sources/libs/nvdsinferserver/infer_trtis_server.h File Reference
Header file of wrapper classes for Triton Inference Server server instance, inference request, response.
This file declares the wrapper classes used for inference processing using the Triton Inference Server C-API mode.
Definition in file sources/libs/nvdsinferserver/infer_trtis_server.h.
Data Structures
class  nvdsinferserver::TrtServerRequest
 Wrapper class for Triton inference request. More...
class  nvdsinferserver::TrtServerResponse
 Wrapper class for Triton output parsing. More...
class  nvdsinferserver::TrtServerAllocator
 Wrapper class for Triton server output memory allocator. More...
struct  nvdsinferserver::triton::BackendConfig
 The backend configuration settings. More...
struct  nvdsinferserver::triton::RepoSettings
 Model repository settings for the Triton Inference Server. More...
class  nvdsinferserver::TrtISServer
 Wrapper class for creating Triton Inference Server instance. More...
Namespaces
 nvdsinferserver
Macros
#define TRITON_DEFAULT_MINIMUM_COMPUTE_CAPABILITY   6.0
#define TRITON_DEFAULT_PINNED_MEMORY_BYTES   (1 << 28)
#define TRITON_DEFAULT_BACKEND_DIR   "/opt/tritonserver/backends"
Typedefs
using nvdsinferserver::SharedRequest = std::shared_ptr< TrtServerRequest >
using nvdsinferserver::UniqResponse = std::unique_ptr< TrtServerResponse >
using nvdsinferserver::SharedResponse = std::shared_ptr< TrtServerResponse >
using nvdsinferserver::TritonInferAsyncDone = std::function< void(SharedRequest, UniqResponse)>
◆ TRITON_DEFAULT_BACKEND_DIR
◆ TRITON_DEFAULT_MINIMUM_COMPUTE_CAPABILITY
◆ TRITON_DEFAULT_PINNED_MEMORY_BYTES
