6. Single Precision Mathematical Functions
This section describes single precision mathematical functions.
To use these functions, you do not need to include any additional header file in your program.
Functions
- __device__ float acosf(float x)
Calculate the arc cosine of the input argument.
- __device__ float acoshf(float x)
Calculate the nonnegative inverse hyperbolic cosine of the input argument.
- __device__ float asinf(float x)
Calculate the arc sine of the input argument.
- __device__ float asinhf(float x)
Calculate the inverse hyperbolic sine of the input argument.
- __device__ float atan2f(float y, float x)
Calculate the arc tangent of the ratio of first and second input arguments.
- __device__ float atanf(float x)
Calculate the arc tangent of the input argument.
- __device__ float atanhf(float x)
Calculate the inverse hyperbolic tangent of the input argument.
- __device__ float cbrtf(float x)
Calculate the cube root of the input argument.
- __device__ float ceilf(float x)
Calculate ceiling of the input argument.
- __device__ float copysignf(float x, float y)
Create value with given magnitude, copying sign of second value.
- __device__ float cosf(float x)
Calculate the cosine of the input argument.
- __device__ float coshf(float x)
Calculate the hyperbolic cosine of the input argument.
- __device__ float cospif(float x)
Calculate the cosine of the input argument \(\times \pi\) .
- __device__ float cyl_bessel_i0f(float x)
Calculate the value of the regular modified cylindrical Bessel function of order 0 for the input argument.
- __device__ float cyl_bessel_i1f(float x)
Calculate the value of the regular modified cylindrical Bessel function of order 1 for the input argument.
- __device__ float erfcf(float x)
Calculate the complementary error function of the input argument.
- __device__ float erfcinvf(float x)
Calculate the inverse complementary error function of the input argument.
- __device__ float erfcxf(float x)
Calculate the scaled complementary error function of the input argument.
- __device__ float erff(float x)
Calculate the error function of the input argument.
- __device__ float erfinvf(float x)
Calculate the inverse error function of the input argument.
- __device__ float exp10f(float x)
Calculate the base 10 exponential of the input argument.
- __device__ float exp2f(float x)
Calculate the base 2 exponential of the input argument.
- __device__ float expf(float x)
Calculate the base \(e\) exponential of the input argument.
- __device__ float expm1f(float x)
Calculate the base \(e\) exponential of the input argument, minus 1.
- __device__ float fabsf(float x)
Calculate the absolute value of its argument.
- __device__ float fdimf(float x, float y)
Compute the positive difference between
x
andy
.- __device__ float fdividef(float x, float y)
Divide two floating-point values.
- __device__ float floorf(float x)
Calculate the largest integer less than or equal to
x
.- __device__ float fmaf(float x, float y, float z)
Compute \(x \times y + z\) as a single operation.
- __device__ float fmaxf(float x, float y)
Determine the maximum numeric value of the arguments.
- __device__ float fminf(float x, float y)
Determine the minimum numeric value of the arguments.
- __device__ float fmodf(float x, float y)
Calculate the floating-point remainder of
x
/y
.- __device__ float frexpf(float x, int *nptr)
Extract mantissa and exponent of a floating-point value.
- __device__ float hypotf(float x, float y)
Calculate the square root of the sum of squares of two arguments.
- __device__ int ilogbf(float x)
Compute the unbiased integer exponent of the argument.
- __device__ __RETURN_TYPE isfinite(float a)
Determine whether argument is finite.
- __device__ __RETURN_TYPE isinf(float a)
Determine whether argument is infinite.
- __device__ __RETURN_TYPE isnan(float a)
Determine whether argument is a NaN.
- __device__ float j0f(float x)
Calculate the value of the Bessel function of the first kind of order 0 for the input argument.
- __device__ float j1f(float x)
Calculate the value of the Bessel function of the first kind of order 1 for the input argument.
- __device__ float jnf(int n, float x)
Calculate the value of the Bessel function of the first kind of order n for the input argument.
- __device__ float ldexpf(float x, int exp)
Calculate the value of \(x\cdot 2^{exp}\) .
- __device__ float lgammaf(float x)
Calculate the natural logarithm of the absolute value of the gamma function of the input argument.
- __device__ long long int llrintf(float x)
Round input to nearest integer value.
- __device__ long long int llroundf(float x)
Round to nearest integer value.
- __device__ float log10f(float x)
Calculate the base 10 logarithm of the input argument.
- __device__ float log1pf(float x)
Calculate the value of \(\log_{e}(1+x)\) .
- __device__ float log2f(float x)
Calculate the base 2 logarithm of the input argument.
- __device__ float logbf(float x)
Calculate the floating-point representation of the exponent of the input argument.
- __device__ float logf(float x)
Calculate the natural logarithm of the input argument.
- __device__ long int lrintf(float x)
- __device__ long int lroundf(float x)
- __device__ float max(const float a, const float b)
Calculate the maximum value of the input
float
arguments.- __device__ float min(const float a, const float b)
Calculate the minimum value of the input
float
arguments.- __device__ float modff(float x, float *iptr)
Break down the input argument into fractional and integral parts.
- __device__ float nanf(const char *tagp)
Returns "Not a Number" value.
- __device__ float nearbyintf(float x)
Round the input argument to the nearest integer.
- __device__ float nextafterf(float x, float y)
Return next representable single-precision floating-point value after argument
x
in the direction ofy
.- __device__ float norm3df(float a, float b, float c)
Calculate the square root of the sum of squares of three coordinates of the argument.
- __device__ float norm4df(float a, float b, float c, float d)
Calculate the square root of the sum of squares of four coordinates of the argument.
- __device__ float normcdff(float x)
Calculate the standard normal cumulative distribution function.
- __device__ float normcdfinvf(float x)
Calculate the inverse of the standard normal cumulative distribution function.
- __device__ float normf(int dim, float const *p)
Calculate the square root of the sum of squares of any number of coordinates.
- __device__ float powf(float x, float y)
Calculate the value of first argument to the power of second argument.
- __device__ float rcbrtf(float x)
Calculate reciprocal cube root function.
- __device__ float remainderf(float x, float y)
Compute single-precision floating-point remainder.
- __device__ float remquof(float x, float y, int *quo)
Compute single-precision floating-point remainder and part of quotient.
- __device__ float rhypotf(float x, float y)
Calculate one over the square root of the sum of squares of two arguments.
- __device__ float rintf(float x)
Round input to nearest integer value in floating-point.
- __device__ float rnorm3df(float a, float b, float c)
Calculate one over the square root of the sum of squares of three coordinates.
- __device__ float rnorm4df(float a, float b, float c, float d)
Calculate one over the square root of the sum of squares of four coordinates.
- __device__ float rnormf(int dim, float const *p)
Calculate the reciprocal of square root of the sum of squares of any number of coordinates.
- __device__ float roundf(float x)
Round to nearest integer value in floating-point.
- __device__ float rsqrtf(float x)
Calculate the reciprocal of the square root of the input argument.
- __device__ float scalblnf(float x, long int n)
Scale floating-point input by integer power of two.
- __device__ float scalbnf(float x, int n)
- __device__ __RETURN_TYPE signbit(float a)
Return the sign bit of the input.
- __device__ void sincosf(float x, float *sptr, float *cptr)
Calculate the sine and cosine of the first input argument.
- __device__ void sincospif(float x, float *sptr, float *cptr)
Calculate the sine and cosine of the first input argument \(\times \pi\) .
- __device__ float sinf(float x)
Calculate the sine of the input argument.
- __device__ float sinhf(float x)
Calculate the hyperbolic sine of the input argument.
- __device__ float sinpif(float x)
Calculate the sine of the input argument \(\times \pi\) .
- __device__ float sqrtf(float x)
Calculate the square root of the input argument.
- __device__ float tanf(float x)
Calculate the tangent of the input argument.
- __device__ float tanhf(float x)
Calculate the hyperbolic tangent of the input argument.
- __device__ float tgammaf(float x)
Calculate the gamma function of the input argument.
- __device__ float truncf(float x)
Truncate input argument to the integral part.
- __device__ float y0f(float x)
Calculate the value of the Bessel function of the second kind of order 0 for the input argument.
- __device__ float y1f(float x)
Calculate the value of the Bessel function of the second kind of order 1 for the input argument.
- __device__ float ynf(int n, float x)
Calculate the value of the Bessel function of the second kind of order n for the input argument.
6.1. Functions
Calculate the principal value of the arc cosine of the input argument
x
.Note
For accuracy information, see the CUDA C++ Programming Guide, Mathematical Functions Appendix, Single-Precision Floating-Point Functions section.
- Returns
Result will be in radians, in the interval [0, \( \pi \) ] for
x
inside [-1, +1].acosf(1) returns +0.
acosf(
x
) returns NaN forx
outside [-1, +1].acosf(NaN) returns NaN.
x
.Note
- Returns
Result will be in the interval [0, \( +\infty \) ].
acoshf(1) returns 0.
acoshf(
x
) returns NaN forx
in the interval [ \( -\infty \) , 1).acoshf( \( +\infty \) ) returns \( +\infty \).
acoshf(NaN) returns NaN.
Calculate the principal value of the arc sine of the input argument
x
.Note
- Returns
Result will be in radians, in the interval [- \( \pi/2 \) , + \( \pi/2 \) ] for
x
inside [-1, +1].asinf( \( \pm 0 \) ) returns \( \pm 0 \).
asinf(
x
) returns NaN forx
outside [-1, +1].asinf(NaN) returns NaN.
x
.Note
- Returns
asinhf( \( \pm 0 \) ) returns \( \pm 0 \).
asinhf( \( \pm \infty \) ) returns \( \pm \infty \).
asinhf(NaN) returns NaN.
Calculate the principal value of the arc tangent of the ratio of first and second input arguments
y
/x
. The quadrant of the result is determined by the signs of inputsy
andx
.Note
- Returns
Result will be in radians, in the interval [- \( \pi \) , + \( \pi \) ].
atan2f( \( \pm 0 \) , -0) returns \( \pm \pi \).
atan2f( \( \pm 0 \) , +0) returns \( \pm 0 \).
x
) returns \( \pm \pi \) forx
< 0.atan2f( \( \pm 0 \) ,
x
) returns \( \pm 0 \) forx
> 0.atan2f(
y
, \( \pm 0 \) ) returns \( -\pi \) /2 fory
< 0.atan2f(
y
, \( \pm 0 \) ) returns \( \pi \) /2 fory
> 0.atan2f( \( \pm y \) , \( -\infty \) ) returns \( \pm \pi \) for finite
y
> 0.atan2f( \( \pm y \) , \( +\infty \) ) returns \( \pm 0 \) for finite
y
> 0.atan2f( \( \pm \infty \) ,
x
) returns \( \pm \pi \) /2 for finitex
.atan2f( \( \pm \infty \) , \( -\infty \) ) returns \( \pm 3\pi \) /4.
atan2f( \( \pm \infty \) , \( +\infty \) ) returns \( \pm \pi \) /4.
If either argument is NaN, NaN is returned.
Calculate the principal value of the arc tangent of the input argument
x
.Note
- Returns
Result will be in radians, in the interval [- \( \pi/2 \) , + \( \pi/2 \) ].
atanf( \( \pm 0 \) ) returns \( \pm 0 \).
atanf( \( \pm \infty \) ) returns \( \pm \pi \) /2.
atanf(NaN) returns NaN.
x
.Note
- Returns
atanhf( \( \pm 0 \) ) returns \( \pm 0 \).
atanhf( \( \pm 1 \) ) returns \( \pm \infty \).
atanhf(
x
) returns NaN forx
outside interval [-1, 1].atanhf(NaN) returns NaN.
x
, \( x^{1/3} \).Note
- Returns
Returns \( x^{1/3} \).
cbrtf( \( \pm 0 \) ) returns \( \pm 0 \).
cbrtf( \( \pm \infty \) ) returns \( \pm \infty \).
cbrtf(NaN) returns NaN.
Compute the smallest integer value not less than
x
.Note
- Returns
Returns \( \lceil x \rceil \) expressed as a floating-point number.
ceilf( \( \pm 0 \) ) returns \( \pm 0 \).
ceilf( \( \pm \infty \) ) returns \( \pm \infty \).
ceilf(NaN) returns NaN.
Create a floating-point value with the magnitude
x
and the sign ofy
.- Returns
a value with the magnitude of
x
and the sign ofy
.copysignf(
NaN
,y
) returns aNaN
with the sign ofy
x
(measured in radians).Note
Note
This function is affected by the
use_fast_math
compiler flag. See the CUDA C++ Programming Guide, Mathematical Functions Appendix, Intrinsic Functions section for a complete list of functions affected.- Returns
cosf( \( \pm 0 \) ) returns 1.
cosf( \( \pm \infty \) ) returns NaN.
x
.Note
- Returns
coshf( \( \pm 0 \) ) returns 1.
coshf( \( \pm \infty \) ) returns \( +\infty \).
Calculate the cosine of the input argument \( \times \pi \).
x
\( \times \pi \) (measured in radians), wherex
is the input argument.Note
- Returns
cospif( \( \pm 0 \) ) returns 1.
cospif( \( \pm \infty \) ) returns NaN.
cospif(NaN) returns NaN.
x
, \( I_0(x) \).Note
- Returns
Returns the value of the regular modified cylindrical Bessel function of order 0.
cyl_bessel_i0f( \( \pm 0 \)) returns +1.
cyl_bessel_i0f( \( \pm\infty \)) returns \( +\infty \).
cyl_bessel_i0f(NaN) returns NaN.
x
, \( I_1(x) \).Note
- Returns
Returns the value of the regular modified cylindrical Bessel function of order 1.
cyl_bessel_i1f( \( \pm 0 \)) returns \( \pm 0 \).
cyl_bessel_i1f( \( \pm\infty \)) returns \( \pm\infty \).
cyl_bessel_i1f(NaN) returns NaN.
x
, 1 - erf(x
).Note
- Returns
erfcf( \( -\infty \) ) returns 2.
erfcf( \( +\infty \) ) returns +0.
erfcf(NaN) returns NaN.
Calculate the inverse complementary error function \( \operatorname{erfc}^{-1} \) (
x
), of the input argumentx
in the interval [0, 2].Note
- Returns
erfcinvf( \( \pm 0 \) ) returns \( +\infty \).
erfcinvf(2) returns \( -\infty \).
erfcinvf(
x
) returns NaN forx
outside [0, 2].erfcinvf(NaN) returns NaN.
x
, \( e^{x^2}\cdot \operatorname{erfc}(x) \).Note
- Returns
erfcxf( \( -\infty \) ) returns \( +\infty \).
erfcxf( \( +\infty \) ) returns +0.
erfcxf(NaN) returns NaN.
Calculate the value of the error function for the input argument
x
, \( \frac{2}{\sqrt \pi} \int_0^x e^{-t^2} dt \).Note
- Returns
erff( \( \pm 0 \) ) returns \( \pm 0 \).
erff( \( \pm \infty \) ) returns \( \pm 1 \).
erff(NaN) returns NaN.
Calculate the inverse error function \( \operatorname{erf}^{-1} \) (
x
in the interval [-1, 1].Note
- Returns
erfinvf( \( \pm 0 \) ) returns \( \pm 0 \).
erfinvf(1) returns \( +\infty \).
erfinvf(-1) returns \( -\infty \).
erfinvf(
x
) returns NaN forx
outside [-1, +1].erfinvf(NaN) returns NaN.
Calculate \( 10^x \) , the base 10 exponential of the input argument
x
.Note
Note
use_fast_math
exp10f( \( \pm 0 \) ) returns 1.
exp10f( \( -\infty \) ) returns +0.
exp10f( \( +\infty \) ) returns \( +\infty \).
exp10f(NaN) returns NaN.
Calculate \( 2^x \) , the base 2 exponential of the input argument
x
.Note
- Returns
exp2f( \( \pm 0 \) ) returns 1.
exp2f( \( -\infty \) ) returns +0.
exp2f( \( +\infty \) ) returns \( +\infty \).
exp2f(NaN) returns NaN.
Calculate the base \( e \) exponential of the input argument.
Calculate \( e^x \) , the base \( e \) exponential of the input argument
x
.Note
Note
use_fast_math
expf( \( \pm 0 \) ) returns 1.
expf( \( -\infty \) ) returns +0.
expf( \( +\infty \) ) returns \( +\infty \).
expf(NaN) returns NaN.
Calculate the base \( e \) exponential of the input argument, minus 1.
Calculate \( e^x \) -1, the base \( e \) exponential of the input argument
x
, minus 1.Note
- Returns
expm1f( \( \pm 0 \) ) returns \( \pm 0 \).
expm1f( \( -\infty \) ) returns -1.
expm1f( \( +\infty \) ) returns \( +\infty \).
expm1f(NaN) returns NaN.
Calculate the absolute value of the input argument
x
.Note
- Returns
Returns the absolute value of its argument.
fabsf( \( \pm \infty \) ) returns \( +\infty \).
fabsf( \( \pm 0 \) ) returns +0.
fabsf(NaN) returns an unspecified NaN.
x
andy
.Compute the positive difference between
x
andy
. The positive difference isx
-y
whenx
>y
and +0 otherwise.Note
- Returns
Returns the positive difference between
x
andy
.fdimf(
x
,y
) returnsx
-y
ifx
>y
.fdimf(
x
,y
) returns +0 ifx
\( \leq \)y
.If either argument is NaN, NaN is returned.
Compute
x
divided byy
.Note
Note
use_fast_math
Returns
x
/y
.Follows the regular division operation behavior by default.
If
-use_fast_math
is specified and is not amended by an explicit-prec_div=true
, uses __fdividef() for higher performance
x
.Calculate the largest integer value which is less than or equal to
x
.Note
- Returns
Returns \( \lfloor x \rfloor \) expressed as a floating-point number.
floorf( \( \pm \infty \) ) returns \( \pm \infty \).
floorf( \( \pm 0 \) ) returns \( \pm 0 \).
floorf(NaN) returns NaN.
Compute \( x \times y + z \) as a single operation.
Compute the value of \( x \times y + z \) as a single ternary operation. After computing the value to infinite precision, the value is rounded once using round-to-nearest, ties-to-even rounding mode.
Note
- Returns
Returns the rounded value of \( x \times y + z \) as a single operation.
fmaf( \( \pm \infty \) , \( \pm 0 \) ,
z
) returns NaN.fmaf( \( \pm 0 \) , \( \pm \infty \) ,
z
) returns NaN.fmaf(
x
,y
, \( -\infty \) ) returns NaN if \( x \times y \) is an exact \( +\infty \).fmaf(
x
,y
, \( +\infty \) ) returns NaN if \( x \times y \) is an exact \( -\infty \).fmaf(
x
,y
, \( \pm 0 \)) returns \( \pm 0 \) if \( x \times y \) is exact \( \pm 0 \).fmaf(
x
,y
, \( \mp 0 \)) returns \( +0 \) if \( x \times y \) is exact \( \pm 0 \).fmaf(
x
,y
,z
) returns \( +0 \) if \( x \times y + z \) is exactly zero and \( z \neq 0 \).If either argument is NaN, NaN is returned.
Determines the maximum numeric value of the arguments
x
andy
. Treats NaN arguments as missing data. If one argument is a NaN and the other is legitimate numeric value, the numeric value is chosen.Note
- Returns
Returns the maximum numeric values of the arguments
x
andy
.If both arguments are NaN, returns NaN.
If one argument is NaN, returns the numeric argument.
Determines the minimum numeric value of the arguments
x
andy
- Returns
Returns the minimum numeric value of the arguments
x
andy
x
/y
.Calculate the floating-point remainder of
x
/y
. The floating-point remainder of the division operationx
/y
calculated by this function is exactly the valuex - n*y
, wheren
isx
/y
with its fractional part truncated. The computed value will have the same sign asx
, and its magnitude will be less than the magnitude ofy
.Note
- Returns
Returns the floating-point remainder of
x
/y
.fmodf( \( \pm 0 \) ,
y
) returns \( \pm 0 \) ify
is not zero.fmodf(
x
, \( \pm \infty \) ) returnsx
ifx
is finite.fmodf(
x
,y
) returns NaN ifx
is \( \pm\infty \) ory
is zero.If either argument is NaN, NaN is returned.
Decomposes the floating-point value
x
into a componentm
for the normalized fraction element and another termn
for the exponent. The absolute value ofm
will be greater than or equal to 0.5 and less than 1.0 or it will be equal to 0; \( x = m\cdot 2^n \). The integer exponentn
will be stored in the location to whichnptr
points.Note
- Returns
Returns the fractional component
m
.frexpf( \( \pm 0 \) ,
nptr
) returns \( \pm 0 \) and stores zero in the location pointed to bynptr
.frexpf( \( \pm \infty \) ,
nptr
) returns \( \pm \infty \) and stores an unspecified value in the location to whichnptr
points.frexpf(NaN,
y
) returns a NaN and stores an unspecified value in the location to whichnptr
points.
Calculates the length of the hypotenuse of a right triangle whose two sides have lengths
x
andy
without undue overflow or underflow.Note
- Returns
Returns the length of the hypotenuse \( \sqrt{x^2+y^2} \).
hypotf(
x
,y
), hypotf(y
,x
), and hypotf(x
,-y
) are equivalent.hypotf(
x
, \( \pm 0 \) ) is equivalent to fabsf(x
).hypotf( \( \pm \infty \) ,
y
) returns \( +\infty \) , even ify
is a NaN.hypotf(NaN,
y
) returns NaN, wheny
is not \( \pm\infty \).
Calculates the unbiased integer exponent of the input argument
x
.Note
- Returns
If successful, returns the unbiased exponent of the argument.
ilogbf( \( \pm 0 \) ) returns
INT_MIN
.ilogbf(NaN) returns
INT_MIN
.ilogbf( \( \pm \infty \) ) returns
INT_MAX
.Note: above behavior does not take into account
FP_ILOGB0
norFP_ILOGBNAN
Determine whether the floating-point value
a
is a finite value (zero, subnormal, or normal and not infinity or NaN).- Returns
With Visual Studio 2013 host compiler: __RETURN_TYPE is ‘bool’. Returns true if and only if
a
is a finite value.With other host compilers: __RETURN_TYPE is ‘int’. Returns a nonzero value if and only if
a
is a finite value.
a
is an infinite value (positive or negative).- Returns
a
is an infinite value.With other host compilers: __RETURN_TYPE is ‘int’. Returns a nonzero value if and only if
a
a
is a NaN.- Returns
a
is a NaN value.With other host compilers: __RETURN_TYPE is ‘int’. Returns a nonzero value if and only if
a
is a NaN value.
x
, \( J_0(x) \).Note
- Returns
Returns the value of the Bessel function of the first kind of order 0.
j0f( \( \pm \infty \) ) returns +0.
j0f(NaN) returns NaN.
x
, \( J_1(x) \).Note
- Returns
Returns the value of the Bessel function of the first kind of order 1.
j1f( \( \pm 0 \) ) returns \( \pm 0 \).
j1f( \( \pm \infty \) ) returns \( \pm 0 \).
j1f(NaN) returns NaN.
n
for the input argumentx
, \( J_n(x) \).Note
- Returns
n
.jnf(
n
, NaN) returns NaN.jnf(
n
,x
) returns NaN forn
< 0.jnf(
n
, \( +\infty \) ) returns +0.
Calculate the value of \( x\cdot 2^{exp} \).
Calculate the value of \( x\cdot 2^{exp} \) of the input arguments
x
andexp
.Note
- Returns
ldexpf(
x
,exp
) is equivalent to scalbnf(x
,exp
x
, namely the value of \( \log_{e}\left|\Gamma(x)\right| \)Note
- Returns
lgammaf(1) returns +0.
lgammaf(2) returns +0.
lgammaf(
x
) returns \( +\infty \) ifx
\( \leq \) 0 andx
is an integer.lgammaf( \( -\infty \) ) returns \( +\infty \).
lgammaf( \( +\infty \) ) returns \( +\infty \).
lgammaf(NaN) returns NaN.
Round
x
to the nearest integer value, with halfway cases rounded to the nearest even integer value. If the result is outside the range of the return type, the behavior is undefined.- Returns
Returns rounded integer value.
Round
x
to the nearest integer value, with halfway cases rounded away from zero. If the result is outside the range of the return type, the behavior is undefined.Note
This function may be slower than alternate rounding methods. See llrintf().
- Returns
x
.Note
Note
use_fast_math
log10f( \( \pm 0 \) ) returns \( -\infty \).
log10f(1) returns +0.
log10f(
x
) returns NaN forx
< 0.log10f( \( +\infty \) ) returns \( +\infty \).
log10f(NaN) returns NaN.
Calculate the value of \( \log_{e}(1+x) \).
Calculate the value of \( \log_{e}(1+x) \) of the input argument
x
.Note
- Returns
log1pf( \( \pm 0 \) ) returns \( \pm 0 \).
log1pf(-1) returns \( -\infty \).
log1pf(
x
) returns NaN forx
< -1.log1pf( \( +\infty \) ) returns \( +\infty \).
log1pf(NaN) returns NaN.
x
.Note
Note
use_fast_math
log2f( \( \pm 0 \) ) returns \( -\infty \).
log2f(1) returns +0.
log2f(
x
) returns NaN forx
< 0.log2f( \( +\infty \) ) returns \( +\infty \).
log2f(NaN) returns NaN.
x
.Note
- Returns
logbf( \( \pm 0 \) ) returns \( -\infty \).
logbf( \( \pm \infty \) ) returns \( +\infty \).
logbf(NaN) returns NaN.
x
.Note
Note
use_fast_math
logf( \( \pm 0 \) ) returns \( -\infty \).
logf(1) returns +0.
logf(
x
) returns NaN forx
< 0.logf( \( +\infty \) ) returns \( +\infty \).
logf(NaN) returns NaN.
Round
x
Round
x
This function may be slower than alternate rounding methods. See lrintf().
- Returns
float
arguments.Calculate the maximum value of the arguments
a
andb
. Behavior is equivalent to fmaxf() function.Note, this is different from
std:
: specification
float
arguments.Calculate the minimum value of the arguments
a
andb
. Behavior is equivalent to fminf() function.Note, this is different from
std:
: specification
Break down the argument
x
into fractional and integral parts. The integral part is stored in the argumentiptr
. Fractional and integral parts are given the same sign as the argumentx
.Note
- Returns
modff( \( \pm x \) ,
iptr
) returns a result with the same sign asx
.modff( \( \pm \infty \) ,
iptr
) returns \( \pm 0 \) and stores \( \pm \infty \) in the object pointed to byiptr
.modff(NaN,
iptr
) stores a NaN in the object pointed to byiptr
and returns a NaN.
Returns “Not a Number” value.
Return a representation of a quiet NaN. Argument
tagp
selects one of the possible representations.Note
- Returns
nanf(
tagp
) returns NaN.
Round argument
x
to an integer value in single precision floating-point format. Uses round to nearest rounding, with ties rounding to even.Note
- Returns
nearbyintf( \( \pm 0 \) ) returns \( \pm 0 \).
nearbyintf( \( \pm \infty \) ) returns \( \pm \infty \).
nearbyintf(NaN) returns NaN.
x
.Calculate the next representable single-precision floating-point value following
x
. For example, ify
is greater thanx
, nextafterf() returns the smallest representable number greater thanx
Note
- Returns
nextafterf(
x
,y
) =y
ifx
equalsy
.nextafterf(
x
,y
) =NaN
if eitherx
ory
areNaN
Calculates the length of three dimensional vector in Euclidean space without undue overflow or underflow.
Note
- Returns
Returns the length of the 3D vector \( \sqrt{a^2+b^2+c^2} \).
In the presence of an exactly infinite coordinate \( +\infty \) is returned, even if there are NaNs.
returns +0, when all coordinates are \( \pm 0 \).
returns NaN, when at least one of the coordinates is NaN and none are infinite.
Calculates the length of four dimensional vector in Euclidean space without undue overflow or underflow.
Note
- Returns
Returns the length of the 4D vector \( \sqrt{a^2+b^2+c^2+d^2} \).
Calculate the cumulative distribution function of the standard normal distribution for input argument
x
, \( \Phi(x) \).Note
- Returns
normcdff( \( +\infty \) ) returns 1.
normcdff( \( -\infty \) ) returns +0
normcdff(NaN) returns NaN.
Calculate the inverse of the standard normal cumulative distribution function for input argument
x
, \( \Phi^{-1}(x) \). The function is defined for input values in the interval \( (0, 1) \).Note
- Returns
normcdfinvf( \( \pm 0 \) ) returns \( -\infty \).
normcdfinvf(1) returns \( +\infty \).
normcdfinvf(
x
) returns NaN ifx
is not in the interval [0,1].normcdfinvf(NaN) returns NaN.
Calculates the length of a vector
p
, dimension of which is passed as an argument without undue overflow or underflow.Note
- Returns
Returns the length of the dim-D vector \( \sqrt{\sum_{i=0}^{dim-1} p_i^2} \).
x
to the power ofy
.Note
Note
use_fast_math
powf( \( \pm 0 \) ,
y
) returns \( \pm \infty \) fory
an odd integer less than 0.powf( \( \pm 0 \) ,
y
) returns \( +\infty \) fory
less than 0 and not an odd integer.powf( \( \pm 0 \) ,
y
) returns \( \pm 0 \) fory
an odd integer greater than 0.powf( \( \pm 0 \) ,
y
) returns +0 fory
> 0 and not an odd integer.powf(-1, \( \pm \infty \) ) returns 1.
powf(+1,
y
) returns 1 for anyy
, even a NaN.powf(
x
, \( \pm 0 \) ) returns 1 for anyx
, even a NaN.powf(
x
,y
) returns a NaN for finitex
< 0 and finite non-integery
.powf(
x
, \( -\infty \) ) returns \( +\infty \) for \( | x | < 1 \).powf(
x
, \( -\infty \) ) returns +0 for \( | x | > 1 \).powf(
x
, \( +\infty \) ) returns +0 for \( | x | < 1 \).powf(
x
, \( +\infty \) ) returns \( +\infty \) for \( | x | > 1 \).powf( \( -\infty \) ,
y
) returns -0 fory
an odd integer less than 0.powf( \( -\infty \) ,
y
) returns +0 fory
< 0 and not an odd integer.powf( \( -\infty \) ,
y
) returns \( -\infty \) fory
an odd integer greater than 0.powf( \( -\infty \) ,
y
> 0 and not an odd integer.powf( \( +\infty \) ,
y
) returns +0 fory
< 0.powf( \( +\infty \) ,
y
> 0.powf(
x
,y
) returns NaN if eitherx
ory
or both are NaN andx
\( \neq \) +1 andy
\( \neq\pm 0 \).
Calculate reciprocal cube root function of
x
.Note
- Returns
rcbrtf( \( \pm 0 \) ) returns \( \pm \infty \).
rcbrtf( \( \pm \infty \) ) returns \( \pm 0 \).
rcbrtf(NaN) returns NaN.
r
of dividingx
byy
for nonzeroy
. Thus \( r = x - n y \). The valuen
is the integer value nearest \( \frac{x}{y} \). In the case when \( | n -\frac{x}{y} | = \frac{1}{2} \) , the evenn
- Returns
remainderf(
x
, \( \pm 0 \) ) returns NaN.remainderf( \( \pm \infty \) ,
y
x
for finitex
Compute a single-precision floating-point remainder in the same way as the remainderf() function. Argument
quo
returns part of quotient upon division ofx
byy
. Valuequo
has the same sign as \( \frac{x}{y} \) and may not be the exact quotient but agrees with the exact quotient in the low order 3 bits.Note
- Returns
Returns the remainder.
remquof(
x
, \( \pm 0 \) ,quo
) returns NaN and stores an unspecified value in the location to whichquo
points.remquof( \( \pm \infty \) ,
y
,quo
points.remquof(
x
,y
,quo
points if either ofx
ory
is NaN.remquof(
x
, \( \pm \infty \) ,quo
) returnsx
and stores zero in the location to whichquo
points for finitex
Calculates one over the length of the hypotenuse of a right triangle whose two sides have lengths
x
andy
- Returns
Returns one over the length of the hypotenuse \( \frac{1}{\sqrt{x^2+y^2}} \).
rhypotf(
x
,y
), rhypotf(y
,x
), and rhypotf(x
,-y
) are equivalent.rhypotf( \( \pm \infty \) ,
y
) returns +0, even ify
is a NaN.rhypotf( \( \pm 0, \pm 0 \)) returns \( +\infty \).
rhypotf(NaN,
y
Round
x
to the nearest integer value in floating-point format, with halfway cases rounded to the nearest even integer value.- Returns
rintf( \( \pm 0 \) ) returns \( \pm 0 \).
rintf( \( \pm \infty \) ) returns \( \pm \infty \).
rintf(NaN) returns NaN.
Calculates one over the length of three dimension vector in Euclidean space without undue overflow or underflow.
Note
- Returns
Returns one over the length of the 3D vector \( \frac{1}{\sqrt{a^2+b^2+c^2}} \).
In the presence of an exactly infinite coordinate \( +0 \) is returned, even if there are NaNs.
returns \( +\infty \), when all coordinates are \( \pm 0 \).
Calculates one over the length of four dimension vector in Euclidean space without undue overflow or underflow.
Note
- Returns
Returns one over the length of the 3D vector \( \frac{1}{\sqrt{a^2+b^2+c^2+d^2}} \).
Calculates one over the length of vector
p
, dimension of which is passed as an argument, in Euclidean space without undue overflow or underflow.Note
- Returns
Returns one over the length of the vector \( \frac{1}{\sqrt{\sum_{i=0}^{dim-1} p_i^2}} \).
Round
x
to the nearest integer value in floating-point format, with halfway cases rounded away from zero.Note
This function may be slower than alternate rounding methods. See rintf().
- Returns
roundf( \( \pm 0 \) ) returns \( \pm 0 \).
roundf( \( \pm \infty \) ) returns \( \pm \infty \).
roundf(NaN) returns NaN.
Calculate the reciprocal of the nonnegative square root of
x
, \( 1/\sqrt{x} \).Note
- Returns
Returns \( 1/\sqrt{x} \).
rsqrtf( \( +\infty \) ) returns +0.
rsqrtf( \( \pm 0 \) ) returns \( \pm \infty \).
rsqrtf(
x
) returns NaN ifx
is less than 0.rsqrtf(NaN) returns NaN.
Scale
x
by \( 2^n \) by efficient manipulation of the floating-point exponent.- Returns
Returns
x
* \( 2^n \).scalblnf( \( \pm 0 \) ,
n
) returns \( \pm 0 \).scalblnf(
x
, 0) returnsx
.scalblnf( \( \pm \infty \) ,
n
) returns \( \pm \infty \).scalblnf(NaN,
n
) returns NaN.
Scale
x
Returns
x
* \( 2^n \).scalbnf( \( \pm 0 \) ,
n
) returns \( \pm 0 \).scalbnf(
x
, 0) returnsx
.scalbnf( \( \pm \infty \) ,
n
) returns \( \pm \infty \).scalbnf(NaN,
n
) returns NaN.
a
is negative.- Returns
Reports the sign bit of all values including infinities, zeros, and NaNs.
a
is negative.With other host compilers: __RETURN_TYPE is ‘int’. Returns a nonzero value if and only if
a
is negative.
x
(measured in radians). The results for sine and cosine are written into the second argument,sptr
, and, respectively, third argument,cptr
.Note
Note
use_fast_math
Calculate the sine and cosine of the first input argument \( \times \pi \).
Calculate the sine and cosine of the first input argument,
x
(measured in radians), \( \times \pi \). The results for sine and cosine are written into the second argument,sptr
.Note
x
Note
use_fast_math
sinf( \( \pm \infty \) ) returns NaN.
x
.Note
- Returns
Calculate the sine of the input argument \( \times \pi \).
x
- Returns
sinpif( \( \pm 0 \) ) returns \( \pm 0 \).
sinpif( \( \pm \infty \) ) returns NaN.
sinpif(NaN) returns NaN.
Calculate the nonnegative square root of
x
, \( \sqrt{x} \).Note
- Returns
Returns \( \sqrt{x} \).
sqrtf( \( \pm 0 \) ) returns \( \pm 0 \).
sqrtf( \( +\infty \) ) returns \( +\infty \).
sqrtf(
x
) returns NaN ifx
is less than 0.sqrtf(NaN) returns NaN.
x
Note
use_fast_math
tanf( \( \pm \infty \) ) returns NaN.
x
.Note
- Returns
tanhf( \( \pm \infty \) ) returns \( \pm 1 \).
x
, namely the value of \( \Gamma(x) \).Note
- Returns
tgammaf( \( \pm 0 \) ) returns \( \pm \infty \).
tgammaf(
x
) returns NaN ifx
< 0 andx
is an integer.tgammaf( \( -\infty \) ) returns NaN.
tgammaf( \( +\infty \) ) returns \( +\infty \).
tgammaf(NaN) returns NaN.
Round
x
to the nearest integer value that does not exceedx
in magnitude.Note
- Returns
Returns truncated integer value.
truncf( \( \pm 0 \) ) returns \( \pm 0 \).
truncf( \( \pm \infty \) ) returns \( \pm \infty \).
truncf(NaN) returns NaN.
x
, \( Y_0(x) \).Note
- Returns
Returns the value of the Bessel function of the second kind of order 0.
y0f( \( \pm 0 \) ) returns \( -\infty \).
y0f(
x
) returns NaN forx
< 0.y0f( \( +\infty \) ) returns +0.
y0f(NaN) returns NaN.
x
, \( Y_1(x) \).Note
- Returns
Returns the value of the Bessel function of the second kind of order 1.
y1f( \( \pm 0 \) ) returns \( -\infty \).
y1f(
x
) returns NaN forx
< 0.y1f( \( +\infty \) ) returns +0.
y1f(NaN) returns NaN.
n
, \( Y_n(x) \).Note
- Returns
n
.ynf(
n
,x
) returns NaN forn
< 0.ynf(
n
, \( \pm 0 \) ) returns \( -\infty \).ynf(
n
,x
) returns NaN forx
< 0.ynf(
n
, \( +\infty \) ) returns +0.ynf(
n
, NaN) returns NaN.
