15.18. __nv_fp8_e4m3
struct __nv_fp8_e4m3
__nv_fp8_e4m3 datatype
This structure implements the datatype for storing
fp8
floating-point numbers ofe4m3
kind: with 1 sign, 4 exponent, 1 implicit and 3 explicit mantissa bits. The encoding doesn’t support Infinity. NaNs are limited to 0x7F and 0xFF values.The structure implements converting constructors and operators.
Public Functions
__nv_fp8_e4m3() = default
Constructor by default.
__host__ __device__ inline explicit __nv_fp8_e4m3(const __half f)
Constructor from
__half
data type, relies on__NV_SATFINITE
behavior for out-of-range values.
__host__ __device__ inline explicit __nv_fp8_e4m3(const __nv_bfloat16 f)
Constructor from
__nv_bfloat16
__host__ __device__ inline explicit __nv_fp8_e4m3(const double f)
Constructor from
double
__host__ __device__ inline explicit __nv_fp8_e4m3(const float f)
Constructor from
float
__host__ __device__ inline explicit __nv_fp8_e4m3(const int val)
Constructor from
int
__host__ __device__ inline explicit __nv_fp8_e4m3(const long int val)
Constructor from
long
int
__host__ __device__ inline explicit __nv_fp8_e4m3(const long long int val)
Constructor from
long
long
int
__host__ __device__ inline explicit __nv_fp8_e4m3(const short int val)
Constructor from
short
int
__host__ __device__ inline explicit __nv_fp8_e4m3(const unsigned int val)
Constructor from
unsigned
int
__host__ __device__ inline explicit __nv_fp8_e4m3(const unsigned long int val)
Constructor from
unsigned
long
int
__host__ __device__ inline explicit __nv_fp8_e4m3(const unsigned long long int val)
Constructor from
unsigned
long
long
int
__host__ __device__ inline explicit __nv_fp8_e4m3(const unsigned short int val)
Constructor from
unsigned
short
int
__host__ __device__ inline explicit operator __half() const
Conversion operator to
__half
data type.
__host__ __device__ inline explicit operator __nv_bfloat16() const
__nv_bfloat16
data type.
__host__ __device__ inline explicit operator bool() const
bool
data type.+0 and -0 inputs convert to
false
. Non-zero inputs convert totrue
__host__ __device__ inline explicit operator char() const
Conversion operator to an implementation defined
char
data type.Detects signedness of the
char
type and proceeds accordingly, see further details in signed and unsigned char operators.Clamps inputs to the output range.
NaN
inputs convert tozero
__host__ __device__ inline explicit operator double() const
double
data type.
__host__ __device__ inline explicit operator float() const
float
data type.
__host__ __device__ inline explicit operator int() const
int
data type.NaN
__host__ __device__ inline explicit operator long int() const
long
int
data type.Clamps too large inputs to the output range.
NaN
if output type is 32-bit.NaN
inputs convert to0x8000000000000000ULL
if output type is 64-bit.
__host__ __device__ inline explicit operator long long int() const
long
long
int
data type.NaN
inputs convert to0x8000000000000000LL
__host__ __device__ inline explicit operator short int() const
short
int
data type.NaN
__host__ __device__ inline explicit operator signed char() const
signed
char
NaN
__host__ __device__ inline explicit operator unsigned char() const
unsigned
char
data type.Clamps negative and too large inputs to the output range.
NaN
__host__ __device__ inline explicit operator unsigned int() const
unsigned
int
data type.Clamps negative inputs to zero.
NaN
__host__ __device__ inline explicit operator unsigned long int() const
unsigned
long
int
NaN
__host__ __device__ inline explicit operator unsigned long long int() const
unsigned
long
long
int
NaN
__host__ __device__ inline explicit operator unsigned short int() const
unsigned
short
int
NaN
Public Members
__nv_fp8_storage_t __x
Storage variable contains the
fp8
floating-point data.
