10. FP128 Quad Precision Mathematical Functions
This section describes quad precision mathematical functions.
To use these functions, include the header file device_fp128_functions.h
in your program.
Functions declared here have __nv_fp128_
prefix to distinguish them from other global namespace symbols.
Note that FP128 CUDA Math functions are only available to device programs on platforms where host compiler supports the basic quad precision datatype __float128
or _Float128
Every FP128 CUDA Math function name is overloaded to support either of these host-compiler-specific types, whenever the types are available. See for example:
#ifdef __FLOAT128_CPP_SPELLING_ENABLED__
__float128 __nv_fp128_sqrt(__float128 x);
#endif
#ifdef __FLOAT128_C_SPELLING_ENABLED__
_Float128 __nv_fp128_sqrt(_Float128 x);
#endif
Note
FP128 device computations require compute capability >= 10.0.
Functions
- __device__ __float128 __nv_fp128_acos(__float128 x)
Calculate \(\cos^{-1}{x}\) , the arc cosine of input argument.
- __device__ __float128 __nv_fp128_acosh(__float128 x)
Calculate \(\cosh^{-1}{x}\) , the nonnegative inverse hyperbolic cosine of the input argument.
- __device__ __float128 __nv_fp128_add(__float128 x, __float128 y)
Compute \(x + y\) , the sum of the two floating-point inputs using round-to-nearest-even rounding mode.
- __device__ __float128 __nv_fp128_asin(__float128 x)
Calculate \(\sin^{-1}{x}\) , the arc sine of input argument.
- __device__ __float128 __nv_fp128_asinh(__float128 x)
Calculate \(\sinh^{-1}{x}\) , the inverse hyperbolic sine of the input argument.
- __device__ __float128 __nv_fp128_atan(__float128 x)
Calculate \(\tan^{-1}{x}\) , the arc tangent of input argument.
- __device__ __float128 __nv_fp128_atanh(__float128 x)
Calculate \(\tanh^{-1}{x}\) , the inverse hyperbolic tangent of the input argument.
- __device__ __float128 __nv_fp128_ceil(__float128 x)
Calculate \(\lceil x \rceil\) , the smallest integer greater than or equal to
x
.- __device__ __float128 __nv_fp128_copysign(__float128 x, __float128 y)
Create value with the magnitude of the first agument
x
, and the sign of the second argumenty
.- __device__ __float128 __nv_fp128_cos(__float128 x)
Calculate \(\cos{x}\) , the cosine of input argument (measured in radians).
- __device__ __float128 __nv_fp128_cosh(__float128 x)
Calculate \(\cosh{x}\) , the hyperbolic cosine of the input argument.
- __device__ __float128 __nv_fp128_div(__float128 x, __float128 y)
Compute \(\frac{x}{y}\) , the quotient of the two floating-point inputs using round-to-nearest-even rounding mode.
- __device__ __float128 __nv_fp128_exp(__float128 x)
Calculate \(e^x\) , the base \(e\) exponential of the input argument.
- __device__ __float128 __nv_fp128_exp10(__float128 x)
Calculate \(10^x\) , the base 10 exponential of the input argument.
- __device__ __float128 __nv_fp128_exp2(__float128 x)
Calculate \(2^x\) , the base 2 exponential of the input argument.
- __device__ __float128 __nv_fp128_expm1(__float128 x)
Calculate \(e^x - 1\) , the base e exponential of the input argument, minus 1.
- __device__ __float128 __nv_fp128_fabs(__float128 x)
Calculate \(|x|\) , the absolute value of the input argument.
- __device__ __float128 __nv_fp128_fdim(__float128 x, __float128 y)
Compute the positive difference between
x
andy
.- __device__ __float128 __nv_fp128_floor(__float128 x)
Calculate \(\lfloor x \rfloor\) , the largest integer less than or equal to
x
.- __device__ __float128 __nv_fp128_fma(__float128 x, __float128 y, __float128 c)
Compute \(x \times y + z\) as a single operation using round-to-nearest-even rounding mode.
- __device__ __float128 __nv_fp128_fmax(__float128 x, __float128 y)
Determine the maximum numeric value of the arguments.
- __device__ __float128 __nv_fp128_fmin(__float128 x, __float128 y)
Determine the minimum numeric value of the arguments.
- __device__ __float128 __nv_fp128_fmod(__float128 x, __float128 y)
Calculate the floating-point remainder of
x
/y
.- __device__ __float128 __nv_fp128_frexp(__float128 x, int *nptr)
Extract mantissa and exponent of the floating-point input argument.
- __device__ __float128 __nv_fp128_hypot(__float128 x, __float128 y)
Calculate \(\sqrt{x^2+y^2}\) , the square root of the sum of squares of two arguments.
- __device__ int __nv_fp128_ilogb(__float128 x)
Compute the unbiased integer exponent of the input argument.
- __device__ int __nv_fp128_isnan(__float128 x)
Determine whether the input argument is a NaN.
- __device__ int __nv_fp128_isunordered(__float128 x, __float128 y)
Determine whether the pair of inputs is unordered.
- __device__ __float128 __nv_fp128_ldexp(__float128 x, int exp)
Calculate the value of \(x\cdot 2^{exp}\) .
- __device__ __float128 __nv_fp128_log(__float128 x)
Calculate \(\log_{e}{x}\) , the base \(e\) logarithm of the input argument.
- __device__ __float128 __nv_fp128_log10(__float128 x)
Calculate \(\log_{10}{x}\) , the base 10 logarithm of the input argument.
- __device__ __float128 __nv_fp128_log1p(__float128 x)
Calculate the value of \(\log_{e}(1+x)\) .
- __device__ __float128 __nv_fp128_log2(__float128 x)
Calculate \(\log_{2}{x}\) , the base 2 logarithm of the input argument.
- __device__ __float128 __nv_fp128_modf(__float128 x, __float128 *iptr)
Break down the input argument into fractional and integral parts.
- __device__ __float128 __nv_fp128_mul(__float128 x, __float128 y)
Compute \(x \cdot y\) , the product of the two floating-point inputs using round-to-nearest-even rounding mode.
- __device__ __float128 __nv_fp128_pow(__float128 x, __float128 y)
Calculate the value of \(x^{y}\) , first argument to the power of second argument.
- __device__ __float128 __nv_fp128_remainder(__float128 x, __float128 y)
Compute the floating-point remainder function.
- __device__ __float128 __nv_fp128_rint(__float128 x)
Round to nearest integer value in floating-point format, with halfway cases rounded to the nearest even integer value.
- __device__ __float128 __nv_fp128_round(__float128 x)
Round to nearest integer value in floating-point format, with halfway cases rounded away from zero.
- __device__ __float128 __nv_fp128_sin(__float128 x)
Calculate \(\sin{x}\) , the sine of input argument (measured in radians).
- __device__ __float128 __nv_fp128_sinh(__float128 x)
Calculate \(\sinh{x}\) , the hyperbolic sine of the input argument.
- __device__ __float128 __nv_fp128_sqrt(__float128 x)
Calculate \(\sqrt{x}\) , the square root of the input argument.
- __device__ __float128 __nv_fp128_sub(__float128 x, __float128 y)
Compute \(x - y\) , the difference of the two floating-point inputs using round-to-nearest-even rounding mode.
- __device__ __float128 __nv_fp128_tan(__float128 x)
Calculate \(\tan{x}\) , the tangent of input argument (measured in radians).
- __device__ __float128 __nv_fp128_tanh(__float128 x)
Calculate \(\tanh{x}\) , the hyperbolic tangent of the input argument.
- __device__ __float128 __nv_fp128_trunc(__float128 x)
Truncate input argument to the integral part.
10.1. Functions
Calculate \( \cos^{-1}{x} \), the arc cosine of input argument.
Note
For accuracy information, see the CUDA C++ Programming Guide, Mathematical Functions Appendix, Quad-Precision Floating-Point Functions section.
Note
- Returns
The principal value of the arc cosine of the input argument
x
. Result will be in radians, in the interval [0, \( \pi \) ] forx
inside [-1, +1].__nv_fp128_acos(1) returns +0.
__nv_fp128_acos(
x
) returns NaN forx
outside [-1, +1].__nv_fp128_acos(NaN) returns NaN.
Calculate \( \cosh^{-1}{x} \), the nonnegative inverse hyperbolic cosine of the input argument.
Note
Note
- Returns
Result will be in the interval [0, \( +\infty \) ].
__nv_fp128_acosh(1) returns 0.
__nv_fp128_acosh(
x
) returns NaN forx
in the interval [ \( -\infty \) , 1).__nv_fp128_acosh( \( +\infty \) ) returns \( +\infty \).
__nv_fp128_acosh(NaN) returns NaN.
Compute \( x + y \), the sum of the two floating-point inputs using round-to-nearest-even rounding mode.
Note
Note
- Returns
Returns
x
+y
.__nv_fp128_add(
x
,y
) is equivalent to __nv_fp128_add(y
,x
).__nv_fp128_add(
x
, \( \pm\infty \)) returns \( \pm\infty \) for finitex
.__nv_fp128_add( \( \pm\infty \), \( \pm\infty \)) returns \( \pm\infty \).
__nv_fp128_add( \( \pm\infty \), \( \mp\infty \)) returns NaN.
__nv_fp128_add( \( \pm 0 \), \( \pm 0 \)) returns \( \pm 0 \).
__nv_fp128_add(
x
,-x
) returns \( +0 \) for finitex
, including \( \pm 0 \).If either argument is NaN, NaN is returned.
Calculate \( \sin^{-1}{x} \), the arc sine of input argument.
Note
Note
- Returns
The principal value of the arc sine of the input argument
x
. Result will be in radians, in the interval [- \( \pi/2 \) , + \( \pi/2 \) ] forx
inside [-1, +1].__nv_fp128_asin( \( \pm 0 \) ) returns \( \pm 0 \).
__nv_fp128_asin(
x
) returns NaN forx
outside [-1, +1].__nv_fp128_asin(NaN) returns NaN.
Calculate \( \sinh^{-1}{x} \), the inverse hyperbolic sine of the input argument.
Note
Note
- Returns
__nv_fp128_asinh( \( \pm 0 \) ) returns \( \pm 0 \).
__nv_fp128_asinh( \( \pm \infty \) ) returns \( \pm \infty \).
__nv_fp128_asinh(NaN) returns NaN.
Calculate \( \tan^{-1}{x} \), the arc tangent of input argument.
Note
Note
- Returns
The principal value of the arc tangent of the input argument
x
. Result will be in radians, in the interval [- \( \pi/2 \) , + \( \pi/2 \) ].__nv_fp128_atan( \( \pm 0 \) ) returns \( \pm 0 \).
__nv_fp128_atan( \( \pm \infty \) ) returns \( \pm \pi \) /2.
__nv_fp128_atan(NaN) returns NaN.
Calculate \( \tanh^{-1}{x} \), the inverse hyperbolic tangent of the input argument.
Note
Note
- Returns
__nv_fp128_atanh( \( \pm 0 \) ) returns \( \pm 0 \).
__nv_fp128_atanh( \( \pm 1 \) ) returns \( \pm \infty \).
__nv_fp128_atanh(
x
) returns NaN forx
outside interval [-1, 1].__nv_fp128_atanh(NaN) returns NaN.
Calculate \( \lceil x \rceil \), the smallest integer greater than or equal to
x
.Note
Note
- Returns
\( \lceil x \rceil \) expressed as a floating-point number.
__nv_fp128_ceil( \( \pm \infty \) ) returns \( \pm \infty \).
__nv_fp128_ceil( \( \pm 0 \) ) returns \( \pm 0 \).
__nv_fp128_ceil(NaN) returns NaN.
x
.Note
Note
- Returns
copysign(
NaN
,y
) returns aNaN
with the sign ofy
Calculate \( \cos{x} \), the cosine of input argument (measured in radians).
Note
Note
- Returns
\( \cos{x} \).
__nv_fp128_cos( \( \pm 0 \) ) returns \( 1 \).
__nv_fp128_cos( \( \pm \infty \) ) returns NaN.
__nv_fp128_cos(NaN) returns NaN.
Calculate \( \cosh{x} \), the hyperbolic cosine of the input argument.
Note
Note
- Returns
__nv_fp128_cosh( \( \pm 0 \) ) returns 1.
__nv_fp128_cosh( \( \pm \infty \) ) returns \( +\infty \).
__nv_fp128_cosh(NaN) returns NaN.
Compute \( \frac{x}{y} \), the quotient of the two floating-point inputs using round-to-nearest-even rounding mode.
Note
Note
- Returns
sign of the quotient
x
/y
is XOR of the signs ofx
andy
when neither inputs nor result are NaN.__nv_fp128_div( \( \pm 0 \), \( \pm 0 \)) returns NaN.
__nv_fp128_div( \( \pm\infty \), \( \pm\infty \)) returns NaN.
__nv_fp128_div(
x
, \( \pm\infty \)) returns \( 0 \) of appropriate sign for finitex
.__nv_fp128_div( \( \pm\infty \),
y
) returns \( \infty \) of appropriate sign for finitey
.__nv_fp128_div(
x
, \( \pm 0 \)) returns \( \infty \) of appropriate sign forx
\( \neq 0 \).__nv_fp128_div( \( \pm 0 \),
y
) returns \( 0 \) of appropriate sign fory
\( \neq 0 \).If either argument is NaN, NaN is returned.
Calculate \( e^x \), the base \( e \) exponential of the input argument.
Note
Note
- Returns
__nv_fp128_exp( \( \pm 0 \) ) returns 1.
__nv_fp128_exp( \( -\infty \) ) returns +0.
__nv_fp128_exp( \( +\infty \) ) returns \( +\infty \).
__nv_fp128_exp(NaN) returns NaN.
Calculate \( 10^x \), the base 10 exponential of the input argument.
Note
Note
- Returns
__nv_fp128_exp10( \( \pm 0 \) ) returns 1.
__nv_fp128_exp10( \( -\infty \) ) returns +0.
__nv_fp128_exp10( \( +\infty \) ) returns \( +\infty \).
__nv_fp128_exp10(NaN) returns NaN.
Calculate \( 2^x \), the base 2 exponential of the input argument.
Note
Note
- Returns
__nv_fp128_exp2( \( \pm 0 \) ) returns 1.
ex__nv_fp128_exp2p2f( \( -\infty \) ) returns +0.
__nv_fp128_exp2( \( +\infty \) ) returns \( +\infty \).
__nv_fp128_exp2(NaN) returns NaN.
Calculate \( e^x - 1 \), the base e exponential of the input argument, minus 1.
Note
Note
- Returns
__nv_fp128_expm1( \( \pm 0 \) ) returns \( \pm 0 \).
__nv_fp128_expm1( \( -\infty \) ) returns -1.
__nv_fp128_expm1( \( +\infty \) ) returns \( +\infty \).
__nv_fp128_expm1(NaN) returns NaN.
Calculate \( |x| \), the absolute value of the input argument.
Note
Note
- Returns
__nv_fp128_fabs( \( \pm \infty \) ) returns \( +\infty \).
__nv_fp128_fabs( \( \pm 0 \) ) returns +0.
__nv_fp128_fabs(NaN) returns an unspecified NaN.
x
andy
.Note
Note
- Returns
__nv_fp128_fdim(
x
,y
) returnsx
-y
if \( x > y \).__nv_fp128_fdim(
x
,y
) returns +0 if \( x \leq y \).If either argument is NaN, NaN is returned.
Calculate \( \lfloor x \rfloor \), the largest integer less than or equal to
x
.Note
Note
- Returns
\( \lfloor x \rfloor \) expressed as a floating-point number.
__nv_fp128_floor( \( \pm \infty \) ) returns \( \pm \infty \).
__nv_fp128_floor( \( \pm 0 \) ) returns \( \pm 0 \).
__nv_fp128_floor(NaN) returns NaN.
Compute \( x \times y + z \) as a single operation using round-to-nearest-even rounding mode.
Note
Note
- Returns
The value of \( x \times y + z \) as a single ternary operation, rounded once using round-to-nearest, ties-to-even rounding mode.
__nv_fp128_fma( \( \pm \infty \) , \( \pm 0 \) ,
z
) returns NaN.__nv_fp128_fma( \( \pm 0 \) , \( \pm \infty \) ,
z
x
,y
, \( -\infty \) ) returns NaN if \( x \times y \) is an exact \( +\infty \).__nv_fp128_fma(
x
,y
, \( +\infty \) ) returns NaN if \( x \times y \) is an exact \( -\infty \).__nv_fp128_fma(
x
,y
, \( \pm 0 \)) returns \( \pm 0 \) if \( x \times y \) is exact \( \pm 0 \).__nv_fp128_fma(
x
,y
, \( \mp 0 \)) returns \( +0 \) if \( x \times y \) is exact \( \pm 0 \).__nv_fp128_fma(
x
,y
,z
) returns \( +0 \) if \( x \times y + z \) is exactly zero and \( z \neq 0 \).If either argument is NaN, NaN is returned.
Note
Note
- Returns
The maximum numeric value of the arguments
x
andy
. Treats NaN arguments as missing data.If both arguments are NaN, returns NaN.
If one argument is NaN, returns the numeric argument.
Note
Note
- Returns
The minimum numeric value of the arguments
x
andy
x
/y
.Note
Note
- Returns
The floating-point remainder of the division operation
x
/y
calculated by this function is exactly the valuex - n*y
, wheren
isx
/y
with its fractional part truncated.The computed value will have the same sign as
x
, and its magnitude will be less than the magnitude ofy
.__nv_fp128_fmod( \( \pm 0 \) ,
y
) returns \( \pm 0 \) ify
is not zero.__nv_fp128_fmod(
x
, \( \pm \infty \) ) returnsx
ifx
is finite.__nv_fp128_fmod(
x
,y
) returns NaN ifx
is \( \pm\infty \) ory
is zero.If either argument is NaN, NaN is returned.
Decompose the floating-point value
x
into a componentm
for the normalized fraction element and an integral termn
for the exponent. The absolute value ofm
will be greater than or equal to 0.5 and less than 1.0 or it will be equal to 0; \( x = m\cdot 2^n \). The integer exponentn
will be stored in the location to whichnptr
points.Note
Note
- Returns
The fractional component
m
.__nv_fp128_frexp( \( \pm 0 \) ,
nptr
) returns \( \pm 0 \) and stores zero in the location pointed to bynptr
.__nv_fp128_frexp( \( \pm \infty \) ,
nptr
) returns \( \pm \infty \) and stores an unspecified value in the location to whichnptr
points.__nv_fp128_frexp(NaN,
y
) returns a NaN and stores an unspecified value in the location to whichnptr
points.
Calculate \( \sqrt{x^2+y^2} \), the square root of the sum of squares of two arguments.
Note
Note
- Returns
The length of the hypotenuse of a right triangle whose two sides have lengths \( |x| \) and \( |y| \) without undue overflow or underflow.
__nv_fp128_hypot(
x
,y
), __nv_fp128_hypot(y
,x
), and __nv_fp128_hypot(x
,-y
) are equivalent.__nv_fp128_hypot(
x
, \( \pm 0 \) ) is equivalent to __nv_fp128_fabs(x
).__nv_fp128_hypot( \( \pm \infty \) ,
y
) returns \( +\infty \), even ify
is a NaN.__nv_fp128_hypot(NaN,
y
) returns NaN, wheny
is not \( \pm\infty \).
Note
Note
- Returns
If successful, returns the unbiased exponent of the argument.
__nv_fp128_ilogb( \( \pm 0 \) ) returns
INT_MIN
.__nv_fp128_ilogb(NaN) returns
INT_MIN
.__nv_fp128_ilogb( \( \pm \infty \) ) returns
INT_MAX
.Note: above behavior does not take into account
FP_ILOGB0
norFP_ILOGBNAN
Note
- Returns
A nonzero value if and only if
x
is a NaN value.
Note
- Returns
nonzero value if at least one of input values is a NaN.
zero otherwise
Calculate the value of \( x\cdot 2^{exp} \).
Note
Note
- Returns
__nv_fp128_ldexp( \( \pm 0 \) ,
exp
) returns \( \pm 0 \).__nv_fp128_ldexp(
x
, 0) returnsx
.__nv_fp128_ldexp( \( \pm \infty \) ,
exp
) returns \( \pm \infty \).__nv_fp128_ldexp(NaN,
exp
) returns NaN.
Calculate \( \log_{e}{x} \), the base \( e \) logarithm of the input argument.
Note
Note
- Returns
__nv_fp128_log( \( \pm 0 \) ) returns \( -\infty \).
__nv_fp128_log(1) returns +0.
__nv_fp128_log(
x
) returns NaN forx
< 0.__nv_fp128_log( \( +\infty \) ) returns \( +\infty \).
__nv_fp128_log(NaN) returns NaN.
Calculate \( \log_{10}{x} \), the base 10 logarithm of the input argument.
Note
Note
- Returns
__nv_fp128_log10( \( \pm 0 \) ) returns \( -\infty \).
__nv_fp128_log10(1) returns +0.
__nv_fp128_log10(
x
) returns NaN forx
< 0.__nv_fp128_log10( \( +\infty \) ) returns \( +\infty \).
__nv_fp128_log10(NaN) returns NaN.
Calculate the value of \( \log_{e}(1+x) \).
Note
Note
- Returns
__nv_fp128_log1p( \( \pm 0 \) ) returns \( \pm 0 \).
__nv_fp128_log1p(-1) returns \( -\infty \).
__nv_fp128_log1p(
x
) returns NaN forx
< -1.__nv_fp128_log1p( \( +\infty \) ) returns \( +\infty \).
__nv_fp128_log1p(NaN) returns NaN.
Calculate \( \log_{2}{x} \), the base 2 logarithm of the input argument.
Note
Note
- Returns
__nv_fp128_log2( \( \pm 0 \) ) returns \( -\infty \).
__nv_fp128_log2(1) returns +0.
__nv_fp128_log2(
x
) returns NaN forx
< 0.__nv_fp128_log2( \( +\infty \) ) returns \( +\infty \).
__nv_fp128_log2(NaN) returns NaN.
Break down the argument
x
into fractional and integral parts. The integral part is stored in floating-point format in the location to whichiptr
points. Fractional and integral parts are given the same sign as the argumentx
.Note
Note
- Returns
__nv_fp128_modf( \( \pm x \) ,
iptr
) returns a result with the same sign asx
.__nv_fp128_modf( \( \pm \infty \) ,
iptr
) returns \( \pm 0 \) and stores \( \pm \infty \) in the object pointed to byiptr
.__nv_fp128_modf(NaN,
iptr
) stores a NaN in the object pointed to byiptr
and returns a NaN.
Compute \( x \cdot y \), the product of the two floating-point inputs using round-to-nearest-even rounding mode.
Note
Note
- Returns
Returns
x
*y
.sign of the product
x
*y
andy
when neither inputs nor result are NaN.__nv_fp128_mul(
x
,y
) is equivalent to __nv_fp128_mul(y
,x
).__nv_fp128_mul(
x
, \( \pm\infty \)) returns \( \infty \) of appropriate sign forx
\( \neq 0 \).__nv_fp128_mul( \( \pm 0 \), \( \pm\infty \)) returns NaN.
y
) returns \( 0 \) of appropriate sign for finitey
Calculate the value of \( x^{y} \), first argument to the power of second argument.
Note
Note
- Returns
__nv_fp128_pow( \( \pm 0 \) ,
y
) returns \( \pm \infty \) fory
an odd integer less than 0.__nv_fp128_pow( \( \pm 0 \) ,
y
) returns \( +\infty \) fory
less than 0 and not an odd integer.__nv_fp128_pow( \( \pm 0 \) ,
y
) returns \( \pm 0 \) fory
an odd integer greater than 0.__nv_fp128_pow( \( \pm 0 \) ,
y
) returns +0 fory
> 0 and not an odd integer.__nv_fp128_pow(-1, \( \pm \infty \) ) returns 1.
__nv_fp128_pow(+1,
y
) returns 1 for anyy
, even a NaN.__nv_fp128_pow(
x
, \( \pm 0 \) ) returns 1 for anyx
x
,y
) returns a NaN for finitex
< 0 and finite non-integery
.__nv_fp128_pow(
x
, \( -\infty \) ) returns \( +\infty \) for \( | x | < 1 \).__nv_fp128_pow(
x
, \( -\infty \) ) returns +0 for \( | x | > 1 \).__nv_fp128_pow(
x
, \( +\infty \) ) returns +0 for \( | x | < 1 \).__nv_fp128_pow(
x
, \( +\infty \) ) returns \( +\infty \) for \( | x | > 1 \).__nv_fp128_pow( \( -\infty \) ,
y
) returns -0 fory
an odd integer less than 0.__nv_fp128_pow( \( -\infty \) ,
y
) returns +0 fory
< 0 and not an odd integer.__nv_fp128_pow( \( -\infty \) ,
y
) returns \( -\infty \) fory
an odd integer greater than 0.__nv_fp128_pow( \( -\infty \) ,
y
> 0 and not an odd integer.__nv_fp128_pow( \( +\infty \) ,
y
) returns +0 fory
< 0.__nv_fp128_pow( \( +\infty \) ,
y
> 0.__nv_fp128_pow(
x
,y
) returns NaN if eitherx
ory
or both are NaN andx
\( \neq \) +1 andy
\( \neq\pm 0 \).
Note
Note
- Returns
r
of dividingx
byy
for nonzeroy
is defined as \( r = x - n y \). The valuen
is the integer value nearest \( \frac{x}{y} \). In the halfway cases when \( | n -\frac{x}{y} | = \frac{1}{2} \) , the evenn
value is chosen.__nv_fp128_remainder(
x
, \( \pm 0 \) ) returns NaN.__nv_fp128_remainder( \( \pm \infty \) ,
y
x
for finitex
Note
Note
- Returns
__nv_fp128_rint( \( \pm 0 \) ) returns \( \pm 0 \).
__nv_fp128_rint( \( \pm \infty \) ) returns \( \pm \infty \).
__nv_fp128_rint(NaN) returns NaN.
Note
Note
- Returns
__nv_fp128_round( \( \pm 0 \) ) returns \( \pm 0 \).
__nv_fp128_round( \( \pm \infty \) ) returns \( \pm \infty \).
__nv_fp128_round(NaN) returns NaN.
Calculate \( \sin{x} \), the sine of input argument (measured in radians).
Note
Note
- Returns
\( \sin{x} \).
__nv_fp128_sin( \( \pm 0 \) ) returns \( \pm 0 \).
__nv_fp128_sin( \( \pm \infty \) ) returns NaN.
__nv_fp128_sin(NaN) returns NaN.
Calculate \( \sinh{x} \), the hyperbolic sine of the input argument.
x
.Note
Note
- Returns
__nv_fp128_sinhinh( \( \pm 0 \) ) returns \( \pm 0 \).
__nv_fp128_sinh( \( \pm \infty \) ) returns \( \pm \infty \).
__nv_fp128_sinh(NaN) returns NaN.
Calculate \( \sqrt{x} \), the square root of the input argument.
Note
Note
- Returns
\( \sqrt{x} \).
__nv_fp128_sqrt( \( \pm 0 \) ) returns \( \pm 0 \).
__nv_fp128_sqrt( \( +\infty \) ) returns \( +\infty \).
__nv_fp128_sqrt(
x
) returns NaN ifx
is less than 0.__nv_fp128_sqrt(NaN) returns NaN.
Compute \( x - y \), the difference of the two floating-point inputs using round-to-nearest-even rounding mode.
Note
Note
- Returns
Returns
x
-y
.__nv_fp128_sub( \( \pm\infty \),
y
) returns \( \pm\infty \) for finitey
.__nv_fp128_sub(
x
, \( \pm\infty \)) returns \( \mp\infty \) for finitex
.__nv_fp128_sub( \( \pm\infty \), \( \pm\infty \)) returns NaN.
__nv_fp128_sub( \( \pm\infty \), \( \mp\infty \)) returns \( \pm\infty \).
__nv_fp128_sub( \( \pm 0 \), \( \mp 0 \)) returns \( \pm 0 \).
__nv_fp128_sub(
x
,x
Calculate \( \tan{x} \), the tangent of input argument (measured in radians).
Note
Note
- Returns
\( \tan{x} \).
__nv_fp128_tan( \( \pm 0 \) ) returns \( \pm 0 \).
__nv_fp128_tan( \( \pm \infty \) ) returns NaN.
__nv_fp128_tan(NaN) returns NaN.
Calculate \( \tanh{x} \), the hyperbolic tangent of the input argument.
Note
Note
- Returns
__nv_fp128_tanh( \( \pm 0 \) ) returns \( \pm 0 \).
__nv_fp128_tanh( \( \pm \infty \) ) returns \( \pm 1 \).
__nv_fp128_tanh(NaN) returns NaN.
Note
Note
- Returns
Rounded
x
to the nearest integer value in floating-point format, that does not exceedx
in magnitude.__nv_fp128_trunc( \( \pm 0 \) ) returns \( \pm 0 \).
__nv_fp128_trunc( \( \pm \infty \) ) returns \( \pm \infty \).
__nv_fp128_trunc(NaN) returns NaN.
