4.5. Half Precision Conversion and Data Movement
To use these functions, include the header file cuda_fp16.h
in your program.
Functions
- __host__ __device__ __half __double2half(const double a)
Converts double number to half precision in round-to-nearest-even mode and returns
half
with converted value.- __host__ __device__ __half2 __float22half2_rn(const float2 a)
Converts both components of
float2
number to half precision in round-to-nearest-even mode and returnshalf2
with converted values.- __host__ __device__ __half __float2half(const float a)
Converts float number to half precision in round-to-nearest-even mode and returns
half
with converted value.- __host__ __device__ __half2 __float2half2_rn(const float a)
Converts input to half precision in round-to-nearest-even mode and populates both halves of
half2
with converted value.- __host__ __device__ __half __float2half_rd(const float a)
Converts float number to half precision in round-down mode and returns
half
with converted value.- __host__ __device__ __half __float2half_rn(const float a)
half
with converted value.- __host__ __device__ __half __float2half_ru(const float a)
Converts float number to half precision in round-up mode and returns
half
with converted value.- __host__ __device__ __half __float2half_rz(const float a)
Converts float number to half precision in round-towards-zero mode and returns
half
with converted value.- __host__ __device__ __half2 __floats2half2_rn(const float a, const float b)
Converts both input floats to half precision in round-to-nearest-even mode and returns
half2
with converted values.- __host__ __device__ float2 __half22float2(const __half2 a)
Converts both halves of
half2
tofloat2
and returns the result.- __host__ __device__ __half2::__half2(const __half2_raw &h2r)
Constructor from
__half2_raw
.- __host__ __device__ constexpr __half2::__half2(const __half &a, const __half &b)
Constructor from two
__half
variables.- __host__ __device__ __half2::__half2(const __half2 &&src)
Move constructor, available for
C++11
and later dialects.- __host__ __device__ __half2::__half2(const __half2 &src)
Copy constructor.
- __half2::__half2()=default
Constructor by default.
- __host__ __device__ __half2::operator __half2_raw() const
Conversion operator to
__half2_raw
.- __host__ __device__ __half2 & __half2::operator=(const __half2_raw &h2r)
Assignment operator from
__half2_raw
.- __host__ __device__ __half2 & __half2::operator=(const __half2 &&src)
Move assignment operator, available for
C++11
and later dialects.- __host__ __device__ __half2 & __half2::operator=(const __half2 &src)
Copy assignment operator.
- __host__ __device__ signed char __half2char_rz(const __half h)
Convert a half to a signed char in round-towards-zero mode.
- __host__ __device__ float __half2float(const __half a)
Converts
half
number to float.- __host__ __device__ __half2 __half2half2(const __half a)
Returns
half2
with both halves equal to the input value.- __device__ int __half2int_rd(const __half h)
Convert a half to a signed integer in round-down mode.
- __device__ int __half2int_rn(const __half h)
Convert a half to a signed integer in round-to-nearest-even mode.
- __device__ int __half2int_ru(const __half h)
Convert a half to a signed integer in round-up mode.
- __host__ __device__ int __half2int_rz(const __half h)
Convert a half to a signed integer in round-towards-zero mode.
- __device__ long long int __half2ll_rd(const __half h)
Convert a half to a signed 64-bit integer in round-down mode.
- __device__ long long int __half2ll_rn(const __half h)
Convert a half to a signed 64-bit integer in round-to-nearest-even mode.
- __device__ long long int __half2ll_ru(const __half h)
Convert a half to a signed 64-bit integer in round-up mode.
- __host__ __device__ long long int __half2ll_rz(const __half h)
Convert a half to a signed 64-bit integer in round-towards-zero mode.
- __device__ short int __half2short_rd(const __half h)
Convert a half to a signed short integer in round-down mode.
- __device__ short int __half2short_rn(const __half h)
Convert a half to a signed short integer in round-to-nearest-even mode.
- __device__ short int __half2short_ru(const __half h)
Convert a half to a signed short integer in round-up mode.
- __host__ __device__ short int __half2short_rz(const __half h)
Convert a half to a signed short integer in round-towards-zero mode.
- __host__ __device__ unsigned char __half2uchar_rz(const __half h)
Convert a half to an unsigned char in round-towards-zero mode.
- __device__ unsigned int __half2uint_rd(const __half h)
Convert a half to an unsigned integer in round-down mode.
- __device__ unsigned int __half2uint_rn(const __half h)
Convert a half to an unsigned integer in round-to-nearest-even mode.
- __device__ unsigned int __half2uint_ru(const __half h)
Convert a half to an unsigned integer in round-up mode.
- __host__ __device__ unsigned int __half2uint_rz(const __half h)
Convert a half to an unsigned integer in round-towards-zero mode.
- __device__ unsigned long long int __half2ull_rd(const __half h)
Convert a half to an unsigned 64-bit integer in round-down mode.
- __device__ unsigned long long int __half2ull_rn(const __half h)
Convert a half to an unsigned 64-bit integer in round-to-nearest-even mode.
- __device__ unsigned long long int __half2ull_ru(const __half h)
Convert a half to an unsigned 64-bit integer in round-up mode.
- __host__ __device__ unsigned long long int __half2ull_rz(const __half h)
Convert a half to an unsigned 64-bit integer in round-towards-zero mode.
- __device__ unsigned short int __half2ushort_rd(const __half h)
Convert a half to an unsigned short integer in round-down mode.
- __device__ unsigned short int __half2ushort_rn(const __half h)
Convert a half to an unsigned short integer in round-to-nearest-even mode.
- __device__ unsigned short int __half2ushort_ru(const __half h)
Convert a half to an unsigned short integer in round-up mode.
- __host__ __device__ unsigned short int __half2ushort_rz(const __half h)
Convert a half to an unsigned short integer in round-towards-zero mode.
- __host__ __device__ constexpr __half::__half(const __half_raw &hr)
Constructor from
__half_raw
.- __host__ __device__ __half::__half(const unsigned short val)
Construct
__half
fromunsigned
short
integer input using default round-to-nearest-even rounding mode.- __host__ __device__ __half::__half(const unsigned int val)
Construct
__half
fromunsigned
int
input using default round-to-nearest-even rounding mode.- __host__ __device__ __half::__half(const short val)
Construct
__half
fromshort
integer input using default round-to-nearest-even rounding mode.- __host__ __device__ __half::__half(const double f)
Construct
__half
fromdouble
input using default round-to-nearest-even rounding mode.- __host__ __device__ __half::__half(const unsigned long val)
Construct
__half
fromunsigned
long
input using default round-to-nearest-even rounding mode.- __host__ __device__ __half::__half(const float f)
Construct
__half
fromfloat
input using default round-to-nearest-even rounding mode.- __host__ __device__ __half::__half(const int val)
Construct
__half
fromint
input using default round-to-nearest-even rounding mode.- __host__ __device__ __half::__half(const long val)
Construct
__half
fromlong
input using default round-to-nearest-even rounding mode.- __host__ __device__ __half::__half(const long long val)
Construct
__half
fromlong
long
input using default round-to-nearest-even rounding mode.- __half::__half()=default
- __host__ __device__ __half::__half(const __nv_bfloat16 f)
Construct
__half
from__nv_bfloat16
input using default round-to-nearest-even rounding mode.- __host__ __device__ __half::__half(const unsigned long long val)
Construct
__half
fromunsigned
long
long
input using default round-to-nearest-even rounding mode.- __host__ __device__ __half::operator __half_raw() const volatile
Type cast to
__half_raw
operator withvolatile
input.- __host__ __device__ __half::operator __half_raw() const
Type cast to
__half_raw
operator.- __host__ __device__ constexpr __half::operator bool() const
bool
data type.- __host__ __device__ __half::operator char() const
Conversion operator to an implementation defined
char
data type.- __host__ __device__ __half::operator float() const
Type cast to
float
operator.- __host__ __device__ __half::operator int() const
int
data type.- __host__ __device__ __half::operator long() const
long
data type.- __host__ __device__ __half::operator long long() const
long
long
data type.- __host__ __device__ __half::operator short() const
short
data type.- __host__ __device__ __half::operator signed char() const
signed
char
data type.- __host__ __device__ __half::operator unsigned char() const
unsigned
char
data type.- __host__ __device__ __half::operator unsigned int() const
unsigned
int
data type.- __host__ __device__ __half::operator unsigned long() const
unsigned
long
data type.- __host__ __device__ __half::operator unsigned long long() const
unsigned
long
long
data type.- __host__ __device__ __half::operator unsigned short() const
unsigned
short
data type.- __host__ __device__ __half & __half::operator=(const float f)
Type cast to
__half
assignment operator fromfloat
input using default round-to-nearest-even rounding mode.- __host__ __device__ volatile __half & __half::operator=(const volatile __half_raw &hr) volatile
volatile
__half_raw
tovolatile
__half
.- __host__ __device__ __half & __half::operator=(const long long val)
Type cast from
long
long
assignment operator, using default round-to-nearest-even rounding mode.- __host__ __device__ volatile __half & __half::operator=(const __half_raw &hr) volatile
__half_raw
tovolatile
__half
.- __host__ __device__ __half & __half::operator=(const unsigned int val)
Type cast from
unsigned
int
assignment operator, using default round-to-nearest-even rounding mode.- __host__ __device__ __half & __half::operator=(const unsigned short val)
Type cast from
unsigned
short
assignment operator, using default round-to-nearest-even rounding mode.- __host__ __device__ __half & __half::operator=(const short val)
Type cast from
short
assignment operator, using default round-to-nearest-even rounding mode.- __host__ __device__ __half & __half::operator=(const double f)
Type cast to
__half
assignment operator fromdouble
input using default round-to-nearest-even rounding mode.- __host__ __device__ __half & __half::operator=(const __half_raw &hr)
__half_raw
.- __host__ __device__ __half & __half::operator=(const unsigned long long val)
Type cast from
unsigned
long
long
assignment operator, using default round-to-nearest-even rounding mode.- __host__ __device__ __half & __half::operator=(const int val)
Type cast from
int
assignment operator, using default round-to-nearest-even rounding mode.- __host__ __device__ short int __half_as_short(const __half h)
Reinterprets bits in a
half
as a signed short integer.- __host__ __device__ unsigned short int __half_as_ushort(const __half h)
half
as an unsigned short integer.- __host__ __device__ __half2 __halves2half2(const __half a, const __half b)
Combines two
half
numbers into onehalf2
number.- __host__ __device__ float __high2float(const __half2 a)
Converts high 16 bits of
half2
to float and returns the result.- __host__ __device__ __half __high2half(const __half2 a)
Returns high 16 bits of
half2
input.- __host__ __device__ __half2 __high2half2(const __half2 a)
Extracts high 16 bits from
half2
input.- __host__ __device__ __half2 __highs2half2(const __half2 a, const __half2 b)
Extracts high 16 bits from each of the two
half2
inputs and combines into onehalf2
number.- __host__ __device__ __half __int2half_rd(const int i)
Convert a signed integer to a half in round-down mode.
- __host__ __device__ __half __int2half_rn(const int i)
Convert a signed integer to a half in round-to-nearest-even mode.
- __host__ __device__ __half __int2half_ru(const int i)
Convert a signed integer to a half in round-up mode.
- __host__ __device__ __half __int2half_rz(const int i)
Convert a signed integer to a half in round-towards-zero mode.
- __device__ __half2 __ldca(const __half2 *const ptr)
Generates a
ld.global.ca
load instruction.- __device__ __half __ldca(const __half *const ptr)
Generates a
ld.global.ca
load instruction.- __device__ __half __ldcg(const __half *const ptr)
Generates a
ld.global.cg
load instruction.- __device__ __half2 __ldcg(const __half2 *const ptr)
Generates a
ld.global.cg
load instruction.- __device__ __half __ldcs(const __half *const ptr)
Generates a
ld.global.cs
load instruction.- __device__ __half2 __ldcs(const __half2 *const ptr)
Generates a
ld.global.cs
load instruction.- __device__ __half2 __ldcv(const __half2 *const ptr)
Generates a
ld.global.cv
load instruction.- __device__ __half __ldcv(const __half *const ptr)
Generates a
ld.global.cv
load instruction.- __device__ __half2 __ldg(const __half2 *const ptr)
Generates a
ld.global.nc
load instruction.- __device__ __half __ldg(const __half *const ptr)
Generates a
ld.global.nc
load instruction.- __device__ __half __ldlu(const __half *const ptr)
Generates a
ld.global.lu
load instruction.- __device__ __half2 __ldlu(const __half2 *const ptr)
Generates a
ld.global.lu
load instruction.- __host__ __device__ __half __ll2half_rd(const long long int i)
Convert a signed 64-bit integer to a half in round-down mode.
- __host__ __device__ __half __ll2half_rn(const long long int i)
Convert a signed 64-bit integer to a half in round-to-nearest-even mode.
- __host__ __device__ __half __ll2half_ru(const long long int i)
Convert a signed 64-bit integer to a half in round-up mode.
- __host__ __device__ __half __ll2half_rz(const long long int i)
Convert a signed 64-bit integer to a half in round-towards-zero mode.
- __host__ __device__ float __low2float(const __half2 a)
Converts low 16 bits of
half2
to float and returns the result.- __host__ __device__ __half __low2half(const __half2 a)
Returns low 16 bits of
half2
input.- __host__ __device__ __half2 __low2half2(const __half2 a)
Extracts low 16 bits from
half2
input.- __host__ __device__ __half2 __lowhigh2highlow(const __half2 a)
Swaps both halves of the
half2
input.- __host__ __device__ __half2 __lows2half2(const __half2 a, const __half2 b)
Extracts low 16 bits from each of the two
half2
number.- __device__ __half __shfl_down_sync(const unsigned int mask, const __half var, const unsigned int delta, const int width=warpSize)
Exchange a variable between threads within a warp.
- __device__ __half2 __shfl_down_sync(const unsigned int mask, const __half2 var, const unsigned int delta, const int width=warpSize)
- __device__ __half2 __shfl_sync(const unsigned int mask, const __half2 var, const int srcLane, const int width=warpSize)
- __device__ __half __shfl_sync(const unsigned int mask, const __half var, const int srcLane, const int width=warpSize)
- __device__ __half2 __shfl_up_sync(const unsigned int mask, const __half2 var, const unsigned int delta, const int width=warpSize)
- __device__ __half __shfl_up_sync(const unsigned int mask, const __half var, const unsigned int delta, const int width=warpSize)
- __device__ __half2 __shfl_xor_sync(const unsigned int mask, const __half2 var, const int laneMask, const int width=warpSize)
- __device__ __half __shfl_xor_sync(const unsigned int mask, const __half var, const int laneMask, const int width=warpSize)
- __host__ __device__ __half __short2half_rd(const short int i)
Convert a signed short integer to a half in round-down mode.
- __host__ __device__ __half __short2half_rn(const short int i)
Convert a signed short integer to a half in round-to-nearest-even mode.
- __host__ __device__ __half __short2half_ru(const short int i)
Convert a signed short integer to a half in round-up mode.
- __host__ __device__ __half __short2half_rz(const short int i)
Convert a signed short integer to a half in round-towards-zero mode.
- __host__ __device__ __half __short_as_half(const short int i)
Reinterprets bits in a signed short integer as a
half
.- __device__ void __stcg(__half2 *const ptr, const __half2 value)
Generates a
st.global.cg
store instruction.- __device__ void __stcg(__half *const ptr, const __half value)
Generates a
st.global.cg
store instruction.- __device__ void __stcs(__half2 *const ptr, const __half2 value)
Generates a
st.global.cs
store instruction.- __device__ void __stcs(__half *const ptr, const __half value)
Generates a
st.global.cs
store instruction.- __device__ void __stwb(__half2 *const ptr, const __half2 value)
Generates a
st.global.wb
store instruction.- __device__ void __stwb(__half *const ptr, const __half value)
Generates a
st.global.wb
store instruction.- __device__ void __stwt(__half *const ptr, const __half value)
Generates a
st.global.wt
store instruction.- __device__ void __stwt(__half2 *const ptr, const __half2 value)
Generates a
st.global.wt
store instruction.- __host__ __device__ __half __uint2half_rd(const unsigned int i)
Convert an unsigned integer to a half in round-down mode.
- __host__ __device__ __half __uint2half_rn(const unsigned int i)
Convert an unsigned integer to a half in round-to-nearest-even mode.
- __host__ __device__ __half __uint2half_ru(const unsigned int i)
Convert an unsigned integer to a half in round-up mode.
- __host__ __device__ __half __uint2half_rz(const unsigned int i)
Convert an unsigned integer to a half in round-towards-zero mode.
- __host__ __device__ __half __ull2half_rd(const unsigned long long int i)
Convert an unsigned 64-bit integer to a half in round-down mode.
- __host__ __device__ __half __ull2half_rn(const unsigned long long int i)
Convert an unsigned 64-bit integer to a half in round-to-nearest-even mode.
- __host__ __device__ __half __ull2half_ru(const unsigned long long int i)
Convert an unsigned 64-bit integer to a half in round-up mode.
- __host__ __device__ __half __ull2half_rz(const unsigned long long int i)
Convert an unsigned 64-bit integer to a half in round-towards-zero mode.
- __host__ __device__ __half __ushort2half_rd(const unsigned short int i)
Convert an unsigned short integer to a half in round-down mode.
- __host__ __device__ __half __ushort2half_rn(const unsigned short int i)
Convert an unsigned short integer to a half in round-to-nearest-even mode.
- __host__ __device__ __half __ushort2half_ru(const unsigned short int i)
Convert an unsigned short integer to a half in round-up mode.
- __host__ __device__ __half __ushort2half_rz(const unsigned short int i)
Convert an unsigned short integer to a half in round-towards-zero mode.
- __host__ __device__ __half __ushort_as_half(const unsigned short int i)
Reinterprets bits in an unsigned short integer as a
half
.- __host__ __device__ __half2 make_half2(const __half x, const __half y)
Vector function, combines two
__half
numbers into one__half2
number.
4.5.1. Functions
half
with converted value.Converts double number
a
to half precision in round-to-nearest-even mode.- Parameters
a – [in] - double. Is only being read.
- Returns
half
a
converted to half precision using round-to-nearest-even mode.__double2half \( (\pm 0)\) returns \( \pm 0 \).
__double2half \( (\pm \infty)\) returns \( \pm \infty \).
__double2half(NaN) returns NaN.
float2
with converted values.Converts both components of
float2
to half precision in round-to-nearest-even mode and combines the results into onehalf2
number. Low 16 bits of the return value correspond toa.x
and high 16 bits of the return value correspond toa.y
.See also
__float2half_rn(float) for further details.
- Parameters
a – [in] - float2. Is only being read.
- Returns
half2
The
half2
which has corresponding halves equal to the convertedfloat2
components.
half
with converted value.Converts float number
a
to half precision in round-to-nearest-even mode.See also
- Parameters
a – [in] - float. Is only being read.
- Returns
half
a
half2
with converted value.Converts input
a
to half precision in round-to-nearest-even mode and populates both halves ofhalf2
with converted value.See also
- Parameters
- Returns
half2
The
half2
value with both halves equal to the converted half precision number.
half
a
to half precision in round-down mode.- Parameters
- Returns
half
a
converted to half precision using round-down mode.__float2half_rd \( (\pm 0)\) returns \( \pm 0 \).
__float2half_rd \( (\pm \infty)\) returns \( \pm \infty \).
__float2half_rd(NaN) returns NaN.
half
a
- Returns
half
a
converted to half precision using round-to-nearest-even mode.__float2half_rn \( (\pm 0)\) returns \( \pm 0 \).
__float2half_rn \( (\pm \infty)\) returns \( \pm \infty \).
__float2half_rn(NaN) returns NaN.
half
a
to half precision in round-up mode.- Parameters
- Returns
half
a
converted to half precision using round-up mode.__float2half_ru \( (\pm 0)\) returns \( \pm 0 \).
__float2half_ru \( (\pm \infty)\) returns \( \pm \infty \).
__float2half_ru(NaN) returns NaN.
half
a
to half precision in round-towards-zero mode.- Parameters
- Returns
half
a
converted to half precision using round-towards-zero mode.__float2half_rz \( (\pm 0)\) returns \( \pm 0 \).
__float2half_rz \( (\pm \infty)\) returns \( \pm \infty \).
__float2half_rz(NaN) returns NaN.
half2
with converted values.Converts both input floats to half precision in round-to-nearest-even mode and combines the results into one
half2
number. Low 16 bits of the return value correspond to the inputa
, high 16 bits correspond to the inputb
.See also
- Parameters
b – [in] - float. Is only being read.
- Returns
half2
The
half2
value with corresponding halves equal to the converted input floats.
half2
tofloat2
and returns the result.Converts both halves of
half2
inputa
tofloat2
and returns the result.See also
__half2float(__half) for further details.
- Parameters
a – [in] - half2. Is only being read.
- Returns
float2
a
converted tofloat2
Convert the half-precision floating-point value
h
to a signed char integer in round-towards-zero mode. NaN inputs are converted to 0.- Parameters
h – [in] - half. Is only being read.
- Returns
signed char
h
converted to a signed char using round-towards-zero mode.__half2char_rz \( (\pm 0)\) returns 0.
__half2char_rz \( (x), x > 127\) returns SCHAR_MAX =
0x7F
.__half2char_rz \( (x), x < -128\) returns SCHAR_MIN =
0x80
.__half2char_rz(NaN) returns 0.
Converts
half
number to float.Converts half number
a
to float.- Parameters
- Returns
float
a
converted to float.__half2float \( (\pm 0)\) returns \( \pm 0 \).
__half2float \( (\pm \infty)\) returns \( \pm \infty \).
__half2float(NaN) returns NaN.
Returns
half2
with both halves equal to the input value.Returns
half2
number with both halves equal to the inputa
half
number.- Parameters
a – [in] - half. Is only being read.
- Returns
half2
The vector which has both its halves equal to the input
a
h
to a signed integer in round-down mode. NaN inputs are converted to 0.- Parameters
- Returns
int
h
converted to a signed integer using round-down mode.__half2int_rd \( (\pm 0)\) returns 0.
__half2int_rd \( (+\infty)\) returns INT_MAX =
0x7FFFFFFF
.__half2int_rd \( (-\infty)\) returns INT_MIN =
0x80000000
.__half2int_rd(NaN) returns 0.
h
to a signed integer in round-to-nearest-even mode. NaN inputs are converted to 0.- Parameters
- Returns
int
h
converted to a signed integer using round-to-nearest-even mode.__half2int_rn \( (\pm 0)\) returns 0.
__half2int_rn \( (+\infty)\) returns INT_MAX =
0x7FFFFFFF
.__half2int_rn \( (-\infty)\) returns INT_MIN =
0x80000000
.__half2int_rn(NaN) returns 0.
h
to a signed integer in round-up mode. NaN inputs are converted to 0.- Parameters
- Returns
int
h
converted to a signed integer using round-up mode.__half2int_ru \( (\pm 0)\) returns 0.
__half2int_ru \( (+\infty)\) returns INT_MAX =
0x7FFFFFFF
.__half2int_ru \( (-\infty)\) returns INT_MIN =
0x80000000
.__half2int_ru(NaN) returns 0.
h
to a signed integer in round-towards-zero mode. NaN inputs are converted to 0.- Parameters
- Returns
int
h
converted to a signed integer using round-towards-zero mode.__half2int_rz \( (\pm 0)\) returns 0.
__half2int_rz \( (+\infty)\) returns INT_MAX =
0x7FFFFFFF
.__half2int_rz \( (-\infty)\) returns INT_MIN =
0x80000000
.__half2int_rz(NaN) returns 0.
h
to a signed 64-bit integer in round-down mode. NaN inputs return a long long int with hex value of0x8000000000000000
.- Parameters
- Returns
long long int
h
converted to a signed 64-bit integer using round-down mode.__half2ll_rd \( (\pm 0)\) returns 0.
__half2ll_rd \( (+\infty)\) returns LLONG_MAX =
0x7FFFFFFFFFFFFFFF
.__half2ll_rd \( (-\infty)\) returns LLONG_MIN =
0x8000000000000000
.__half2ll_rd(NaN) returns
0x8000000000000000
h
to a signed 64-bit integer in round-to-nearest-even mode. NaN inputs return a long long int with hex value of0x8000000000000000
.- Parameters
- Returns
long long int
h
converted to a signed 64-bit integer using round-to-nearest-even mode.__half2ll_rn \( (\pm 0)\) returns 0.
__half2ll_rn \( (+\infty)\) returns LLONG_MAX =
0x7FFFFFFFFFFFFFFF
.__half2ll_rn \( (-\infty)\) returns LLONG_MIN =
0x8000000000000000
.__half2ll_rn(NaN) returns
0x8000000000000000
h
to a signed 64-bit integer in round-up mode. NaN inputs return a long long int with hex value of0x8000000000000000
.- Parameters
- Returns
long long int
h
converted to a signed 64-bit integer using round-up mode.__half2ll_ru \( (\pm 0)\) returns 0.
__half2ll_ru \( (+\infty)\) returns LLONG_MAX =
0x7FFFFFFFFFFFFFFF
.__half2ll_ru \( (-\infty)\) returns LLONG_MIN =
0x8000000000000000
.__half2ll_ru(NaN) returns
0x8000000000000000
h
to a signed 64-bit integer in round-towards-zero mode. NaN inputs return a long long int with hex value of0x8000000000000000
.- Parameters
- Returns
long long int
h
converted to a signed 64-bit integer using round-towards-zero mode.__half2ll_rz \( (\pm 0)\) returns 0.
__half2ll_rz \( (+\infty)\) returns LLONG_MAX =
0x7FFFFFFFFFFFFFFF
.__half2ll_rz \( (-\infty)\) returns LLONG_MIN =
0x8000000000000000
.__half2ll_rz(NaN) returns
0x8000000000000000
h
to a signed short integer in round-down mode. NaN inputs are converted to 0.- Parameters
- Returns
short int
h
converted to a signed short integer using round-down mode.__half2short_rd \( (\pm 0)\) returns 0.
__half2short_rd \( (x), x > 32767\) returns SHRT_MAX =
0x7FFF
.__half2short_rd \( (x), x < -32768\) returns SHRT_MIN =
0x8000
.__half2short_rd(NaN) returns 0.
h
to a signed short integer in round-to-nearest-even mode. NaN inputs are converted to 0.- Parameters
- Returns
short int
h
converted to a signed short integer using round-to-nearest-even mode.__half2short_rn \( (\pm 0)\) returns 0.
__half2short_rn \( (x), x > 32767\) returns SHRT_MAX =
0x7FFF
.__half2short_rn \( (x), x < -32768\) returns SHRT_MIN =
0x8000
.__half2short_rn(NaN) returns 0.
h
to a signed short integer in round-up mode. NaN inputs are converted to 0.- Parameters
- Returns
short int
h
converted to a signed short integer using round-up mode.__half2short_ru \( (\pm 0)\) returns 0.
__half2short_ru \( (x), x > 32767\) returns SHRT_MAX =
0x7FFF
.__half2short_ru \( (x), x < -32768\) returns SHRT_MIN =
0x8000
.__half2short_ru(NaN) returns 0.
h
to a signed short integer in round-towards-zero mode. NaN inputs are converted to 0.- Parameters
- Returns
short int
h
converted to a signed short integer using round-towards-zero mode.__half2short_rz \( (\pm 0)\) returns 0.
__half2short_rz \( (x), x > 32767\) returns SHRT_MAX =
0x7FFF
.__half2short_rz \( (x), x < -32768\) returns SHRT_MIN =
0x8000
.__half2short_rz(NaN) returns 0.
h
to an unsigned char in round-towards-zero mode. NaN inputs are converted to 0.- Parameters
- Returns
unsigned char
h
converted to an unsigned char using round-towards-zero mode.__half2uchar_rz \( (\pm 0)\) returns 0.
__half2uchar_rz \( (x), x > 255\) returns UCHAR_MAX =
0xFF
.__half2uchar_rz \( (x), x < 0.0\) returns 0.
__half2uchar_rz(NaN) returns 0.
h
to an unsigned integer in round-down mode. NaN inputs are converted to 0.- Parameters
- Returns
unsigned int
h
converted to an unsigned integer using round-down mode.__half2uint_rd \( (\pm 0)\) returns 0.
__half2uint_rd \( (+\infty)\) returns UINT_MAX =
0xFFFFFFFF
.__half2uint_rd \( (x), x < 0.0\) returns 0.
__half2uint_rd(NaN) returns 0.
h
to an unsigned integer in round-to-nearest-even mode. NaN inputs are converted to 0.- Parameters
- Returns
unsigned int
h
converted to an unsigned integer using round-to-nearest-even mode.__half2uint_rn \( (\pm 0)\) returns 0.
__half2uint_rn \( (+\infty)\) returns UINT_MAX =
0xFFFFFFFF
.__half2uint_rn \( (x), x < 0.0\) returns 0.
__half2uint_rn(NaN) returns 0.
h
to an unsigned integer in round-up mode. NaN inputs are converted to 0.- Parameters
- Returns
unsigned int
h
converted to an unsigned integer using round-up mode.__half2uint_ru \( (\pm 0)\) returns 0.
__half2uint_ru \( (+\infty)\) returns UINT_MAX =
0xFFFFFFFF
.__half2uint_ru \( (x), x < 0.0\) returns 0.
__half2uint_ru(NaN) returns 0.
h
to an unsigned integer in round-towards-zero mode. NaN inputs are converted to 0.- Parameters
- Returns
unsigned int
h
converted to an unsigned integer using round-towards-zero mode.__half2uint_rz \( (\pm 0)\) returns 0.
__half2uint_rz \( (+\infty)\) returns UINT_MAX =
0xFFFFFFFF
.__half2uint_rz \( (x), x < 0.0\) returns 0.
__half2uint_rz(NaN) returns 0.
h
to an unsigned 64-bit integer in round-down mode. NaN inputs return0x8000000000000000
.- Parameters
- Returns
h
converted to an unsigned 64-bit integer using round-down mode.__half2ull_rd \( (\pm 0)\) returns 0.
__half2ull_rd \( (+\infty)\) returns ULLONG_MAX =
0xFFFFFFFFFFFFFFFF
.__half2ull_rd \( (x), x < 0.0\) returns 0.
__half2ull_rd(NaN) returns
0x8000000000000000
h
to an unsigned 64-bit integer in round-to-nearest-even mode. NaN inputs return0x8000000000000000
.- Parameters
- Returns
h
converted to an unsigned 64-bit integer using round-to-nearest-even mode.__half2ull_rn \( (\pm 0)\) returns 0.
__half2ull_rn \( (+\infty)\) returns ULLONG_MAX =
0xFFFFFFFFFFFFFFFF
.__half2ull_rn \( (x), x < 0.0\) returns 0.
__half2ull_rn(NaN) returns
0x8000000000000000
h
to an unsigned 64-bit integer in round-up mode. NaN inputs return0x8000000000000000
.- Parameters
- Returns
h
converted to an unsigned 64-bit integer using round-up mode.__half2ull_ru \( (\pm 0)\) returns 0.
__half2ull_ru \( (+\infty)\) returns ULLONG_MAX =
0xFFFFFFFFFFFFFFFF
.__half2ull_ru \( (x), x < 0.0\) returns 0.
__half2ull_ru(NaN) returns
0x8000000000000000
h
to an unsigned 64-bit integer in round-towards-zero mode. NaN inputs return0x8000000000000000
.- Parameters
- Returns
h
converted to an unsigned 64-bit integer using round-towards-zero mode.__half2ull_rz \( (\pm 0)\) returns 0.
__half2ull_rz \( (+\infty)\) returns ULLONG_MAX =
0xFFFFFFFFFFFFFFFF
.__half2ull_rz \( (x), x < 0.0\) returns 0.
__half2ull_rz(NaN) returns
0x8000000000000000
h
to an unsigned short integer in round-down mode. NaN inputs are converted to 0.- Parameters
- Returns
unsigned short int
h
converted to an unsigned short integer using round-down mode.__half2ushort_rd \( (\pm 0)\) returns 0.
__half2ushort_rd \( (+\infty)\) returns USHRT_MAX =
0xFFFF
.__half2ushort_rd \( (x), x < 0.0\) returns 0.
__half2ushort_rd(NaN) returns 0.
h
to an unsigned short integer in round-to-nearest-even mode. NaN inputs are converted to 0.- Parameters
- Returns
unsigned short int
h
converted to an unsigned short integer using round-to-nearest-even mode.__half2ushort_rn \( (\pm 0)\) returns 0.
__half2ushort_rn \( (+\infty)\) returns USHRT_MAX =
0xFFFF
.__half2ushort_rn \( (x), x < 0.0\) returns 0.
__half2ushort_rn(NaN) returns 0.
h
to an unsigned short integer in round-up mode. NaN inputs are converted to 0.- Parameters
- Returns
unsigned short int
h
converted to an unsigned short integer using round-up mode.__half2ushort_ru \( (\pm 0)\) returns 0.
__half2ushort_ru \( (+\infty)\) returns USHRT_MAX =
0xFFFF
.__half2ushort_ru \( (x), x < 0.0\) returns 0.
__half2ushort_ru(NaN) returns 0.
h
to an unsigned short integer in round-towards-zero mode. NaN inputs are converted to 0.- Parameters
- Returns
unsigned short int
h
converted to an unsigned short integer using round-towards-zero mode.__half2ushort_rz \( (\pm 0)\) returns 0.
__half2ushort_rz \( (+\infty)\) returns USHRT_MAX =
0xFFFF
.__half2ushort_rz \( (x), x < 0.0\) returns 0.
__half2ushort_rz(NaN) returns 0.
half
as a signed short integer.Reinterprets the bits in the half-precision floating-point number
h
as a signed short integer.- Parameters
- Returns
short int
The reinterpreted value.
half
as an unsigned short integer.Reinterprets the bits in the half-precision floating-point
h
as an unsigned short number.- Parameters
- Returns
unsigned short int
Combines two
half
number.Combines two input
half
numbera
andb
into onehalf2
number. Inputa
is stored in low 16 bits of the return value, inputb
is stored in high 16 bits of the return value.- Parameters
b – [in] - half. Is only being read.
- Returns
half2
The half2 with one half equal to
a
and the other tob
half2
to float and returns the result.Converts high 16 bits of
half2
inputa
to 32-bit floating-point number and returns the result.See also
- Parameters
- Returns
float
The high 16 bits of
a
converted to float.
half2
input.Returns high 16 bits of
half2
inputa
.- Parameters
- Returns
half
The high 16 bits of the input.
half2
input.Extracts high 16 bits from
half2
inputa
and returns a newhalf2
number which has both halves equal to the extracted bits.- Parameters
- Returns
half2
The half2 with both halves equal to the high 16 bits of the input.
half2
number.Extracts high 16 bits from each of the two
half2
number. High 16 bits from inputa
is stored in low 16 bits of the return value, high 16 bits from inputb
b – [in] - half2. Is only being read.
- Returns
half2
The high 16 bits of
a
and ofb
Convert the signed integer value
i
to a half-precision floating-point value in round-down mode.- Parameters
i – [in] - int. Is only being read.
- Returns
half
i
converted to half.
i
to a half-precision floating-point value in round-to-nearest-even mode.- Parameters
- Returns
half
i
converted to half.
i
to a half-precision floating-point value in round-up mode.- Parameters
- Returns
half
i
converted to half.
i
to a half-precision floating-point value in round-towards-zero mode.- Parameters
- Returns
half
i
converted to half.
Generates a
ld.global.ca
load instruction.- Parameters
ptr – [in] - memory location
- Returns
The value pointed by
ptr
Generates a
ld.global.ca
- Returns
ptr
Generates a
ld.global.cg
- Returns
ptr
Generates a
ld.global.cg
- Returns
ptr
Generates a
ld.global.cs
- Returns
ptr
Generates a
ld.global.cs
- Returns
ptr
Generates a
ld.global.cv
- Returns
ptr
Generates a
ld.global.cv
- Returns
ptr
Generates a
ld.global.nc
load instruction.defined(CUDA_ARCH) || (CUDA_ARCH >= 300)
- Parameters
- Returns
ptr
Generates a
ld.global.nc
- Returns
ptr
Generates a
ld.global.lu
- Returns
ptr
Generates a
ld.global.lu
- Returns
ptr
Convert the signed 64-bit integer value
i
i – [in] - long long int. Is only being read.
- Returns
half
i
converted to half.
i
- Returns
half
i
converted to half.
i
- Returns
half
i
converted to half.
i
- Returns
half
i
converted to half.
half2
to float and returns the result.Converts low 16 bits of
half2
inputa
- Parameters
- Returns
float
The low 16 bits of
a
converted to float.
half2
input.Returns low 16 bits of
half2
inputa
.- Parameters
- Returns
half
Returns
half
which contains low 16 bits of the inputa
half2
input.Extracts low 16 bits from
half2
inputa
- Returns
half2
The half2 with both halves equal to the low 16 bits of the input.
half2
input.Swaps both halves of the
half2
input and returns a newhalf2
number with swapped halves.- Parameters
- Returns
half2
a
with its halves being swapped.
half2
number.Extracts low 16 bits from each of the two
half2
number. Low 16 bits from inputa
is stored in low 16 bits of the return value, low 16 bits from inputb
- Returns
half2
The low 16 bits of
a
and ofb
__device__ __half __shfl_down_sync(const unsigned int mask, const __half var, const unsigned int delta, const int width = warpSize)
Copy from a thread with higher ID relative to the caller.
Calculates a source thread ID by adding
delta
to the caller’s thread ID. The value ofvar
held by the resulting thread ID is returned: this has the effect of shiftingvar
down the warp bydelta
threads. If thewidth
is less thanwarpSize
, then each subsection of the warp behaves as a separate entity with a starting logical thread ID of 0. Similarly to the __shfl_up_sync(), the ID number of the source thread will not wrap around the value ofwidth
and the upperdelta
threads will remain unchanged. Threads may only read data from another thread which is actively participating in the__shfl_*sync
() command. If the target thread is inactive, the retrieved value is undefined.Note
For more details about this function, see the Warp Shuffle Functions section in the CUDA C++ Programming Guide.
- Parameters
mask – [in] - unsigned int. Is only being read.
Indicates the threads participating in the call.
A bit, representing the thread’s lane ID, must be set for each participating thread to ensure they are properly converged before the intrinsic is executed by the hardware.
Each calling thread must have its own bit set in the
mask
and all non-exited threads named inmask
must execute the same intrinsic with the samemask
, or the result is undefined.
var – [in] - half. Is only being read.
delta – [in] - unsigned int. Is only being read.
width – [in] - int. Is only being read.
- Returns
Returns the 2-byte word referenced by
var
from the source thread ID ashalf
__device__ __half2 __shfl_down_sync(const unsigned int mask, const __half2 var, const unsigned int delta, const int width = warpSize)
delta
and the upperdelta
- Parameters
mask
var – [in] - half2. Is only being read.
- Returns
Returns the 4-byte word referenced by
var
from the source thread ID ashalf2
__device__ __half2 __shfl_sync(const unsigned int mask, const __half2 var, const int srcLane, const int width = warpSize)
Direct copy from indexed thread.
Returns the value of
var
held by the thread whose ID is given bysrcLane
. If thewidth
, then each subsection of the warp behaves as a separate entity with a starting logical thread ID of 0. IfsrcLane
is outside the range[0:width-1], the value returned corresponds to the value of
var
held by thesrcLane
modulowidth
(i.e. within the same subsection).width
must have a value which is a power of 2; results are undefined ifwidth
is not a power of 2, or is a number greater thanwarpSize
- Parameters
mask
srcLane – [in] - int. Is only being read.
- Returns
var
__device__ __half __shfl_sync(const unsigned int mask, const __half var, const int srcLane, const int width = warpSize)
var
. If thewidth
var
held by thesrcLane
modulowidth
- Parameters
mask
- Returns
var
__device__ __half2 __shfl_up_sync(const unsigned int mask, const __half2 var, const unsigned int delta, const int width = warpSize)
Copy from a thread with lower ID relative to the caller.
Calculates a source thread ID by subtracting
delta
from the caller’s lane ID. The value ofvar
held by the resulting lane ID is returned: in effect,var
is shifted up the warp bydelta
, then each subsection of the warp behaves as a separate entity with a starting logical thread ID of 0. The source thread index will not wrap around the value ofwidth
, so effectively the lowerdelta
threads will be unchanged.width
- Parameters
mask
- Returns
var
__device__ __half __shfl_up_sync(const unsigned int mask, const __half var, const unsigned int delta, const int width = warpSize)
delta
- Parameters
mask
- Returns
var
__device__ __half2 __shfl_xor_sync(const unsigned int mask, const __half2 var, const int laneMask, const int width = warpSize)
Copy from a thread based on bitwise XOR of own thread ID.
Calculates a source thread ID by performing a bitwise XOR of the caller’s thread ID with
laneMask:
the value ofvar
held by the resulting thread ID is returned. If thewidth
, then each group ofwidth
consecutive threads are able to access elements from earlier groups of threads, however if they attempt to access elements from later groups of threads their own value ofvar
will be returned. This mode implements a butterfly addressing pattern such as is used in tree reduction and broadcast. Threads may only read data from another thread which is actively participating in the__shfl_*sync
- Parameters
mask
laneMask – [in] - int. Is only being read.
- Returns
var
__device__ __half __shfl_xor_sync(const unsigned int mask, const __half var, const int laneMask, const int width = warpSize)
laneMask:
the value ofvar
- Parameters
mask
- Returns
var
Convert the signed short integer value
i
i – [in] - short int. Is only being read.
- Returns
half
i
converted to half.
i
- Returns
half
i
converted to half.
i
- Returns
half
i
converted to half.
i
- Returns
half
i
converted to half.
half
.Reinterprets the bits in the signed short integer
i
as a half-precision floating-point number.- Parameters
- Returns
half
Generates a
st.global.cg
store instruction.- Parameters
ptr – [out] - memory location
value – [in] - the value to be stored
Generates a
st.global.cg
Generates a
st.global.cs
Generates a
st.global.cs
Generates a
st.global.wb
Generates a
st.global.wb
Generates a
st.global.wt
Generates a
st.global.wt
Convert the unsigned integer value
i
i – [in] - unsigned int. Is only being read.
- Returns
half
i
converted to half.
i
- Returns
half
i
converted to half.
i
- Returns
half
i
converted to half.
i
- Returns
half
i
converted to half.
Convert the unsigned 64-bit integer value
i
i – [in] - unsigned long long int. Is only being read.
- Returns
half
i
converted to half.
i
- Returns
half
i
converted to half.
i
- Returns
half
i
converted to half.
i
- Returns
half
i
converted to half.
Convert the unsigned short integer value
i
i – [in] - unsigned short int. Is only being read.
- Returns
half
i
converted to half.
i
- Returns
half
i
converted to half.
i
- Returns
half
i
converted to half.
i
- Returns
half
i
converted to half.
half
.Reinterprets the bits in the unsigned short integer
i
- Returns
half
__half
__half
numberx
andy
into one__half2
number. Inputx
is stored in low 16 bits of the return value, inputy
