sources/includes/nvdsinfer_context.h File Reference
NVIDIA DeepStream Inference Interface
Description: This file specifies the DeepStream inference interface API.
Definition in file sources/includes/nvdsinfer_context.h.
Data Structures
struct  NvDsInferDetectionParams
 Holds detection and bounding box grouping parameters. More...
struct  _NvDsInferContextInitParams
 Holds the initialization parameters required for the NvDsInferContext interface. More...
struct  NvDsInferContextBatchInput
 Holds information about one batch to be inferred. More...
struct  NvDsInferContextBatchPreprocessedInput
struct  NvDsInferObject
 Holds information about one detected object. More...
struct  NvDsInferDetectionOutput
 Holds information on all objects detected by a detector network in one frame. More...
struct  NvDsInferClassificationOutput
 Holds information on all attributes classifed by a classifier network for one frame. More...
struct  NvDsInferSegmentationOutput
 Holds information parsed from segmentation network output for one frame. More...
struct  NvDsInferFrameOutput
 Holds the information inferred by the network on one frame. More...
struct  NvDsInferContextBatchOutput
 Holds the output for all of the frames in a batch (an array of frame), and related buffer information. More...
Variables
NvDsInferDimsCHW inputDims
 Holds the input dimensions for the model. More...
NvDsInferDimsCHW uffDimsCHW
 Holds the input dimensions for the UFF model. More...
NvDsInferContext API common types and functions.
This section describes the common types and functions for both the C and C++ interfaces for the NvDsInferContext class.
#define _PATH_MAX   4096
 Maximum length of a file path parameter. More...
#define _MAX_CHANNELS   4
 Defines the maximum number of channels supported by the API for image input layers. More...
#define _MAX_STR_LENGTH   1024
 Defines the maximum length of string parameters. More...
#define NVDSINFER_MAX_BATCH_SIZE   1024
 Defines the maximum batch size supported by nvdsinfer. More...
#define NVDSINFER_MIN_OUTPUT_BUFFERPOOL_SIZE   2
 Defines the minimum number of sets of output buffers that must be allocated. More...
#define NvDsInferUffOrder
enum  NvDsInferNetworkMode {
  NvDsInferNetworkMode_FP32,
  NvDsInferNetworkMode_INT8,
  NvDsInferNetworkMode_FP16,
  NvDsInferNetworkMode_BEST,
 Defines internal data formats used by the inference engine. More...
enum  NvDsInferNetworkType {
  NvDsInferNetworkType_Detector,
  NvDsInferNetworkType_Classifier,
  NvDsInferNetworkType_Segmentation,
  NvDsInferNetworkType_InstanceSegmentation,
  NvDsInferNetworkType_Other = 100,
 Defines network types. More...
enum  NvDsInferFormat {
  NvDsInferFormat_RGB,
  NvDsInferFormat_BGR,
  NvDsInferFormat_GRAY,
  NvDsInferFormat_RGBA,
  NvDsInferFormat_BGRx,
  NvDsInferFormat_Tensor,
  NvDsInferFormat_Unknown = 0xFFFFFFFF,
 Defines color formats. More...
enum  NvDsInferTensorOrder {
  NvDsInferTensorOrder_kNCHW,
  NvDsInferTensorOrder_kNHWC,
  NvDsInferTensorOrder_kNC,
  NvDsInferUffOrder_kNCHW =("Use NvDsInferTensorOrder_kNCHW instead") = NvDsInferTensorOrder_kNCHW,
  NvDsInferUffOrder_kNHWC =("Use NvDsInferTensorOrder_kNCWH instead") = NvDsInferTensorOrder_kNHWC,
  NvDsInferUffOrder_kNC =("Use NvDsInferTensorOrder_kNC instead") = NvDsInferTensorOrder_kNC,
 Defines UFF input layer orders. More...
enum  NvDsInferClusterMode {
  NVDSINFER_CLUSTER_GROUP_RECTANGLES = 0,
  NVDSINFER_CLUSTER_DBSCAN,
  NVDSINFER_CLUSTER_NMS,
  NVDSINFER_CLUSTER_DBSCAN_NMS_HYBRID,
  NVDSINFER_CLUSTER_NONE,
 Enum for clustering mode for detectors. More...
typedef struct _NvDsInferContextInitParams NvDsInferContextInitParams
typedef void(* NvDsInferContextReturnInputAsyncFunc) (void *data)
 Defines a callback function type for asynchronously returning the input client buffers to the NvDsInferContext client. More...
typedef struct INvDsInferContext * NvDsInferContextHandle
 An opaque pointer type to be used as a handle for a context instance. More...
typedef void(* NvDsInferContextLoggingFunc) (NvDsInferContextHandle handle, unsigned int uniqueID, NvDsInferLogLevel logLevel, const char *logMessage, void *userCtx)
 Type declaration for a logging callback. More...
void NvDsInferContext_ResetInitParams (NvDsInferContextInitParams *initParams)
 Resets a context parameter structure to default values. More...
int NvDsInferContext_SetDynamicProperty (NvDsInferContextInitParams *initParams, const char *key, const char *value)
 Dynamic property management functions for extensible TensorRT/trtexec flags. More...
const char * NvDsInferContext_GetDynamicProperty (const NvDsInferContextInitParams *initParams, const char *key)
 Get a dynamic property value. More...
int NvDsInferContext_HasDynamicProperty (const NvDsInferContextInitParams *initParams, const char *key)
 Check if a dynamic property exists. More...
void NvDsInferContext_ClearDynamicProperties (NvDsInferContextInitParams *initParams)
 Clear all dynamic properties. More...
void NvDsInferContext_ApplyDynamicPropertiesToBuilder (const NvDsInferContextInitParams *initParams, void *builderConfig)
 Apply dynamic properties to TensorRT builder configuration. More...
NvDsInferContext_GetStatusName is deprecated Use NvDsInferStatus2Str const instead char * NvDsInferContext_GetStatusName (NvDsInferStatus status)
 Gets the string name of the status. More...
Variable Documentation
◆ inputDims
Definition at line 272 of file sources/includes/nvdsinfer_context.h.
◆ uffDimsCHW
Definition at line 274 of file sources/includes/nvdsinfer_context.h.
