GXF Command Line Interface¶
The GXF command line interface (CLI) can be invoked by gxf_cli command with the following options:
gxf_cli –help
gxf_cli --version
gxf_cli [-s SERVER] [-t TRANSPORT] command [args]
- Where
-h/--helpbrings up the help options and exit-v/--versionprints the version and exits.
Optional arguments:
-s/--server: specify the server address, bed default it is ‘localhost:8000’, which is the default address used by the http server in the GXF graph.-t/--transport: specify the transport type, by default it is ‘http’, can also be set to ‘grpc’ if the GXF graph enables GRPC server
The sections below provide details about the command options that can be used with the gxf_cli.
stat¶
This command is used to continuous monitor the statistic information from a running gxe process.
Command syntax
gxf_cli stat [-h] [-u UID] target
The target can be one of the follows:
entity- Monitor the entity statisticscodelet- Monitor the codelet statisticsevent- Monitor the scheduling event statisticsterm- Monitor the scheduling term statistics
Optional arguments:
-u/--uid: only monitor data on an entity or component with specified uid-h/--help- Print help and exit.
config¶
This command is used to set the parameter of a specific component in a running graph
Command syntax
gxf_cli config [-h] cid key value
cid: cid is the uid of the target component, can be replaced by “entity_name/component_name” if the names are availablekey: the parameter namevalue: the value to be set, in JSON format
Optional arguments:
dump¶
This command is used to dump the entities in the current running graph in parsable YAML format.
command syntax
gxf_cli dump [-h] [-u UID]
Optional arguments:
-u/--uid: only dump the data on the entity with specified uid-h/--help- Print help and exit.
Sample content dumped from a running graph:
components:
- name: signal
type: nvidia::gxf::DoubleBufferReceiver
parameters:
capacity: 1
policy: 2
- name: nvidia::gxf::MessageAvailableSchedulingTerm_rx
type: nvidia::gxf::MessageAvailableSchedulingTerm
parameters:
receiver: rx/signal
min_size: 1
- name: ping_rx
type: nvidia::gxf::test::PingRx
parameters:
signal: rx/signal
- name: step_count_rx
type: nvidia::gxf::test::StepCount
parameters:
use_assert: false
expected_start_count: 1
expected_count: 100
