5.3. Bfloat16 Comparison Functions
To use these functions, include the header file cuda_bf16.h
in your program.
Functions
- __host__ __device__ bool __heq(const __nv_bfloat16 a, const __nv_bfloat16 b)
Performs
nv_bfloat16
if-equal comparison.- __host__ __device__ bool __hequ(const __nv_bfloat16 a, const __nv_bfloat16 b)
Performs
nv_bfloat16
unordered if-equal comparison.- __host__ __device__ bool __hge(const __nv_bfloat16 a, const __nv_bfloat16 b)
Performs
nv_bfloat16
greater-equal comparison.- __host__ __device__ bool __hgeu(const __nv_bfloat16 a, const __nv_bfloat16 b)
Performs
nv_bfloat16
unordered greater-equal comparison.- __host__ __device__ bool __hgt(const __nv_bfloat16 a, const __nv_bfloat16 b)
Performs
nv_bfloat16
greater-than comparison.- __host__ __device__ bool __hgtu(const __nv_bfloat16 a, const __nv_bfloat16 b)
Performs
nv_bfloat16
unordered greater-than comparison.- __host__ __device__ int __hisinf(const __nv_bfloat16 a)
Checks if the input
nv_bfloat16
number is infinite.- __host__ __device__ bool __hisnan(const __nv_bfloat16 a)
Determine whether
nv_bfloat16
argument is a NaN.- __host__ __device__ bool __hle(const __nv_bfloat16 a, const __nv_bfloat16 b)
Performs
nv_bfloat16
less-equal comparison.- __host__ __device__ bool __hleu(const __nv_bfloat16 a, const __nv_bfloat16 b)
Performs
nv_bfloat16
unordered less-equal comparison.- __host__ __device__ bool __hlt(const __nv_bfloat16 a, const __nv_bfloat16 b)
Performs
nv_bfloat16
less-than comparison.- __host__ __device__ bool __hltu(const __nv_bfloat16 a, const __nv_bfloat16 b)
Performs
nv_bfloat16
unordered less-than comparison.- __host__ __device__ __nv_bfloat16 __hmax(const __nv_bfloat16 a, const __nv_bfloat16 b)
Calculates
nv_bfloat16
maximum of two input values.- __host__ __device__ __nv_bfloat16 __hmax_nan(const __nv_bfloat16 a, const __nv_bfloat16 b)
Calculates
nv_bfloat16
maximum of two input values, NaNs pass through.- __host__ __device__ __nv_bfloat16 __hmin(const __nv_bfloat16 a, const __nv_bfloat16 b)
Calculates
nv_bfloat16
minimum of two input values.- __host__ __device__ __nv_bfloat16 __hmin_nan(const __nv_bfloat16 a, const __nv_bfloat16 b)
Calculates
nv_bfloat16
minimum of two input values, NaNs pass through.- __host__ __device__ bool __hne(const __nv_bfloat16 a, const __nv_bfloat16 b)
Performs
nv_bfloat16
not-equal comparison.- __host__ __device__ bool __hneu(const __nv_bfloat16 a, const __nv_bfloat16 b)
Performs
nv_bfloat16
unordered not-equal comparison.- __host__ __device__ bool operator!=(const __nv_bfloat16 &lh, const __nv_bfloat16 &rh)
Performs
nv_bfloat16
unordered compare not-equal operation.- __host__ __device__ bool operator<(const __nv_bfloat16 &lh, const __nv_bfloat16 &rh)
Performs
nv_bfloat16
ordered less-than compare operation.- __host__ __device__ bool operator<=(const __nv_bfloat16 &lh, const __nv_bfloat16 &rh)
Performs
nv_bfloat16
ordered less-or-equal compare operation.- __host__ __device__ bool operator==(const __nv_bfloat16 &lh, const __nv_bfloat16 &rh)
Performs
nv_bfloat16
ordered compare equal operation.- __host__ __device__ bool operator>(const __nv_bfloat16 &lh, const __nv_bfloat16 &rh)
Performs
nv_bfloat16
ordered greater-than compare operation.- __host__ __device__ bool operator>=(const __nv_bfloat16 &lh, const __nv_bfloat16 &rh)
Performs
nv_bfloat16
ordered greater-or-equal compare operation.
5.3.1. Functions
Performs
nv_bfloat16
if-equal comparison.Performs
nv_bfloat16
if-equal comparison of inputsa
andb
. NaN inputs generate false results.- Parameters
a – [in] - nv_bfloat16. Is only being read.
b – [in] - nv_bfloat16. Is only being read.
- Returns
bool
The boolean result of if-equal comparison of
a
andb
Performs
nv_bfloat16
unordered if-equal comparison.Performs
nv_bfloat16
andb
. NaN inputs generate true results.- Parameters
- Returns
bool
The boolean result of unordered if-equal comparison of
a
andb
Performs
nv_bfloat16
greater-equal comparison.Performs
nv_bfloat16
greater-equal comparison of inputsa
andb
- Returns
bool
The boolean result of greater-equal comparison of
a
andb
Performs
nv_bfloat16
unordered greater-equal comparison.Performs
nv_bfloat16
andb
- Returns
bool
The boolean result of unordered greater-equal comparison of
a
andb
Performs
nv_bfloat16
greater-than comparison.Performs
nv_bfloat16
greater-than comparison of inputsa
andb
- Returns
bool
The boolean result of greater-than comparison of
a
andb
Performs
nv_bfloat16
unordered greater-than comparison.Performs
nv_bfloat16
andb
- Returns
bool
The boolean result of unordered greater-than comparison of
a
andb
Checks if the input
nv_bfloat16
number is infinite.Checks if the input
nv_bfloat16
numbera
is infinite.- Parameters
- Returns
int
-1 if
a
is equal to negative infinity,1 if
a
is equal to positive infinity,0 otherwise.
Determine whether
nv_bfloat16
argument is a NaN.Determine whether
nv_bfloat16
valuea
is a NaN.- Parameters
- Returns
bool
true if argument is NaN.
Performs
nv_bfloat16
less-equal comparison.Performs
nv_bfloat16
less-equal comparison of inputsa
andb
- Returns
bool
The boolean result of less-equal comparison of
a
andb
Performs
nv_bfloat16
unordered less-equal comparison.Performs
nv_bfloat16
andb
- Returns
bool
The boolean result of unordered less-equal comparison of
a
andb
Performs
nv_bfloat16
less-than comparison.Performs
nv_bfloat16
less-than comparison of inputsa
andb
- Returns
bool
The boolean result of less-than comparison of
a
andb
Performs
nv_bfloat16
unordered less-than comparison.Performs
nv_bfloat16
andb
- Returns
bool
The boolean result of unordered less-than comparison of
a
andb
Calculates
nv_bfloat16
maximum of two input values.Calculates
nv_bfloat16
max(a
,b
) defined as (a
>b
) ?a
:b
.If either of inputs is NaN, the other input is returned.
If both inputs are NaNs, then canonical NaN is returned.
If values of both inputs are 0.0, then +0.0 > -0.0
- Parameters
- Returns
nv_bfloat16
Calculates
nv_bfloat16
maximum of two input values, NaNs pass through.Calculates
nv_bfloat16
max(a
,b
) defined as (a
>b
) ?a
:b
.If either of inputs is NaN, then canonical NaN is returned.
- Parameters
- Returns
nv_bfloat16
Calculates
nv_bfloat16
minimum of two input values.Calculates
nv_bfloat16
min(a
,b
) defined as (a
<b
) ?a
:b
- Parameters
- Returns
nv_bfloat16
Calculates
nv_bfloat16
minimum of two input values, NaNs pass through.Calculates
nv_bfloat16
min(a
,b
) defined as (a
<b
) ?a
:b
- Parameters
- Returns
nv_bfloat16
Performs
nv_bfloat16
not-equal comparison.Performs
nv_bfloat16
not-equal comparison of inputsa
andb
- Returns
bool
The boolean result of not-equal comparison of
a
andb
Performs
nv_bfloat16
unordered not-equal comparison.Performs
nv_bfloat16
andb
- Returns
bool
The boolean result of unordered not-equal comparison of
a
andb
Performs
nv_bfloat16
unordered compare not-equal operation.See also __hneu(__nv_bfloat16, __nv_bfloat16)
Performs
nv_bfloat16
ordered less-than compare operation.See also __hlt(__nv_bfloat16, __nv_bfloat16)
Performs
nv_bfloat16
ordered less-or-equal compare operation.See also __hle(__nv_bfloat16, __nv_bfloat16)
Performs
nv_bfloat16
ordered compare equal operation.See also __heq(__nv_bfloat16, __nv_bfloat16)
Performs
nv_bfloat16
ordered greater-than compare operation.See also __hgt(__nv_bfloat16, __nv_bfloat16)
Performs
nv_bfloat16
ordered greater-or-equal compare operation.See also __hge(__nv_bfloat16, __nv_bfloat16)
