12. Integer Mathematical Functions
This section describes integer mathematical functions.
To use these functions, you do not need to include any additional header file in your program.
Functions
- __device__ long int abs(long int a)
Calculate the absolute value of the input
longintargument. - __device__ int abs(int a)
intargument. - __device__ long long int abs(long long int a)
longlongintargument. - __device__ long int labs(long int a)
longintargument. - __device__ long long int llabs(long long int a)
longlongintargument. - __device__ long long int llmax(const long long int a, const long long int b)
Calculate the maximum value of the input
longlongintarguments. - __device__ long long int llmin(const long long int a, const long long int b)
Calculate the minimum value of the input
longlongintarguments. - __device__ unsigned long int max(const long int a, const unsigned long int b)
longintandunsignedlongintarguments. - __device__ unsigned long long int max(const unsigned long long int a, const unsigned long long int b)
unsignedlonglongintarguments. - __device__ unsigned int max(const unsigned int a, const int b)
unsignedintandintarguments. - __device__ unsigned long long int max(const long long int a, const unsigned long long int b)
longlongintandunsignedlonglongintarguments. - __device__ unsigned long int max(const unsigned long int a, const unsigned long int b)
unsignedlongintarguments. - __device__ long long int max(const long long int a, const long long int b)
longlongintarguments. - __device__ unsigned long long int max(const unsigned long long int a, const long long int b)
unsignedlonglongintandlonglongintarguments. - __device__ unsigned long int max(const unsigned long int a, const long int b)
unsignedlongintandlongintarguments. - __device__ long int max(const long int a, const long int b)
longintarguments. - __device__ int max(const int a, const int b)
intarguments. - __device__ unsigned int max(const unsigned int a, const unsigned int b)
unsignedintarguments. - __device__ unsigned int max(const int a, const unsigned int b)
intandunsignedintarguments. - __device__ unsigned long int min(const long int a, const unsigned long int b)
longintandunsignedlongintarguments. - __device__ unsigned long long int min(const unsigned long long int a, const unsigned long long int b)
unsignedlonglongintarguments. - __device__ unsigned long long int min(const unsigned long long int a, const long long int b)
unsignedlonglongintandlonglongintarguments. - __device__ int min(const int a, const int b)
intarguments. - __device__ unsigned int min(const unsigned int a, const int b)
unsignedintandintarguments. - __device__ unsigned long long int min(const long long int a, const unsigned long long int b)
longlongintandunsignedlonglongintarguments. - __device__ long long int min(const long long int a, const long long int b)
longlongintarguments. - __device__ unsigned int min(const int a, const unsigned int b)
intandunsignedintarguments. - __device__ long int min(const long int a, const long int b)
longintarguments. - __device__ unsigned int min(const unsigned int a, const unsigned int b)
unsignedintarguments. - __device__ unsigned long int min(const unsigned long int a, const long int b)
unsignedlongintandlongintarguments. - __device__ unsigned long int min(const unsigned long int a, const unsigned long int b)
unsignedlongintarguments. - __device__ unsigned long long int ullmax(const unsigned long long int a, const unsigned long long int b)
unsignedlonglongintarguments. - __device__ unsigned long long int ullmin(const unsigned long long int a, const unsigned long long int b)
unsignedlonglongintarguments. - __device__ unsigned int umax(const unsigned int a, const unsigned int b)
unsignedintarguments. - __device__ unsigned int umin(const unsigned int a, const unsigned int b)
12.1. Functions
longintargument.Calculate the absolute value of the input argument
a.- Returns
Returns the absolute value of the input argument.
abs(
LONG_MIN) isUndefined
a.- Returns
abs(
INT_MIN) isUndefined
longlongintargument.Calculate the absolute value of the input argument
a.- Returns
abs(
LLONG_MIN) isUndefined
a.- Returns
labs(
a.- Returns
llabs(
longlongintarguments.Calculate the maximum value of the arguments
aandb.
longlongintarguments.Calculate the minimum value of the arguments
aandb.
longintandunsignedlongintarguments.Calculate the maximum value of the arguments
aandb, perform integer promotion first.
unsignedlonglongintarguments.Calculate the maximum value of the arguments
aandb.
unsignedintandintarguments.Calculate the maximum value of the arguments
longlongintandunsignedlonglongintarguments.Calculate the maximum value of the arguments
aandb.
aandb.
unsignedlonglongintandlonglongintarguments.Calculate the maximum value of the arguments
unsignedlongintandlongintarguments.Calculate the maximum value of the arguments
aandb.
aandb.
unsignedintarguments.Calculate the maximum value of the arguments
aandb.
intandunsignedintarguments.Calculate the maximum value of the arguments
longintandunsignedlongintarguments.Calculate the minimum value of the arguments
unsignedlonglongintarguments.Calculate the minimum value of the arguments
aandb.
unsignedlonglongintandlonglongintarguments.Calculate the minimum value of the arguments
aandb.
unsignedintandintarguments.Calculate the minimum value of the arguments
longlongintandunsignedlonglongintarguments.Calculate the minimum value of the arguments
aandb.
intandunsignedintarguments.Calculate the minimum value of the arguments
aandb.
aandb.
unsignedlongintandlongintarguments.Calculate the minimum value of the arguments
aandb.
aandb.
aandb.
aandb.
aandb.
