8.0 Release
28 #ifndef __NVDSPREPROCESS_INTERFACE_H__
29 #define __NVDSPREPROCESS_INTERFACE_H__
32 #include <cuda_runtime.h>
38 #include "nvtx3/nvToolsExt.h"
39 #include <unordered_map>
135 std::vector<int> network_input_shape;
139 guint64 buffer_size = 1;
145 std::string tensor_name;
158 unsigned int channels;
167 std::vector<NvDsRoiMeta> roi_vector;
191 std::unordered_map <std::string, std::string> user_configs;
193 gchar *config_file_path;
229 guint batch_index = 0;
231 gulong frame_num = 0;
238 gpointer converted_frame_ptr =
nullptr;
250 std::vector<NvDsPreProcessUnit> units;
252 std::vector<NvBufSurfTransformSyncObj_t> sync_objects;
256 gulong inbuf_batch_num = 0;
261 gboolean push_buffer = FALSE;
265 gboolean event_marker = FALSE;
275 nvtxRangeId_t nvtx_complete_buf_range = 0;
278 #endif //__NVDSPREPROCESS_INTERFACE_H__
@ NvDsPreProcessFormat_Unknown
Custom Initialization parameter for custom library.
struct NvBufSurfTransformSyncObj * NvBufSurfTransformSyncObj_t
Holds the information about synchronization objects for asynchronous transform/composite APIs.
@ NVDSPREPROCESS_CUSTOM_LIB_FAILED
Custom Library interface implementation failed.
virtual gboolean release(NvDsPreProcessCustomBuf *)=0
method to release buffer from buffer pool
@ NVDSPREPROCESS_CONFIG_FAILED
Failed to configure the tensor_impl instance possibly due to an erroneous initialization property.
@ NvDsPreProcessFormat_RGB
Specifies 24-bit interleaved R-G-B format.
@ NvDsPreProcessNetworkInputOrder_kNHWC
Specifies NHWC network input order.
@ NVDSPREPROCESS_TENSOR_NOT_READY
Tensor Yet not ready to be attached as meta.
@ NVDSPREPROCESS_RESOURCE_ERROR
Resource error was encountered.
Holds information about the batch of frames to be inferred.
@ NvDsPreProcessFormat_RGBA
Specifies 32-bit interleaved R-G-B-A format.
@ NvDsPreProcessFormat_GRAY
Specifies 8-bit Luma format.
@ NVDSPREPROCESS_INVALID_PARAMS
Invalid parameters were supplied.
NvDsPreProcessStatus
Enum for the status codes returned by NvDsPreProcessImpl.
@ NVDSPREPROCESS_SUCCESS
NvDsPreprocess operation succeeded.
Hold the information of single buffer in the batch.
@ NvDsPreProcessFormat_Tensor
NCHW planar.
@ NVDSPREPROCESS_CUSTOM_TENSOR_FAILED
Custom Tensor Preparation failed.
A preprocess unit for processing which can be Frame/ROI.
@ NVDSPREPROCESS_TENSORRT_ERROR
TensorRT interface failed.
Tensor params passed to custom library for tensor preparation.
@ NVDSPREPROCESS_CUSTOM_TRANSFORMATION_FAILED
Custom Group Transformation failed.
Custom Buffer passed to the custom lib for preparing tensor.
class for acquiring and releasing a buffer from tensor pool by custom lib.
NvBufSurfaceMemType
Specifies memory types for NvBufSurface.
Holds model parameters for tensor preparation.
Enum for the network input order according to which network shape will be provided to prepare raw ten...
@ NvDsPreProcessFormat_BGRx
Specifies 32-bit interleaved B-G-R-x format.
struct _GstBuffer GstBuffer
@ NvDsPreProcessNetworkInputOrder_kNCHW
Specifies NCHW network input order.
@ NvDsPreProcessNetworkInputOrder_CUSTOM
Specifies any other custom input order handled by custom lib.
struct CustomCtx CustomCtx
Context for custom library.
Specifies 24-bit interleaved B-G-R format.
@ NVDSPREPROCESS_OUTPUT_PARSING_FAILED
Output parsing failed.
Defines model color formats.
@ NVDSPREPROCESS_CUDA_ERROR
CUDA error was encountered.
virtual NvDsPreProcessCustomBuf * acquire()=0
method to acquire a buffer from buffer pool
NvDsDataType
Data type used for model in infer.
Tensor params for Custom sequence processing for 3d conv network.
void * memory_ptr
memory ptr where to store prepared tensor
