                8.0 Release
   13 #ifndef __NVGSTDS_AUDIO_H__
   14 #define __NVGSTDS_AUDIO_H__
   42   gulong all_bbox_buffer_probe_id;
   43   gulong primary_bbox_buffer_probe_id;
   66   gboolean source_list_enabled;
   67   guint total_num_sources;
   68   guint num_source_sub_bins;
   69   guint num_sink_sub_bins;
   70   guint perf_measurement_interval_sec;
  102     struct timespec timespec_first_frame;
gboolean resume_pipeline(AppCtx *appCtx)
gboolean enable_perf_measurement(NvDsAppPerfStructInt *str, GstPad *sink_bin_pad, guint num_sources, gulong interval_sec, guint num_surfaces_per_frame, perf_callback callback)
REST server application context.
void(* perf_callback)(gpointer ctx, NvDsAppPerfStruct *str)
gboolean parse_config_file(NvDsConfig *config, gchar *cfg_file_path)
Function to read properties from configuration file.
gboolean seek_pipeline(AppCtx *appCtx, glong milliseconds, gboolean seek_is_relative)
GstClockTime gst_ts_first_frame
GMutex lock_stream_rtcp_sr
gboolean create_pipeline(AppCtx *appCtx, perf_callback perf_cb, bbox_generated_callback bgpa_cb)
Create DS Anyalytics Pipeline per the appCtx configurations.
gboolean pause_pipeline(AppCtx *appCtx)
NvDsAppPerfStructInt perf_struct
GstClockTime last_ntp_time
void(* bbox_generated_callback)(AppCtx *appCtx, GstBuffer *buf, NvDsBatchMeta *batch_meta, guint index)
bbox_generated_callback bbox_generated_post_analytics_cb
NvDsInstanceBin instance_bin
void destroy_pipeline(AppCtx *appCtx)
NvDsAudioClassifierBin audio_classifier_bin
struct _GstBuffer GstBuffer
NvDsGieConfig audio_classifier_config
void restart_pipeline(AppCtx *appCtx)
