9.0/sources/libs/nvdsinferserver/infer_trtis_context.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2019-2022 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
22 #ifndef __INFER_TRTIS_CONTEXT_H__
23 #define __INFER_TRTIS_CONTEXT_H__
24
25 #include "infer_common.h"
26 #include "infer_cuda_context.h"
27
28 namespace nvdsinferserver {
29
33 class InferTrtISContext : public InferCudaContext {
34 public:
39
43  ~InferTrtISContext() override;
44
48  NvDsInferStatus deinit() override;
49
54  {
55  assert(m_MainStream);
56  return m_MainStream;
57  }
58
59 private:
67  NvDsInferStatus createNNBackend(const ic::BackendParams& params,
69
79  NvDsInferStatus allocateResource(
80  const ic::InferenceConfig& config) override;
81
90  NvDsInferStatus specifyBackendDims(
91  BaseBackend* be, const std::string& model, const ic::BackendParams& params);
92
101  NvDsInferStatus getConfigInOutMap(
102  const ic::BackendParams& params,
103  std::unordered_map<std::string, InferDims>& inputs,
104  std::set<std::string>& outputs);
105
106 private:
110  SharedCuStream m_MainStream;
114  TrtISBackend* m_Backend{nullptr};
115 };
116
117 } // namespace nvdsinferserver
118
119 #endif
nvdsinferserver
Definition: sources/gst-plugins/gst-nvinferserver/gstnvinferserver_impl.h:64
nvdsinferserver::InferTrtISContext::InferTrtISContext
InferTrtISContext()
Constructor, default.
infer_common.h
nvdsinferserver::InferBaseContext::maxBatchSize
int maxBatchSize() const
Definition: sources/libs/nvdsinferserver/infer_base_context.h:99
nvdsinferserver::TrtISBackend
Triton backend processing class.
Definition: sources/libs/nvdsinferserver/infer_trtis_backend.h:39
nvdsinferserver::InferTrtISContext::mainStream
SharedCuStream & mainStream() override
Get the main processing CUDA event.
Definition: 9.0/sources/libs/nvdsinferserver/infer_trtis_context.h:53
nvdsinferserver::SharedCuStream
std::shared_ptr< CudaStream > SharedCuStream
Cuda based pointers.
Definition: sources/libs/nvdsinferserver/infer_common.h:84
nvdsinferserver::InferTrtISContext::~InferTrtISContext
Destructor, default.
nvdsinferserver::UniqBackend
std::unique_ptr< BaseBackend > UniqBackend
Definition: sources/libs/nvdsinferserver/infer_base_backend.h:212
nvdsinferserver::InferBaseContext::backend
BaseBackend * backend()
Definition: sources/libs/nvdsinferserver/infer_base_context.h:101
nvdsinferserver::InferBaseContext::config
const ic::InferenceConfig & config() const
Definition: sources/libs/nvdsinferserver/infer_base_context.h:98
nvdsinferserver::InferTrtISContext::deinit
Synchronize on the CUDA stream and call InferCudaContext::deinit().
Header file for the CUDA inference context class.
nvdsinferserver::BaseBackend
Base class of inference backend processing.
Definition: sources/libs/nvdsinferserver/infer_base_backend.h:40
NvDsInferStatus
NvDsInferStatus
Definition: sources/includes/nvdsinfer.h:226
