9.0/sources/includes/nvbufsurface.h File Reference
NvBufSurface Interface
This file specifies the NvBufSurface management API.
The NvBufSurface API provides methods to allocate / deallocate, map / unmap and copy batched buffers.
Definition in file 9.0/sources/includes/nvbufsurface.h.
Data Structures
struct  NvBufSurfacePlaneParamsEx
 Holds plane wise parameters(extended) of a buffer. More...
 Holds plane wise parameters of a buffer. More...
struct  NvBufSurfaceChromaSubsamplingParams
 Holds Chroma Subsampling parameters for NvBufSurface allocation. More...
struct  NvBufSurfaceCreateParams
 Holds parameters required to allocate an NvBufSurface. More...
struct  NvBufSurfaceAllocateParams
 Hold extended parameters required to allocate NvBufSurface. More...
struct  NvBufSurfaceMappedAddr
 Hold the pointers of mapped buffer. More...
struct  NvBufSurfaceParamsEx
 Hold the information(extended) of single buffer in the batch. More...
struct  NvBufSurfaceCudaBuffer
 Holds information of CUDA buffer. More...
 Hold the information of single buffer in the batch. More...
struct  NvBufSurface
 Holds information about batched buffers. More...
struct  NvBufSurfaceMapPlaneParams
 Holds plane parameters to map the buffer received from another process. More...
struct  NvBufSurfaceCudaIpcMemHandle_t
 CUDA IPC memory handle for NvBufSurface. More...
struct  NvBufSurfaceExtendedMapParams_t
 The extended map parameters NvBufSurface. More...
struct  NvBufSurfaceMapParams
 Holds buffer parameters to map the buffer received from another process. More...
struct  NvBufSurfaceNvmmBuffer
 Holds information about mapped CUDA buffer. More...
struct  NvBufSurfaceDeviceInfo
 Holds information about the underlying device. More...
struct  NvBufSurfaceGPUL2SyncParams
Macros
#define STRUCTURE_PADDING   4
 Defines the default padding length for reserved fields of structures. More...
#define NVBUF_MAX_PLANES   4
 Defines the maximum number of planes. More...
#define NVBUFSURFACE_CHROMA_SUBSAMPLING_HORIZ_DEFAULT   0
 Defines the default values for chroma subsampling. More...
#define NVBUFSURFACE_CHROMA_SUBSAMPLING_VERT_DEFAULT   1
#define NVBUFSURFACE_CHROMA_SUBSAMPLING_PARAMS_DEFAULT
Typedefs
typedef struct NvBufSurfacePlaneParamsEx NvBufSurfacePlaneParamsEx
typedef struct NvBufSurfacePlaneParams NvBufSurfacePlaneParams
typedef struct NvBufSurfaceChromaSubsamplingParams NvBufSurfaceChromaSubsamplingParams
typedef struct NvBufSurfaceCreateParams NvBufSurfaceCreateParams
typedef struct NvBufSurfaceAllocateParams NvBufSurfaceAllocateParams
typedef struct NvBufSurfaceMappedAddr NvBufSurfaceMappedAddr
typedef struct NvBufSurfaceParamsEx NvBufSurfaceParamsEx
typedef struct NvBufSurfaceCudaBuffer NvBufSurfaceCudaBuffer
typedef struct NvBufSurfaceParams NvBufSurfaceParams
typedef struct NvBufSurface NvBufSurface
typedef struct NvBufSurfaceMapPlaneParams NvBufSurfaceMapPlaneParams
typedef struct NvBufSurfaceCudaIpcMemHandle_t NvBufSurfaceCudaIpcMemHandle
typedef struct NvBufSurfaceExtendedMapParams_t NvBufSurfaceExtendedMapParams
typedef struct NvBufSurfaceMapParams NvBufSurfaceMapParams
typedef struct NvBufSurfaceNvmmBuffer NvBufSurfaceNvmmBuffer
typedef struct NvBufSurfaceDeviceInfo NvBufSurfaceDeviceInfo
typedef enum NvBufSurfaceGPUL2SyncCacheOps NvBufSurfaceGPUL2SyncCacheOps
typedef struct NvBufSurfaceGPUL2SyncParams NvBufSurfaceGPUL2SyncParams
Enumerations
enum  NvBufSurfaceMemMapFlags {
  NVBUF_MAP_READ,
  NVBUF_MAP_WRITE,
  NVBUF_MAP_READ_WRITE,
  NVBUF_MAP_READ,
  NVBUF_MAP_WRITE,
 Defines mapping types of NvBufSurface. More...
enum  NvBufSurfaceTag {
  NvBufSurfaceTag_NONE = 0x0,
  NvBufSurfaceTag_CAMERA = 0x200,
  NvBufSurfaceTag_JPEG = 0x1500,
  NvBufSurfaceTag_PROTECTED = 0x1504,
  NvBufSurfaceTag_VIDEO_ENC = 0x1200,
  NvBufSurfaceTag_VIDEO_DEC = 0x1400,
  NvBufSurfaceTag_VIDEO_CONVERT = 0xf01,
 Defines tags that identify the components requesting a memory allocation. More...
enum  NvBufSurfaceColorFormat {
  NVBUF_COLOR_FORMAT_INVALID,
  NVBUF_COLOR_FORMAT_GRAY8,
  NVBUF_COLOR_FORMAT_YUV420,
  NVBUF_COLOR_FORMAT_YVU420,
  NVBUF_COLOR_FORMAT_YUV420_ER,
  NVBUF_COLOR_FORMAT_YVU420_ER,
  NVBUF_COLOR_FORMAT_NV12,
  NVBUF_COLOR_FORMAT_NV12_ER,
  NVBUF_COLOR_FORMAT_NV21,
  NVBUF_COLOR_FORMAT_NV21_ER,
  NVBUF_COLOR_FORMAT_UYVY,
  NVBUF_COLOR_FORMAT_UYVY_ER,
  NVBUF_COLOR_FORMAT_VYUY,
  NVBUF_COLOR_FORMAT_VYUY_ER,
  NVBUF_COLOR_FORMAT_YUYV,
  NVBUF_COLOR_FORMAT_YUYV_ER,
  NVBUF_COLOR_FORMAT_YVYU,
  NVBUF_COLOR_FORMAT_YVYU_ER,
  NVBUF_COLOR_FORMAT_YUV444,
  NVBUF_COLOR_FORMAT_RGBA,
  NVBUF_COLOR_FORMAT_BGRA,
  NVBUF_COLOR_FORMAT_ARGB,
  NVBUF_COLOR_FORMAT_ABGR,
  NVBUF_COLOR_FORMAT_RGBx,
  NVBUF_COLOR_FORMAT_BGRx,
  NVBUF_COLOR_FORMAT_xRGB,
  NVBUF_COLOR_FORMAT_xBGR,
  NVBUF_COLOR_FORMAT_RGB,
  NVBUF_COLOR_FORMAT_BGR,
  NVBUF_COLOR_FORMAT_NV12_10LE,
  NVBUF_COLOR_FORMAT_NV12_12LE,
  NVBUF_COLOR_FORMAT_YUV420_709,
  NVBUF_COLOR_FORMAT_YUV420_709_ER,
  NVBUF_COLOR_FORMAT_NV12_709,
  NVBUF_COLOR_FORMAT_NV12_709_ER,
  NVBUF_COLOR_FORMAT_YUV420_2020,
  NVBUF_COLOR_FORMAT_NV12_2020,
  NVBUF_COLOR_FORMAT_NV12_10LE_ER,
  NVBUF_COLOR_FORMAT_NV12_10LE_709,
  NVBUF_COLOR_FORMAT_NV12_10LE_709_ER,
  NVBUF_COLOR_FORMAT_NV12_10LE_2020,
  NVBUF_COLOR_FORMAT_SIGNED_R16G16,
  NVBUF_COLOR_FORMAT_R8_G8_B8,
  NVBUF_COLOR_FORMAT_B8_G8_R8,
  NVBUF_COLOR_FORMAT_R32F_G32F_B32F,
  NVBUF_COLOR_FORMAT_B32F_G32F_R32F,
  NVBUF_COLOR_FORMAT_YUV422,
  NVBUF_COLOR_FORMAT_NV21_10LE,
  NVBUF_COLOR_FORMAT_NV21_12LE,
  NVBUF_COLOR_FORMAT_NV12_12LE_2020,
  NVBUF_COLOR_FORMAT_NV16,
  NVBUF_COLOR_FORMAT_NV16_10LE,
  NVBUF_COLOR_FORMAT_NV24,
  NVBUF_COLOR_FORMAT_NV24_10LE,
  NVBUF_COLOR_FORMAT_NV16_ER,
  NVBUF_COLOR_FORMAT_NV24_ER,
  NVBUF_COLOR_FORMAT_NV16_709,
  NVBUF_COLOR_FORMAT_NV24_709,
  NVBUF_COLOR_FORMAT_NV16_709_ER,
  NVBUF_COLOR_FORMAT_NV24_709_ER,
  NVBUF_COLOR_FORMAT_NV24_10LE_709,
  NVBUF_COLOR_FORMAT_NV24_10LE_709_ER,
  NVBUF_COLOR_FORMAT_NV24_10LE_2020,
  NVBUF_COLOR_FORMAT_NV24_12LE_2020,
  NVBUF_COLOR_FORMAT_RGBA_10_10_10_2_709,
  NVBUF_COLOR_FORMAT_RGBA_10_10_10_2_2020,
  NVBUF_COLOR_FORMAT_BGRA_10_10_10_2_709,
  NVBUF_COLOR_FORMAT_BGRA_10_10_10_2_2020,
  NVBUF_COLOR_FORMAT_A32,
  NVBUF_COLOR_FORMAT_UYVP,
  NVBUF_COLOR_FORMAT_UYVP_ER,
  NVBUF_COLOR_FORMAT_YUV444_ER,
  NVBUF_COLOR_FORMAT_YUV444_709,
  NVBUF_COLOR_FORMAT_YUV444_709_ER,
  NVBUF_COLOR_FORMAT_YUV444_2020,
  NVBUF_COLOR_FORMAT_YUV444_10LE,
  NVBUF_COLOR_FORMAT_YUV444_10LE_ER,
  NVBUF_COLOR_FORMAT_YUV444_10LE_709,
  NVBUF_COLOR_FORMAT_YUV444_10LE_709_ER,
  NVBUF_COLOR_FORMAT_YUV444_10LE_2020,
  NVBUF_COLOR_FORMAT_YUV444_12LE,
  NVBUF_COLOR_FORMAT_YUV444_12LE_ER,
  NVBUF_COLOR_FORMAT_YUV444_12LE_709,
  NVBUF_COLOR_FORMAT_YUV444_12LE_709_ER,
  NVBUF_COLOR_FORMAT_YUV444_12LE_2020,
  NVBUF_COLOR_FORMAT_NV12_12LE_ER,
  NVBUF_COLOR_FORMAT_NV12_12LE_709,
  NVBUF_COLOR_FORMAT_NV12_12LE_709_ER,
  NVBUF_COLOR_FORMAT_GRAY8_ER,
  NVBUF_COLOR_FORMAT_UYVY_709,
  NVBUF_COLOR_FORMAT_UYVY_709_ER,
  NVBUF_COLOR_FORMAT_UYVY_2020,
  NVBUF_COLOR_FORMAT_GRAY16_LE,
  NVBUF_COLOR_FORMAT_BGRA64_LE,
  NVBUF_COLOR_FORMAT_NV16_2020,
  NVBUF_COLOR_FORMAT_NV16_10LE_ER,
  NVBUF_COLOR_FORMAT_NV16_10LE_709,
  NVBUF_COLOR_FORMAT_NV16_10LE_709_ER,
  NVBUF_COLOR_FORMAT_NV16_10LE_2020,
  NVBUF_COLOR_FORMAT_NV16_12LE,
  NVBUF_COLOR_FORMAT_NV16_12LE_ER,
  NVBUF_COLOR_FORMAT_NV16_12LE_709,
  NVBUF_COLOR_FORMAT_NV16_12LE_709_ER,
  NVBUF_COLOR_FORMAT_NV16_12LE_2020,
  NVBUF_COLOR_FORMAT_NV24_2020,
  NVBUF_COLOR_FORMAT_NV24_10LE_ER,
  NVBUF_COLOR_FORMAT_NV24_12LE,
  NVBUF_COLOR_FORMAT_NV24_12LE_ER,
  NVBUF_COLOR_FORMAT_NV24_12LE_709,
  NVBUF_COLOR_FORMAT_NV24_12LE_709_ER,
  NVBUF_COLOR_FORMAT_UYVP_709,
  NVBUF_COLOR_FORMAT_UYVP_709_ER,
  NVBUF_COLOR_FORMAT_UYVP_2020,
  NVBUF_COLOR_FORMAT_LAST,
 Defines color formats for NvBufSurface. More...
enum  NvBufSurfaceLayout {
  NVBUF_LAYOUT_PITCH,
  NVBUF_LAYOUT_BLOCK_LINEAR,
  NVBUF_LAYOUT_PITCH,
 Specifies layout formats for NvBufSurface video planes. More...
enum  NvBufSurfaceMemType {
  NVBUF_MEM_DEFAULT,
  NVBUF_MEM_CUDA_PINNED,
  NVBUF_MEM_CUDA_DEVICE,
  NVBUF_MEM_CUDA_UNIFIED,
  NVBUF_MEM_SURFACE_ARRAY,
  NVBUF_MEM_HANDLE,
  NVBUF_MEM_SYSTEM,
  NVBUF_MEM_CUDA_ARRAY,
  NVBUF_MEM_DEFAULT,
  NVBUF_MEM_HANDLE,
  NVBUF_MEM_SYSTEM,
 Specifies memory types for NvBufSurface. More...
enum  NvBufSurfaceDisplayScanFormat {
  NVBUF_DISPLAYSCANFORMAT_PROGRESSIVE,
  NVBUF_DISPLAYSCANFORMAT_INTERLACED,
 Defines display scan formats for NvBufSurface video planes. More...
enum  NvBufSurfaceDriverType {
  NVBUF_DRIVER_TYPE_UNKNOWN = 0,
  NVBUF_DRIVER_TYPE_NVGPU,
  NVBUF_DRIVER_TYPE_RM,
 Defines the type of underlying kernel driver detected for GPU access. More...
enum  NvBufSurfacePlatformType {
  NVBUF_PLATFORM_TYPE_UNKNOWN = 0,
  NVBUF_PLATFORM_TYPE_T186 = 1,
  NVBUF_PLATFORM_TYPE_T194 = 2,
  NVBUF_PLATFORM_TYPE_T210 = 3,
  NVBUF_PLATFORM_TYPE_T234 = 4,
  NVBUF_PLATFORM_TYPE_T256 = 5,
  NVBUF_PLATFORM_TYPE_T264 = 6,
enum  NvBufSurfaceGPUL2SyncCacheOps {
  NVBUF_GPU_L2_CACHE_INVALIDATE = 1,
  NVBUF_GPU_L2_CACHE_FLUSH = 2,
  NVBUF_GPU_L2_CACHE_FLUSH_INVALIDATE = NVBUF_GPU_L2_CACHE_FLUSH | NVBUF_GPU_L2_CACHE_INVALIDATE,
Functions
int NvBufSurfaceCreate (NvBufSurface **surf, uint32_t batchSize, NvBufSurfaceCreateParams *params)
 Allocates a batch of buffers. More...
int NvBufSurfaceAllocate (NvBufSurface **surf, uint32_t batchSize, NvBufSurfaceAllocateParams *paramsext)
 Allocate batch of buffers. More...
int NvBufSurfaceDestroy (NvBufSurface *surf)
 Free the batched buffers previously allocated through NvBufSurfaceCreate. More...
int NvBufSurfaceMap (NvBufSurface *surf, int index, int plane, NvBufSurfaceMemMapFlags type)
 Maps hardware batched buffers to the HOST or CPU address space. More...
int NvBufSurfaceUnMap (NvBufSurface *surf, int index, int plane)
 Unmaps previously mapped buffer(s). More...
int NvBufSurfaceCopy (NvBufSurface *srcSurf, NvBufSurface *dstSurf)
 Copies the content of source batched buffer(s) to destination batched buffer(s). More...
int NvBufSurface2Raw (NvBufSurface *Surf, unsigned int index, unsigned int plane, unsigned int out_width, unsigned int out_height, unsigned char *ptr)
 Copies the NvBufSurface plane memory content to a raw buffer plane for a specific batched buffer. More...
int Raw2NvBufSurface (unsigned char *ptr, unsigned int index, unsigned int plane, unsigned int in_width, unsigned int in_height, NvBufSurface *Surf)
 Copies the raw buffer plane memory content to the NvBufSurface plane memory of a specific batched buffer. More...
int NvBufSurfaceSyncForCpu (NvBufSurface *surf, int index, int plane)
 Syncs the HW memory cache for the CPU. More...
int NvBufSurfaceSyncForDevice (NvBufSurface *surf, int index, int plane)
 Syncs the hardware memory cache for the device. More...
int NvBufSurfaceFromFd (int dmabuf_fd, void **buffer)
 Gets the NvBufSurface from the DMABUF FD. More...
int NvBufSurfaceMemSet (NvBufSurface *surf, int index, int plane, uint8_t value)
 Fills each byte of the buffer(s) in an NvBufSurface with a provided value. More...
int NvBufSurfaceMapEglImage (NvBufSurface *surf, int index)
 Creates an EGLImage from the memory of one or more NvBufSurface buffers. More...
int NvBufSurfaceUnMapEglImage (NvBufSurface *surf, int index)
 Destroys the previously created EGLImage object(s). More...
int NvBufSurfaceImport (NvBufSurface **out_nvbuf_surf, const NvBufSurfaceMapParams *in_params)
 Import parameters received from another process and create hardware buffer. More...
int NvBufSurfaceGetMapParams (const NvBufSurface *surf, int index, NvBufSurfaceMapParams *params)
 Get buffer information to map the buffer in another process. More...
int NvBufSurfaceMapCudaBuffer (NvBufSurface *surf, int index)
 Creates an CUDA buffer from the memory of one or more NvBufSurface buffers. More...
int NvBufSurfaceUnMapCudaBuffer (NvBufSurface *surf, int index)
 Destroys the previously created CUDA buffer. More...
int NvBufSurfaceMapNvmmBuffer (NvBufSurface *surf, int index)
 Creates an NVMM buffer from the memory of one or more NvBufSurface buffers. More...
int NvBufSurfaceUnMapNvmmBuffer (NvBufSurface *surf, int index)
 Destroys the previously created NVMM buffer. More...
int NvBufSurfaceGetDeviceInfo (NvBufSurfaceDeviceInfo *info)
 Retrieves information about the underlying GPU device driver. More...
int NvBufSurfaceSyncGpuL2CacheForDevice (NvBufSurface *surf, int index, NvBufSurfaceGPUL2SyncParams *params)
 Syncs the GPU L2 cache memory for the device. More...
