8.0 Release
- n -
NEW_METADATA :
gstnvstreammux.h
NV_MSGBROKER_VERSION :
nvmsgbroker.h
NVBUF_MAX_PLANES :
nvbufsurface.h
NVBUFSURF_MAX_SYNCOBJ :
nvbufsurftransform.h
NVBUFSURFACE_CHROMA_SUBSAMPLING_HORIZ_DEFAULT :
nvbufsurface.h
NVBUFSURFACE_CHROMA_SUBSAMPLING_PARAMS_DEFAULT :
nvbufsurface.h
NVBUFSURFACE_CHROMA_SUBSAMPLING_VERT_DEFAULT :
nvbufsurface.h
NVDS3D_BUF_MAGIC_ID :
nvds3d_meta.h
NVDS3D_MAGIC_ID :
nvds3d_meta.h
NVDS_3D_DATAMAP_META_TYPE :
nvds3d_meta.h
NVDS_APP_VERSION_MAJOR :
deepstream_app_version.h
NVDS_APP_VERSION_MICRO :
NVDS_APP_VERSION_MINOR :
NVDS_CONFIG_FILE_PROPERTY :
gst-nvdsspeech/includes/nvdscustomlib_interface.hpp
gst-nvdstexttospeech/includes/nvdscustomlib_interface.hpp
NVDS_DUMMY_BBOX_META :
nvdsdummyusermeta.h
NVDS_ELEM_AUDIO_CONV :
deepstream_config.h
NVDS_ELEM_AUDIO_RESAMPLER :
deepstream_config.h
NVDS_ELEM_BBOXFILTER :
deepstream_config.h
NVDS_ELEM_CAPS_FILTER :
deepstream_config.h
NVDS_ELEM_DECODEBIN :
deepstream_config.h
NVDS_ELEM_DEWARPER :
deepstream_config.h
NVDS_ELEM_DSANALYTICS_ELEMENT :
deepstream_config.h
NVDS_ELEM_DSEXAMPLE_ELEMENT :
deepstream_config.h
NVDS_ELEM_EGLTRANSFORM :
deepstream_config.h
NVDS_ELEM_ENC_H264_HW :
deepstream_config.h
NVDS_ELEM_ENC_H264_SW :
deepstream_config.h
NVDS_ELEM_ENC_H265_HW :
deepstream_config.h
NVDS_ELEM_ENC_H265_SW :
deepstream_config.h
NVDS_ELEM_ENC_MPEG4 :
deepstream_config.h
NVDS_ELEM_IDENTITY :
deepstream_config.h
NVDS_ELEM_INFER_AUDIO :
deepstream_config.h
NVDS_ELEM_INFER_SERVER :
deepstream_config.h
NVDS_ELEM_MKV :
deepstream_config.h
NVDS_ELEM_MSG_BROKER :
deepstream_config.h
NVDS_ELEM_MSG_CONV :
deepstream_config.h
NVDS_ELEM_MUX_MP4 :
deepstream_config.h
NVDS_ELEM_NVAISLE :
deepstream_config.h
NVDS_ELEM_NVINFER :
deepstream_config.h
NVDS_ELEM_NVMULTIURISRCBIN :
deepstream_config.h
NVDS_ELEM_OSD :
deepstream_config.h
NVDS_ELEM_PGIE :
deepstream_config.h
NVDS_ELEM_PREPROCESS :
deepstream_config.h
NVDS_ELEM_QUEUE :
deepstream_config.h
NVDS_ELEM_SECONDARY_PREPROCESS :
deepstream_config.h
NVDS_ELEM_SEGVISUAL :
deepstream_config.h
NVDS_ELEM_SGIE :
deepstream_config.h
NVDS_ELEM_SINK_3D :
deepstream_config.h
NVDS_ELEM_SINK_DRM :
deepstream_config.h
NVDS_ELEM_SINK_EGL :
deepstream_config.h
NVDS_ELEM_SINK_FAKESINK :
deepstream_config.h
NVDS_ELEM_SINK_FILE :
deepstream_config.h
NVDS_ELEM_SPOTANALYSIS :
deepstream_config.h
NVDS_ELEM_SRC_ALSA :
deepstream_config.h
NVDS_ELEM_SRC_CAMERA_CSI :
deepstream_config.h
NVDS_ELEM_SRC_CAMERA_V4L2 :
deepstream_config.h
NVDS_ELEM_SRC_MULTIFILE :
deepstream_config.h
NVDS_ELEM_SRC_URI :
deepstream_config.h
NVDS_ELEM_STREAM_DEMUX :
deepstream_config.h
NVDS_ELEM_STREAM_MUX :
deepstream_config.h
NVDS_ELEM_TEE :
deepstream_config.h
NVDS_ELEM_TILER :
deepstream_config.h
NVDS_ELEM_TRACKER :
deepstream_config.h
NVDS_ELEM_VIDEO_CONV :
deepstream_config.h
NVDS_ELEM_WAVPARSE :
deepstream_config.h
nvds_enable_component_latency_measurement :
nvds_latency_meta_internal.h
nvds_enable_latency_measurement :
nvds_latency_meta.h
NVDS_KAFKA_LOG_CAT :
kafka_client.h
NVDS_MAKE_FOURCC :
deepstream_can_context.hpp
NVDS_META_API_TYPE :
gstnvdsmeta.h
NVDS_META_INFO :
gstnvdsmeta.h
NVDS_META_STRING :
gstnvdsmeta.h
NVDS_MSGAPI_PROTOCOL :
nvds_kafka_proto.h
NVDS_MSGAPI_VERSION :
nvds_kafka_proto.h
NVDS_OBJ_IMAGE_FOOT_LOCATION :
kitti_dump_probe.hpp
NVDS_OBJ_VISIBILITY :
NVDS_RFC3339_STR_BUF_LEN :
gstnvstreammux_ntp.h
NVDS_TRACKER_PAST_FRAME_META :
NVDS_USER_CUSTOM_META :
nvdscustomusermeta.h
NVDS_USER_FRAME_META_NVDSANALYTICS :
nvds_analytics_meta.h
NVDS_USER_OBJ_META_NVDSANALYTICS :
NVDS_VERSION_MAJOR :
nvds_version.h
NVDS_VERSION_MICRO :
nvds_version.h
NVDS_VERSION_MINOR :
nvds_version.h
NVDSEXAMPLE_MAX_BATCH_SIZE :
gstdsexample_cuda.h
gstdsexample.h
gstdsexample_optimized.h
NVDSINFER_INVALID_CONVERSION_KEY :
infer_preprocess_kernel.h
NVDSINFER_MAX_BATCH_SIZE :
nvdsinfer_context.h
NVDSINFER_MAX_DIMS :
nvdsinfer.h
NVDSINFER_MAX_PREPROC_CHANNELS :
NVDSINFER_MIN_OUTPUT_BUFFERPOOL_SIZE :
nvdsinfer_context.h
NvDsInferUffOrder :
nvdsinfer_context.h
NVDSNMOS_API :
nvdsnmos.h
NVDSPREPROCESS_GROUP :
nvdspreprocess_property_parser.h
NVDSPREPROCESS_GROUP_CUSTOM_INPUT_PREPROCESS_FUNCTION :
NVDSPREPROCESS_GROUP_DRAW_ROI :
NVDSPREPROCESS_GROUP_INTERVAL :
NVDSPREPROCESS_GROUP_OBJECT_MAX_HEIGHT :
NVDSPREPROCESS_GROUP_OBJECT_MAX_WIDTH :
NVDSPREPROCESS_GROUP_OBJECT_MIN_HEIGHT :
NVDSPREPROCESS_GROUP_OBJECT_MIN_WIDTH :
NVDSPREPROCESS_GROUP_OPERATE_ON_CLASS_IDS :
NVDSPREPROCESS_GROUP_PROCESS_ON_ALL_OBJECTS :
NVDSPREPROCESS_GROUP_PROCESS_ON_ROI :
NVDSPREPROCESS_GROUP_ROI_COLOR :
NVDSPREPROCESS_GROUP_ROI_PARAMS_SRC :
NVDSPREPROCESS_GROUP_SRC_IDS :
NVDSPREPROCESS_PROPERTY :
NVDSPREPROCESS_PROPERTY_CUSTOM_LIB_NAME :
NVDSPREPROCESS_PROPERTY_ENABLE :
NVDSPREPROCESS_PROPERTY_GIE_ID_FOR_OPERATION :
NVDSPREPROCESS_PROPERTY_GPU_ID :
NVDSPREPROCESS_PROPERTY_MAINTAIN_ASPECT_RATIO :
NVDSPREPROCESS_PROPERTY_NETWORK_COLOR_FORMAT :
NVDSPREPROCESS_PROPERTY_NETWORK_INPUT_ORDER :
NVDSPREPROCESS_PROPERTY_NETWORK_SHAPE :
NVDSPREPROCESS_PROPERTY_PROCESS_ON_FRAME :
NVDSPREPROCESS_PROPERTY_PROCESSING_HEIGHT :
NVDSPREPROCESS_PROPERTY_PROCESSING_WIDTH :
NVDSPREPROCESS_PROPERTY_SCALING_BUF_POOL_SIZE :
NVDSPREPROCESS_PROPERTY_SCALING_FILTER :
NVDSPREPROCESS_PROPERTY_SCALING_POOL_COMPUTE_HW :
NVDSPREPROCESS_PROPERTY_SCALING_POOL_MEMORY_TYPE :
NVDSPREPROCESS_PROPERTY_SYMMETRIC_PADDING :
NVDSPREPROCESS_PROPERTY_TARGET_IDS :
NVDSPREPROCESS_PROPERTY_TENSOR_BUF_POOL_SIZE :
NVDSPREPROCESS_PROPERTY_TENSOR_DATA_TYPE :
NVDSPREPROCESS_PROPERTY_TENSOR_NAME :
NVDSPREPROCESS_PROPERTY_TENSOR_PREPARATION_FUNCTION :
NVDSPREPROCESS_PROPERTY_UNIQUE_ID :
NVDSPREPROCESS_SKIP_FRAME :
seq_process_common.h
NVDSPREPROCESS_USER_CONFIGS :
NVDSPREPROCESS_USER_CONFIGS_MEAN_FILE :
nvdspreprocess_lib.h
NVDSPREPROCESS_USER_CONFIGS_OFFSETS :
NVDSPREPROCESS_USER_CONFIGS_PIXEL_NORMALIZATION_FACTOR :
NVGSTDS_BIN_ADD_GHOST_PAD :
deepstream_common.h
NVGSTDS_BIN_ADD_GHOST_PAD_NAMED :
deepstream_common.h
NVGSTDS_ELEM_ADD_PROBE :
deepstream_common.h
NVGSTDS_ELEM_REMOVE_PROBE :
deepstream_common.h
NVGSTDS_ERR_MSG_V :
deepstream_common.h
NVGSTDS_INFO_MSG_V :
deepstream_common.h
NVGSTDS_LINK_ELEMENT :
deepstream_common.h
NVGSTDS_LINK_ELEMENT_FULL :
deepstream_common.h
NVGSTDS_WARN_MSG_V :
deepstream_common.h
NVINFER_PLUGIN :
deepstream_ucx_test_app.h
NVINFERSERVER_PLUGIN :
NVMOT_MAX_TRANSFORMS :
nvdstracker.h
NVMOTCOMP_ANY :
nvdstracker.h
NVMOTCOMP_CPU :
nvdstracker.h
NVMOTCOMP_DEFAULT :
nvdstracker.h
NVMOTCOMP_GPU :
nvdstracker.h
NVMOTCOMP_PVA :
nvdstracker.h
NVOSD_PRINT_E :
nvll_osd_api.h
NVSTREAMMUX_AUDIOSAMPLESIZE_TO_BYTES :
gstnvstreammux_audio.h
NVSTREAMMUX_BYTES_TO_AUDIOSAMPLESIZE :
NVWARP_VERSION_MAJOR :
NVWarp360.h
NVWARP_VERSION_MINOR :
NVWarp360.h
NVWARP_VERSION_REVISION :
NVWarp360.h
NVWARPAPI :
NVWarp360.h
Privacy Policy
Manage My Privacy
Do Not Sell or Share My Data
Terms of Service
Accessibility
Corporate Policies
Product Security
Contact
© 2025 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
NVIDIA Confidential | Subject to Change | For test and development only.
Tue Sep 9 2025 11:37:09 | PR-09318-R32
