deepstream::BufferProbe Class Reference
Represent a custom object for the purpose of probing output buffers.
Appropriate interface must be implemented and assigned to an BufferProbe instance for it to work.
BufferProbe instances are not copyable/movable.
Definition at line 58 of file service-maker/includes/buffer_probe.hpp.
Inheritance diagram for deepstream::BufferProbe:
Collaboration diagram for deepstream::BufferProbe:
Data Structures
class  IBatchMetadataObserver
 Readonly interface for handling batch metadata. More...
class  IBatchMetadataOperator
 Read/write interface for handling batch metadata. More...
class  IBufferHandler
 Derived interface for handling buffer itself. More...
class  IBufferObserver
 Readonly interface for handling buffer. More...
class  IBufferOperator
 Read/write interface for handling buffer. More...
class  IHandler
 Root interface required by a BufferProbe instance. More...
class  IMetadataHandler
 Derived interface for handling metadata. More...
Public Member Functions
 BufferProbe (const std::string &name, IHandler *handler)
 Constructor. More...
 BufferProbe (const std::string &name, const char *factory, IHandler *handler)
 Constructor for factory. More...
virtual ~BufferProbe ()
 Destructor. More...
BufferProbeattach (Element *target, Pad pad)
 Attach the BufferProbe instance to an Element instance. More...
ElementgetTarget ()
 Return the pointer to the element where the probe is attached. More...
const PadgetPad ()
 Return the pad from which the probe takes buffers. More...
template<typename T >
bool query (T *&interface) const
 Template class to query the type of the handler inteface. More...
 Destructor. More...
ElementgetTarget ()
const PadgetPad ()
const std::string getName () const
 Return the name assigned during the construction. More...
 operator bool () const noexcept
 Check if the object is void. More...
bool operator== (const Object &other) noexcept
 Check if the two objects are the same. More...
GstObjectgive ()
 Give up the ownership and return the opaque pointer. More...
GstObjectgive ()
GstObjectgetGObject ()
 Return the opaque object pointer. More...
Objecttake (GstObject *object)
 Takes the ownership of a object through the opaque pointer. More...
Objectseize (GstObject *object)
 Seize a opaque object to prevent it from being destroyed somewhere. More...
Objectset (const YAML::Node &params)
 Set the properties from key/value pairs in the yaml format. More...
Objectset (const std::string &name, const Value &value)
template<typename T , typename... Args>
Objectset (const std::string &name, const T &value, const Args &... args)
ObjectgetProperty (const std::string &name, T &value, Args &... args)
 Template for getting multiple properties. More...
std::vector< std::string > listSignals (bool is_action)
 List all the supported signals from the object. More...
bool connectSignal (const std::string &signal_name, SignalHandler &handler)
 Connect a signal handler to the object. More...
void emitSignal (const std::string &signal_name, va_list args)
 Emit a signal. More...
static unsigned long type ()
 Get the unique id associated with this type of BufferProbe. More...
Protected Member Functions
virtual void set_ (const std::string &name, const Value &value)
virtual void set_ (const std::string &name, const YAML::Node &value)
virtual Value get_ (const std::string &name)
Protected Attributes
std::unique_ptr< IHandlermetadata_handler_
 Buffer probe takes the ownership of the handler instance assigned to it during construction. More...
Pad pad_
 the Pad from which the probe takes buffers, More...
Elementtarget_
 weak reference to the target element to which it is attached, More...
std::string param_spec_
 property spec in YAML format More...
std::map< std::string, Object::Valueproperties_
 property map More...
GstObjectobject_
◆ BufferProbe() [1/4]
deepstream::BufferProbe::BufferProbe ( const std::string &  name,
IHandler handler
Constructor.
Create a BufferProbe instance with user implemented handler interface
Parameters
[in]namename of the instance
[in]handlerimplementation of the IHandler interface
◆ BufferProbe() [2/4]
const char *  factory,
IHandler handler
Parameters
◆ ~BufferProbe() [1/2]
virtual deepstream::BufferProbe::~BufferProbe ( )
virtual
Destructor.
◆ BufferProbe() [3/4]
IHandler handler
Constructor.
Parameters
◆ BufferProbe() [4/4]
IHandler handler
Parameters
◆ ~BufferProbe() [2/2]
virtual
Destructor.
Member Function Documentation
◆ attach() [1/2]
BufferProbe& deepstream::BufferProbe::attach ( Element target,
Pad  pad
The probe must be attached to the output.
Parameters
[in]targetpointer to the Element instance
[in]padtarget pad from which the probe takes buffers
◆ attach() [2/2]
Pad  pad
Parameters
◆ connectSignal() [1/2]
bool deepstream::Object::connectSignal ( const std::string &  signal_name,
SignalHandler handler
inherited
Parameters
[in]signal_namename of the signal to be connected
[in]handlerhandler for the signal
◆ connectSignal() [2/2]
inherited
Parameters
◆ emitSignal() [1/2]
void deepstream::Object::emitSignal ( const std::string &  signal_name,
va_list  args
inherited
Emit a signal.
◆ emitSignal() [2/2]
va_list  args
inherited
Emit a signal.
◆ get_() [1/2]
virtual Value deepstream::CustomObject::get_ ( const std::string &  name)
protectedvirtualinherited
Reimplemented from deepstream::Object.
◆ get_() [2/2]
◆ getGObject() [1/2]
GstObject* deepstream::Object::getGObject ( )
inlineinherited
Definition at line 140 of file service-maker/includes/object.hpp.
References deepstream::Object::object_.
◆ getGObject() [2/2]
inlineinherited
Definition at line 140 of file 9.0/service-maker/includes/object.hpp.
◆ getName() [1/2]
const std::string deepstream::Object::getName ( ) const
inherited
◆ getName() [2/2]
inherited
◆ getPad() [1/2]
const Pad& deepstream::BufferProbe::getPad ( )
inline
Definition at line 169 of file service-maker/includes/buffer_probe.hpp.
References pad_.
◆ getPad() [2/2]
inline
Definition at line 169 of file 9.0/service-maker/includes/buffer_probe.hpp.
References pad_.
◆ getProperty() [1/2]
Object& deepstream::Object::getProperty ( const std::string &  name,
T &  value,
Args &...  args
inlineinherited
◆ getProperty() [2/2]
T &  value,
Args &...  args
inlineinherited
Definition at line 171 of file 9.0/service-maker/includes/object.hpp.
References deepstream::Object::get_(), and deepstream::Object::getProperty().
◆ getTarget() [1/2]
Element* deepstream::BufferProbe::getTarget ( )
inline
Definition at line 163 of file 9.0/service-maker/includes/buffer_probe.hpp.
References target_.
◆ getTarget() [2/2]
inline
Definition at line 163 of file service-maker/includes/buffer_probe.hpp.
References target_.
◆ give() [1/2]
GstObject* deepstream::Object::give ( )
inherited
◆ give() [2/2]
inherited
◆ listSignals() [1/2]
std::vector<std::string> deepstream::Object::listSignals ( bool  is_action)
inherited
◆ listSignals() [2/2]
inherited
◆ operator bool() [1/2]
deepstream::Object::operator bool ( ) const
inlineexplicitnoexceptinherited
Definition at line 131 of file 9.0/service-maker/includes/object.hpp.
◆ operator bool() [2/2]
Definition at line 131 of file service-maker/includes/object.hpp.
◆ operator==() [1/2]
bool deepstream::Object::operator== ( const Object other)
inlinenoexceptinherited
Definition at line 134 of file service-maker/includes/object.hpp.
◆ operator==() [2/2]
Definition at line 134 of file 9.0/service-maker/includes/object.hpp.
◆ query() [1/2]
bool deepstream::BufferProbe::query ( T *&  interface) const
inline
Definition at line 176 of file 9.0/service-maker/includes/buffer_probe.hpp.
References metadata_handler_.
◆ query() [2/2]
inline
Definition at line 176 of file service-maker/includes/buffer_probe.hpp.
◆ seize() [1/2]
Object& deepstream::Object::seize ( GstObject object)
inherited
◆ seize() [2/2]
inherited
◆ set() [1/6]
Object& deepstream::Object::set ( const std::string &  name,
const T &  value,
inlineinherited
◆ set() [2/6]
const T &  value,
inlineinherited
◆ set() [3/6]
const Value value
inlineinherited
Definition at line 154 of file service-maker/includes/object.hpp.
References deepstream::Object::set_().
◆ set() [4/6]
const Value value
inlineinherited
Definition at line 154 of file 9.0/service-maker/includes/object.hpp.
◆ set() [5/6]
Object& deepstream::Object::set ( const YAML::Node &  params)
inherited
Referenced by deepstream::Pipeline::add(), and deepstream::Object::set().
◆ set() [6/6]
inherited
◆ set_() [1/4]
virtual void deepstream::CustomObject::set_ ( const std::string &  name,
const Value value
◆ set_() [2/4]
const Value value
◆ set_() [3/4]
const YAML::Node &  value
◆ set_() [4/4]
◆ take() [1/2]
Object& deepstream::Object::take ( GstObject object)
inherited
◆ take() [2/2]
inherited
◆ type() [1/2]
static unsigned long deepstream::BufferProbe::type ( )
static
An unique number is assigned for each BufferProbe class defined within a custom plugin.
◆ type() [2/2]
static
Field Documentation
◆ metadata_handler_
std::unique_ptr< IHandler > deepstream::BufferProbe::metadata_handler_
protected
Definition at line 187 of file service-maker/includes/buffer_probe.hpp.
Referenced by query().
◆ object_
GstObject * deepstream::Object::object_
protectedinherited
◆ pad_
Pad deepstream::BufferProbe::pad_
protected
See also
Pad
Definition at line 189 of file service-maker/includes/buffer_probe.hpp.
Referenced by getPad().
◆ param_spec_
std::string deepstream::CustomObject::param_spec_
protectedinherited
Definition at line 51 of file service-maker/includes/custom_object.hpp.
◆ properties_
std::map< std::string, Object::Value > deepstream::CustomObject::properties_
protectedinherited
property map
Definition at line 53 of file service-maker/includes/custom_object.hpp.
◆ target_
Element * deepstream::BufferProbe::target_
protected
See also
Element
Definition at line 194 of file service-maker/includes/buffer_probe.hpp.
Referenced by getTarget().
