9. Double Precision Intrinsics
This section describes double precision intrinsic functions that are only supported in device code.
To use these functions, you do not need to include any additional header file in your program.
Functions
__device__ double __dadd_rd(double x, double y)
Add two floating-point values in round-down mode.
__device__ double __dadd_rn(double x, double y)
Add two floating-point values in round-to-nearest-even mode.
__device__ double __dadd_ru(double x, double y)
Add two floating-point values in round-up mode.
__device__ double __dadd_rz(double x, double y)
Add two floating-point values in round-towards-zero mode.
__device__ double __ddiv_rd(double x, double y)
Divide two floating-point values in round-down mode.
__device__ double __ddiv_rn(double x, double y)
Divide two floating-point values in round-to-nearest-even mode.
__device__ double __ddiv_ru(double x, double y)
Divide two floating-point values in round-up mode.
__device__ double __ddiv_rz(double x, double y)
Divide two floating-point values in round-towards-zero mode.
__device__ double __dmul_rd(double x, double y)
Multiply two floating-point values in round-down mode.
__device__ double __dmul_rn(double x, double y)
Multiply two floating-point values in round-to-nearest-even mode.
__device__ double __dmul_ru(double x, double y)
Multiply two floating-point values in round-up mode.
__device__ double __dmul_rz(double x, double y)
Multiply two floating-point values in round-towards-zero mode.
__device__ double __drcp_rd(double x)
Compute 1x in round-down mode.
__device__ double __drcp_rn(double x)
Compute 1x in round-to-nearest-even mode.
__device__ double __drcp_ru(double x)
Compute 1x in round-up mode.
__device__ double __drcp_rz(double x)
Compute 1x in round-towards-zero mode.
__device__ double __dsqrt_rd(double x)
Compute x in round-down mode.
__device__ double __dsqrt_rn(double x)
Compute x in round-to-nearest-even mode.
__device__ double __dsqrt_ru(double x)
Compute x in round-up mode.
__device__ double __dsqrt_rz(double x)
Compute x in round-towards-zero mode.
__device__ double __dsub_rd(double x, double y)
Subtract two floating-point values in round-down mode.
__device__ double __dsub_rn(double x, double y)
Subtract two floating-point values in round-to-nearest-even mode.
__device__ double __dsub_ru(double x, double y)
Subtract two floating-point values in round-up mode.
__device__ double __dsub_rz(double x, double y)
Subtract two floating-point values in round-towards-zero mode.
__device__ double __fma_rd(double x, double y, double z)
Compute x×y+z as a single operation in round-down mode.
__device__ double __fma_rn(double x, double y, double z)
Compute x×y+z as a single operation in round-to-nearest-even mode.
__device__ double __fma_ru(double x, double y, double z)
Compute x×y+z as a single operation in round-up mode.
__device__ double __fma_rz(double x, double y, double z)
Compute x×y+z as a single operation in round-towards-zero mode.
9.1. Functions
Adds two floating-point values x and y in round-down (to negative infinity) mode.
Note
For accuracy information, see the CUDA C++ Programming Guide, Mathematical Functions Appendix, Intrinsic Functions section.
Note
This operation will never be merged into a single multiply-add instruction.
Returns
Returns x + y.
  • __dadd_rd(x, y) is equivalent to __dadd_rd(y, x).
  • __dadd_rd(x, ±) returns ± for finite x.
  • __dadd_rd( ±, ±) returns ±.
  • __dadd_rd( ±, ) returns NaN.
  • __dadd_rd( ±0, ±0) returns ±0.
  • __dadd_rd(x, -x) returns 0 for finite x, including ±0.
  • If either argument is NaN, NaN is returned.
Adds two floating-point values x and y in round-to-nearest-even mode.
Note
Note
Returns
Returns x + y.
  • __dadd_rn(x, y) is equivalent to __dadd_rn(y, x).
  • __dadd_rn(x, ±) returns ± for finite x.
  • __dadd_rn( ±, ±) returns ±.
  • __dadd_rn( ±, ) returns NaN.
  • __dadd_rn( ±0, ±0) returns ±0.
  • __dadd_rn(x, -x) returns +0 for finite x, including ±0.
Adds two floating-point values x and y in round-up (to positive infinity) mode.
Note
Note
Returns
Returns x + y.
  • __dadd_ru(x, y) is equivalent to __dadd_ru(y, x).
  • __dadd_ru(x, ±) returns ± for finite x.
  • __dadd_ru( ±, ±) returns ±.
  • __dadd_ru( ±, ) returns NaN.
  • __dadd_ru( ±0, ±0) returns ±0.
  • __dadd_ru(x, -x) returns +0 for finite x, including ±0.
Adds two floating-point values x and y in round-towards-zero mode.
Note
Note
Returns
Returns x + y.
  • __dadd_rz(x, y) is equivalent to __dadd_rz(y, x).
  • __dadd_rz(x, ±) returns ± for finite x.
  • __dadd_rz( ±, ±) returns ±.
  • __dadd_rz( ±, ) returns NaN.
  • __dadd_rz( ±0, ±0) returns ±0.
  • __dadd_rz(x, -x) returns +0 for finite x, including ±0.
Divides two floating-point values x by y in round-down (to negative infinity) mode.
Note
Note
Requires compute capability >= 2.0.
Returns
Returns x / y.
  • sign of the quotient x / y is XOR of the signs of x and y when neither inputs nor result are NaN.
  • __ddiv_rd( ±0, ±0) returns NaN.
  • __ddiv_rd( ±, ±) returns NaN.
  • __ddiv_rd(x, ±) returns 0 of appropriate sign for finite x.
  • __ddiv_rd( ±, y) returns of appropriate sign for finite y.
  • __ddiv_rd(x, ±0) returns of appropriate sign for x 0.
  • __ddiv_rd( ±0, y) returns 0 of appropriate sign for y 0.
Divides two floating-point values x by y in round-to-nearest-even mode.
Note
Note
Returns
Returns x / y.
  • __ddiv_rn( ±0, ±0) returns NaN.
  • __ddiv_rn( ±, ±) returns NaN.
  • __ddiv_rn(x, ±) returns 0 of appropriate sign for finite x.
  • __ddiv_rn( ±, y) returns of appropriate sign for finite y.
  • __ddiv_rn(x, ±0) returns of appropriate sign for x 0.
  • __ddiv_rn( ±0, y) returns 0 of appropriate sign for y 0.
Divides two floating-point values x by y in round-up (to positive infinity) mode.
Note
Note
Returns
Returns x / y.
  • __ddiv_ru( ±0, ±0) returns NaN.
  • __ddiv_ru( ±, ±) returns NaN.
  • __ddiv_ru(x, ±) returns 0 of appropriate sign for finite x.
  • __ddiv_ru( ±, y) returns of appropriate sign for finite y.
  • __ddiv_ru(x, ±0) returns of appropriate sign for x 0.
  • __ddiv_ru( ±0, y) returns 0 of appropriate sign for y 0.
Divides two floating-point values x by y in round-towards-zero mode.
Note
Note
Returns
Returns x / y.
  • __ddiv_rz( ±0, ±0) returns NaN.
  • __ddiv_rz( ±, ±) returns NaN.
  • __ddiv_rz(x, ±) returns 0 of appropriate sign for finite x.
  • __ddiv_rz( ±, y) returns of appropriate sign for finite y.
  • __ddiv_rz(x, ±0) returns of appropriate sign for x 0.
  • __ddiv_rz( ±0, y) returns 0 of appropriate sign for y 0.
Multiplies two floating-point values x and y in round-down (to negative infinity) mode.
Note
Note
Returns
Returns x * y.
  • sign of the product x * y is XOR of the signs of x and y when neither inputs nor result are NaN.
  • __dmul_rd(x, y) is equivalent to __dmul_rd(y, x).
  • __dmul_rd(x, ±) returns of appropriate sign for x 0.
  • __dmul_rd( ±0, ±) returns NaN.
  • __dmul_rd( ±0, y) returns 0 of appropriate sign for finite y.
Multiplies two floating-point values x and y in round-to-nearest-even mode.
Note
Note
Returns
Returns x * y.
  • __dmul_rn(x, y) is equivalent to __dmul_rn(y, x).
  • __dmul_rn(x, ±) returns of appropriate sign for x 0.
  • __dmul_rn( ±0, ±) returns NaN.
  • __dmul_rn( ±0, y) returns 0 of appropriate sign for finite y.
Multiplies two floating-point values x and y in round-up (to positive infinity) mode.
Note
Note
Returns
Returns x * y.
  • __dmul_ru(x, y) is equivalent to __dmul_ru(y, x).
  • __dmul_ru(x, ±) returns of appropriate sign for x 0.
  • __dmul_ru( ±0, ±) returns NaN.
  • __dmul_ru( ±0, y) returns 0 of appropriate sign for finite y.
Multiplies two floating-point values x and y in round-towards-zero mode.
Note
Note
Returns
Returns x * y.
  • __dmul_rz(x, y) is equivalent to __dmul_rz(y, x).
  • __dmul_rz(x, ±) returns of appropriate sign for x 0.
  • __dmul_rz( ±0, ±) returns NaN.
  • __dmul_rz( ±0, y) returns 0 of appropriate sign for finite y.
Compute the reciprocal of x in round-down (to negative infinity) mode.
Note
Note
Returns
Returns 1x.
Compute the reciprocal of x in round-to-nearest-even mode.
Note
Note
Returns
Returns 1x.
Compute the reciprocal of x in round-up (to positive infinity) mode.
Note
Note
Returns
Returns 1x.
Compute the reciprocal of x in round-towards-zero mode.
Note
Note
Returns
Returns 1x.
Compute the square root of x in round-down (to negative infinity) mode.
Note
Note
Returns
Returns x.
Compute the square root of x in round-to-nearest-even mode.
Note
Note
Returns
Returns x.
Compute the square root of x in round-up (to positive infinity) mode.
Note
Note
Returns
Returns x.
Compute the square root of x in round-towards-zero mode.
Note
Note
Returns
Returns x.
Subtracts two floating-point values x and y in round-down (to negative infinity) mode.
Note
Note
Returns
Returns x - y.
  • __dsub_rd( ±, y) returns ± for finite y.
  • __dsub_rd(x, ±) returns for finite x.
  • __dsub_rd( ±, ±) returns NaN.
  • __dsub_rd( ±, ) returns ±.
  • __dsub_rd( ±0, 0) returns ±0.
  • __dsub_rd(x, x) returns 0 for finite x, including ±0.
Subtracts two floating-point values x and y in round-to-nearest-even mode.
Note
Note
Returns
Returns x - y.
  • __dsub_rn( ±, y) returns ± for finite y.
  • __dsub_rn(x, ±) returns for finite x.
  • __dsub_rn( ±, ±) returns NaN.
  • __dsub_rn( ±, ) returns ±.
  • __dsub_rn( ±0, 0) returns ±0.
  • __dsub_rn(x, x) returns +0 for finite x, including ±0.
Subtracts two floating-point values x and y in round-up (to positive infinity) mode.
Note
Note
Returns
Returns x - y.
  • __dsub_ru( ±, y) returns ± for finite y.
  • __dsub_ru(x, ±) returns for finite x.
  • __dsub_ru( ±, ±) returns NaN.
  • __dsub_ru( ±, ) returns ±.
  • __dsub_ru( ±0, 0) returns ±0.
  • __dsub_ru(x, x) returns +0 for finite x, including ±0.
Subtracts two floating-point values x and y in round-towards-zero mode.
Note
Note
Returns
Returns x - y.
  • __dsub_rz( ±, y) returns ± for finite y.
  • __dsub_rz(x, ±) returns for finite x.
  • __dsub_rz( ±, ±) returns NaN.
  • __dsub_rz( ±, ) returns ±.
  • __dsub_rz( ±0, 0) returns ±0.
  • __dsub_rz(x, x) returns +0 for finite x, including ±0.
Computes the value of x×y+z as a single ternary operation, rounding the result once in round-down (to negative infinity) mode.
Note
Returns
Returns the rounded value of x×y+z as a single operation.
  • __fma_rd( ± , ±0 , z) returns NaN.
  • __fma_rd( ±0 , ± , z) returns NaN.
  • __fma_rd(x, y, ) returns NaN if x×y is an exact +.
  • __fma_rd(x, y, + ) returns NaN if x×y is an exact .
  • __fma_rd(x, y, ±0) returns ±0 if x×y is exact ±0.
  • __fma_rd(x, y, 0) returns 0 if x×y is exact ±0.
  • __fma_rd(x, y, z) returns 0 if x×y+z is exactly zero and z0.
Computes the value of x×y+z as a single ternary operation, rounding the result once in round-to-nearest-even mode.
Note
Returns
  • __fma_rn( ± , ±0 , z) returns NaN.
  • __fma_rn( ±0 , ± , z) returns NaN.
  • __fma_rn(x, y, ) returns NaN if x×y is an exact +.
  • __fma_rn(x, y, + ) returns NaN if x×y is an exact .
  • __fma_rn(x, y, ±0) returns ±0 if x×y is exact ±0.
  • __fma_rn(x, y, 0) returns +0 if x×y is exact ±0.
  • __fma_rn(x, y, z) returns +0 if x×y+z is exactly zero and z0.
Computes the value of x×y+z as a single ternary operation, rounding the result once in round-up (to positive infinity) mode.
Note
Returns
  • __fma_ru( ± , ±0 , z) returns NaN.
  • __fma_ru( ±0 , ± , z) returns NaN.
  • __fma_ru(x, y, ) returns NaN if x×y is an exact +.
  • __fma_ru(x, y, + ) returns NaN if x×y is an exact .
  • __fma_ru(x, y, ±0) returns ±0 if x×y is exact ±0.
  • __fma_ru(x, y, 0) returns +0 if x×y is exact ±0.
  • __fma_ru(x, y, z) returns +0 if x×y+z is exactly zero and z0.
Computes the value of x×y+z as a single ternary operation, rounding the result once in round-towards-zero mode.
Note
Returns
  • __fma_rz( ± , ±0 , z) returns NaN.
  • __fma_rz( ±0 , ± , z) returns NaN.
  • __fma_rz(x, y, ) returns NaN if x×y is an exact +.
  • __fma_rz(x, y, + ) returns NaN if x×y is an exact .
  • __fma_rz(x, y, ±0) returns ±0 if x×y is exact ±0.
  • __fma_rz(x, y, 0) returns +0 if x×y is exact ±0.
  • __fma_rz(x, y, z) returns +0 if x×y+z is exactly zero and z0.
