sources/includes/nvdsinfer_custom_impl.h File Reference
Defines specification for Custom Method Implementations for custom models
Description: This file defines the API that implements custom methods required by the GStreamer Gst-nvinfer plugin to infer using custom models.
All custom functionality must be implemented in an independent shared library. The library is dynamically loaded (using dlopen()) by the plugin. It implements custom methods which are called as required. The custom library can be specified in the Gst-nvinfer configuration file by the custom-lib-name property.
Custom Detector Output Parsing Function
This section describes the custom bounding box parsing function for custom detector models.
The custom parsing function should be of the type NvDsInferParseCustomFunc. The custom parsing function can be specified in the Gst-nvinfer configuration file by the properties parse-bbox-func-name (name of the parsing function) and custom-lib-name. `parse-func must be set to 0.
The Gst-nvinfer plugin loads the library and looks for the custom parsing function symbol. The function is called after each inference call is executed.
You can call the macro CHECK_CUSTOM_PARSE_FUNC_PROTOTYPE() after defining the function to validate the function definition.
TensorRT Plugin Factory interface for DeepStream
For the Caffe model, the library must implement NvDsInferPluginFactoryCaffeGet(). During model parsing, "nvinfer" looks for that function' symbol in the custom library. If symbol is found, the plugin calls that function to get a pointer to the PluginFactory instance required for parsing.
If the IPluginFactory is needed during deserialization of CUDA engines, the library must implement NvDsInferPluginFactoryRuntimeGet().
Each Get function has a corresponding Destroy function which is called, if defined, when the returned PluginFactory is to be destroyed.
A library that implements this interface must use the same function names as the header file. Gst-nvinfer dynamically loads the library and looks for the same symbol names.
Input layer initialization
By default, Gst-nvinfer works with networks having only one input layer for video frames. If a network has more than one input layer, the custom library can implement the NvDsInferInitializeInputLayers interface for initializing the other input layers. Gst-nvinfer assumes that the other input layers have static input information, and hence this method is called only once before the first inference.
Interface for building Custom Networks
The "nvinfer" plugin supports two interfaces for to create and build custom networks not directly supported by nvinfer.
  • IModelParser / NvDsInferCreateModelParser interface
  • NvDsInferEngineCreateCustomFunc interface
In case of IModelParser / NvDsInferCreateModelParser interface, the custom library must derive and implement IModelParser, an interface to parse the custom networks and build the TensorRT network (nvinfer1::INetworkDefinition). The "nvinfer" plugin will then use this TensorRT network to build the inference engine. The plugin will look for the symbol "NvDsInferCreateModelParser" in the library and call the function to get an instance of the model parser implementation from the library.
Alternatively, you can use the custom engine creation function to build networks that are not natively supported by nvinfer. The function must be of the type NvDsInferEngineCreateCustomFunc. You can specify it in the nvinfer element configuration file using the property engine-create-func-name (name of the engine creation function) in addition to custom-lib-name.
The nvinfer plugin loads the custom library dynamically and looks for the engine creation symbol. The function is called only once during initialization of the nvinfer plugin. The function must build and return the CudaEngine interface using the supplied nvinfer1::IBuilder instance. The builder instance is already configured with properties like MaxBatchSize, MaxWorkspaceSize, INT8/FP16 precision parameters, etc. The builder instance is managed by nvinfer, and the function may not destroy it.
You can call the macro CHECK_CUSTOM_ENGINE_CREATE_FUNC_PROTOTYPE() after the function definition to validate the function definition.
Definition in file sources/includes/nvdsinfer_custom_impl.h.
Data Structures
struct  NvDsInferParseDetectionParams
 Holds the detection parameters required for parsing objects. More...
Macros
#define CHECK_CUSTOM_PARSE_FUNC_PROTOTYPE(customParseFunc)
 Validates a custom parser function definition. More...
#define CHECK_CUSTOM_INSTANCE_MASK_PARSE_FUNC_PROTOTYPE(customParseFunc)
#define CHECK_CUSTOM_CLASSIFIER_PARSE_FUNC_PROTOTYPE(customParseFunc)
 Validates the classifier custom parser function definition. More...
#define CHECK_CUSTOM_SEM_SEGMENTATION_PARSE_FUNC_PROTOTYPE(customParseFunc)
 Validates the semantic segmentation custom parser function definition. More...
#define CHECK_CUSTOM_ENGINE_CREATE_FUNC_PROTOTYPE(customEngineCreateFunc)
 A macro that validates a custom engine creator function definition. More...
Typedefs
typedef bool(* NvDsInferParseCustomFunc) (std::vector< NvDsInferLayerInfo > const &outputLayersInfo, NvDsInferNetworkInfo const &networkInfo, NvDsInferParseDetectionParams const &detectionParams, std::vector< NvDsInferObjectDetectionInfo > &objectList)
 Type definition for the custom bounding box parsing function. More...
typedef bool(* NvDsInferInstanceMaskParseCustomFunc) (std::vector< NvDsInferLayerInfo > const &outputLayersInfo, NvDsInferNetworkInfo const &networkInfo, NvDsInferParseDetectionParams const &detectionParams, std::vector< NvDsInferInstanceMaskInfo > &objectList)
 Type definition for the custom bounding box and instance mask parsing function. More...
typedef bool(* NvDsInferClassiferParseCustomFunc) (std::vector< NvDsInferLayerInfo > const &outputLayersInfo, NvDsInferNetworkInfo const &networkInfo, float classifierThreshold, std::vector< NvDsInferAttribute > &attrList, std::string &descString)
 Type definition for the custom classifier output parsing function. More...
typedef bool(* NvDsInferSemSegmentationParseCustomFunc) (std::vector< NvDsInferLayerInfo > const &outputLayersInfo, NvDsInferNetworkInfo const &networkInfo, float segmentationThreshold, unsigned int numClasses, int *classificationMap, float *&classProbabilityMap)
 Type definition for the custom semantic segmentation output parsing function. More...
typedef struct _NvDsInferContextInitParams NvDsInferContextInitParams
typedef bool(* NvDsInferEngineCreateCustomFunc) (nvinfer1::IBuilder *const builder, nvinfer1::IBuilderConfig *const builderConfig, const NvDsInferContextInitParams *const initParams, nvinfer1::DataType dataType, nvinfer1::ICudaEngine *&cudaEngine)
 Type definition for functions that build and return a CudaEngine for custom models. More...
Functions
bool NvDsInferPluginFactoryRuntimeGet (nvinfer1::IPluginFactory *&pluginFactory)
 Returns a new instance of a Plugin Factory interface to be used during parsing deserialization of CUDA engines. More...
void NvDsInferPluginFactoryRuntimeDestroy (nvinfer1::IPluginFactory *pluginFactory)
 Destroys a Plugin Factory instance created by NvDsInferPluginFactoryRuntimeGet(). More...
bool NvDsInferInitializeInputLayers (std::vector< NvDsInferLayerInfo > const &inputLayersInfo, NvDsInferNetworkInfo const &networkInfo, unsigned int maxBatchSize)
 Initializes the input layers for inference. More...
bool NvDsInferCudaEngineGet (nvinfer1::IBuilder *builder, NvDsInferContextInitParams *initParams, nvinfer1::DataType dataType, nvinfer1::ICudaEngine *&cudaEngine) __attribute__((deprecated("Use 'engine-create-func-name' config parameter instead")))
 The NvDsInferCudaEngineGet interface has been deprecated and has been replaced by NvDsInferEngineCreateCustomFunc function. More...
IModelParser * NvDsInferCreateModelParser (const NvDsInferContextInitParams *initParams)
 Create a customized neural network parser for user-defined models. More...
◆ CHECK_CUSTOM_CLASSIFIER_PARSE_FUNC_PROTOTYPE
#define CHECK_CUSTOM_CLASSIFIER_PARSE_FUNC_PROTOTYPE (   customParseFunc)
Value:
static void checkFunc_ ## customParseFunc (NvDsInferClassiferParseCustomFunc func = customParseFunc) \
{ checkFunc_ ## customParseFunc (); }; \
extern "C" bool customParseFunc (std::vector<NvDsInferLayerInfo> const &outputLayersInfo, \
NvDsInferNetworkInfo const &networkInfo, \
float classifierThreshold, \
std::vector<NvDsInferAttribute> &attrList, \
std::string &descString);
Must be called after defining the function.
Definition at line 281 of file sources/includes/nvdsinfer_custom_impl.h.
◆ CHECK_CUSTOM_ENGINE_CREATE_FUNC_PROTOTYPE
#define CHECK_CUSTOM_ENGINE_CREATE_FUNC_PROTOTYPE (   customEngineCreateFunc)
Value:
static void checkFunc_ ## customEngineCreateFunc (NvDsInferEngineCreateCustomFunc = customEngineCreateFunc) \
{ checkFunc_ ## customEngineCreateFunc(); }; \
extern "C" bool customEngineCreateFunc ( \
nvinfer1::IBuilder * const builder, \
nvinfer1::IBuilderConfig * const builderConfig, \
const NvDsInferContextInitParams * const initParams, \
nvinfer1::DataType dataType, \
nvinfer1::ICudaEngine *& cudaEngine);
Call this macro after the function is defined.
Definition at line 372 of file sources/includes/nvdsinfer_custom_impl.h.
◆ CHECK_CUSTOM_INSTANCE_MASK_PARSE_FUNC_PROTOTYPE
#define CHECK_CUSTOM_INSTANCE_MASK_PARSE_FUNC_PROTOTYPE (   customParseFunc)
Value:
static void checkFunc_ ## customParseFunc (NvDsInferInstanceMaskParseCustomFunc func = customParseFunc) \
NvDsInferParseDetectionParams const &detectionParams, \
std::vector<NvDsInferInstanceMaskInfo> &objectList);
Definition at line 249 of file sources/includes/nvdsinfer_custom_impl.h.
◆ CHECK_CUSTOM_PARSE_FUNC_PROTOTYPE
#define CHECK_CUSTOM_PARSE_FUNC_PROTOTYPE (   customParseFunc)
Value:
static void checkFunc_ ## customParseFunc (NvDsInferParseCustomFunc func = customParseFunc) \
std::vector<NvDsInferObjectDetectionInfo> &objectList);
Definition at line 220 of file sources/includes/nvdsinfer_custom_impl.h.
◆ CHECK_CUSTOM_SEM_SEGMENTATION_PARSE_FUNC_PROTOTYPE
#define CHECK_CUSTOM_SEM_SEGMENTATION_PARSE_FUNC_PROTOTYPE (   customParseFunc)
Value:
static void checkFunc_ ## customParseFunc (NvDsInferSemSegmentationParseCustomFunc func = customParseFunc) \
float segmentationThreshold, \
unsigned int numClasses, \
int* classificationMap, \
float*& classProbabilityMap);
Definition at line 319 of file sources/includes/nvdsinfer_custom_impl.h.
Typedef Documentation
◆ NvDsInferClassiferParseCustomFunc
Parameters
[in]outputLayersInfoA vector containing information on the output layers of the model.
[in]networkInfoNetwork information.
[in]classifierThresholdClassification confidence threshold.
[out]attrListA reference to a vector in which the function is to add the parsed attributes.
[out]descStringA reference to a string object in which the function may place a description string.
Definition at line 270 of file sources/includes/nvdsinfer_custom_impl.h.
◆ NvDsInferContextInitParams
◆ NvDsInferEngineCreateCustomFunc
Deprecated:
The NvDsInferCudaEngineGet interface is replaced by NvDsInferEngineCreateCustomFunc().
The implementation of this interface must build the nvinfer1::ICudaEngine instance using nvinfer1::IBuilder instance builder. The builder instance is managed by the caller; the implementation must not destroy it.
Properties like MaxBatchSize, MaxWorkspaceSize, INT8/FP16 precision parameters, and DLA parameters (if applicable) are set on the builder and builderConfig before it is passed to the interface. The corresponding Get functions of the nvinfer1::IBuilder and nvinfer1::IBuilderConfig interface can be used to get the property values.
The implementation must make sure not to reduce the MaxBatchSize of the returned CudaEngine.
Parameters
[in]builderAn nvinfer1::IBuilder instance.
[in]builderConfigA nvinfer1::IBuilderConfig instance.
[in]initParamsA pointer to the structure to be used for initializing the NvDsInferContext instance.
[in]dataTypeData precision.
[out]cudaEngineA pointer to a location where the function is to store a reference to the nvinfer1::ICudaEngine instance it has built.
Returns
True if the engine build was successful, or false otherwise.
Definition at line 362 of file sources/includes/nvdsinfer_custom_impl.h.
◆ NvDsInferInstanceMaskParseCustomFunc
Parameters
[in]detectionParamsDetection parameters required for parsing objects.
[out]objectListA reference to a vector in which the function is to add parsed objects and instance mask.
Definition at line 239 of file sources/includes/nvdsinfer_custom_impl.h.
◆ NvDsInferParseCustomFunc
Parameters
[out]objectListA reference to a vector in which the function is to add parsed objects.
Definition at line 210 of file sources/includes/nvdsinfer_custom_impl.h.
◆ NvDsInferSemSegmentationParseCustomFunc
Parameters
[in]segmentationThresholdSegmentation confidence threshold.
[in]numClassesNumber of classes in the segmentation output.
[out]classificationMapPointer to interger array of image height * width where the semantic segmentation output index is stored after parsing.
[out]classProbabilityMapA reference to a pointer which can be used to point to the probability map of the segmentation output. Can be set to null.
Definition at line 307 of file sources/includes/nvdsinfer_custom_impl.h.
Function Documentation
◆ NvDsInferCreateModelParser()
IModelParser* NvDsInferCreateModelParser ( const NvDsInferContextInitParams initParams)
User need to implement a new IModelParser class with initParams referring to any model path and/or customNetworkConfigFilePath.
Parameters
[in]initParamswith model paths or config files.
Returns
Instance of IModelParser implementation.
◆ NvDsInferCudaEngineGet()
bool NvDsInferCudaEngineGet ( nvinfer1::IBuilder *  builder,
NvDsInferContextInitParams initParams,
◆ NvDsInferInitializeInputLayers()
bool NvDsInferInitializeInputLayers ( std::vector< NvDsInferLayerInfo > const &  inputLayersInfo,
NvDsInferNetworkInfo const &  networkInfo,
This function is called only once during before the first inference call.
Parameters
[in]inputLayersInfoA reference to a vector containing information on the input layers of the model. This does not contain the NvDsInferLayerInfo structure for the layer for video frame input.
[in]networkInfoA reference to anetwork information structure.
[in]maxBatchSizeThe maximum batch size for inference. The input layer buffers are allocated for this batch size.
Returns
True if input layers are initialized successfully, or false otherwise.
◆ NvDsInferPluginFactoryRuntimeDestroy()
void NvDsInferPluginFactoryRuntimeDestroy ( nvinfer1::IPluginFactory *  pluginFactory)
Parameters
[in]pluginFactoryA pointer to the Plugin Factory instance returned by NvDsInferPluginFactoryRuntimeGet().
◆ NvDsInferPluginFactoryRuntimeGet()
bool NvDsInferPluginFactoryRuntimeGet ( nvinfer1::IPluginFactory *&  pluginFactory)
Parameters
[out]pluginFactoryA reference to nvinfer1::IPluginFactory* in which the function is to place a pointer to the instance.
Returns
True if the Plugin Factory was created successfully, or false otherwise.
bool(* NvDsInferClassiferParseCustomFunc)(std::vector< NvDsInferLayerInfo > const &outputLayersInfo, NvDsInferNetworkInfo const &networkInfo, float classifierThreshold, std::vector< NvDsInferAttribute > &attrList, std::string &descString)
Definition: sources/includes/nvdsinfer_custom_impl.h:270
bool(* NvDsInferSemSegmentationParseCustomFunc)(std::vector< NvDsInferLayerInfo > const &outputLayersInfo, NvDsInferNetworkInfo const &networkInfo, float segmentationThreshold, unsigned int numClasses, int *classificationMap, float *&classProbabilityMap)
Definition: sources/includes/nvdsinfer_custom_impl.h:307
ds3d::DataType
DataType
Definition: sources/includes/ds3d/common/idatatype.h:77
bool(* NvDsInferInstanceMaskParseCustomFunc)(std::vector< NvDsInferLayerInfo > const &outputLayersInfo, NvDsInferNetworkInfo const &networkInfo, NvDsInferParseDetectionParams const &detectionParams, std::vector< NvDsInferInstanceMaskInfo > &objectList)
Definition: sources/includes/nvdsinfer_custom_impl.h:239
Definition: sources/includes/nvdsinfer_custom_impl.h:179
Definition: sources/includes/nvdsinfer.h:114
bool(* NvDsInferEngineCreateCustomFunc)(nvinfer1::IBuilder *const builder, nvinfer1::IBuilderConfig *const builderConfig, const NvDsInferContextInitParams *const initParams, nvinfer1::DataType dataType, nvinfer1::ICudaEngine *&cudaEngine)
Definition: sources/includes/nvdsinfer_custom_impl.h:362
Holds the initialization parameters required for the NvDsInferContext interface.
Definition: sources/includes/nvdsinfer_context.h:241
bool(* NvDsInferParseCustomFunc)(std::vector< NvDsInferLayerInfo > const &outputLayersInfo, NvDsInferNetworkInfo const &networkInfo, NvDsInferParseDetectionParams const &detectionParams, std::vector< NvDsInferObjectDetectionInfo > &objectList)
Definition: sources/includes/nvdsinfer_custom_impl.h:210
