13. Integer Intrinsics
This section describes integer intrinsic functions.
All of these functions are supported in device code. For some of the functions, host-specific implementations are also provided. For example, see __nv_bswap16()
. To use these functions, you do not need to include any additional header file in your program.
Functions
- __device__ unsigned int __brev(unsigned int x)
Reverse the bit order of a 32-bit unsigned integer.
- __device__ unsigned long long int __brevll(unsigned long long int x)
Reverse the bit order of a 64-bit unsigned integer.
- __device__ unsigned int __byte_perm(unsigned int x, unsigned int y, unsigned int s)
Return selected bytes from two 32-bit unsigned integers.
- __device__ int __clz(int x)
Return the number of consecutive high-order zero bits in a 32-bit integer.
- __device__ int __clzll(long long int x)
Count the number of consecutive high-order zero bits in a 64-bit integer.
- __device__ int __dp2a_hi(int srcA, int srcB, int c)
Two-way
signed
int16
byint8
dot product withint32
accumulate, taking the upper half of the second input.- __device__ unsigned int __dp2a_hi(unsigned int srcA, unsigned int srcB, unsigned int c)
Two-way
unsigned
int16
byint8
dot product withunsigned
int32
accumulate, taking the upper half of the second input.- __device__ unsigned int __dp2a_hi(ushort2 srcA, uchar4 srcB, unsigned int c)
Two-way
unsigned
int16
byint8
int32
accumulate, taking the upper half of the second input.- __device__ int __dp2a_hi(short2 srcA, char4 srcB, int c)
Two-way
signed
int16
byint8
accumulate, taking the upper half of the second input.- __device__ unsigned int __dp2a_lo(ushort2 srcA, uchar4 srcB, unsigned int c)
Two-way
unsigned
int16
byint8
int32
accumulate, taking the lower half of the second input.- __device__ int __dp2a_lo(short2 srcA, char4 srcB, int c)
Two-way
signed
int16
byint8
accumulate, taking the lower half of the second input.- __device__ unsigned int __dp2a_lo(unsigned int srcA, unsigned int srcB, unsigned int c)
Two-way
unsigned
int16
byint8
int32
accumulate, taking the lower half of the second input.- __device__ int __dp2a_lo(int srcA, int srcB, int c)
Two-way
signed
int16
byint8
accumulate, taking the lower half of the second input.- __device__ unsigned int __dp4a(uchar4 srcA, uchar4 srcB, unsigned int c)
Four-way
unsigned
int8
int32
accumulate.- __device__ unsigned int __dp4a(unsigned int srcA, unsigned int srcB, unsigned int c)
Four-way
unsigned
int8
int32
accumulate.- __device__ int __dp4a(int srcA, int srcB, int c)
Four-way
signed
int8
accumulate.- __device__ int __dp4a(char4 srcA, char4 srcB, int c)
Four-way
signed
int8
accumulate.- __device__ int __ffs(int x)
Find the position of the least significant bit set to 1 in a 32-bit integer.
- __device__ int __ffsll(long long int x)
Find the position of the least significant bit set to 1 in a 64-bit integer.
- __device__ unsigned __fns(unsigned mask, unsigned base, int offset)
Find the position of the n-th set to 1 bit in a 32-bit integer.
- __device__ unsigned int __funnelshift_l(unsigned int lo, unsigned int hi, unsigned int shift)
Concatenate
hi
:lo
, shift left byshift
& 31 bits, return the most significant 32 bits.- __device__ unsigned int __funnelshift_lc(unsigned int lo, unsigned int hi, unsigned int shift)
Concatenate
hi
:lo
, shift left by min(shift
, 32) bits, return the most significant 32 bits.- __device__ unsigned int __funnelshift_r(unsigned int lo, unsigned int hi, unsigned int shift)
Concatenate
hi
:lo
, shift right byshift
& 31 bits, return the least significant 32 bits.- __device__ unsigned int __funnelshift_rc(unsigned int lo, unsigned int hi, unsigned int shift)
Concatenate
hi
:lo
, shift right by min(shift
, 32) bits, return the least significant 32 bits.- __device__ int __hadd(int x, int y)
Compute average of signed input arguments, avoiding overflow in the intermediate sum.
- __device__ int __mul24(int x, int y)
Calculate the least significant 32 bits of the product of the least significant 24 bits of two integers.
- __device__ long long int __mul64hi(long long int x, long long int y)
Calculate the most significant 64 bits of the product of the two 64-bit integers.
- __device__ int __mulhi(int x, int y)
Calculate the most significant 32 bits of the product of the two 32-bit integers.
- __host__ __device__ unsigned short __nv_bswap16(unsigned short x)
Reverse the order of bytes of the 16-bit unsigned integer.
- __host__ __device__ unsigned int __nv_bswap32(unsigned int x)
Reverse the order of bytes of the 32-bit unsigned integer.
- __host__ __device__ unsigned long long __nv_bswap64(unsigned long long x)
Reverse the order of bytes of the 64-bit unsigned integer.
- __device__ int __popc(unsigned int x)
Count the number of bits that are set to 1 in a 32-bit integer.
- __device__ int __popcll(unsigned long long int x)
Count the number of bits that are set to 1 in a 64-bit integer.
- __device__ int __rhadd(int x, int y)
Compute rounded average of signed input arguments, avoiding overflow in the intermediate sum.
- __device__ unsigned int __sad(int x, int y, unsigned int z)
Calculate \(|x - y| + z\) , the sum of absolute difference.
- __device__ unsigned int __uhadd(unsigned int x, unsigned int y)
Compute average of unsigned input arguments, avoiding overflow in the intermediate sum.
- __device__ unsigned int __umul24(unsigned int x, unsigned int y)
Calculate the least significant 32 bits of the product of the least significant 24 bits of two unsigned integers.
- __device__ unsigned long long int __umul64hi(unsigned long long int x, unsigned long long int y)
Calculate the most significant 64 bits of the product of the two 64 unsigned bit integers.
- __device__ unsigned int __umulhi(unsigned int x, unsigned int y)
Calculate the most significant 32 bits of the product of the two 32-bit unsigned integers.
- __device__ unsigned int __urhadd(unsigned int x, unsigned int y)
Compute rounded average of unsigned input arguments, avoiding overflow in the intermediate sum.
- __device__ unsigned int __usad(unsigned int x, unsigned int y, unsigned int z)
13.1. Functions
Reverses the bit order of the 32-bit unsigned integer
x
.- Returns
Returns the bit-reversed value of
x
. i.e. bit N of the return value corresponds to bit 31-N ofx
Reverses the bit order of the 64-bit unsigned integer
x
.- Returns
x
. i.e. bit N of the return value corresponds to bit 63-N ofx
Create 8-byte source
uint64_t
tmp64
= ((uint64_t)y
<< 32) |x
Extract selector bits
selector0
= (s
>> 0) & 0x7;selector1
= (s
>> 4) & 0x7;selector2
= (s
>> 8) & 0x7;selector3
= (s
>> 12) & 0x7;
Return 4 selected bytes from 8-byte source:
res
[07:00] =tmp64
[selector0
];res
[15:08] =tmp64
[selector1
];res
[23:16] =tmp64
[selector2
];res
[31:24] =tmp64
[selector3
- Returns
Returns a 32-bit integer consisting of four bytes from eight input bytes provided in the two input integers
x
andy
, as specified by a selector,s
Count the number of consecutive leading zero bits, starting at the most significant bit (bit 31) of
x
.- Returns
Returns a value between 0 and 32 inclusive representing the number of zero bits.
Count the number of consecutive leading zero bits, starting at the most significant bit (bit 63) of
x
.- Returns
Returns a value between 0 and 64 inclusive representing the number of zero bits.
Two-way
signed
int16
byint8
accumulate, taking the upper half of the second input.Extracts two packed 16-bit integers from
scrA
and two packed 8-bit integers from the upper 16 bits ofsrcB
, then creates two pairwise 8x16 products and adds them together to a signed 32-bit integerc
Two-way
unsigned
int16
byint8
int32
scrA
, then creates two pairwise 8x16 products and adds them together to an unsigned 32-bit integerc
Two-way
unsigned
int16
byint8
int32
accumulate, taking the upper half of the second input.Takes two packed 16-bit integers from
scrA
vector and two packed 8-bit integers from the upper 16 bits ofsrcB
vector, then creates two pairwise 8x16 products and adds them together to an unsigned 32-bit integerc
Two-way
signed
int16
byint8
scrA
vector, then creates two pairwise 8x16 products and adds them together to a signed 32-bit integerc
Two-way
unsigned
int16
byint8
int32
accumulate, taking the lower half of the second input.Takes two packed 16-bit integers from
scrA
vector and two packed 8-bit integers from the lower 16 bits ofsrcB
Two-way
signed
int16
byint8
scrA
Two-way
unsigned
int16
byint8
int32
accumulate, taking the lower half of the second input.Extracts two packed 16-bit integers from
scrA
Two-way
signed
int16
byint8
scrA
Four-way
unsigned
int8
int32
accumulate.Takes four pairs of packed byte-sized integers from
scrA
andsrcB
vectors, then creates four pairwise products and adds them together to an unsigned 32-bit integerc
Four-way
unsigned
int8
int32
accumulate.Extracts four pairs of packed byte-sized integers from
scrA
andsrcB
Four-way
signed
int8
scrA
andsrcB
, then creates four pairwise products and adds them together to a signed 32-bit integerc
Four-way
signed
int8
scrA
andsrcB
vectors, then creates four pairwise products and adds them together to a signed 32-bit integerc
Find the position of the first (least significant) bit set to 1 in
x
, where the least significant bit position is 1.- Returns
Returns a value between 0 and 32 inclusive representing the position of the first bit set.
__ffs(0) returns 0.
x
Returns a value between 0 and 64 inclusive representing the position of the first bit set.
__ffsll(0) returns 0.
Given a 32-bit value
mask
and an integer valuebase
(between 0 and 31), find the n-th (given byoffset
) set bit inmask
from thebase
bit. If not found, return 0xFFFFFFFF.See also https://docs.nvidia.com/cuda/parallel-thread-execution/index.html#integer-arithmetic-instructions-fns for more information.
- Returns
Returns a value between 0 and 32 inclusive representing the position of the n-th set bit.
parameter
base
must be <=31, otherwise behavior is undefined.
Concatenate
hi
:lo
& 31 bits, return the most significant 32 bits.Shift the 64-bit value formed by concatenating argument
lo
andhi
left by the amount specified by the argumentshift
. Argumentlo
holds bits 31:0 and argumenthi
holds bits 63:32 of the 64-bit source value. The source is shifted left by the wrapped value ofshift
(shift
& 31). The most significant 32-bits of the result are returned.- Returns
Returns the most significant 32 bits of the shifted 64-bit value.
Concatenate
hi
:lo
, 32) bits, return the most significant 32 bits.Shift the 64-bit value formed by concatenating argument
lo
andhi
. Argumentlo
holds bits 63:32 of the 64-bit source value. The source is shifted left by the clamped value ofshift
(min(shift
, 32)). The most significant 32-bits of the result are returned.- Returns
Concatenate
hi
:lo
& 31 bits, return the least significant 32 bits.Shift the 64-bit value formed by concatenating argument
lo
andhi
right by the amount specified by the argumentshift
. Argumentlo
holds bits 63:32 of the 64-bit source value. The source is shifted right by the wrapped value ofshift
(shift
& 31). The least significant 32-bits of the result are returned.- Returns
Returns the least significant 32 bits of the shifted 64-bit value.
Concatenate
hi
:lo
, 32) bits, return the least significant 32 bits.Shift the 64-bit value formed by concatenating argument
lo
andhi
. Argumentlo
holds bits 63:32 of the 64-bit source value. The source is shifted right by the clamped value ofshift
(min(shift
, 32)). The least significant 32-bits of the result are returned.- Returns
x
andy
as (x
+y
) >> 1, avoiding overflow in the intermediate sum.- Returns
Returns a signed integer value representing the signed average value of the two inputs.
x
andy
. The high order 8 bits ofx
andy
are ignored.- Returns
Returns the least significant 32 bits of the product
x
*y
Calculate the most significant 64 bits of the 128-bit product
x
*y
, wherex
andy
are 64-bit integers.- Returns
Returns the most significant 64 bits of the product
x
*y
Calculate the most significant 32 bits of the 64-bit product
x
*y
, wherex
andy
are 32-bit integers.- Returns
Returns the most significant 32 bits of the product
x
*y
x
. Only supported in MSVC and other host compilers which define the__GNUC__
macro, such as GCC and CLANG.- Returns
Returns
x
with the order of bytes reversed.
x
Returns
x
x
Returns
x
x
.- Returns
Returns a value between 0 and 32 inclusive representing the number of set bits.
x
.- Returns
Returns a value between 0 and 64 inclusive representing the number of set bits.
x
andy
as (x
+y
+ 1 ) >> 1, avoiding overflow in the intermediate sum.- Returns
Returns a signed integer value representing the signed rounded average value of the two inputs.
Calculate \( |x - y| + z \) , the sum of absolute difference.
Calculate \( |x - y| + z \) , the 32-bit sum of the third argument
z
plus and the absolute value of the difference between the first argument,x
, and second argument,y
.Inputs
x
andy
are signed 32-bit integers, inputz
is a 32-bit unsigned integer.- Returns
Returns \( |x - y| + z \).
x
andy
as (x
+y
Returns an unsigned integer value representing the unsigned average value of the two inputs.
x
andy
andy
x
*y
x
*y
, wherex
andy
are 64-bit unsigned integers.- Returns
x
*y
x
*y
, wherex
andy
are 32-bit unsigned integers.- Returns
x
*y
x
andy
as (x
+y
Returns an unsigned integer value representing the unsigned rounded average value of the two inputs.
z
.Inputs
x
,y
, andz
are unsigned 32-bit integers.- Returns
