5.8. Bfloat162 Math Functions
To use these functions, include the header file cuda_bf16.h in your program.
Functions
- __device__ __nv_bfloat162 h2ceil(const __nv_bfloat162 h)
Calculate
nv_bfloat162vector ceiling of the input argument. - __device__ __nv_bfloat162 h2cos(const __nv_bfloat162 a)
Calculates
nv_bfloat162vector cosine in round-to-nearest-even mode. - __device__ __nv_bfloat162 h2exp(const __nv_bfloat162 a)
Calculates
nv_bfloat162vector exponential function in round-to-nearest-even mode. - __device__ __nv_bfloat162 h2exp10(const __nv_bfloat162 a)
Calculates
nv_bfloat162vector decimal exponential function in round-to-nearest-even mode. - __device__ __nv_bfloat162 h2exp2(const __nv_bfloat162 a)
Calculates
nv_bfloat162vector binary exponential function in round-to-nearest-even mode. - __device__ __nv_bfloat162 h2floor(const __nv_bfloat162 h)
Calculate the largest integer less than or equal to
h. - __device__ __nv_bfloat162 h2log(const __nv_bfloat162 a)
Calculates
nv_bfloat162vector natural logarithm in round-to-nearest-even mode. - __device__ __nv_bfloat162 h2log10(const __nv_bfloat162 a)
Calculates
nv_bfloat162vector decimal logarithm in round-to-nearest-even mode. - __device__ __nv_bfloat162 h2log2(const __nv_bfloat162 a)
Calculates
nv_bfloat162vector binary logarithm in round-to-nearest-even mode. - __device__ __nv_bfloat162 h2rcp(const __nv_bfloat162 a)
Calculates
nv_bfloat162vector reciprocal in round-to-nearest-even mode. - __device__ __nv_bfloat162 h2rint(const __nv_bfloat162 h)
Round input to nearest integer value in nv_bfloat16 floating-point number.
- __device__ __nv_bfloat162 h2rsqrt(const __nv_bfloat162 a)
Calculates
nv_bfloat162vector reciprocal square root in round-to-nearest-even mode. - __device__ __nv_bfloat162 h2sin(const __nv_bfloat162 a)
Calculates
nv_bfloat162vector sine in round-to-nearest-even mode. - __device__ __nv_bfloat162 h2sqrt(const __nv_bfloat162 a)
Calculates
nv_bfloat162vector square root in round-to-nearest-even mode. - __device__ __nv_bfloat162 h2tanh(const __nv_bfloat162 a)
Calculates
nv_bfloat162vector hyperbolic tangent function in round-to-nearest-even mode. - __device__ __nv_bfloat162 h2tanh_approx(const __nv_bfloat162 a)
Calculates
nv_bfloat162vector approximate hyperbolic tangent function. - __device__ __nv_bfloat162 h2trunc(const __nv_bfloat162 h)
Truncate
nv_bfloat162vector input argument to the integral part.
5.8.1. Functions
Calculate
nv_bfloat162vector ceiling of the input argument.For each component of vector
hcompute the smallest integer value not less thanh.- Parameters
h – [in] - nv_bfloat162. Is only being read.
- Returns
nv_bfloat162
The vector of smallest integers not less than
h.
Calculates
nv_bfloat162vector cosine in round-to-nearest-even mode.Calculates
nv_bfloat162cosine of input vectorain round-to-nearest-even mode.NOTE: this function’s implementation calls cosf(float) function and is exposed to compiler optimizations. Specifically,
--use_fast_mathflag changes cosf(float) into an intrinsic __cosf(float), which has less accurate numeric behavior.- Parameters
a – [in] - nv_bfloat162. Is only being read.
- Returns
nv_bfloat162
The elementwise cosine on vector
a.
Calculates
nv_bfloat162vector exponential function in round-to-nearest-even mode.Calculates
nv_bfloat162exponential function of input vectorain round-to-nearest-even mode.- Parameters
- Returns
nv_bfloat162
The elementwise exponential function on vector
a.
Calculates
nv_bfloat162vector decimal exponential function in round-to-nearest-even mode.Calculates
nv_bfloat162decimal exponential function of input vectorain round-to-nearest-even mode.- Parameters
- Returns
nv_bfloat162
The elementwise decimal exponential function on vector
a.
Calculates
nv_bfloat162vector binary exponential function in round-to-nearest-even mode.Calculates
nv_bfloat162binary exponential function of input vectorain round-to-nearest-even mode.- Parameters
- Returns
nv_bfloat162
The elementwise binary exponential function on vector
a.
h.For each component of vector
hcalculate the largest integer value which is less than or equal toh.- Parameters
- Returns
nv_bfloat162
The vector of largest integers which is less than or equal to
h.
Calculates
nv_bfloat162vector natural logarithm in round-to-nearest-even mode.Calculates
nv_bfloat162natural logarithm of input vectorain round-to-nearest-even mode.- Parameters
- Returns
nv_bfloat162
The elementwise natural logarithm on vector
a.
Calculates
nv_bfloat162vector decimal logarithm in round-to-nearest-even mode.Calculates
nv_bfloat162decimal logarithm of input vectorain round-to-nearest-even mode.- Parameters
- Returns
nv_bfloat162
The elementwise decimal logarithm on vector
a.
Calculates
nv_bfloat162vector binary logarithm in round-to-nearest-even mode.Calculates
nv_bfloat162binary logarithm of input vectorain round-to-nearest-even mode.- Parameters
- Returns
nv_bfloat162
The elementwise binary logarithm on vector
a.
Calculates
nv_bfloat162vector reciprocal in round-to-nearest-even mode.Calculates
nv_bfloat162reciprocal of input vectorain round-to-nearest-even mode.- Parameters
- Returns
nv_bfloat162
The elementwise reciprocal on vector
a.
Round each component of
nv_bfloat162vectorhto the nearest integer value in nv_bfloat16 floating-point format, with halfway cases rounded to the nearest even integer value.- Parameters
- Returns
nv_bfloat162
The vector of rounded integer values.
Calculates
nv_bfloat162vector reciprocal square root in round-to-nearest-even mode.Calculates
nv_bfloat162reciprocal square root of input vectorain round-to-nearest-even mode.- Parameters
- Returns
nv_bfloat162
The elementwise reciprocal square root on vector
a.
Calculates
nv_bfloat162vector sine in round-to-nearest-even mode.Calculates
nv_bfloat162sine of input vectorain round-to-nearest-even mode.NOTE: this function’s implementation calls sinf(float) function and is exposed to compiler optimizations. Specifically,
--use_fast_mathflag changes sinf(float) into an intrinsic __sinf(float), which has less accurate numeric behavior.- Parameters
- Returns
nv_bfloat162
The elementwise sine on vector
a.
Calculates
nv_bfloat162vector square root in round-to-nearest-even mode.Calculates
nv_bfloat162square root of input vectorain round-to-nearest-even mode.- Parameters
- Returns
nv_bfloat162
The elementwise square root on vector
a.
Calculates
nv_bfloat162vector hyperbolic tangent function in round-to-nearest-even mode.Calculates
nv_bfloat162hyperbolic tangent function of input vectorain round-to-nearest-even mode.See also
htanh(__nv_bfloat16) for further details.
- Parameters
- Returns
nv_bfloat162
The elementwise hyperbolic tangent function on vector
a.
Calculates
nv_bfloat162vector approximate hyperbolic tangent function.Calculates
nv_bfloat162approximate hyperbolic tangent function of input vectora. This operation uses HW acceleration on devices of compute capability 9.x and higher.See also
htanh_approx(__nv_bfloat16) for further details.
- Parameters
- Returns
nv_bfloat162
The elementwise approximate hyperbolic tangent function on vector
a.
Truncate
nv_bfloat162vector input argument to the integral part.Round each component of vector
hto the nearest integer value that does not exceedhin magnitude.- Parameters
- Returns
nv_bfloat162
The truncated
h.
