1.4. FP4 Conversion and Data Movement
To use these functions, include the header file cuda_fp4.h in your program.
Enumerations
- __nv_fp4_interpretation_t
Enumerates the possible interpretations of the 4-bit values when referring to them as
fp4types.
Functions
- __host__ __device__ __nv_fp4x2_storage_t __nv_cvt_bfloat16raw2_to_fp4x2(const __nv_bfloat162_raw x, const __nv_fp4_interpretation_t fp4_interpretation, const enum cudaRoundMode rounding)
Converts input vector of two
nv_bfloat16precision numbers packed in__nv_bfloat162_rawxinto a vector of two values offp4type of the requested kind using specified rounding mode and saturating the out-of-range values. - __host__ __device__ __nv_fp4_storage_t __nv_cvt_bfloat16raw_to_fp4(const __nv_bfloat16_raw x, const __nv_fp4_interpretation_t fp4_interpretation, const enum cudaRoundMode rounding)
Converts input
nv_bfloat16precisionxtofp4type of the requested kind using specified rounding mode and saturating the out-of-range values. - __host__ __device__ __nv_fp4x2_storage_t __nv_cvt_double2_to_fp4x2(const double2 x, const __nv_fp4_interpretation_t fp4_interpretation, const enum cudaRoundMode rounding)
doubleprecision numbers packed indouble2xinto a vector of two values offp4type of the requested kind using specified rounding mode and saturating the out-of-range values. - __host__ __device__ __nv_fp4_storage_t __nv_cvt_double_to_fp4(const double x, const __nv_fp4_interpretation_t fp4_interpretation, const enum cudaRoundMode rounding)
Converts input
doubleprecisionxtofp4type of the requested kind using specified rounding mode and saturating the out-of-range values. - __host__ __device__ __nv_fp4x2_storage_t __nv_cvt_float2_to_fp4x2(const float2 x, const __nv_fp4_interpretation_t fp4_interpretation, const enum cudaRoundMode rounding)
singleprecision numbers packed infloat2xinto a vector of two values offp4type of the requested kind using specified rounding mode and saturating the out-of-range values. - __host__ __device__ __nv_fp4_storage_t __nv_cvt_float_to_fp4(const float x, const __nv_fp4_interpretation_t fp4_interpretation, const enum cudaRoundMode rounding)
Converts input
singleprecisionxtofp4type of the requested kind using specified rounding mode and saturating the out-of-range values. - __host__ __device__ __half_raw __nv_cvt_fp4_to_halfraw(const __nv_fp4_storage_t x, const __nv_fp4_interpretation_t fp4_interpretation)
Converts input
fp4xof the specified kind tohalfprecision. - __host__ __device__ __half2_raw __nv_cvt_fp4x2_to_halfraw2(const __nv_fp4x2_storage_t x, const __nv_fp4_interpretation_t fp4_interpretation)
fp4values of the specified kind to a vector of twohalfprecision values packed in__half2_rawstructure. - __host__ __device__ __nv_fp4x2_storage_t __nv_cvt_halfraw2_to_fp4x2(const __half2_raw x, const __nv_fp4_interpretation_t fp4_interpretation, const enum cudaRoundMode rounding)
halfprecision numbers packed in__half2_rawxinto a vector of two values offp4type of the requested kind using specified rounding mode and saturating the out-of-range values. - __host__ __device__ __nv_fp4_storage_t __nv_cvt_halfraw_to_fp4(const __half_raw x, const __nv_fp4_interpretation_t fp4_interpretation, const enum cudaRoundMode rounding)
Converts input
halfprecisionxtofp4type of the requested kind using specified rounding mode and saturating the out-of-range values. - __host__ __device__ __nv_fp4_e2m1::__nv_fp4_e2m1()
Constructor by default.
- __host__ __device__ __nv_fp4_e2m1::__nv_fp4_e2m1(const unsigned long int val)
Constructor from
unsignedlongintdata type, relies on__NV_SATFINITEbehavior for out-of-range values. - __host__ __device__ __nv_fp4_e2m1::__nv_fp4_e2m1(const double f)
Constructor from
doubledata type, relies on__NV_SATFINITEbehavior for out-of-range values andcudaRoundNearestrounding mode. - __host__ __device__ __nv_fp4_e2m1::__nv_fp4_e2m1(const long int val)
Constructor from
longintdata type, relies on__NV_SATFINITEbehavior for out-of-range values. - __host__ __device__ __nv_fp4_e2m1::__nv_fp4_e2m1(const float f)
Constructor from
floatdata type, relies on__NV_SATFINITEbehavior for out-of-range values andcudaRoundNearestrounding mode. - __host__ __device__ __nv_fp4_e2m1::__nv_fp4_e2m1(const int val)
Constructor from
intdata type, relies on__NV_SATFINITEbehavior for out-of-range values. - __host__ __device__ __nv_fp4_e2m1::__nv_fp4_e2m1(const unsigned short int val)
Constructor from
unsignedshortintdata type, relies on__NV_SATFINITEbehavior for out-of-range values. - __host__ __device__ __nv_fp4_e2m1::__nv_fp4_e2m1(const long long int val)
Constructor from
longlongintdata type, relies on__NV_SATFINITEbehavior for out-of-range values. - __host__ __device__ __nv_fp4_e2m1::__nv_fp4_e2m1(const short int val)
Constructor from
shortintdata type. - __host__ __device__ __nv_fp4_e2m1::__nv_fp4_e2m1(const __nv_bfloat16 f)
Constructor from
__nv_bfloat16data type, relies on__NV_SATFINITEbehavior for out-of-range values andcudaRoundNearestrounding mode. - __host__ __device__ __nv_fp4_e2m1::__nv_fp4_e2m1(const unsigned int val)
Constructor from
unsignedintdata type, relies on__NV_SATFINITEbehavior for out-of-range values. - __host__ __device__ __nv_fp4_e2m1::__nv_fp4_e2m1(const unsigned long long int val)
Constructor from
unsignedlonglongintdata type, relies on__NV_SATFINITEbehavior for out-of-range values. - __host__ __device__ __nv_fp4_e2m1::__nv_fp4_e2m1(const __half f)
Constructor from
__halfdata type, relies on__NV_SATFINITEbehavior for out-of-range values andcudaRoundNearestrounding mode. - __host__ __device__ __nv_fp4x2_e2m1::__nv_fp4x2_e2m1(const double2 f)
Constructor from
double2data type, relies on__NV_SATFINITEbehavior for out-of-range values. - __host__ __device__ __nv_fp4x2_e2m1::__nv_fp4x2_e2m1(const __nv_bfloat162 f)
Constructor from
__nv_bfloat162data type, relies on__NV_SATFINITEbehavior for out-of-range values. - __host__ __device__ __nv_fp4x2_e2m1::__nv_fp4x2_e2m1(const __half2 f)
Constructor from
__half2data type, relies on__NV_SATFINITEbehavior for out-of-range values. - __host__ __device__ __nv_fp4x2_e2m1::__nv_fp4x2_e2m1(const float2 f)
Constructor from
float2data type, relies on__NV_SATFINITEbehavior for out-of-range values. - __host__ __device__ __nv_fp4x2_e2m1::__nv_fp4x2_e2m1()
- __NV_SILENCE_DEPRECATION_END __host__ __device__ __nv_fp4x4_e2m1::__nv_fp4x4_e2m1(const double4_16a f)
Constructor from
double4_16avector data type, relies on__NV_SATFINITEbehavior for out-of-range values. - __host__ __device__ __nv_fp4x4_e2m1::__nv_fp4x4_e2m1()
- __host__ __device__ __nv_fp4x4_e2m1::__nv_fp4x4_e2m1(const __nv_bfloat162 flo, const __nv_bfloat162 fhi)
Constructor from a pair of
__nv_bfloat162data type values, relies on__NV_SATFINITEbehavior for out-of-range values. - __host__ __device__ __nv_fp4x4_e2m1::__nv_fp4x4_e2m1(const float4 f)
Constructor from
float4vector data type, relies on__NV_SATFINITEbehavior for out-of-range values. - __host__ __device__ __nv_fp4x4_e2m1::__nv_fp4x4_e2m1(const __half2 flo, const __half2 fhi)
__half2data type values, relies on__NV_SATFINITEbehavior for out-of-range values. - __NV_SILENCE_DEPRECATION_BEGIN __host__ __device__ __nv_fp4x4_e2m1::__nv_fp4x4_e2m1(const double4 f)
Constructor from
double4vector data type, relies on__NV_SATFINITEbehavior for out-of-range values. - __host__ __device__ __nv_fp4x4_e2m1::__nv_fp4x4_e2m1(const double4_32a f)
Constructor from
double4_32avector data type, relies on__NV_SATFINITEbehavior for out-of-range values.
Typedefs
- __nv_fp4_storage_t
8-bit
unsignedintegertype abstraction used forfp4floating-point numbers storage. - __nv_fp4x2_storage_t
8-bit
unsignedintegertype abstraction used for storage of pairs offp4floating-point numbers. - __nv_fp4x4_storage_t
16-bit
unsignedintegertype abstraction used for storage of tetrads offp4floating-point numbers.
1.4.1. Enumerations
1.4.2. Functions
nv_bfloat16precision numbers packed in__nv_bfloat162_rawxinto a vector of two values offp4type of the requested kind using specified rounding mode and saturating the out-of-range values.Converts input vector
xto a vector of twofp4values of the kind specified byfp4_interpretationparameter, using rounding mode specified byroundingparameter. Large out-of-range values saturate to MAXNORM of the same sign.NaNinput values result in positive MAXNORM.- Returns
The
__nv_fp4x2_storage_tvalue holds the result of conversion.
Converts input
nv_bfloat16precisionxtofp4type of the requested kind using specified rounding mode and saturating the out-of-range values.Converts input
xtofp4type of the kind specified byfp4_interpretationparameter, using rounding mode specified byroundingparameter. Large out-of-range values saturate to MAXNORM of the same sign.NaNinput values result in positive MAXNORM.- Returns
The
__nv_fp4_storage_tvalue holds the result of conversion.
doubleprecision numbers packed indouble2xinto a vector of two values offp4type of the requested kind using specified rounding mode and saturating the out-of-range values.Converts input vector
The
Converts input
doubleprecisionxtofp4type of the requested kind using specified rounding mode and saturating the out-of-range values.Converts input
The
singleprecision numbers packed infloat2xinto a vector of two values offp4type of the requested kind using specified rounding mode and saturating the out-of-range values.Converts input vector
The
Converts input
singleprecisionxtofp4type of the requested kind using specified rounding mode and saturating the out-of-range values.Converts input
The
Converts input
fp4xof the specified kind tohalfprecision.Converts input
xoffp4type of the kind specified byfp4_interpretationparameter tohalfprecision.- Returns
The
__half_rawvalue holds the result of conversion.
fp4values of the specified kind to a vector of twohalfprecision values packed in__half2_rawstructure.Converts input vector
xoffp4type of the kind specified byfp4_interpretationparameter to a vector of twohalfprecision values and returns as__half2_rawstructure.- Returns
The
__half2_rawvalue holds the result of conversion.
halfprecision numbers packed in__half2_rawxinto a vector of two values offp4type of the requested kind using specified rounding mode and saturating the out-of-range values.Converts input vector
The
Converts input
halfprecisionxtofp4type of the requested kind using specified rounding mode and saturating the out-of-range values.Converts input
The
1.4.3. Typedefs
typedef __nv_fp8_storage_t __nv_fp4_storage_t
8-bit
typedef __nv_fp8_storage_t __nv_fp4x2_storage_t
8-bit
typedef __nv_fp8x2_storage_t __nv_fp4x4_storage_t
16-bit
