Logo
6.2 Release
DeepStream Getting Started
  • Welcome to the DeepStream Documentation
    • NVIDIA DeepStream Overview
      • DeepStream Graph Architecture
      • DeepStream reference app
      • Getting started with building apps
      • DeepStream in Python
  • Readme First
    • Additional Resources
      • Documentation
      • Forums
  • Quickstart Guide
    • Jetson Setup [ Not applicable for NVAIE customers ]
      • Install Jetson SDK components
      • Install Dependencies
        • Install librdkafka (to enable Kafka protocol adaptor for message broker)
      • Install latest NVIDIA BSP packages
      • Install the DeepStream SDK
      • Run deepstream-app (the reference application)
        • Boost the clocks
      • Run precompiled sample applications
    • dGPU Setup for Ubuntu
      • Remove all previous DeepStream installations
        • Install CUDA Toolkit 11.8
        • Install NVIDIA driver 525.60.13
        • Install TensorRT 8.5.1.7
      • Run the deepstream-app (the reference application)
    • dGPU Setup for RedHat Enterprise Linux (RHEL)
    • Running without an X server
    • Platform and OS Compatibility
    • DeepStream Triton Inference Server Usage Guidelines
      • dGPU
      • Jetson
    • Using DLA for inference
      • Separate processes
      • Single process
  • Docker Containers
    • A Docker Container for dGPU
    • A Docker Container for Jetson
    • Creating custom DeepStream docker for dGPU using DeepStreamSDK package
    • Creating custom DeepStream docker for Jetson using DeepStreamSDK package
    • Recommended Minimal L4T Setup necessary to run the new docker images on Jetson
DeepStream Samples
  • C/C++ Sample Apps Source Details
    • Plugin and Library Source Details
  • Python Sample Apps and Bindings Source Details
    • Sample Application Source Details
    • Python Bindings and Application Development
      • Prerequisites
      • Running Sample Applications
      • Pipeline Construction
    • MetaData Access
      • Memory Management
      • Allocations
      • String Access
        • Setting String Fields
        • Reading String Fields
      • Casting
      • Callback Function Registration
      • Optimizations and Utilities
      • Image Data Access
  • DeepStream Reference Application - deepstream-app
    • Application Architecture
    • Reference Application Configuration
      • Expected Output for the DeepStream Reference Application (deepstream-app)
    • Configuration Groups
      • Application Group
      • Tiled-display Group
      • Source Group
      • Source-list and source-attr-all Groups
      • Streammux Group
      • Preprocess Group
      • Primary GIE and Secondary GIE Group
      • Tracker Group
      • Message Converter Group
      • Message Consumer Group
      • OSD Group
      • Sink Group
      • Tests Group
      • NvDs-analytics Group
    • Application Tuning for DeepStream SDK
      • Performance Optimization
        • DeepStream best practices
        • Jetson optimization
        • Triton
        • Inference Throughput
      • Reducing Spurious Detections
  • DeepStream Reference Application - deepstream-test5 app
    • IoT Protocols supported and cloud configuration
    • Message consumer
    • Smart Record - Event based recording
    • OTA model update
      • Using the OTA functionality
    • Sensor Provisioning Support over REST API (Runtime sensor add/remove capability)
  • DeepStream Reference Application - deepstream-audio app
    • DeepStream Audio Reference Application Architecture and Sample Graphs
  • DeepStream Reference Application - deepstream-nmos app
    • Using Easy-NMOS for NMOS Registry and Controller
  • DeepStream Reference Application on GitHub
    • Use case applications
    • AI models with DeepStream
    • DeepStream features sample
  • Sample Configurations and Streams
    • Contents of the package
      • Scripts included along with package
  • Implementing a Custom GStreamer Plugin with OpenCV Integration Example
    • Description of the Sample Plugin: gst-dsexample
      • GstBaseTransfrom Class Functions
      • Other supporting functions
    • Enabling and configuring the sample plugin
    • Using the sample plugin in a custom application/pipeline
    • Implementing Custom Logic Within the Sample Plugin
    • Adding NVTX APIs for sample plugin
    • Accessing NvBufSurface memory in OpenCV
TAO toolkit Integration with DeepStream
  • TAO Toolkit Integration with DeepStream
    • Pre-trained models
Tutorials and How-to's
  • Custom YOLO Model in the DeepStream YOLO App
    • How to Use the Custom YOLO Model
      • Set up the sample
  • NvMultiObjectTracker Parameter Tuning Guide
    • Accuracy-Performance Tradeoffs
      • Visual Feature Types and Feature Sizes
      • Detection Interval
      • Video Frame Size for Tracker
    • Robustness
      • Target Creation Policy
      • Target Termination Policy
    • State Estimation
      • Kalman Filter
    • Data Association
    • DCF Core Tuning
      • DCF Filter Learning
  • DeepStream 3D Custom Manual
    • DS3D Application Examples
    • ds3d::dataloader - Load Custom Lib for Data Capture
      • Load and Manage Dataloader
      • Dataloader in User Application
      • Implement a Custom Dataloader
    • ds3d::datafilter- Loads Custom Lib for Input and Output Processing
      • Load And Manage Datafilter
      • Datafilter in User Application
      • Implement a Custom Datafilter
    • ds3d::datarender - Loads Custom Lib for Data Rendering
      • Load And Manage Datarender
      • Datarender in User Application
      • Implement a Custom Datarender
    • DS3D GuardDataMap Buffer Management
      • DS3D Data Map Read
      • DS3D Data Map Write
    • Custom Libs Configuration Specifications
      • Components Common Configuration Specifications
      • libnvds_3d_dataloader_realsense Configuration Specifications
      • libnvds_3d_depth2point_datafilter Configuration Specifications
      • libnvds_3d_gl_datarender Configuration Specifications
      • libnvds_3d_depth_datasource Depth file source Specific Configuration Specifications
DeepStream Performance
  • Performance
    • TAO Pre-trained models
    • DeepStream reference model and tracker
    • Configuration File Settings for Performance Measurement
      • Data center GPU - GA100
        • System Configuration
        • Application Configuration
      • Data center GPU - T4
      • Jetson
        • Jetson AGX Xavier
        • Jetson NX
        • Jetson Orin
DeepStream Custom Model
  • Using a Custom Model with DeepStream
    • Custom Model Implementation Interface
    • Custom Output Parsing
    • IPlugin Implementation
      • How to Use IPluginCreator
      • How to Use IPluginFactory
        • For Caffe Files
        • For Uff Files
        • During Deserialization
    • Input Layer Initialization
    • CUDA Engine Creation for Custom Models
    • IModelParser Interface for Custom Model Parsing
DeepStream Key Features
  • Smart Video Record
    • Smart Video Record Module APIs
    • Smart Video Record Configurations
  • IoT
    • Secure Edge-to-Cloud Messaging
      • 2-way TLS Authentication
        • Overview of Steps
        • TLS Version
        • Key generation
        • Certificate Signing
        • Choice of Cipher
        • Configure TLS options in Kafka config file for DeepStream
      • SASL/Plain
        • Overview of Steps
        • TLS Configuration
        • Credential Storage
        • Choosing Between 2-way TLS and SASL/Plain
      • Impact on performance
    • Bidirectional Messaging
      • Edge-to-Cloud
      • Cloud-to-Edge
      • NvMsgbroker Library
    • Autoreconnect feature
  • On the Fly Model Update
    • Assumptions
  • NTP Timestamp in DeepStream
  • AV Sync in DeepStream
    • Setup for RTMP/RTSP Input streams for testing
      • RTMP Server Setup
        • Command to simulate 2 RTMP streams using ffmpeg
      • RTSP Server Setup
    • AVSync Reference Pipelines
      • Pipelines with existing nvstreammux component
        • RTMP_IN -> RTMP_OUT
        • FILE_IN->RTSP_OUT
        • FILE_IN->RTMP_OUT
        • RTMP_IN->FILE_OUT
        • RTSP_IN->FILE_OUT
        • FILE_IN->FILE_OUT
        • RTSP_IN->RTSP_OUT
        • RTMP_IN->RTSP_OUT
      • Reference AVSync + ASR (Automatic Speech Recognition) Pipelines with existing nvstreammux
        • RTMP_IN->RTMP_OUT
        • RTSP_IN->RTMP_OUT
        • FILE_IN->RTMP_OUT
      • Pipelines with New nvstreammux component
        • RTMP_IN->RTMP_OUT
        • RTSP_IN->RTMP_OUT
        • FILE_IN->RTSP_OUT
        • FILE_IN->RTMP_OUT
        • RTMP_IN->FILE_OUT
        • RTSP_IN->FILE_OUT
        • FILE_IN->FILE_OUT
        • RTSP_IN->RTSP_OUT
        • RTMP_IN->RTSP_OUT
      • Reference AVSync + ASR Pipelines (with new nvstreammux)
        • RTMP_IN->RTMP_OUT
        • RTSP_IN->RTMP_OUT
        • FILE_IN->RTMP_OUT
      • Gst-pipeline with audiomuxer (single source, without ASR + new nvstreammux)
        • RTMP_IN->FILE_OUT
  • DeepStream With REST API Sever (Alpha)
    • Features
    • nvds_rest_server
    • deepstream-server-app
    • Sensor provisioning with deepstream-test5-app
    • How to add custom REST API support
      • REST API endpoints implementation
      • Handler Function Implementation Details
      • Custom event generation
      • Callback implementation for REST API endpoints
    • Limitations
  • DeepStream 3D Action Recognition App
    • Getting Started
      • Prerequisites
      • Run 3D Action Recognition Examples
      • Run 2D Action Recognition Examples
    • DeepStream 3D Action Recognition App Configuration Specifications
      • deepstream-3d-action-recognition [action-recognition] group settings
      • Custom sequence preprocess lib user settings [user-configs] for gst-nvdspreprocess
      • Custom lib and `gst-nvdspreprocess` Settings for Action Recognition
    • Build Custom sequence preprocess lib and application From Source
  • DeepStream 3D Depth Camera App
    • Prerequisites
    • Depth Color Capture to 2D Rendering Pipeline Overview
    • Depth Color Capture to 3D Point Cloud Processing and Rendering
    • Getting Started
      • Run RealSense Camera for Depth Capture and 2D Rendering Examples
    • Run 3D Depth Capture, Point Cloud filter, and 3D Points Rendering Examples
    • DeepStream 3D Depth Camera App Configuration Specifications
      • deepstream-3d-depth-camera [ds3d::userapp] group settings
      • DS3D Custom Components Configuration Specifications
        • Build application From Source
  • DeepStream Lidar Inference App (Alpha)
    • Prerequisites
    • Lidar Point Cloud to 3D Point Cloud Processing and Rendering
    • Getting Started
    • Run Lidar Point Cloud Data File reader, Point Cloud Inferencing filter, and Point Cloud 3D rendering and data dump Examples
    • DeepStream Lidar Inference App Configuration Specifications
      • deepstream-lidar-inference-app [ds3d::userapp] group settings
  • Networked Media Open Specifications (NMOS) in DeepStream
    • Supported Specifications
    • Prerequisites
    • NvDsNmos API
  • Gst-nvdspostprocess in DeepStream
    • Detector models
    • Primary Classification model
    • Mask RCNN Model
    • Custom Parsing functions
  • DeepStream Can Orientation App
    • Getting Started
      • Prerequisites
      • Run DeepStream Can Orientation Examples
    • DeepStream Can Orientation App Configuration Specifications
      • deepstream-can-orientation-app settings
      • Custom lib libnvds_vpicanmatch.so Settings for Can Template Matching
DeepStream Application Migration
  • Application Migration to DeepStream 6.2 from DeepStream 6.1
    • Running DeepStream 6.1 compiled Apps in DeepStream 6.2
    • Compiling DeepStream 6.1 Apps in DeepStream 6.2
DeepStream Plugin Guide
  • GStreamer Plugin Overview
  • MetaData in the DeepStream SDK
    • NvDsBatchMeta: Basic Metadata Structure
    • User/Custom Metadata Addition inside NvDsBatchMeta
    • Adding Custom Meta in Gst Plugins Upstream from Gst-nvstreammux
      • Adding metadata to the plugin before Gst-nvstreammux
      • New metadata fields
  • Gst-nvdspreprocess (Alpha)
    • Inputs and Outputs
    • Features
    • Custom library Interfaces
    • Gst-nvdspreprocess File Configuration Specifications
    • Gst Properties
    • Sample pipelines
  • Gst-nvinfer
    • Features
    • Gst-nvinfer File Configuration Specifications
    • Gst Properties
    • Clustering algorithms supported by nvinfer
      • cluster-mode = 0 | GroupRectangles
      • cluster-mode = 1 | DBSCAN
      • cluster-mode = 2 | NMS
      • cluster-mode = 3 | Hybrid
      • cluster-mode=4 | No clustering
    • Tensor Metadata
      • To read or parse inference raw tensor data of output layers
    • Segmentation Metadata
  • Gst-nvinferaudio
    • Features
    • Gst Properties
  • Gst-nvinferserver
    • Gst-nvinferserver Configuration File Specifications
    • Features
    • Gst Properties
    • DeepStream Triton samples
    • DeepStream Triton gRPC support
    • Triton Ensemble Models
    • Custom Process interface IInferCustomProcessor for Extra Input, LSTM Loop, Output Data Postprocess
    • Tensor Metadata Output for Downstream Plugins
  • Gst-nvtracker
    • Gst Properties
    • NvDsTracker API for Low-Level Tracker Library
    • NvMultiObjectTracker : A Reference Low-Level Tracker Library
    • Unified Tracker Architecture for Composable Multi-Object Tracker
    • Workflow and Core Modules in The NvMultiObjectTracker Library
      • Data Association
      • Target Management and Error Handling
      • State Estimation
      • Object Re-Identification
      • Target Re-Association
      • Bounding-box Unclipping
      • Configuration Parameters
    • IOU Tracker
    • NvSORT Tracker
    • NvDeepSORT Tracker
      • Setup Official Re-ID Model
      • Data Association
      • Customize Re-ID Model
      • Implementation Details and Reference
    • NvDCF Tracker
      • Visual Tracking
      • Data Association
    • Setup and Visualization of Tracker Sample Pipelines
      • People Tracking
        • PeopleNet + NvSORT
        • PeopleNet + NvDeepSORT
        • PeopleNet + NvDCF
      • Traffic Tracking
        • DetectNet_v2 + NvDCF
        • DetectNet_v2 (w/ interval=2) + NvDCF
    • Low-Level Tracker Comparisons and Tradeoffs
    • How to Implement a Custom Low-Level Tracker Library
  • Gst-nvstreammux
    • Features
    • Gst Properties
  • Gst-nvstreammux New
    • Features
    • Gst Properties
    • Mux Config Properties
    • NvStreamMux Tuning Solutions for specific use cases
      • 1. Aim
      • 2. Important Tuning parameters
      • 3. Video + Audio muxing Use cases
        • 3.1. Video and Audio muxing; file sources of different fps
        • 3.2 Video and Audio muxing; RTMP/RTSP sources
      • 4. Troubleshooting
        • 4.1 GstAggregator plugin -> filesink does not write data into the file
        • 4.2 nvstreammux WARNING “Lot of buffers are being dropped”
      • 5. Metadata propagation through nvstreammux and nvstreamdemux
        • 5.1 Adding GstMeta to buffers before nvstreammux.
        • 5.2 Accessing GstMeta post nvstreammux.
        • 5.3 Adding GstMeta post nvstreammux.
      • 6. Cascaded Muxing
    • Known Issues and FAQ
      • 1. Observing video and/or audio stutter (low framerate)
      • 2. Sink plugin shall not move asynchronously to PAUSED
      • 3. Heterogeneous batching
      • 4. Adaptive Batching
      • 5. Optimizing nvstreammux config for low-latency vs Compute
      • 6. Latency Measurement API Usage guide for audio
  • Gst-nvstreamdemux
      • Use case 1
      • Use case 2
      • Use case 3
  • Gst-nvmultistreamtiler
    • Features
    • Gst Properties
  • Gst-nvdsosd
    • Features
    • Gst Properties
  • Gst-nvdsmetautils
    • Gst-nvdsmetainsert
    • Features
    • customlib_impl Interfaces
    • Gst Properties
    • Use Cases & Sample Pipelines
    • Gst-nvdsmetaextract
    • Features
    • Gst Properties
  • Gst-nvdsvideotemplate
    • Features
    • Gst Properties
    • Sample pipelines
  • Gst-nvdsaudiotemplate
    • Features
    • Gst Properties
    • Sample pipelines
  • Gst-nvvideoconvert
    • Features
    • Gst Properties
  • Gst-nvdewarper
    • Features
    • Configuration File Parameters
    • Gst Properties
  • Gst-nvof
    • Features
    • Gst Properties
  • Gst-nvofvisual
    • Features
    • Gst Properties
  • Gst-nvsegvisual
    • Features
    • Gst Properties
  • Gst-nvvideo4linux2
    • Decoder
      • Features
      • Gst Properties
    • Encoder
      • Features
      • Gst Properties
  • Gst-nvjpegdec
    • Features
    • Gst Properties
  • Gst-nvmsgconv
    • Features
    • Gst Properties
    • NvMsgConv low level library API’s
    • Schema Customization
    • Payload with Custom Objects
  • Gst-nvmsgbroker
    • Features
    • Gst Properties
    • nvds_msgapi: Protocol Adapter Interface
      • nvds_msgapi_connect(): Create a Connection
      • nvds_msgapi_send() and nvds_msgapi_send_async(): Send an event
      • nvds_msgapi_subscribe(): Consume data by subscribing to topics
      • nvds_msgapi_do_work(): Incremental Execution of Adapter Logic
      • nvds_msgapi_disconnect(): Terminate a Connection
      • nvds_msgapi_getversion(): Get Version Number
      • nvds_msgapi_get_protocol_name(): Get name of the protocol
      • nvds_msgapi_connection_signature(): Get Connection signature
    • nvds_kafka_proto: Kafka Protocol Adapter
      • Installing Dependencies
      • Using the Adapter
      • Configuring Protocol Settings
      • Programmatic Integration
      • Security for Kafka
    • Azure MQTT Protocol Adapter Libraries
      • Setting Up Azure IoT
      • Configuring Adapter Settings
      • Using the Adapter
        • Connection Details for the Device Client Adapter
        • Connection Details for the Module Client Adapter
      • Monitor Adapter Execution
        • Azure device client library log messages
        • Azure Module Client Library Log Messages
      • Message Topics and Routes
    • AMQP Protocol Adapter
      • AMQP broker
      • Configure Adapter Settings
      • Using the Adapter
    • REDIS Protocol Adapter
      • REDIS server
      • Using the Adapter
    • nv_msgbroker: Message Broker interface
      • nv_msgbroker_connect(): Create a Connection
      • nv_msgbroker_send_async(): Send an event asynchronously
      • nv_msgbroker_subscribe(): Consume data by subscribing to topics
      • nv_msgbroker_disconnect(): Terminate a Connection
      • nv_msgbroker_version(): Get Version Number
      • Work-interval configuration
      • nvds_logger: Logging Framework
        • Enabling Logging
        • Filtering Logs
        • Retiring and Managing Logs
        • Generating Logs
  • Gst-nvdsanalytics
    • Features
    • Gst Properties
  • Gst-nvdsasr
    • Features
    • DS-Riva ASR Yaml File Configuration Specifications
    • Gst Properties
      • Riva ASR model data generation and gRPC installation
  • Gst-nvds_text_to_speech (Alpha)
    • Features
    • DS-Riva TTS Yaml File Configuration Specifications
    • Gst Properties
      • Riva TTS Service Initiation
      • gRPC C++ Installation
  • Gst-nvdsudpsrc
    • Features
    • Gst Properties
    • Example pipelines
  • Gst-nvdsudpsink
    • Features
    • Gst Properties
    • Example pipelines
  • Gst-nvdspostprocess (Alpha)
    • Features
    • Gst-nvdspostprocess File Configuration Specifications
    • Gst Properties
    • Sample pipelines
  • Gst-nvds3dfilter
    • Gst-nvds3dfilter properties Specifications
  • Gst-nvdsucx (Alpha)
    • Description
    • Requirements
    • Gst Properties
    • Examples
  • Gst-nvdsxfer
    • Gst Properties
    • How to test
    • Use cases
      • Single Stream + Multi-dGPUs Setup
      • Multiple Streams + Multi-dGPU Setup
  • Gst-nvmultiurisrcbin (Alpha)
    • 1. Introduction
    • 2. Features
    • 3. How to use nvmultiurisrcbin in a pipeline
      • 3.1 REST API payload definitions and sample curl commands for reference
        • 3.1.1 ADD a new stream to a DeepStream pipeline
        • 3.1.2 REMOVE a new stream to a DeepStream pipeline
    • 4. Gst Properties
      • 4.1 Gst Properties directly configuring nvmultiurisrcbin
      • 4.2 Gst Properties to configure each instance of nvurisrcbin created inside this bin
      • 4.3 Gst Properties to configure the instance of nvstreammux created inside this bin
    • 5. Important Notes
      • 5.1 nvmultiurisrcbin config recommendations and notes on expected behavior
    • 6. Known Issues
  • Gst-nvurisrcbin
    • 1. Introduction
    • 2. How to use nvurisrcbin in a pipeline
    • 3. Gst Properties
      • 3.1 Gst Properties to configure nvurisrcbin
DeepStream Troubleshooting and FAQ
  • Troubleshooting
    • You are migrating from DeepStream 6.0 to DeepStream 6.2
    • “NvDsBatchMeta not found for input buffer” error while running DeepStream pipeline
    • The DeepStream reference application fails to launch, or any plugin fails to load
    • Application fails to run when the neural network is changed
    • The DeepStream application is running slowly (Jetson only)
    • Errors occur when deepstream-app is run with a number of streams greater than 100
    • Errors occur when deepstream-app fails to load plugin Gst-nvinferserver
    • Tensorflow models are running into OOM (Out-Of-Memory) problem
    • After removing all the sources from the pipeline crash is seen if muxer and tiler are present in the pipeline
    • Some RGB video format pipelines worked before DeepStream 6.1 onwards on Jetson but don’t work now
    • UYVP video format pipeline doesn’t work on Jetson
    • Memory usage keeps on increasing when the source is a long duration containerized files(e.g. mp4, mkv)
    • Stale frames observed on RTSP output
    • Troubleshooting in NvDCF Parameter Tuning
      • Flickering Bbox
      • Frequent tracking ID changes although no nearby objects
      • Frequent tracking ID switches to the nearby objects
      • Error while running ONNX / Explicit batch dimension networks
    • DeepStream plugins failing to load without DISPLAY variable set when launching DS dockers
      • 1. [When user expect to use Display window]
      • 2. [When user expect to not use a Display window]
    • Nvidia driver installation issues
    • On Jetson, observing error : gstnvarguscamerasrc.cpp, execute:751 No cameras available
    • Graph Composer Troubleshooting
      • My component is not visible in the composer even after registering the extension with registry
      • My component is getting registered as an abstract type.
      • When executing a graph, the execution ends immediately with the warning “No system specified. Nothing to do”
  • Frequently Asked Questions
    • DeepStream General topics
      • How do I uninstall DeepStream?
      • What types of input streams does DeepStream 6.2 support?
      • What’s the throughput of H.264 and H.265 decode on dGPU (Tesla)?
      • How can I run the DeepStream sample application in debug mode?
      • Where can I find the DeepStream sample applications?
      • How can I verify that CUDA was installed correctly?
      • How can I interpret frames per second (FPS) display information on console?
      • My DeepStream performance is lower than expected. How can I determine the reason?
      • How can I specify RTSP streaming of DeepStream output?
      • What is the official DeepStream Docker image and where do I get it?
      • What is the recipe for creating my own Docker image?
      • How can I display graphical output remotely over VNC? How can I determine whether X11 is running?
      • Why does the deepstream-nvof-test application show the error message “Device Does NOT support Optical Flow Functionality” ?
      • Why is the Gst-nvstreammux plugin required in DeepStream 4.0+?
      • How do I profile DeepStream pipeline?
      • How can I check GPU and memory utilization on a dGPU system?
      • What is the approximate memory utilization for 1080p streams on dGPU?
      • When deepstream-app is run in loop on Jetson AGX Xavier using “while true; do deepstream-app -c <config_file>; done;”, after a few iterations I see low FPS for certain iterations. Why is that?
      • Why do I get the error incorrect camera parameters provided, please provide supported resolution and frame rate when I compile DeepStream sample application with source1_usb_dec_infer_resnet_int8.txt config in default setting on Jetson?
      • Why do I get the error Makefile:13: *** "CUDA_VER is not set".  Stop when I compile DeepStream sample applications?
      • How can I construct the DeepStream GStreamer pipeline?
      • How to set camera calibration parameters in Dewarper plugin config file?
      • How to get camera calibration parameters for usage in Dewarper plugin?
      • How to minimize FPS jitter with DS application while using RTSP Camera Streams?
      • Why am I getting “ImportError: No module named google.protobuf.internal when running convert_to_uff.py on Jetson AGX Xavier”?
      • Does DeepStream Support 10 Bit Video streams?
      • What is the difference between batch-size of nvstreammux and nvinfer? What are the recommended values for nvstreammux batch-size?
      • Why do some caffemodels fail to build after upgrading to DeepStream 6.2?
      • How do I configure the pipeline to get NTP timestamps?
      • Why is the NTP timestamp value 0?
      • How to handle operations not supported by Triton Inference Server?
      • Why do I see confidence value as -0.1.?
      • How to use the OSS version of the TensorRT plugins in DeepStream?
      • Why do I see the below Error while processing H265 RTSP stream?
      • Why do I observe: A lot of buffers are being dropped. When running live camera streams even for few or single stream, also output looks jittery?
      • Why does the RTSP source used in gst-launch pipeline through uridecodebin show blank screen followed by the error - WARNING: from element /GstPipeline:pipeline0/GstNvStreamMux:m: No Sources found at the input of muxer. Waiting for sources?
      • What if I do not get expected 30 FPS from camera using v4l2src plugin in pipeline but instead get 15 FPS or less than 30 FPS?
      • On Jetson platform, I get same output when multiple Jpeg images are fed to nvv4l2decoder using multifilesrc plugin. Why is that?
      • On Jetson platform, I observe lower FPS output when screen goes idle.
      • How do I obtain individual sources after batched inferencing/processing? What are the sample pipelines for nvstreamdemux?
      • Why do I encounter such error while running Deepstream pipeline memory type configured and i/p buffer mismatch ip_surf 0 muxer 3?
      • How does secondary GIE crop and resize objects?
      • How to save frames from GstBuffer?
      • What are different Memory types supported on Jetson and dGPU?
      • What are different Memory transformations supported on Jetson and dGPU?
      • Why does my image look distorted if I wrap my cudaMalloc’ed memory into NvBufSurface and provide to NvBufSurfTransform?
      • Why am I getting following warning when running deepstream app for first time?
      • How to find out the maximum number of streams supported on given platform?
      • How to find the performance bottleneck in DeepStream?
      • How to fix “cannot allocate memory in static TLS block” error?
      • How to measure pipeline latency if pipeline contains open source components
      • Migration to newer gstreamer version
    • Smart Record
      • Does smart record module work with local video streams?
      • Are multiple parallel records on same source supported?
      • What if I forgot to stop the recording?
      • I started the record with a set duration. Can I stop it before that duration ends?
      • What if I don’t set default duration for smart record?
      • What if I don’t set video cache size for smart record?
      • What is maximum duration of data I can cache as history for smart record?
      • Can I record the video with bounding boxes and other information overlaid?
    • Triton
      • Can Jetson platform support the same features as dGPU for Triton plugin?
      • How to enable TensorRT optimization for Tensorflow and ONNX models?
      • How to tune GPU memory for Tensorflow models?
      • Can Gst-nvinferserver support models cross processes or containers?
      • Can users set different model repos when running multiple Triton models in single process?
      • What is the difference between DeepStream classification and Triton classification?
      • Why is max_batch_size: 0 used in some Triton model config files (samples/triton_model_repo/*/config.pbtxt)?
      • How to support Triton ensemble model?
      • Why am I getting error Could not get EGL display connection while running deepstream sample application?
      • Does Gst-nvinferserver support Triton multiple instance groups?
      • Can Gst-nvinferserver support inference on multiple GPUs?
      • What is batch-size differences for a single model in different config files (gie group in source, config_inferserver.., and Triton model’s config.pbtxt)?
      • How to use NVTX for profiling?
      • Why do I get the WARNING WARNING from src_elem: No decoder available for type 'audio/mpeg, mpegversion=(int)4’ when I run deepstream-app sample configuration on DS docker containers?
      • Why do I get the WARNING: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': libavfilter.so.7: cannot open shared object file: No such file or directory when using deepstream-app –version-all?
DeepStream API Guide
  • DeepStream API Guides
DeepStream Legal Information
  • DeepStream Legal Information
    • Notice
    • Trademarks
    • Copyright
DeepStream Feedback
  • Feedback form
    • Request Documentation Fix
DeepStream
  • Docs »
  • View page source
DeepStream Legal Information¶
Notice¶
ALL NVIDIA DESIGN SPECIFICATIONS, REFERENCE BOARDS, FILES, DRAWINGS, DIAGNOSTICS, LISTS, AND OTHER DOCUMENTS (TOGETHER AND SEPARATELY, ”MATERIALS”) ARE BEING PROVIDED ”AS IS.” NVIDIA MAKES NO WARRANTIES, EXPRESS, IMPLIED, STATUTORY, OR OTHERWISE WITH RESPECT TO THE MATERIALS, AND ALL EXPRESS OR IMPLIED CONDITIONS, REPRESENTATIONS AND WARRANTIES, INCLUDING ANY IMPLIED WARRANTY OR CONDITION OF TITLE, MERCHANTABILITY, SATISFACTORY QUALITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT, ARE HEREBY EXCLUDED TO THE MAXIMUM EXTENT PERMITTED BY LAW.
Information furnished is believed to be accurate and reliable. However, NVIDIA Corporation assumes no responsibility for the consequences of use of such information or for any infringement of patents or other rights of third parties that may result from its use. No license is granted by implication or otherwise under any patent or patent rights of NVIDIA Corporation. Specifications mentioned in this publication are subject to change without notice. This publication supersedes and replaces all information previously supplied. NVIDIA Corporation products are not authorized for use as critical components in life support devices or systems without express written approval of NVIDIA Corporation.
Trademarks¶
NVIDIA, the NVIDIA logo, CUDA, Jetson, Jetson Nano, NVIDIA AGX, Tegra, TensorRT, Tesla and Xavier are trademarks or registered trademarks of NVIDIA Corporation in the United States and other countries. Other company and product names may be trademarks of the respective companies with which they are associated. The Android robot is reproduced or modified from work created and shared by Google and is used according to terms described in the Creative Commons 3.0 Attribution License. HDMI, the HDMI logo, and High-Definition Multimedia Interface are trademarks or registered trademarks of HDMI Licensing LLC. ARM, AMBA, and ARM Powered are registered trademarks of ARM Limited. Cortex, MPCore and Mali are trademarks of ARM Limited. All other brands or product names are the property of their respective holders. ”ARM” is used to represent ARM Holdings plc; its operating company ARM Limited; and the regional subsidiaries ARM Inc.; ARM KK; ARM Korea Limited.; ARM Taiwan Limited; ARM France SAS; ARM Consulting (Shanghai) Co. Ltd.; ARM Germany GmbH; ARM Embedded Technologies Pvt. Ltd.; ARM Norway, AS and ARM Sweden AB.
Copyright¶
© 2021-2022 by NVIDIA CORPORATION & AFFILIATES. All rights reserved.
Next Previous
© Copyright 2022, NVIDIA. Last updated on Dec 16, 2022.
Built with Sphinx using a theme provided by Read the Docs.
