Quickstart Guide¶
NVIDIA® DeepStream Software Development Kit (SDK) is an accelerated AI framework to build intelligent video analytics (IVA) pipelines. DeepStream runs on NVIDIA® T4, NVIDIA® Hopper, NVIDIA® Ampere and platforms such as NVIDIA® Jetson AGX Xavier™, NVIDIA® Jetson Xavier NX™, NVIDIA® Jetson AGX Orin™, NVIDIA® Jetson Orin™ NX.
Note
The current release is applicable only to x86/dGPU and not valid for Jetson, though the document mentions jetson at multiple places.
Jetson Setup [ Not applicable for NVAIE customers ]¶
This section explains how to prepare a Jetson device before installing the DeepStream SDK.
Install Jetson SDK components¶
Download NVIDIA SDK Manager from https://developer.nvidia.com/embedded/jetpack. You will use this to install JetPack X[TBD] (corresponding to X[TBD] release)
NVIDIA SDK Manager is a graphical application which flashes and installs the JetPack packages.
The flashing procedure takes approximately 10-30 minutes, depending on the host system.
Note
If you are using Jetson Xavier NX developer kit, you can download the SD card image from https://developer.nvidia.com/embedded/jetpack. This comes packaged with CUDA, TensorRT and cuDNN.
Install Dependencies¶
Enter the following commands to install the prerequisite packages:
$ sudo apt install \
libssl1.1 \
libgstreamer1.0-0 \
gstreamer1.0-tools \
gstreamer1.0-plugins-good \
gstreamer1.0-plugins-bad \
gstreamer1.0-plugins-ugly \
gstreamer1.0-libav \
libgstreamer-plugins-base1.0-dev \
libgstrtspserver-1.0-0 \
libjansson4 \
libyaml-cpp-dev
Install librdkafka (to enable Kafka protocol adaptor for message broker)¶
Clone the librdkafka repository from GitHub:
$ git clone https://github.com/edenhill/librdkafka.git
Configure and build the library:
$ cd librdkafka $ git reset --hard 7101c2310341ab3f4675fc565f64f0967e135a6a ./configure $ make $ sudo make install
Copy the generated libraries to the deepstream directory:
$ sudo mkdir -p /opt/nvidia/deepstream/deepstream-6.2/lib $ sudo cp /usr/local/lib/librdkafka* /opt/nvidia/deepstream/deepstream-6.2/lib
Install latest NVIDIA BSP packages¶
Installation of JetPack X TBD will ensure that latest NVIDIA BSP packages are installed.
Install the DeepStream SDK¶
Method 1: Using SDK Manager
Select
DeepStreamSDKfrom theAdditional SDKssection along with JP X [TBD] software components for installation.Method 2: Using the DeepStream tar package: https://developer.nvidia.com/deepstream_sdk_v6.2.0_jetson.tbz2
Download the DeepStream 6.2 Jetson tar package
deepstream_sdk_v6.2.0_jetson.tbz2to the Jetson device.Enter the following commands to extract and install the DeepStream SDK:
$ sudo tar -xvf deepstream_sdk_v6.2.0_jetson.tbz2 -C / $ cd /opt/nvidia/deepstream/deepstream-6.2 $ sudo ./install.sh $ sudo ldconfig
Method 3: Using the DeepStream Debian package: https://developer.nvidia.com/deepstream-6.2_6.2.0-1_arm64.deb
Download the DeepStream 6.2 Jetson Debian package
deepstream-6.2_6.2.0-1_arm64.debto the Jetson device. Enter the following command:$ sudo apt-get install ./deepstream-6.2_6.2.0-1_arm64.deb
Method 4: Use Docker container DeepStream docker containers are available on NGC. See the Docker Containers section to learn about developing and deploying DeepStream using docker containers.
Run deepstream-app (the reference application)¶
Navigate to the samples directory on the development kit.
Enter the following command to run the reference application:
$ deepstream-app -c <path_to_config_file>
Where
<path_to_config_file>is the pathname of one of the reference application’s configuration files, found inconfigs/deepstream-app/. See Package Contents for a list of the available files.Config files that can be run with deepstream-app:
source30_1080p_dec_infer-resnet_tiled_display_int8.txtsource30_1080p_dec_preprocess_infer-resnet_tiled_display_int8.txtsource4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txtsource4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8_gpu1.txt(dGPU only)source1_usb_dec_infer_resnet_int8.txtsource1_csi_dec_infer_resnet_int8.txt(Jetson only)source2_csi_usb_dec_infer_resnet_int8.txt(Jetson only)source6_csi_dec_infer_resnet_int8.txt(Jetson only)source2_1080p_dec_infer-resnet_demux_int8.txtsource4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.ymlsource30_1080p_dec_infer-resnet_tiled_display_int8.ymlsource4_1080p_dec_preprocess_infer-resnet_preprocess_sgie_tiled_display_int8.txt
Note
You can find sample configuration files under
/opt/nvidia/deepstream/deepstream-6.2/samplesdirectory. Enter this command to see application usage:$ deepstream-app --help
To save TensorRT Engine/Plan file, run the following command:
$ sudo deepstream-app -c <path_to_config_file>
To show labels in 2D Tiled display view, expand the source of interest with mouse left-click on the source. To return to the tiled display, right-click anywhere in the window.
Keyboard selection of source is also supported. On the console where application is running, press the
zkey followed by the desired row index (0 to 9), then the column index (0 to 9) to expand the source. To restore 2D Tiled display view, presszagain.
Boost the clocks¶
After you have installed DeepStream SDK, run these commands on the Jetson device to boost the clocks:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
Note
For Jetson Xavier NX, run sudo nvpmodel -m 8 instead of 0.
Run precompiled sample applications¶
Navigate to the chosen application directory inside
sources/apps/sample_apps.Follow the directory’s README file to run the application.
Note
If the application encounters errors and cannot create Gst elements, remove the GStreamer cache, then try again. To remove the GStreamer cache, enter this command:
$ rm ${HOME}/.cache/gstreamer-1.0/registry.aarch64.binWhen the application is run for a model which does not have an existing engine file, it may take up to a few minutes (depending on the platform and the model) for the file generation and the application launch. For later runs, these generated engine files can be reused for faster loading.
dGPU Setup for Ubuntu¶
This section explains how to prepare an Ubuntu x86_64 system with NVIDIA dGPU devices before installing the DeepStream SDK.
Note
The current release provides x86/dGPU triton based docker only for NVAIE customers. Follow Method 3 mentioned in the section “Install the DeepStream SDK” below.
Note
This document uses the term dGPU (“discrete GPU”) to refer to NVIDIA GPU expansion card products such as NVIDIA Tesla® T4 , NVIDIA GeForce® GTX 1080, NVIDIA GeForce® RTX 2080 and NVIDIA GeForce® RTX 3080. This version of DeepStream SDK runs on specific dGPU products on x86_64 platforms supported by NVIDIA driver 525.60.13 and NVIDIA TensorRT™ 8.5.1.7 and later versions.
You must install the following components:
Ubuntu 20.04
GStreamer 1.16.3
CUDA 11.8
TensorRT 8.5.1.7
Remove all previous DeepStream installations¶
Enter the following commands to remove all previous DeepStream 3.0 or prior installations:
$ sudo rm -rf /usr/local/deepstream /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstnv* /usr/bin/deepstream* /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libnvdsgst*
/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream*
/opt/nvidia/deepstream/deepstream*
$ sudo rm -rf /usr/lib/x86_64-linux-gnu/libv41/plugins/libcuvidv4l2_plugin.so
To remove DeepStream 4.0 or later installations:
Open the
uninstall.shfile in/opt/nvidia/deepstream/deepstream/Set PREV_DS_VER as 4.0
Run the following script as
sudo ./uninstall.sh
Enter the following commands to install the necessary packages before installing the DeepStream SDK:
libssl1.1 \
libgstreamer1.0-0 \
libjansson4 \
libyaml-cpp-dev \
libjsoncpp-dev \
protobuf-compiler \
gcc \
make \
git \
python3
Install CUDA Toolkit 11.8¶
Run the following commands (reference, https://developer.nvidia.com/cuda-downloads):
$ sudo apt-key adv --fetch-keys https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64/3bf863cc.pub
$ sudo add-apt-repository "deb https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64/ /"
$ sudo apt-get update
$ sudo apt-get install cuda-toolkit-11-8
Note
If you observe following errors while CUDA installation, refer https://developer.nvidia.com/blog/updating-the-cuda-linux-gpg-repository-key/
W: GPG error: https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64 InRelease: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY A4B469963BF863CC E: The repository ‘https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64 InRelease’ is no longer signed.
Install NVIDIA driver 525.60.13¶
Download and install using NVIDIA driver 525.60.13 from NVIDIA Unix drivers page at: https://www.nvidia.com/Download/driverResults.aspx/196881/en-us/
Run the following commands:
$chmod 755 NVIDIA-Linux-x86_64-525.60.13.run $sudo ./NVIDIA-Linux-x86_64-525.60.13.run --no-cc-version-check
Note
Ensure gdm, lightdm or Xorg service is stopped while installing nvidia driver
Use command : sudo service gdm stop sudo service lightdm stop sudo pkill -9 Xorg
Install TensorRT 8.5.1.7¶
Run the following command to install TensorRT 8.5.1.7:
sudo apt-get install libnvinfer8=8.5.1-1+cuda11.8 libnvinfer-plugin8=8.5.1-1+cuda11.8 libnvparsers8=8.5.1-1+cuda11.8 \ libnvonnxparsers8=8.5.1-1+cuda11.8 libnvinfer-bin=8.5.1-1+cuda11.8 libnvinfer-dev=8.5.1-1+cuda11.8 \ libnvinfer-plugin-dev=8.5.1-1+cuda11.8 libnvparsers-dev=8.5.1-1+cuda11.8 libnvonnxparsers-dev=8.5.1-1+cuda11.8 \ libnvinfer-samples=8.5.1-1+cuda11.8 libcudnn8=8.6.0.163-1+cuda11.8 libcudnn8-dev=8.6.0.163-1+cuda11.8 \ python3-libnvinfer=8.5.1-1+cuda11.8 python3-libnvinfer-dev=8.5.1-1+cuda11.8Note
It is assumed, “deb https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64/ /” has been added, as mentioned in CUDA Toolkit 11.8 installation step.
Method 1: Using the DeepStream Debian package [ Not valid for NVAIE customers ]
Download the DeepStream 6.2 dGPU Debian package
deepstream-6.2_6.2.0-1_amd64.deb: https://developer.nvidia.com/deepstream-6.2_6.2.0-1_amd64.debEnter the command:
$ sudo apt-get install ./deepstream-6.2_6.2.0-1_amd64.deb
Method 2: Download the DeepStream tar package: https://developer.nvidia.com/deepstream_sdk_v6.2.0_x86_64.tbz2
Navigate to the location of the downloaded DeepStream package to extract and install the DeepStream SDK:
$ sudo tar -xvf deepstream_sdk_v6.2.0_x86_64.tbz2 -C / $ cd /opt/nvidia/deepstream/deepstream-6.2/ $ sudo ./install.sh $ sudo ldconfig
Method 3: Use Docker container DeepStream docker containers are available on NGC. See the Docker Containers section to learn about developing and deploying DeepStream using docker containers.
Run the deepstream-app (the reference application)¶
Go to the samples directory and enter this command:
Where
<path_to_config_file>is the pathname of one of the reference application’s configuration files, found inconfigs/deepstream-app. See Package Contents for a list of the available files.Note
To dump engine file, run the following command:
To show labels in 2D tiled display view, expand the source of interest with a mouse left-click on the source. To return to the tiled display, right-click anywhere in the window.
zkey followed by the desired row index (0 to 9), then the column index (0 to 9) to expand the source. To restore the 2D Tiled display view, presszagain.
sources/apps/sample_apps.Follow that directory’s README file to run the application.
Note
$ rm ${HOME}/.cache/gstreamer-1.0/registry.x86_64.binWhen the application is run for a model which does not have an existing engine file, it may take up to a few minutes (depending on the platform and the model) for the file generation and application launch. For later runs, these generated engine files can be reused for faster loading.
dGPU Setup for RedHat Enterprise Linux (RHEL)¶
Deepstream for RHEL is not supported in this release.
Running without an X server¶
The default configuration files provided with the SDK have the EGL based nveglglessink as the default renderer (indicated by type=2 in the [sink] groups). The renderer requires a running X server and fails without one.
In case of absence of an X server, DeepStream reference applications provide an alternate functionality of streaming the output over RTSP. This can be enabled by adding an RTSP out sink group in the configuration file. Refer to [sink2] group in source30_1080p_dec_infer-resnet_tiled_display_int8.txt file for an example. Don’t forget to disable the nveglglessink renderer by setting enable=0 for the corresponding sink group.
Platform and OS Compatibility¶
The following table provides information about platform and operating system compatibility in the current and earlier versions of DeepStream.
Jetson model Platform and OS Compatibility¶ DS release
DS 6.0
DS 6.0.1
DS 6.1
DS 6.1.1
DS 6.2
Jetson platforms
Nano, AGX Xavier, TX2, TX1, Jetson NX
AGX Xavier, Jetson NX, Jetson Orin
Xavier AGX , Xavier NX, AGX Orin, Orin NX
OS
L4T Ubuntu 18.04
L4T Ubuntu 18.04
L4T Ubuntu 20.04
L4T Ubuntu 20.04
L4T Ubuntu 20.04
JetPack release
4.6 GA
4.6.1 GA
5.0.1 DP
5.0.2 GA Revision 1
TBD
L4T release
32.6.1
32.7.1
34.1.1
35.1
TBD
CUDA release
CUDA 10.2
CUDA 10.2
CUDA 11.4
CUDA 11.4
TBD
cuDNN release
cuDNN 8.2.1.32
cuDNN 8.2.1.32
cuDNN 8.3.2.49
cuDNN 8.4.1.50+
TBD
TensorRT release
TRT 8.0.1
TRT 8.2.1
TRT 8.4.0.11
TRT 8.4.1.5
TBD
OpenCV release
OpenCV 4.1.1
OpenCV 4.1.1
OpenCV 4.2.0
OpenCV 4.2.0
OpenCV 4.2.0
VisionWorks
VisionWorks 1.6.502
VisionWorks 1.6.502
NA
NA
NA
GStreamer
GStreamer 1.14.5
GStreamer 1.14.5
GStreamer 1.16.2
GStreamer 1.16.2
GStreamer 1.16.3
Docker image
deepstream-l4t:6.0-ga
deepstream-l4t:6.0.1
deepstream-l4t:6.1
deepstream-l4t:6.1.1
deepstream-l4t:6.2
dGPU model Platform and OS Compatibility¶ DS release
DS 6.0
DS 6.0.1
DS 6.1
DS 6.1.1
DS 6.2
GPU platforms
P4, T4, V100, A100
P4, T4, V100, A100
T4, V100, A2, A10, A30, A100, RTX Ampere (Ax000/RTX30x0)
T4, V100, A2, A10, A30, A100, RTX Ampere (Ax000/RTX30x0), Hopper, ADA
OS
Ubuntu 18.04 RHEL 8.x
Ubuntu 20.04
Ubuntu 20.04
Ubuntu 20.04
GCC
GCC 7.3.0
GCC 7.3.0
GCC 9.4.0
GCC 9.4.0
GCC 9.4.0
CUDA release
CUDA 11.4.1
CUDA 11.4.1
CUDA 11.6.1
CUDA 11.7.1
CUDA 11.8
cuDNN release
cuDNN 8.2+
cuDNN 8.2+
cuDNN 8.4.0.27
cuDNN 8.4.1.50+
cuDNN 8.6.0.163+
TRT release
TRT 8.0.1
TRT 8.0.1
TRT 8.2.5.1
TRT 8.4.1.5
TRT 8.5.1.7
Display Driver
R470.63.01
R470.63.01
R510.47.03
R515.65.01
R525.60.13
VideoSDK release
SDK 9.1
SDK 9.1
SDK 9.1
SDK 9.1
SDK 9.1
OFSDK release
2.0.23
2.0.23
2.0.23
2.0.23
2.0.23
GStreamer release
GStreamer 1.14.5
GStreamer 1.14.5
GStreamer 1.16.2
GStreamer 1.16.2
GStreamer 1.16.3
OpenCV release
OpenCV 3.4.0
OpenCV 3.4.0
OpenCV 4.2.0
OpenCV 4.2.0
OpenCV 4.2.0
Docker image
deepstream:6.0-ga
deepstream:6.0.1
deepstream:6.1
deepstream:6.1.1
deepstream:6.2
Note
By default, OpenCV has been deprecated. However, OpenCV can be enabled in plugins such as nvinfer (nvdsinfer) and dsexample (gst-dsexample) by setting WITH_OPENCV=1 in the Makefile of these components. Please refer component README for more instructions.
DeepStream Triton Inference Server Usage Guidelines¶
To migrate the Triton version in a DeepStream 6.2 deployment (Triton 22.09) to a newer version (say Triton 22.10 or newer), follow the instructions at DeepStream Triton Migration Guide.
dGPU¶
Pull the DeepStream Triton Inference Server docker
docker pull nvcr.io/nvidia/deepstream:6.2-triton
Start the docker
docker run --gpus "device=0" -it --rm -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -e CUDA_CACHE_DISABLE=0 nvcr.io/nvidia/deepstream:6.2-triton
Note
The triton docker for x86 and Jetson is based on tritonserver 22.09 docker, and has Ubuntu 20.04.
When the triton docker is launched for the first time, it might take a few minutes to start since it has to generate compute cache.
Jetson¶
DeepStream Triton container image (nvcr.io/nvidia/deepstream-l4t:6.2-triton) has Triton Inference Server and supported backend libraries pre-installed.
In order to run the Triton Inference Server directly on device, i.e., without docker, Triton Server setup will be required.
Go to samples directory and run the following commands to set up the Triton Server and backends.
$ cd /opt/nvidia/deepstream/deepstream/samples/
$ sudo ./triton_backend_setup.sh
Note
By default script will download the Triton Server version 2.26. For setting up any other version change the package path accordingly.
Triton backends are installed into /opt/nvidia/deepstream/deepstream/lib/triton_backends by default by the script. User can update infer_config settings for specific folders as follows:
model_repo {
backend_dir: /opt/nvidia/tritonserver/backends/
Using DLA for inference¶
DLA is Deep Learning Accelerator present on the Jetson AGX Xavier and Jetson NX platforms. Both these platforms have two DLA engines. DeepStream can be configured to run inference on either of the DLA engines through the Gst-nvinfer plugin. One instance of Gst-nvinfer plugin and thus a single instance of a model can be configured to be executed on a single DLA engine or the GPU. However, multiple Gst-nvinfer plugin instances can be configured to use the same DLA. To configure Gst-nvinfer to use the DLA engine for inference, modify the corresponding property in nvinfer component configuration file (example: samples/configs/deepstream-app/config_infer_primary.txt): Set enable-dla=1 in [property] group. Set use-dla-core=0 or use-dla-core=1 depending on the DLA engine to use.
DeepStream does support inferencing using GPU and DLAs in parallel. You can run this in separate processes or single process. You will need three separate sets of configs configured to run on GPU, DLA0 and DLA1:
Separate processes¶
When GPU and DLA are run in separate processes, set the environment variable CUDA_DEVICE_MAX_CONNECTIONS as 1 from the terminal where DLA config is running.
Single process¶
DeepStream reference application supports multiple configs in the same process. To run DLA and GPU in same process, set environment variable CUDA_DEVICE_MAX_CONNECTIONS as 32:
$ deepstream-app -c <gpuconfig> -c <dla0config> -c <dla1config>
