Logo
6.2 Release
DeepStream Getting Started
  • Welcome to the DeepStream Documentation
    • NVIDIA DeepStream Overview
      • DeepStream Graph Architecture
      • DeepStream reference app
      • Getting started with building apps
      • DeepStream in Python
  • Readme First
    • Additional Resources
      • Documentation
      • Forums
  • Quickstart Guide
    • Jetson Setup [ Not applicable for NVAIE customers ]
      • Install Jetson SDK components
      • Install Dependencies
        • Install librdkafka (to enable Kafka protocol adaptor for message broker)
      • Install latest NVIDIA BSP packages
      • Install the DeepStream SDK
      • Run deepstream-app (the reference application)
        • Boost the clocks
      • Run precompiled sample applications
    • dGPU Setup for Ubuntu
      • Remove all previous DeepStream installations
        • Install CUDA Toolkit 11.8
        • Install NVIDIA driver 525.60.13
        • Install TensorRT 8.5.1.7
      • Run the deepstream-app (the reference application)
    • dGPU Setup for RedHat Enterprise Linux (RHEL)
    • Running without an X server
    • Platform and OS Compatibility
    • DeepStream Triton Inference Server Usage Guidelines
      • dGPU
      • Jetson
    • Using DLA for inference
      • Separate processes
      • Single process
  • Docker Containers
    • A Docker Container for dGPU
    • A Docker Container for Jetson
    • Creating custom DeepStream docker for dGPU using DeepStreamSDK package
    • Creating custom DeepStream docker for Jetson using DeepStreamSDK package
    • Recommended Minimal L4T Setup necessary to run the new docker images on Jetson
DeepStream Samples
  • C/C++ Sample Apps Source Details
    • Plugin and Library Source Details
  • Python Sample Apps and Bindings Source Details
    • Sample Application Source Details
    • Python Bindings and Application Development
      • Prerequisites
      • Running Sample Applications
      • Pipeline Construction
    • MetaData Access
      • Memory Management
      • Allocations
      • String Access
        • Setting String Fields
        • Reading String Fields
      • Casting
      • Callback Function Registration
      • Optimizations and Utilities
      • Image Data Access
  • DeepStream Reference Application - deepstream-app
    • Application Architecture
    • Reference Application Configuration
      • Expected Output for the DeepStream Reference Application (deepstream-app)
    • Configuration Groups
      • Application Group
      • Tiled-display Group
      • Source Group
      • Source-list and source-attr-all Groups
      • Streammux Group
      • Preprocess Group
      • Primary GIE and Secondary GIE Group
      • Tracker Group
      • Message Converter Group
      • Message Consumer Group
      • OSD Group
      • Sink Group
      • Tests Group
      • NvDs-analytics Group
    • Application Tuning for DeepStream SDK
      • Performance Optimization
        • DeepStream best practices
        • Jetson optimization
        • Triton
        • Inference Throughput
      • Reducing Spurious Detections
  • DeepStream Reference Application - deepstream-test5 app
    • IoT Protocols supported and cloud configuration
    • Message consumer
    • Smart Record - Event based recording
    • OTA model update
      • Using the OTA functionality
    • Sensor Provisioning Support over REST API (Runtime sensor add/remove capability)
  • DeepStream Reference Application - deepstream-audio app
    • DeepStream Audio Reference Application Architecture and Sample Graphs
  • DeepStream Reference Application - deepstream-nmos app
    • Using Easy-NMOS for NMOS Registry and Controller
  • DeepStream Reference Application on GitHub
    • Use case applications
    • AI models with DeepStream
    • DeepStream features sample
  • Sample Configurations and Streams
    • Contents of the package
      • Scripts included along with package
  • Implementing a Custom GStreamer Plugin with OpenCV Integration Example
    • Description of the Sample Plugin: gst-dsexample
      • GstBaseTransfrom Class Functions
      • Other supporting functions
    • Enabling and configuring the sample plugin
    • Using the sample plugin in a custom application/pipeline
    • Implementing Custom Logic Within the Sample Plugin
    • Adding NVTX APIs for sample plugin
    • Accessing NvBufSurface memory in OpenCV
TAO toolkit Integration with DeepStream
  • TAO Toolkit Integration with DeepStream
    • Pre-trained models
Tutorials and How-to's
  • Custom YOLO Model in the DeepStream YOLO App
    • How to Use the Custom YOLO Model
      • Set up the sample
  • NvMultiObjectTracker Parameter Tuning Guide
    • Accuracy-Performance Tradeoffs
      • Visual Feature Types and Feature Sizes
      • Detection Interval
      • Video Frame Size for Tracker
    • Robustness
      • Target Creation Policy
      • Target Termination Policy
    • State Estimation
      • Kalman Filter
    • Data Association
    • DCF Core Tuning
      • DCF Filter Learning
  • DeepStream 3D Custom Manual
    • DS3D Application Examples
    • ds3d::dataloader - Load Custom Lib for Data Capture
      • Load and Manage Dataloader
      • Dataloader in User Application
      • Implement a Custom Dataloader
    • ds3d::datafilter- Loads Custom Lib for Input and Output Processing
      • Load And Manage Datafilter
      • Datafilter in User Application
      • Implement a Custom Datafilter
    • ds3d::datarender - Loads Custom Lib for Data Rendering
      • Load And Manage Datarender
      • Datarender in User Application
      • Implement a Custom Datarender
    • DS3D GuardDataMap Buffer Management
      • DS3D Data Map Read
      • DS3D Data Map Write
    • Custom Libs Configuration Specifications
      • Components Common Configuration Specifications
      • libnvds_3d_dataloader_realsense Configuration Specifications
      • libnvds_3d_depth2point_datafilter Configuration Specifications
      • libnvds_3d_gl_datarender Configuration Specifications
      • libnvds_3d_depth_datasource Depth file source Specific Configuration Specifications
DeepStream Performance
  • Performance
    • TAO Pre-trained models
    • DeepStream reference model and tracker
    • Configuration File Settings for Performance Measurement
      • Data center GPU - GA100
        • System Configuration
        • Application Configuration
      • Data center GPU - T4
      • Jetson
        • Jetson AGX Xavier
        • Jetson NX
        • Jetson Orin
DeepStream Custom Model
  • Using a Custom Model with DeepStream
    • Custom Model Implementation Interface
    • Custom Output Parsing
    • IPlugin Implementation
      • How to Use IPluginCreator
      • How to Use IPluginFactory
        • For Caffe Files
        • For Uff Files
        • During Deserialization
    • Input Layer Initialization
    • CUDA Engine Creation for Custom Models
    • IModelParser Interface for Custom Model Parsing
DeepStream Key Features
  • Smart Video Record
    • Smart Video Record Module APIs
    • Smart Video Record Configurations
  • IoT
    • Secure Edge-to-Cloud Messaging
      • 2-way TLS Authentication
        • Overview of Steps
        • TLS Version
        • Key generation
        • Certificate Signing
        • Choice of Cipher
        • Configure TLS options in Kafka config file for DeepStream
      • SASL/Plain
        • Overview of Steps
        • TLS Configuration
        • Credential Storage
        • Choosing Between 2-way TLS and SASL/Plain
      • Impact on performance
    • Bidirectional Messaging
      • Edge-to-Cloud
      • Cloud-to-Edge
      • NvMsgbroker Library
    • Autoreconnect feature
  • On the Fly Model Update
    • Assumptions
  • NTP Timestamp in DeepStream
  • AV Sync in DeepStream
    • Setup for RTMP/RTSP Input streams for testing
      • RTMP Server Setup
        • Command to simulate 2 RTMP streams using ffmpeg
      • RTSP Server Setup
    • AVSync Reference Pipelines
      • Pipelines with existing nvstreammux component
        • RTMP_IN -> RTMP_OUT
        • FILE_IN->RTSP_OUT
        • FILE_IN->RTMP_OUT
        • RTMP_IN->FILE_OUT
        • RTSP_IN->FILE_OUT
        • FILE_IN->FILE_OUT
        • RTSP_IN->RTSP_OUT
        • RTMP_IN->RTSP_OUT
      • Reference AVSync + ASR (Automatic Speech Recognition) Pipelines with existing nvstreammux
        • RTMP_IN->RTMP_OUT
        • RTSP_IN->RTMP_OUT
        • FILE_IN->RTMP_OUT
      • Pipelines with New nvstreammux component
        • RTMP_IN->RTMP_OUT
        • RTSP_IN->RTMP_OUT
        • FILE_IN->RTSP_OUT
        • FILE_IN->RTMP_OUT
        • RTMP_IN->FILE_OUT
        • RTSP_IN->FILE_OUT
        • FILE_IN->FILE_OUT
        • RTSP_IN->RTSP_OUT
        • RTMP_IN->RTSP_OUT
      • Reference AVSync + ASR Pipelines (with new nvstreammux)
        • RTMP_IN->RTMP_OUT
        • RTSP_IN->RTMP_OUT
        • FILE_IN->RTMP_OUT
      • Gst-pipeline with audiomuxer (single source, without ASR + new nvstreammux)
        • RTMP_IN->FILE_OUT
  • DeepStream With REST API Sever (Alpha)
    • Features
    • nvds_rest_server
    • deepstream-server-app
    • Sensor provisioning with deepstream-test5-app
    • How to add custom REST API support
      • REST API endpoints implementation
      • Handler Function Implementation Details
      • Custom event generation
      • Callback implementation for REST API endpoints
    • Limitations
  • DeepStream 3D Action Recognition App
    • Getting Started
      • Prerequisites
      • Run 3D Action Recognition Examples
      • Run 2D Action Recognition Examples
    • DeepStream 3D Action Recognition App Configuration Specifications
      • deepstream-3d-action-recognition [action-recognition] group settings
      • Custom sequence preprocess lib user settings [user-configs] for gst-nvdspreprocess
      • Custom lib and `gst-nvdspreprocess` Settings for Action Recognition
    • Build Custom sequence preprocess lib and application From Source
  • DeepStream 3D Depth Camera App
    • Prerequisites
    • Depth Color Capture to 2D Rendering Pipeline Overview
    • Depth Color Capture to 3D Point Cloud Processing and Rendering
    • Getting Started
      • Run RealSense Camera for Depth Capture and 2D Rendering Examples
    • Run 3D Depth Capture, Point Cloud filter, and 3D Points Rendering Examples
    • DeepStream 3D Depth Camera App Configuration Specifications
      • deepstream-3d-depth-camera [ds3d::userapp] group settings
      • DS3D Custom Components Configuration Specifications
        • Build application From Source
  • DeepStream Lidar Inference App (Alpha)
    • Prerequisites
    • Lidar Point Cloud to 3D Point Cloud Processing and Rendering
    • Getting Started
    • Run Lidar Point Cloud Data File reader, Point Cloud Inferencing filter, and Point Cloud 3D rendering and data dump Examples
    • DeepStream Lidar Inference App Configuration Specifications
      • deepstream-lidar-inference-app [ds3d::userapp] group settings
  • Networked Media Open Specifications (NMOS) in DeepStream
    • Supported Specifications
    • Prerequisites
    • NvDsNmos API
  • Gst-nvdspostprocess in DeepStream
    • Detector models
    • Primary Classification model
    • Mask RCNN Model
    • Custom Parsing functions
  • DeepStream Can Orientation App
    • Getting Started
      • Prerequisites
      • Run DeepStream Can Orientation Examples
    • DeepStream Can Orientation App Configuration Specifications
      • deepstream-can-orientation-app settings
      • Custom lib libnvds_vpicanmatch.so Settings for Can Template Matching
DeepStream Application Migration
  • Application Migration to DeepStream 6.2 from DeepStream 6.1
    • Running DeepStream 6.1 compiled Apps in DeepStream 6.2
    • Compiling DeepStream 6.1 Apps in DeepStream 6.2
DeepStream Plugin Guide
  • GStreamer Plugin Overview
  • MetaData in the DeepStream SDK
    • NvDsBatchMeta: Basic Metadata Structure
    • User/Custom Metadata Addition inside NvDsBatchMeta
    • Adding Custom Meta in Gst Plugins Upstream from Gst-nvstreammux
      • Adding metadata to the plugin before Gst-nvstreammux
      • New metadata fields
  • Gst-nvdspreprocess (Alpha)
    • Inputs and Outputs
    • Features
    • Custom library Interfaces
    • Gst-nvdspreprocess File Configuration Specifications
    • Gst Properties
    • Sample pipelines
  • Gst-nvinfer
    • Features
    • Gst-nvinfer File Configuration Specifications
    • Gst Properties
    • Clustering algorithms supported by nvinfer
      • cluster-mode = 0 | GroupRectangles
      • cluster-mode = 1 | DBSCAN
      • cluster-mode = 2 | NMS
      • cluster-mode = 3 | Hybrid
      • cluster-mode=4 | No clustering
    • Tensor Metadata
      • To read or parse inference raw tensor data of output layers
    • Segmentation Metadata
  • Gst-nvinferaudio
    • Features
    • Gst Properties
  • Gst-nvinferserver
    • Gst-nvinferserver Configuration File Specifications
    • Features
    • Gst Properties
    • DeepStream Triton samples
    • DeepStream Triton gRPC support
    • Triton Ensemble Models
    • Custom Process interface IInferCustomProcessor for Extra Input, LSTM Loop, Output Data Postprocess
    • Tensor Metadata Output for Downstream Plugins
  • Gst-nvtracker
    • Gst Properties
    • NvDsTracker API for Low-Level Tracker Library
    • NvMultiObjectTracker : A Reference Low-Level Tracker Library
    • Unified Tracker Architecture for Composable Multi-Object Tracker
    • Workflow and Core Modules in The NvMultiObjectTracker Library
      • Data Association
      • Target Management and Error Handling
      • State Estimation
      • Object Re-Identification
      • Target Re-Association
      • Bounding-box Unclipping
      • Configuration Parameters
    • IOU Tracker
    • NvSORT Tracker
    • NvDeepSORT Tracker
      • Setup Official Re-ID Model
      • Data Association
      • Customize Re-ID Model
      • Implementation Details and Reference
    • NvDCF Tracker
      • Visual Tracking
      • Data Association
    • Setup and Visualization of Tracker Sample Pipelines
      • People Tracking
        • PeopleNet + NvSORT
        • PeopleNet + NvDeepSORT
        • PeopleNet + NvDCF
      • Traffic Tracking
        • DetectNet_v2 + NvDCF
        • DetectNet_v2 (w/ interval=2) + NvDCF
    • Low-Level Tracker Comparisons and Tradeoffs
    • How to Implement a Custom Low-Level Tracker Library
  • Gst-nvstreammux
    • Features
    • Gst Properties
  • Gst-nvstreammux New
    • Features
    • Gst Properties
    • Mux Config Properties
    • NvStreamMux Tuning Solutions for specific use cases
      • 1. Aim
      • 2. Important Tuning parameters
      • 3. Video + Audio muxing Use cases
        • 3.1. Video and Audio muxing; file sources of different fps
        • 3.2 Video and Audio muxing; RTMP/RTSP sources
      • 4. Troubleshooting
        • 4.1 GstAggregator plugin -> filesink does not write data into the file
        • 4.2 nvstreammux WARNING “Lot of buffers are being dropped”
      • 5. Metadata propagation through nvstreammux and nvstreamdemux
        • 5.1 Adding GstMeta to buffers before nvstreammux.
        • 5.2 Accessing GstMeta post nvstreammux.
        • 5.3 Adding GstMeta post nvstreammux.
      • 6. Cascaded Muxing
    • Known Issues and FAQ
      • 1. Observing video and/or audio stutter (low framerate)
      • 2. Sink plugin shall not move asynchronously to PAUSED
      • 3. Heterogeneous batching
      • 4. Adaptive Batching
      • 5. Optimizing nvstreammux config for low-latency vs Compute
      • 6. Latency Measurement API Usage guide for audio
  • Gst-nvstreamdemux
      • Use case 1
      • Use case 2
      • Use case 3
  • Gst-nvmultistreamtiler
    • Features
    • Gst Properties
  • Gst-nvdsosd
    • Features
    • Gst Properties
  • Gst-nvdsmetautils
    • Gst-nvdsmetainsert
    • Features
    • customlib_impl Interfaces
    • Gst Properties
    • Use Cases & Sample Pipelines
    • Gst-nvdsmetaextract
    • Features
    • Gst Properties
  • Gst-nvdsvideotemplate
    • Features
    • Gst Properties
    • Sample pipelines
  • Gst-nvdsaudiotemplate
    • Features
    • Gst Properties
    • Sample pipelines
  • Gst-nvvideoconvert
    • Features
    • Gst Properties
  • Gst-nvdewarper
    • Features
    • Configuration File Parameters
    • Gst Properties
  • Gst-nvof
    • Features
    • Gst Properties
  • Gst-nvofvisual
    • Features
    • Gst Properties
  • Gst-nvsegvisual
    • Features
    • Gst Properties
  • Gst-nvvideo4linux2
    • Decoder
      • Features
      • Gst Properties
    • Encoder
      • Features
      • Gst Properties
  • Gst-nvjpegdec
    • Features
    • Gst Properties
  • Gst-nvmsgconv
    • Features
    • Gst Properties
    • NvMsgConv low level library API’s
    • Schema Customization
    • Payload with Custom Objects
  • Gst-nvmsgbroker
    • Features
    • Gst Properties
    • nvds_msgapi: Protocol Adapter Interface
      • nvds_msgapi_connect(): Create a Connection
      • nvds_msgapi_send() and nvds_msgapi_send_async(): Send an event
      • nvds_msgapi_subscribe(): Consume data by subscribing to topics
      • nvds_msgapi_do_work(): Incremental Execution of Adapter Logic
      • nvds_msgapi_disconnect(): Terminate a Connection
      • nvds_msgapi_getversion(): Get Version Number
      • nvds_msgapi_get_protocol_name(): Get name of the protocol
      • nvds_msgapi_connection_signature(): Get Connection signature
    • nvds_kafka_proto: Kafka Protocol Adapter
      • Installing Dependencies
      • Using the Adapter
      • Configuring Protocol Settings
      • Programmatic Integration
      • Security for Kafka
    • Azure MQTT Protocol Adapter Libraries
      • Setting Up Azure IoT
      • Configuring Adapter Settings
      • Using the Adapter
        • Connection Details for the Device Client Adapter
        • Connection Details for the Module Client Adapter
      • Monitor Adapter Execution
        • Azure device client library log messages
        • Azure Module Client Library Log Messages
      • Message Topics and Routes
    • AMQP Protocol Adapter
      • AMQP broker
      • Configure Adapter Settings
      • Using the Adapter
    • REDIS Protocol Adapter
      • REDIS server
      • Using the Adapter
    • nv_msgbroker: Message Broker interface
      • nv_msgbroker_connect(): Create a Connection
      • nv_msgbroker_send_async(): Send an event asynchronously
      • nv_msgbroker_subscribe(): Consume data by subscribing to topics
      • nv_msgbroker_disconnect(): Terminate a Connection
      • nv_msgbroker_version(): Get Version Number
      • Work-interval configuration
      • nvds_logger: Logging Framework
        • Enabling Logging
        • Filtering Logs
        • Retiring and Managing Logs
        • Generating Logs
  • Gst-nvdsanalytics
    • Features
    • Gst Properties
  • Gst-nvdsasr
    • Features
    • DS-Riva ASR Yaml File Configuration Specifications
    • Gst Properties
      • Riva ASR model data generation and gRPC installation
  • Gst-nvds_text_to_speech (Alpha)
    • Features
    • DS-Riva TTS Yaml File Configuration Specifications
    • Gst Properties
      • Riva TTS Service Initiation
      • gRPC C++ Installation
  • Gst-nvdsudpsrc
    • Features
    • Gst Properties
    • Example pipelines
  • Gst-nvdsudpsink
    • Features
    • Gst Properties
    • Example pipelines
  • Gst-nvdspostprocess (Alpha)
    • Features
    • Gst-nvdspostprocess File Configuration Specifications
    • Gst Properties
    • Sample pipelines
  • Gst-nvds3dfilter
    • Gst-nvds3dfilter properties Specifications
  • Gst-nvdsucx (Alpha)
    • Description
    • Requirements
    • Gst Properties
    • Examples
  • Gst-nvdsxfer
    • Gst Properties
    • How to test
    • Use cases
      • Single Stream + Multi-dGPUs Setup
      • Multiple Streams + Multi-dGPU Setup
  • Gst-nvmultiurisrcbin (Alpha)
    • 1. Introduction
    • 2. Features
    • 3. How to use nvmultiurisrcbin in a pipeline
      • 3.1 REST API payload definitions and sample curl commands for reference
        • 3.1.1 ADD a new stream to a DeepStream pipeline
        • 3.1.2 REMOVE a new stream to a DeepStream pipeline
    • 4. Gst Properties
      • 4.1 Gst Properties directly configuring nvmultiurisrcbin
      • 4.2 Gst Properties to configure each instance of nvurisrcbin created inside this bin
      • 4.3 Gst Properties to configure the instance of nvstreammux created inside this bin
    • 5. Important Notes
      • 5.1 nvmultiurisrcbin config recommendations and notes on expected behavior
    • 6. Known Issues
  • Gst-nvurisrcbin
    • 1. Introduction
    • 2. How to use nvurisrcbin in a pipeline
    • 3. Gst Properties
      • 3.1 Gst Properties to configure nvurisrcbin
DeepStream Troubleshooting and FAQ
  • Troubleshooting
    • You are migrating from DeepStream 6.0 to DeepStream 6.2
    • “NvDsBatchMeta not found for input buffer” error while running DeepStream pipeline
    • The DeepStream reference application fails to launch, or any plugin fails to load
    • Application fails to run when the neural network is changed
    • The DeepStream application is running slowly (Jetson only)
    • Errors occur when deepstream-app is run with a number of streams greater than 100
    • Errors occur when deepstream-app fails to load plugin Gst-nvinferserver
    • Tensorflow models are running into OOM (Out-Of-Memory) problem
    • After removing all the sources from the pipeline crash is seen if muxer and tiler are present in the pipeline
    • Some RGB video format pipelines worked before DeepStream 6.1 onwards on Jetson but don’t work now
    • UYVP video format pipeline doesn’t work on Jetson
    • Memory usage keeps on increasing when the source is a long duration containerized files(e.g. mp4, mkv)
    • Stale frames observed on RTSP output
    • Troubleshooting in NvDCF Parameter Tuning
      • Flickering Bbox
      • Frequent tracking ID changes although no nearby objects
      • Frequent tracking ID switches to the nearby objects
      • Error while running ONNX / Explicit batch dimension networks
    • DeepStream plugins failing to load without DISPLAY variable set when launching DS dockers
      • 1. [When user expect to use Display window]
      • 2. [When user expect to not use a Display window]
    • Nvidia driver installation issues
    • On Jetson, observing error : gstnvarguscamerasrc.cpp, execute:751 No cameras available
    • Graph Composer Troubleshooting
      • My component is not visible in the composer even after registering the extension with registry
      • My component is getting registered as an abstract type.
      • When executing a graph, the execution ends immediately with the warning “No system specified. Nothing to do”
  • Frequently Asked Questions
    • DeepStream General topics
      • How do I uninstall DeepStream?
      • What types of input streams does DeepStream 6.2 support?
      • What’s the throughput of H.264 and H.265 decode on dGPU (Tesla)?
      • How can I run the DeepStream sample application in debug mode?
      • Where can I find the DeepStream sample applications?
      • How can I verify that CUDA was installed correctly?
      • How can I interpret frames per second (FPS) display information on console?
      • My DeepStream performance is lower than expected. How can I determine the reason?
      • How can I specify RTSP streaming of DeepStream output?
      • What is the official DeepStream Docker image and where do I get it?
      • What is the recipe for creating my own Docker image?
      • How can I display graphical output remotely over VNC? How can I determine whether X11 is running?
      • Why does the deepstream-nvof-test application show the error message “Device Does NOT support Optical Flow Functionality” ?
      • Why is the Gst-nvstreammux plugin required in DeepStream 4.0+?
      • How do I profile DeepStream pipeline?
      • How can I check GPU and memory utilization on a dGPU system?
      • What is the approximate memory utilization for 1080p streams on dGPU?
      • When deepstream-app is run in loop on Jetson AGX Xavier using “while true; do deepstream-app -c <config_file>; done;”, after a few iterations I see low FPS for certain iterations. Why is that?
      • Why do I get the error incorrect camera parameters provided, please provide supported resolution and frame rate when I compile DeepStream sample application with source1_usb_dec_infer_resnet_int8.txt config in default setting on Jetson?
      • Why do I get the error Makefile:13: *** "CUDA_VER is not set".  Stop when I compile DeepStream sample applications?
      • How can I construct the DeepStream GStreamer pipeline?
      • How to set camera calibration parameters in Dewarper plugin config file?
      • How to get camera calibration parameters for usage in Dewarper plugin?
      • How to minimize FPS jitter with DS application while using RTSP Camera Streams?
      • Why am I getting “ImportError: No module named google.protobuf.internal when running convert_to_uff.py on Jetson AGX Xavier”?
      • Does DeepStream Support 10 Bit Video streams?
      • What is the difference between batch-size of nvstreammux and nvinfer? What are the recommended values for nvstreammux batch-size?
      • Why do some caffemodels fail to build after upgrading to DeepStream 6.2?
      • How do I configure the pipeline to get NTP timestamps?
      • Why is the NTP timestamp value 0?
      • How to handle operations not supported by Triton Inference Server?
      • Why do I see confidence value as -0.1.?
      • How to use the OSS version of the TensorRT plugins in DeepStream?
      • Why do I see the below Error while processing H265 RTSP stream?
      • Why do I observe: A lot of buffers are being dropped. When running live camera streams even for few or single stream, also output looks jittery?
      • Why does the RTSP source used in gst-launch pipeline through uridecodebin show blank screen followed by the error - WARNING: from element /GstPipeline:pipeline0/GstNvStreamMux:m: No Sources found at the input of muxer. Waiting for sources?
      • What if I do not get expected 30 FPS from camera using v4l2src plugin in pipeline but instead get 15 FPS or less than 30 FPS?
      • On Jetson platform, I get same output when multiple Jpeg images are fed to nvv4l2decoder using multifilesrc plugin. Why is that?
      • On Jetson platform, I observe lower FPS output when screen goes idle.
      • How do I obtain individual sources after batched inferencing/processing? What are the sample pipelines for nvstreamdemux?
      • Why do I encounter such error while running Deepstream pipeline memory type configured and i/p buffer mismatch ip_surf 0 muxer 3?
      • How does secondary GIE crop and resize objects?
      • How to save frames from GstBuffer?
      • What are different Memory types supported on Jetson and dGPU?
      • What are different Memory transformations supported on Jetson and dGPU?
      • Why does my image look distorted if I wrap my cudaMalloc’ed memory into NvBufSurface and provide to NvBufSurfTransform?
      • Why am I getting following warning when running deepstream app for first time?
      • How to find out the maximum number of streams supported on given platform?
      • How to find the performance bottleneck in DeepStream?
      • How to fix “cannot allocate memory in static TLS block” error?
      • How to measure pipeline latency if pipeline contains open source components
      • Migration to newer gstreamer version
    • Smart Record
      • Does smart record module work with local video streams?
      • Are multiple parallel records on same source supported?
      • What if I forgot to stop the recording?
      • I started the record with a set duration. Can I stop it before that duration ends?
      • What if I don’t set default duration for smart record?
      • What if I don’t set video cache size for smart record?
      • What is maximum duration of data I can cache as history for smart record?
      • Can I record the video with bounding boxes and other information overlaid?
    • Triton
      • Can Jetson platform support the same features as dGPU for Triton plugin?
      • How to enable TensorRT optimization for Tensorflow and ONNX models?
      • How to tune GPU memory for Tensorflow models?
      • Can Gst-nvinferserver support models cross processes or containers?
      • Can users set different model repos when running multiple Triton models in single process?
      • What is the difference between DeepStream classification and Triton classification?
      • Why is max_batch_size: 0 used in some Triton model config files (samples/triton_model_repo/*/config.pbtxt)?
      • How to support Triton ensemble model?
      • Why am I getting error Could not get EGL display connection while running deepstream sample application?
      • Does Gst-nvinferserver support Triton multiple instance groups?
      • Can Gst-nvinferserver support inference on multiple GPUs?
      • What is batch-size differences for a single model in different config files (gie group in source, config_inferserver.., and Triton model’s config.pbtxt)?
      • How to use NVTX for profiling?
      • Why do I get the WARNING WARNING from src_elem: No decoder available for type 'audio/mpeg, mpegversion=(int)4’ when I run deepstream-app sample configuration on DS docker containers?
      • Why do I get the WARNING: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': libavfilter.so.7: cannot open shared object file: No such file or directory when using deepstream-app –version-all?
DeepStream API Guide
  • DeepStream API Guides
DeepStream Legal Information
  • DeepStream Legal Information
    • Notice
    • Trademarks
    • Copyright
DeepStream Feedback
  • Feedback form
    • Request Documentation Fix
DeepStream
  • Docs »
  • View page source
DeepStream Reference Application on GitHub¶
Use case applications¶
  • Face Mask Detection (TAO + DeepStream)
  • Redaction with DeepStream
  • Using RetinaNet for face redaction
  • People counting using DeepStream
  • DeepStream Pose Estimation
  • DeepStream License Plate detection and recognition
AI models with DeepStream¶
  • YoloV4 with DeepStream
  • Deploy TensorFlow FasterRCNN model using Triton and DeepStream
  • TAO model deployment in DeepStream
DeepStream features sample¶
  • Back to back detectors with DeepStream
  • Runtime source addition/removal with DeepStream
  • Anomaly detection using NV Optical Flow using DeepStream
  • Custom Post-processing for SSD model in Python DeepStream app (Python)
  • Save image metadata from DeepStream pipeline (Python)
Next Previous
© Copyright 2022, NVIDIA. Last updated on Dec 16, 2022.
Built with Sphinx using a theme provided by Read the Docs.
