5. Bfloat16 Precision Intrinsics
This section describes nv_bfloat16 precision intrinsic functions.
To use these functions, include the header file cuda_bf16.h
in your program. All of the functions defined here are available in device code. Some of the functions are also available to host compilers, please refer to respective functions’ documentation for details.
NOTE: Aggressive floating-point optimizations performed by host or device compilers may affect numeric behavior of the functions implemented in this header. Specific examples are:
The following macros are available to help users selectively enable/disable various definitions present in the header file:
CUDA_NO_BFLOAT16
- If defined, this macro will prevent the definition of additional type aliases in the global namespace, helping to avoid potential conflicts with symbols defined in the user program.__CUDA_NO_BFLOAT16_CONVERSIONS__
- If defined, this macro will prevent the use of the C++ type conversions (converting constructors and conversion operators) that are common for built-in floating-point types, but may be undesirable for__nv_bfloat16
which is essentially a user-defined type.__CUDA_NO_BFLOAT16_OPERATORS__
and__CUDA_NO_BFLOAT162_OPERATORS__
- If defined, these macros will prevent the inadvertent use of usual arithmetic and comparison operators. This enforces the storage-only type semantics and prevents C++ style computations on__nv_bfloat16
and__nv_bfloat162
types.
Groups
- Bfloat16 Arithmetic Constants
To use these constants, include the header file
cuda_bf16.h
in your program.- Bfloat16 Arithmetic Functions
cuda_bf16.h
in your program.- Bfloat16 Comparison Functions
cuda_bf16.h
in your program.- Bfloat16 Math Functions
cuda_bf16.h
in your program.- Bfloat16 Precision Conversion and Data Movement
cuda_bf16.h
in your program.- Bfloat162 Arithmetic Functions
cuda_bf16.h
in your program.- Bfloat162 Comparison Functions
cuda_bf16.h
in your program.- Bfloat162 Math Functions
cuda_bf16.h
in your program.
Structs
- __nv_bfloat16
nv_bfloat16 datatype
- __nv_bfloat162
nv_bfloat162 datatype
- __nv_bfloat162_raw
__nv_bfloat162_raw data type
- __nv_bfloat16_raw
__nv_bfloat16_raw data type
Typedefs
- nv_bfloat16
This datatype is meant to be the first-class or fundamental implementation of the bfloat16 numbers format.
- nv_bfloat162
This datatype is meant to be the first-class or fundamental implementation of type for pairs of bfloat16 numbers.
5.9. Typedefs
typedef __nv_bfloat16 nv_bfloat16
Should be implemented in the compiler in the future. Current implementation is a simple typedef to a respective user-level type with underscores.
typedef __nv_bfloat162 nv_bfloat162
