to-nearest-even mode.
Numeric behavior per component is the same as __fmaf_rn().
Note
Note
Compute vector fused multiply-add operation \( x \times y + z \) in round-up mode.
Numeric behavior per component is the same as __fmaf_ru().
Note
Note
Compute vector fused multiply-add operation \( x \times y + z \) in round-towards-zero mode.
Numeric behavior per component is the same as __fmaf_rz().
Note
Note
-ftz=true
compiler flag.Behavior is the same as __fmaf_rd(
x
,y
,z
), the difference is in handling denormalized inputs and outputs:-ftz
compiler flag has no effect.
-ftz=true
compiler flag.Behavior is the same as __fmaf_rn(
x
,y
,z
-ftz=true
compiler flag.Behavior is the same as __fmaf_ru(
x
,y
,z
-ftz=true
compiler flag.Behavior is the same as __fmaf_rz(
x
,y
,z
Compute \( x \times y + z \) as a single operation, in round-down mode.
Computes the value of \( x \times y + z \) as a single ternary operation, rounding the result once in round-down (to negative infinity) mode.
Note
- Returns
Returns the rounded value of \( x \times y + z \) as a single operation.
__fmaf_rd( \( \pm \infty \) , \( \pm 0 \) ,
z
) returns NaN.__fmaf_rd( \( \pm 0 \) , \( \pm \infty \) ,
z
x
,y
, \( -\infty \) ) returns NaN if \( x \times y \) is an exact \( +\infty \).__fmaf_rd(
x
,y
, \( +\infty \) ) returns NaN if \( x \times y \) is an exact \( -\infty \).__fmaf_rd(
x
,y
, \( \pm 0 \)) returns \( \pm 0 \) if \( x \times y \) is exact \( \pm 0 \).__fmaf_rd(
x
,y
, \( \mp 0 \)) returns \( -0 \) if \( x \times y \) is exact \( \pm 0 \).__fmaf_rd(
x
,y
,z
) returns \( -0 \) if \( x \times y + z \) is exactly zero and \( z \neq 0 \).If either argument is NaN, NaN is returned.
Compute \( x \times y + z \) as a single operation, in round-to-nearest-even mode.
Computes the value of \( x \times y + z \) as a single ternary operation, rounding the result once in round-to-nearest-even mode.
Note
- Returns
__fmaf_rn( \( \pm \infty \) , \( \pm 0 \) ,
z
) returns NaN.__fmaf_rn( \( \pm 0 \) , \( \pm \infty \) ,
z
x
,y
, \( -\infty \) ) returns NaN if \( x \times y \) is an exact \( +\infty \).__fmaf_rn(
x
,y
, \( +\infty \) ) returns NaN if \( x \times y \) is an exact \( -\infty \).__fmaf_rn(
x
,y
, \( \pm 0 \)) returns \( \pm 0 \) if \( x \times y \) is exact \( \pm 0 \).__fmaf_rn(
x
,y
, \( \mp 0 \)) returns \( +0 \) if \( x \times y \) is exact \( \pm 0 \).__fmaf_rn(
x
,y
,z
) returns \( +0 \) if \( x \times y + z \) is exactly zero and \( z \neq 0 \).If either argument is NaN, NaN is returned.
Compute \( x \times y + z \) as a single operation, in round-up mode.
Computes the value of \( x \times y + z \) as a single ternary operation, rounding the result once in round-up (to positive infinity) mode.
Note
- Returns
__fmaf_ru( \( \pm \infty \) , \( \pm 0 \) ,
z
) returns NaN.__fmaf_ru( \( \pm 0 \) , \( \pm \infty \) ,
z
x
,y
, \( -\infty \) ) returns NaN if \( x \times y \) is an exact \( +\infty \).__fmaf_ru(
x
,y
, \( +\infty \) ) returns NaN if \( x \times y \) is an exact \( -\infty \).__fmaf_ru(
x
,y
, \( \pm 0 \)) returns \( \pm 0 \) if \( x \times y \) is exact \( \pm 0 \).__fmaf_ru(
x
,y
, \( \mp 0 \)) returns \( +0 \) if \( x \times y \) is exact \( \pm 0 \).__fmaf_ru(
x
,y
,z
Compute \( x \times y + z \) as a single operation, in round-towards-zero mode.
Computes the value of \( x \times y + z \) as a single ternary operation, rounding the result once in round-towards-zero mode.
Note
- Returns
__fmaf_rz( \( \pm \infty \) , \( \pm 0 \) ,
z
) returns NaN.__fmaf_rz( \( \pm 0 \) , \( \pm \infty \) ,
z
x
,y
, \( -\infty \) ) returns NaN if \( x \times y \) is an exact \( +\infty \).__fmaf_rz(
x
,y
, \( +\infty \) ) returns NaN if \( x \times y \) is an exact \( -\infty \).__fmaf_rz(
x
,y
, \( \pm 0 \)) returns \( \pm 0 \) if \( x \times y \) is exact \( \pm 0 \).__fmaf_rz(
x
,y
, \( \mp 0 \)) returns \( +0 \) if \( x \times y \) is exact \( \pm 0 \).__fmaf_rz(
x
,y
,z
Compute vector multiply operation \( x \times y \) in round-down mode.
Numeric behavior per component is the same as __fmul_rd().
Note
Note
Compute vector multiply operation \( x \times y \) in round-to-nearest-even mode.
Numeric behavior per component is the same as __fmul_rn().
Note
Note
Compute vector multiply operation \( x \times y \) in round-up mode.
Numeric behavior per component is the same as __fmul_ru().
Note
Note
Compute vector multiply operation \( x \times y \) in round-towards-zero mode.
Numeric behavior per component is the same as __fmul_rz().
Note
Note
Compute the product of
x
andy
Note
- Returns
Returns
x
*y
.sign of the product
x
*y
andy
when neither inputs nor result are NaN.__fmul_rd(
x
,y
) is equivalent to __fmul_rd(y
,x
).__fmul_rd(
x
, \( \pm\infty \)) returns \( \infty \) of appropriate sign forx
\( \neq 0 \).__fmul_rd( \( \pm 0 \), \( \pm\infty \)) returns NaN.
y
) returns \( 0 \) of appropriate sign for finitey
x
andy
Note
- Returns
Returns
x
*y
x
*y
andy
when neither inputs nor result are NaN.__fmul_rn(
x
,y
) is equivalent to __fmul_rn(y
,x
).__fmul_rn(
x
\( \neq 0 \).__fmul_rn( \( \pm 0 \), \( \pm\infty \)) returns NaN.
y
x
andy
Note
- Returns
Returns
x
*y
x
*y
andy
when neither inputs nor result are NaN.__fmul_ru(
x
,y
) is equivalent to __fmul_ru(y
,x
).__fmul_ru(
x
\( \neq 0 \).__fmul_ru( \( \pm 0 \), \( \pm\infty \)) returns NaN.
y
x
andy
Note
- Returns
Returns
x
*y
x
*y
andy
when neither inputs nor result are NaN.__fmul_rz(
x
,y
) is equivalent to __fmul_rz(y
,x
).__fmul_rz(
x
\( \neq 0 \).__fmul_rz( \( \pm 0 \), \( \pm\infty \)) returns NaN.
y
Compute \( \frac{1}{x} \) in round-down mode.
Compute the reciprocal of
x
- Returns
Returns \( \frac{1}{x} \).
__frcp_rd( \( \pm 0 \)) returns \( \pm\infty \).
__frcp_rd( \( \pm\infty \)) returns \( \pm 0 \).
__frcp_rd(NaN) returns NaN.
Compute \( \frac{1}{x} \) in round-to-nearest-even mode.
x
- Returns
__frcp_rn( \( \pm 0 \)) returns \( \pm\infty \).
__frcp_rn( \( \pm\infty \)) returns \( \pm 0 \).
__frcp_rn(NaN) returns NaN.
Compute \( \frac{1}{x} \) in round-up mode.
x
- Returns
__frcp_ru( \( \pm 0 \)) returns \( \pm\infty \).
__frcp_ru( \( \pm\infty \)) returns \( \pm 0 \).
__frcp_ru(NaN) returns NaN.
Compute \( \frac{1}{x} \) in round-towards-zero mode.
x
- Returns
__frcp_rz( \( \pm 0 \)) returns \( \pm\infty \).
__frcp_rz( \( \pm\infty \)) returns \( \pm 0 \).
__frcp_rz(NaN) returns NaN.
Compute \( 1/\sqrt{x} \) in round-to-nearest-even mode.
Compute the reciprocal square root of
x
- Returns
Returns \( 1/\sqrt{x} \).
__frsqrt_rn( \( \pm 0 \)) returns \( \pm\infty \).
__frsqrt_rn( \( +\infty \)) returns \( +0 \).
__frsqrt_rn(
x
) returns NaN forx
< 0.__frsqrt_rn(NaN) returns NaN.
Compute \( \sqrt{x} \) in round-down mode.
Compute the square root of
x
- Returns
Returns \( \sqrt{x} \).
__fsqrt_rd( \( \pm 0 \)) returns \( \pm 0 \).
__fsqrt_rd( \( +\infty \)) returns \( +\infty \).
__fsqrt_rd(
x
) returns NaN forx
< 0.__fsqrt_rd(NaN) returns NaN.
Compute \( \sqrt{x} \) in round-to-nearest-even mode.
x
- Returns
__fsqrt_rn( \( \pm 0 \)) returns \( \pm 0 \).
__fsqrt_rn( \( +\infty \)) returns \( +\infty \).
__fsqrt_rn(
x
) returns NaN forx
< 0.__fsqrt_rn(NaN) returns NaN.
Compute \( \sqrt{x} \) in round-up mode.
x
- Returns
__fsqrt_ru( \( \pm 0 \)) returns \( \pm 0 \).
__fsqrt_ru( \( +\infty \)) returns \( +\infty \).
__fsqrt_ru(
x
) returns NaN forx
< 0.__fsqrt_ru(NaN) returns NaN.
Compute \( \sqrt{x} \) in round-towards-zero mode.
x
- Returns
__fsqrt_rz( \( \pm 0 \)) returns \( \pm 0 \).
__fsqrt_rz( \( +\infty \)) returns \( +\infty \).
__fsqrt_rz(
x
) returns NaN forx
< 0.__fsqrt_rz(NaN) returns NaN.
Compute the difference of
x
andy
Note
- Returns
Returns
x
-y
.__fsub_rd( \( \pm\infty \),
y
) returns \( \pm\infty \) for finitey
.__fsub_rd(
x
, \( \pm\infty \)) returns \( \mp\infty \) for finitex
.__fsub_rd( \( \pm\infty \), \( \pm\infty \)) returns NaN.
__fsub_rd( \( \pm\infty \), \( \mp\infty \)) returns \( \pm\infty \).
__fsub_rd( \( \pm 0 \), \( \mp 0 \)) returns \( \pm 0 \).
__fsub_rd(
x
,x
x
andy
Note
- Returns
Returns
x
-y
.__fsub_rn( \( \pm\infty \),
y
.__fsub_rn(
x
.__fsub_rn( \( \pm\infty \), \( \pm\infty \)) returns NaN.
__fsub_rn( \( \pm\infty \), \( \mp\infty \)) returns \( \pm\infty \).
__fsub_rn( \( \pm 0 \), \( \mp 0 \)) returns \( \pm 0 \).
__fsub_rn(
x
,x
x
andy
Note
- Returns
Returns
x
-y
.__fsub_ru( \( \pm\infty \),
y
.__fsub_ru(
x
.__fsub_ru( \( \pm\infty \), \( \pm\infty \)) returns NaN.
__fsub_ru( \( \pm\infty \), \( \mp\infty \)) returns \( \pm\infty \).
__fsub_ru( \( \pm 0 \), \( \mp 0 \)) returns \( \pm 0 \).
__fsub_ru(
x
,x
x
andy
Note
- Returns
Returns
x
-y
.__fsub_rz( \( \pm\infty \),
y
.__fsub_rz(
x
.__fsub_rz( \( \pm\infty \), \( \pm\infty \)) returns NaN.
__fsub_rz( \( \pm\infty \), \( \mp\infty \)) returns \( \pm\infty \).
__fsub_rz( \( \pm 0 \), \( \mp 0 \)) returns \( \pm 0 \).
__fsub_rz(
x
,x
x
.See also
log10f() for further special case behavior specification.
Note
- Returns
Returns an approximation to \( \log_{10}(x) \).
x
.See also
log2f() for further special case behavior specification.
Note
- Returns
Returns an approximation to \( \log_2(x) \).
Calculate the fast approximate base \( e \) logarithm of the input argument.
x
.See also
logf() for further special case behavior specification.
Note
- Returns
Returns an approximation to \( \log_e(x) \).
Calculate the fast approximate of \( x^y \).
x
, the first input argument, raised to the power ofy
, the second input argument, \( x^y \).Note
- Returns
Returns an approximation to \( x^y \).
x
to be within the interval [+0.0, 1.0].- Returns
__saturatef(
x
) returns +0 if \( x \le 0 \).__saturatef(
x
) returns 1 if \( x \ge 1 \).__saturatef(
x
) returnsx
if \( 0 < x < 1 \).__saturatef(NaN) returns +0.
x
(measured in radians). The results for sine and cosine are written into the second argument,sptr
, and, respectively, third argument,cptr
.Note
Note
Denorm input/output is flushed to sign preserving 0.0.
x
sinf() for further special case behavior specification.
Note
Note
Output in the denormal range is flushed to sign preserving 0.0.
- Returns
Returns the approximate sine of
x
x
, measured in radians.Note
Note
The result is computed as the fast divide of __sinf() by __cosf(). Denormal output is flushed to sign-preserving 0.0.
- Returns
Returns the approximate tangent of
x
x
tanhf() for further special case behavior specification.
Note
- Returns
Returns the approximate hyperbolic tangent of
x
