8.0 Release
33 #include "yaml-cpp/yaml.h"
66 Element(
const std::string& type_name, std::string name = std::string());
96 return find_<BufferProbe>(name);
110 const std::string& probe_name,
111 const std::string probe_tip =
114 template<
typename... Args>
116 const std::string& probe_name,
117 const std::string probe_tip =
118 const Args&... args) {
119 addProbe(plugin_name, probe_name, probe_tip);
121 if (probe && (
sizeof...(args) > 0)) {
140 return find_<SignalHandler>(name);
170 const std::string& handler_name,
171 const std::string& signal_names);
174 template<
typename... Args>
176 const std::string& handler_name,
177 const std::string& signal_names,
178 const Args&... args) {
181 if (handler && (
182 handler->set(args...);
201 std::shared_ptr<std::unordered_map<std::string, std::unique_ptr<CustomObject>>>
objects_;
210 [&](
const auto& pair) {
211 return pair.first == name && dynamic_cast<T*>(pair.second.get());
214 if (itr !=
objects_->end())
return dynamic_cast<T*
>(itr->second.get());
bool setState(Element::State state)
Set the Element in particular state.
SignalHandler * getSignalHandler(const std::string &name)
Find the signal handler attached to the element by name.
Base class for all the custom objects.
Element class definition.
Represent a custom object for the purpose of probing output buffers.
struct _GstObject GstObject
BufferProbe * getProbe(const std::string &name)
Find the buffer probe attached to the elmenent by name.
Pipeline class definition.
virtual ~Element()
Destructor.
std::shared_ptr< std::unordered_map< std::string, std::unique_ptr< CustomObject > > > objects_
T * find_(const std::string &name)
Element & connectSignal(const std::string &plugin_name, const std::string &handler_name, const std::string &signal_names, const Args &... args)
Template function for creating and connecting signal with properties.
Element & addProbe(const std::string &plugin_name, const std::string &probe_name, const std::string probe_tip="")
Create and add a buffer probe to the element.
Element & addProbe(const std::string &plugin_name, const std::string &probe_name, const std::string probe_tip="", const Args &... args)
Template function for creating and adding buffer probe with properties.
Element & connectSignal(const std::string &signal_name, SignalHandler *handler)
Connect a signal handler to the element.
Element & add_(CustomObject *object)
Element & link(Element &dst, std::pair< std::string, std::string > hint)
Link two Element instances using hint.
const Pipeline & getPipeline()
