Logo
6.3 Release
DeepStream Getting Started
  • Welcome to the DeepStream Documentation
    • NVIDIA DeepStream Overview
      • DeepStream Graph Architecture
      • DeepStream reference app
      • Getting started with building apps
      • DeepStream in Python
  • Readme First
    • Additional Resources
      • Documentation
      • Forums
  • Quickstart Guide
    • Jetson Setup
      • Install Jetson SDK components
      • Install Dependencies
        • Install librdkafka (to enable Kafka protocol adaptor for message broker)
      • Install latest NVIDIA BSP packages
      • Install the DeepStream SDK
      • Run deepstream-app (the reference application)
        • Boost the clocks
      • Run precompiled sample applications
    • dGPU Setup for Ubuntu
      • Remove all previous DeepStream installations
        • Install CUDA Toolkit 12.1
        • Install NVIDIA driver 525.125.06 (only for data center GPUs)
        • Install NVIDIA driver 530.41.03, for professional and consumer GPUs (GeForce/ NVIDIA RTX/ QUADRO)
        • Install cuda-compat-12-1 (only for data center GPUs)
        • Install TensorRT 8.5.3.1
      • Run the deepstream-app (the reference application)
    • dGPU Setup for RedHat Enterprise Linux (RHEL)
    • How to visualize the output if the display is not attached to the system
      • 1 . Running with an X server by creating virtual display
      • 2 . Running without an X server (applicable for applications supporting RTSP streaming output)
    • Platform and OS Compatibility
    • DeepStream Triton Inference Server Usage Guidelines
      • dGPU
      • Jetson
    • Using DLA for inference
      • Separate processes
      • Single process
  • Docker Containers
    • Prerequisites
      • A Docker Container for dGPU
      • A Docker Container for Jetson
      • Creating custom DeepStream dockers for dGPU or Jetson using DeepStreamSDK package
      • Recommended Minimal L4T Setup necessary to run the new docker images on Jetson
DeepStream Samples
  • C/C++ Sample Apps Source Details
    • Plugin and Library Source Details
  • Python Sample Apps and Bindings Source Details
    • Sample Application Source Details
    • Python Bindings and Application Development
      • Prerequisites
      • Running Sample Applications
      • Pipeline Construction
    • MetaData Access
      • Memory Management
      • Allocations
      • String Access
        • Setting String Fields
        • Reading String Fields
      • Casting
      • Callback Function Registration
      • Optimizations and Utilities
      • Image Data Access
  • DeepStream Reference Application - deepstream-app
    • Application Architecture
    • Reference Application Configuration
      • Expected Output for the DeepStream Reference Application (deepstream-app)
    • Configuration Groups
      • Application Group
      • Tiled-display Group
      • Source Group
      • Source-list and source-attr-all Groups
      • Streammux Group
      • Preprocess Group
      • Primary GIE and Secondary GIE Group
      • Tracker Group
      • Message Converter Group
      • Message Consumer Group
      • OSD Group
      • Sink Group
      • Tests Group
      • NvDs-analytics Group
    • Application Tuning for DeepStream SDK
      • Performance Optimization
        • DeepStream best practices
        • Jetson optimization
        • Triton
        • Inference Throughput
      • Reducing Spurious Detections
  • DeepStream Reference Application - deepstream-test5 app
    • IoT Protocols supported and cloud configuration
    • Message consumer
    • Smart Record - Event based recording
    • OTA model update
      • Using the OTA functionality
    • Sensor Provisioning Support over REST API (Runtime sensor add/remove capability)
  • DeepStream Reference Application - deepstream-audio app
    • DeepStream Audio Reference Application Architecture and Sample Graphs
  • DeepStream Reference Application - deepstream-nmos app
    • Using Easy-NMOS for NMOS Registry and Controller
  • DeepStream Reference Application on GitHub
    • Use case applications
    • AI models with DeepStream
    • DeepStream features sample
  • Sample Configurations and Streams
    • Contents of the package
      • Scripts included along with package
  • Implementing a Custom GStreamer Plugin with OpenCV Integration Example
    • Description of the Sample Plugin: gst-dsexample
      • GstBaseTransfrom Class Functions
      • Other supporting functions
    • Enabling and configuring the sample plugin
    • Using the sample plugin in a custom application/pipeline
    • Implementing Custom Logic Within the Sample Plugin
    • Adding NVTX APIs for sample plugin
    • Accessing NvBufSurface memory in OpenCV
TAO toolkit Integration with DeepStream
  • TAO Toolkit Integration with DeepStream
    • Pre-trained models
Tutorials and How-to's
  • Custom YOLO Model in the DeepStream YOLO App
    • How to Use the Custom YOLO Model
      • Set up the sample
  • NvMultiObjectTracker Parameter Tuning Guide
    • Accuracy-Performance Tradeoffs
      • Visual Feature Types and Feature Sizes
      • Detection Interval
      • Video Frame Size for Tracker
    • Robustness
      • Target Creation Policy
      • Target Termination Policy
    • State Estimation
      • Kalman Filter
    • Data Association
    • DCF Core Tuning
      • DCF Filter Learning
  • DeepStream 3D Custom Manual
    • DS3D Application Examples
    • ds3d::dataloader - Load Custom Lib for Data Capture
      • Load and Manage Dataloader
      • Dataloader in User Application
      • Implement a Custom Dataloader
    • ds3d::datafilter- Loads Custom Lib for Input and Output Processing
      • Load And Manage Datafilter
      • Datafilter in User Application
      • Implement a Custom Datafilter
    • ds3d::datarender - Loads Custom Lib for Data Rendering
      • Load And Manage Datarender
      • Datarender in User Application
      • Implement a Custom Datarender
    • DS3D GuardDataMap Buffer Management
      • DS3D Data Map Read
      • DS3D Data Map Write
    • Custom Libs Configuration Specifications
      • Components Common Configuration Specifications
      • libnvds_3d_dataloader_realsense Configuration Specifications
      • libnvds_3d_depth2point_datafilter Configuration Specifications
      • libnvds_3d_gl_datarender Configuration Specifications
      • libnvds_3d_depth_datasource Depth file source Specific Configuration Specifications
DeepStream Performance
  • Performance
    • TAO Pre-trained models
    • DeepStream reference model and tracker
    • Configuration File Settings for Performance Measurement
      • Data center GPU - GA100
        • System Configuration
        • Application Configuration
      • Data center GPU - T4
      • Data center GPU - A30
      • Data center GPU - A2
      • Data center GPU - A10
      • Data center GPU - H100
      • Data center GPU - L40
      • Data center GPU - Quadro (A6000)
      • Jetson
        • Jetson AGX Xavier
        • Jetson NX
        • Jetson AGX Orin
        • Jetson Orin NX
        • Jetson Orin Nano
DeepStream Custom Model
  • Using a Custom Model with DeepStream
    • Custom Model Implementation Interface
    • Custom Output Parsing
    • IPlugin Implementation
      • How to Use IPluginCreator
      • How to Use IPluginFactory
        • For Caffe Files
        • For Uff Files
        • During Deserialization
    • Input Layer Initialization
    • CUDA Engine Creation for Custom Models
    • IModelParser Interface for Custom Model Parsing
DeepStream Key Features
  • Smart Video Record
    • Smart Video Record Module APIs
    • Smart Video Record Configurations
  • IoT
    • Secure Edge-to-Cloud Messaging
      • 2-way TLS Authentication
        • Overview of Steps
        • TLS Version
        • Key generation
        • Certificate Signing
        • Choice of Cipher
        • Configure TLS options in Kafka config file for DeepStream
      • SASL/Plain
        • Overview of Steps
        • TLS Configuration
        • Credential Storage
        • Choosing Between 2-way TLS and SASL/Plain
      • Impact on performance
    • Bidirectional Messaging
      • Edge-to-Cloud
      • Cloud-to-Edge
      • NvMsgbroker Library
    • Autoreconnect feature
  • On the Fly Model Update
    • Assumptions
  • NTP Timestamp in DeepStream
  • AV Sync in DeepStream
    • Setup for RTMP/RTSP Input streams for testing
      • RTMP Server Setup
        • Command to simulate 2 RTMP streams using ffmpeg
      • RTSP Server Setup
    • AVSync Reference Pipelines
      • Pipelines with existing nvstreammux component
        • RTMP_IN -> RTMP_OUT
        • FILE_IN->RTSP_OUT
        • FILE_IN->RTMP_OUT
        • RTMP_IN->FILE_OUT
        • RTSP_IN->FILE_OUT
        • FILE_IN->FILE_OUT
        • RTSP_IN->RTSP_OUT
        • RTMP_IN->RTSP_OUT
      • Reference AVSync + ASR (Automatic Speech Recognition) Pipelines with existing nvstreammux
        • RTMP_IN->RTMP_OUT
        • RTSP_IN->RTMP_OUT
        • FILE_IN->RTMP_OUT
      • Pipelines with New nvstreammux component
        • RTMP_IN->RTMP_OUT
        • RTSP_IN->RTMP_OUT
        • FILE_IN->RTSP_OUT
        • FILE_IN->RTMP_OUT
        • RTMP_IN->FILE_OUT
        • RTSP_IN->FILE_OUT
        • FILE_IN->FILE_OUT
        • RTSP_IN->RTSP_OUT
        • RTMP_IN->RTSP_OUT
      • Reference AVSync + ASR Pipelines (with new nvstreammux)
        • RTMP_IN->RTMP_OUT
        • RTSP_IN->RTMP_OUT
        • FILE_IN->RTMP_OUT
      • Gst-pipeline with audiomuxer (single source, without ASR + new nvstreammux)
        • RTMP_IN->FILE_OUT
  • DeepStream With REST API Sever (Alpha)
    • Features
    • nvds_rest_server
    • deepstream-server-app
    • Sensor provisioning with deepstream-test5-app
    • How to add custom REST API support
      • REST API endpoints implementation
      • Handler Function Implementation Details
      • Custom event generation
      • Callback implementation for REST API endpoints
    • Schema and endpoints
      • Stream add/remove
      • ROI
      • Decoder
      • Nvinfer
      • Nvinferserver
      • Encoder
      • Streammux
      • Nvvideoconvert
      • Nvdsosd
      • Application Instance
    • Limitations
  • DeepStream 3D Action Recognition App
    • Getting Started
      • Prerequisites
      • Run 3D Action Recognition Examples
      • Run 2D Action Recognition Examples
    • DeepStream 3D Action Recognition App Configuration Specifications
      • deepstream-3d-action-recognition [action-recognition] group settings
      • Custom sequence preprocess lib user settings [user-configs] for gst-nvdspreprocess
      • Custom lib and `gst-nvdspreprocess` Settings for Action Recognition
    • Build Custom sequence preprocess lib and application From Source
  • DeepStream 3D Depth Camera App
    • Prerequisites
    • Depth Color Capture to 2D Rendering Pipeline Overview
    • Depth Color Capture to 3D Point Cloud Processing and Rendering
    • Getting Started
      • Run RealSense Camera for Depth Capture and 2D Rendering Examples
    • Run 3D Depth Capture, Point Cloud filter, and 3D Points Rendering Examples
    • DeepStream 3D Depth Camera App Configuration Specifications
      • deepstream-3d-depth-camera [ds3d::userapp] group settings
      • DS3D Custom Components Configuration Specifications
        • Build application From Source
  • DeepStream Lidar Inference App (Alpha)
    • Prerequisites
    • Lidar Point Cloud to 3D Point Cloud Processing and Rendering
    • Getting Started
      • Run Lidar Point Cloud Data File reader, Point Cloud Inferencing filter, and Point Cloud 3D rendering and data dump Examples
      • DeepStream Lidar Inference App Configuration Specifications
        • deepstream-lidar-inference-app [ds3d::userapp] group settings
  • Networked Media Open Specifications (NMOS) in DeepStream
    • Supported Specifications
    • Prerequisites
    • NvDsNmos API
  • Gst-nvdspostprocess in DeepStream
    • Detector models
    • Primary Classification model
    • Mask RCNN Model
    • Custom Parsing functions
  • DeepStream Can Orientation App
    • Getting Started
      • Prerequisites
      • Run DeepStream Can Orientation Examples
    • DeepStream Can Orientation App Configuration Specifications
      • deepstream-can-orientation-app settings
      • Custom lib libnvds_vpicanmatch.so Settings for Can Template Matching
DeepStream Application Migration
  • Application Migration to DeepStream 6.3 from DeepStream 6.2
    • Running DeepStream 6.2 compiled Apps in DeepStream 6.3
    • Compiling DeepStream 6.2 Apps in DeepStream 6.3
DeepStream Plugin Guide
  • GStreamer Plugin Overview
  • MetaData in the DeepStream SDK
    • NvDsBatchMeta: Basic Metadata Structure
    • User/Custom Metadata Addition inside NvDsBatchMeta
    • Adding Custom Meta in Gst Plugins Upstream from Gst-nvstreammux
      • Adding metadata to the plugin before Gst-nvstreammux
      • New metadata fields
  • Gst-nvdspreprocess (Alpha)
    • Inputs and Outputs
    • Features
    • Custom library Interfaces
    • Gst-nvdspreprocess File Configuration Specifications
    • Gst Properties
    • Sample pipelines
  • Gst-nvinfer
    • Features
    • Gst-nvinfer File Configuration Specifications
    • Gst Properties
    • Clustering algorithms supported by nvinfer
      • cluster-mode = 0 | GroupRectangles
      • cluster-mode = 1 | DBSCAN
      • cluster-mode = 2 | NMS
      • cluster-mode = 3 | Hybrid
      • cluster-mode=4 | No clustering
    • Tensor Metadata
      • To read or parse inference raw tensor data of output layers
    • Segmentation Metadata
  • Gst-nvinferaudio
    • Features
    • Gst Properties
  • Gst-nvinferserver
    • Gst-nvinferserver Configuration File Specifications
    • Features
    • Gst Properties
    • DeepStream Triton samples
    • DeepStream Triton gRPC support
    • Triton Ensemble Models
    • Custom Process interface IInferCustomProcessor for Extra Input, LSTM Loop, Output Data Postprocess
    • Tensor Metadata Output for Downstream Plugins
  • Gst-nvtracker
    • Gst Properties
    • NvDsTracker API for Low-Level Tracker Library
    • NvMultiObjectTracker : A Reference Low-Level Tracker Library
    • Unified Tracker Architecture for Composable Multi-Object Tracker
    • Workflow and Core Modules in The NvMultiObjectTracker Library
      • Data Association
      • Target Management and Error Handling
      • State Estimation
      • Object Re-Identification
      • Target Re-Association
      • Bounding-box Unclipping
      • Configuration Parameters
    • Low-Level Tracker Comparisons and Tradeoffs
    • IOU Tracker
    • NvSORT Tracker
    • NvDeepSORT Tracker
      • Data Association
      • Implementation Details and Reference
    • NvDCF Tracker
      • Visual Tracking
      • Data Association
    • Setup and Usage of Re-ID Model
      • Setup Sample Re-ID Models
        • NVIDIA TAO ReIdentificationNet
        • ONNX Model
        • UFF Model (Deprecated)
      • Re-ID Model Calibration (Optional)
      • Customize Re-ID Model
      • Re-ID Feature Output
    • Setup and Visualization of Tracker Sample Pipelines
      • People Tracking
        • Setup
        • PeopleNet + NvSORT
        • PeopleNet + NvDeepSORT
        • PeopleNet + NvDCF
      • Vehicle Tracking
        • Setup
        • DetectNet_v2 + NvDCF
        • DetectNet_v2 (w/ interval=2) + NvDCF
        • TrafficCamNet + NvSORT
        • TrafficCamNet + NvDeepSORT
        • TrafficCamNet + NvDCF
    • How to Implement a Custom Low-Level Tracker Library
  • Gst-nvstreammux
    • Features
    • Gst Properties
    • Known Issues with Solutions and FAQ
      • 1. gst-inspect is not updated properly when switching between legacy and new streammux
  • Gst-nvstreammux New
    • Features
    • Gst Properties
    • Mux Config Properties
    • NvStreamMux Tuning Solutions for specific use cases
      • 1. Aim
      • 2. Important Tuning parameters
      • 3. Video + Audio muxing Use cases
        • 3.1. Video and Audio muxing; file sources of different fps
        • 3.2 Video and Audio muxing; RTMP/RTSP sources
      • 4. Troubleshooting
        • 4.1 GstAggregator plugin -> filesink does not write data into the file
        • 4.2 nvstreammux WARNING “Lot of buffers are being dropped”
      • 5. Metadata propagation through nvstreammux and nvstreamdemux
        • 5.1 Adding GstMeta to buffers before nvstreammux.
        • 5.2 Accessing GstMeta post nvstreammux.
        • 5.3 Adding GstMeta post nvstreammux.
        • 5.4 To access NvDsMeta after nvstreamdemux.src_pad
      • 6. Cascaded Muxing
      • 1. Observing video and/or audio stutter (low framerate)
      • 2. Sink plugin shall not move asynchronously to PAUSED
      • 3. Heterogeneous batching
      • 4. Adaptive Batching
      • 5. Optimizing nvstreammux config for low-latency vs Compute
      • 6. Latency Measurement API Usage guide for audio
      • 7. gst-inspect is not updated properly when switching between legacy and new streammux
  • Gst-nvstreamdemux
      • Use case 1
      • Use case 2
      • Use case 3
  • Gst-nvmultistreamtiler
    • Features
    • Gst Properties
  • Gst-nvdsosd
    • Features
    • Gst Properties
  • Gst-nvdsmetautils
    • Gst-nvdsmetainsert
    • Features
    • customlib_impl Interfaces
    • Gst Properties
    • Use Cases & Sample Pipelines
    • Gst-nvdsmetaextract
    • Features
    • Gst Properties
  • Gst-nvdsvideotemplate
    • Features
    • Gst Properties
    • Sample pipelines
  • Gst-nvdsaudiotemplate
    • Features
    • Gst Properties
    • Sample pipelines
  • Gst-nvvideoconvert
    • Features
    • Gst Properties
  • Gst-nvdewarper
    • Features
    • Configuration File Parameters
    • Gst Properties
  • Gst-nvof
    • Features
    • Gst Properties
  • Gst-nvofvisual
    • Features
    • Gst Properties
  • Gst-nvsegvisual
    • Features
    • Gst Properties
  • Gst-nvvideo4linux2
    • Decoder
      • Features
      • Gst Properties
    • Encoder
      • Features
      • Gst Properties
  • Gst-nvjpegdec
    • Features
    • Gst Properties
  • Gst-nvjpegenc
    • Features
    • Gst Properties
  • Gst-nvmsgconv
    • Features
    • Gst Properties
    • NvMsgConv low level library API’s
    • Schema Customization
    • Payload with Custom Objects
  • Gst-nvmsgbroker
    • Features
    • Gst Properties
    • nvds_msgapi: Protocol Adapter Interface
      • nvds_msgapi_connect(): Create a Connection
      • nvds_msgapi_send() and nvds_msgapi_send_async(): Send an event
      • nvds_msgapi_subscribe(): Consume data by subscribing to topics
      • nvds_msgapi_do_work(): Incremental Execution of Adapter Logic
      • nvds_msgapi_disconnect(): Terminate a Connection
      • nvds_msgapi_getversion(): Get Version Number
      • nvds_msgapi_get_protocol_name(): Get name of the protocol
      • nvds_msgapi_connection_signature(): Get Connection signature
    • nvds_kafka_proto: Kafka Protocol Adapter
      • Installing Dependencies
      • Using the Adapter
      • Configuring Protocol Settings
      • Programmatic Integration
      • Security for Kafka
    • Azure MQTT Protocol Adapter Libraries
      • Setting Up Azure IoT
      • Configuring Adapter Settings
      • Using the Adapter
        • Connection Details for the Device Client Adapter
        • Connection Details for the Module Client Adapter
      • Monitor Adapter Execution
        • Azure device client library log messages
        • Azure Module Client Library Log Messages
      • Message Topics and Routes
    • AMQP Protocol Adapter
      • AMQP broker
      • Configure Adapter Settings
      • Using the Adapter
    • REDIS Protocol Adapter
      • REDIS server
      • Using the Adapter
    • MQTT Protocol Adapter (Alpha)
      • Eclipse Mosquitto
      • Using the Adapter
    • nv_msgbroker: Message Broker interface
      • nv_msgbroker_connect(): Create a Connection
      • nv_msgbroker_send_async(): Send an event asynchronously
      • nv_msgbroker_subscribe(): Consume data by subscribing to topics
      • nv_msgbroker_disconnect(): Terminate a Connection
      • nv_msgbroker_version(): Get Version Number
      • Work-interval configuration
      • nvds_logger: Logging Framework
        • Enabling Logging
        • Filtering Logs
        • Retiring and Managing Logs
        • Generating Logs
  • Gst-nvdsanalytics
    • Features
    • Gst Properties
  • Gst-nvdsasr
    • Features
    • DS-Riva ASR Library YAML File Configuration Specifications
    • Gst Properties
      • Riva ASR Service Deployment
      • gRPC C++ Library Installation
      • Sample Test Application
  • Gst-nvds_text_to_speech (Alpha)
    • Features
    • DS-Riva TTS Yaml File Configuration Specifications
    • Gst Properties
      • Riva TTS Service Initiation
      • gRPC C++ Installation
  • Gst-nvdsudpsrc
    • Features
    • Gst Properties
    • Example pipelines
  • Gst-nvdsudpsink
    • Features
    • Gst Properties
    • Example pipelines
  • Gst-nvdspostprocess (Alpha)
    • Features
    • Gst-nvdspostprocess File Configuration Specifications
    • Gst Properties
    • Sample pipelines
  • Gst-nvds3dfilter
    • Gst-nvds3dfilter properties Specifications
  • Gst-nvdsucx (Alpha)
    • Description
    • Requirements
    • Gst Properties
    • Examples
  • Gst-nvdsxfer
    • Gst Properties
    • How to test
    • Use cases
      • Single Stream + Multi-dGPUs Setup
      • Multiple Streams + Multi-dGPU Setup
  • Gst-nvvideotestsrc
    • Outputs
    • Gst Properties
    • How to test
  • Gst-nvmultiurisrcbin (Alpha)
    • 1. Introduction
    • 2. Features
    • 3. How to use nvmultiurisrcbin in a pipeline
      • 3.1 REST API payload definitions and sample curl commands for reference
        • 3.1.1 ADD a new stream to a DeepStream pipeline
        • 3.1.2 REMOVE a new stream to a DeepStream pipeline
    • 4. Gst Properties
      • 4.1 Gst Properties directly configuring nvmultiurisrcbin
      • 4.2 Gst Properties to configure each instance of nvurisrcbin created inside this bin
      • 4.3 Gst Properties to configure the instance of nvstreammux created inside this bin
    • 5. Important Notes
      • 5.1 nvmultiurisrcbin config recommendations and notes on expected behavior
    • 6. Known Issues
  • Gst-nvurisrcbin
    • 1. Introduction
    • 2. How to use nvurisrcbin in a pipeline
    • 3. Gst Properties
      • 3.1 Gst Properties to configure nvurisrcbin
DeepStream Troubleshooting and FAQ
  • Troubleshooting
    • You are migrating from DeepStream 6.0 to DeepStream 6.3
    • Inference
      • Application fails to run when the neural network is changed
    • Performance
      • The DeepStream application is running slowly (Jetson only)
    • Triton
      • Errors occur when deepstream-app fails to load plugin Gst-nvinferserver
      • Tensorflow models are running into OOM (Out-Of-Memory) problem
    • Troubleshooting in Tracker Setup and Parameter Tuning
      • Flickering Bbox
      • Frequent tracking ID changes although no nearby objects
      • Frequent tracking ID switches to the nearby objects
      • Setup Re-ID model
      • Error while running ONNX / Explicit batch dimension networks
    • Graph Composer Troubleshooting
      • My component is not visible in the composer even after registering the extension with registry
      • My component is getting registered as an abstract type.
      • When executing a graph, the execution ends immediately with the warning “No system specified. Nothing to do”
    • Miscellaneous
      • “NvDsBatchMeta not found for input buffer” error while running DeepStream pipeline
      • The DeepStream reference application fails to launch, or any plugin fails to load
      • Errors occur when deepstream-app is run with a number of streams greater than 100
      • After removing all the sources from the pipeline crash is seen if muxer and tiler are present in the pipeline
      • Some RGB video format pipelines worked before DeepStream 6.1 onwards on Jetson but don’t work now
      • UYVP video format pipeline doesn’t work on Jetson
      • Memory usage keeps on increasing when the source is a long duration containerized files(e.g. mp4, mkv)
      • Stale frames observed on RTSP output
      • DeepStream plugins failing to load without DISPLAY variable set when launching DS dockers
      • Nvidia driver installation issues
      • On Jetson, observing error : gstnvarguscamerasrc.cpp, execute:751 No cameras available
      • deepstream(-test5)-app fail to start when [source-list] config num-source-bins=0
      • Sensor removal is not working as expected with nvmultiurisrcbin [corner case]
  • Frequently Asked Questions
    • DeepStream General topics
      • How do I uninstall DeepStream?
      • What types of input streams does DeepStream 6.3 support?
      • What’s the throughput of H.264 and H.265 decode on dGPU (Tesla)?
      • How can I run the DeepStream sample application in debug mode?
      • Where can I find the DeepStream sample applications?
      • How can I verify that CUDA was installed correctly?
      • How can I interpret frames per second (FPS) display information on console?
      • My DeepStream performance is lower than expected. How can I determine the reason?
      • How can I specify RTSP streaming of DeepStream output?
      • What is the official DeepStream Docker image and where do I get it?
      • What is the recipe for creating my own Docker image?
      • How can I display graphical output remotely over VNC? How can I determine whether X11 is running?
      • Why does the deepstream-nvof-test application show the error message “Device Does NOT support Optical Flow Functionality” ?
      • Why is the Gst-nvstreammux plugin required in DeepStream 4.0+?
      • How do I profile DeepStream pipeline?
      • How can I check GPU and memory utilization on a dGPU system?
      • What is the approximate memory utilization for 1080p streams on dGPU?
      • When deepstream-app is run in loop on Jetson AGX Xavier using “while true; do deepstream-app -c <config_file>; done;”, after a few iterations I see low FPS for certain iterations. Why is that?
      • Why do I get the error incorrect camera parameters provided, please provide supported resolution and frame rate when I compile DeepStream sample application with source1_usb_dec_infer_resnet_int8.txt config in default setting on Jetson?
      • Why do I get the error Makefile:13: *** "CUDA_VER is not set".  Stop when I compile DeepStream sample applications?
      • How can I construct the DeepStream GStreamer pipeline?
      • How to set camera calibration parameters in Dewarper plugin config file?
      • How to get camera calibration parameters for usage in Dewarper plugin?
      • How to minimize FPS jitter with DS application while using RTSP Camera Streams?
      • Why am I getting “ImportError: No module named google.protobuf.internal when running convert_to_uff.py on Jetson AGX Xavier”?
      • Does DeepStream Support 10 Bit Video streams?
      • What is the difference between batch-size of nvstreammux and nvinfer? What are the recommended values for nvstreammux batch-size?
      • Why do some caffemodels fail to build after upgrading to DeepStream 6.3?
      • How do I configure the pipeline to get NTP timestamps?
      • Why is the NTP timestamp value 0?
      • Why do I see confidence value as -0.1.?
      • How to use the OSS version of the TensorRT plugins in DeepStream?
      • Why do I see the below Error while processing H265 RTSP stream?
      • Why do I observe: A lot of buffers are being dropped. When running live camera streams even for few or single stream, also output looks jittery?
      • Why does the RTSP source used in gst-launch pipeline through uridecodebin show blank screen followed by the error - WARNING: from element /GstPipeline:pipeline0/GstNvStreamMux:m: No Sources found at the input of muxer. Waiting for sources?
      • What if I do not get expected 30 FPS from camera using v4l2src plugin in pipeline but instead get 15 FPS or less than 30 FPS?
      • On Jetson platform, I get same output when multiple Jpeg images are fed to nvv4l2decoder using multifilesrc plugin. Why is that?
      • On Jetson platform, I observe lower FPS output when screen goes idle.
      • How do I obtain individual sources after batched inferencing/processing? What are the sample pipelines for nvstreamdemux?
      • Why do I encounter such error while running Deepstream pipeline memory type configured and i/p buffer mismatch ip_surf 0 muxer 3?
      • How does secondary GIE crop and resize objects?
      • How to save frames from GstBuffer?
      • What are different Memory types supported on Jetson and dGPU?
      • What are different Memory transformations supported on Jetson and dGPU?
      • Why does my image look distorted if I wrap my cudaMalloc’ed memory into NvBufSurface and provide to NvBufSurfTransform?
      • How to find out the maximum number of streams supported on given platform?
      • How to find the performance bottleneck in DeepStream?
      • How to fix “cannot allocate memory in static TLS block” error?
      • How to measure pipeline latency if pipeline contains open source components
      • Migration to newer gstreamer version
      • Why do I get the WARNING WARNING from src_elem: No decoder available for type 'audio/mpeg, mpegversion=(int)4’ when I run deepstream-app sample configuration on DS docker containers?
      • Why do I get the WARNING: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': libavfilter.so.7: cannot open shared object file: No such file or directory when using deepstream-app –version-all?
      • On x86, why do I get below ERROR during compilation and running of application/libs/plugins : Cuda failure: the provided PTX was compiled with an unsupported toolchain NvDsInferConvert_C3ToP3Float: cuda err = the provided PTX was compiled with an unsupported toolchain.?
    • Smart Record
      • Does smart record module work with local video streams?
      • Are multiple parallel records on same source supported?
      • What if I forgot to stop the recording?
      • I started the record with a set duration. Can I stop it before that duration ends?
      • What if I don’t set default duration for smart record?
      • What if I don’t set video cache size for smart record?
      • What is maximum duration of data I can cache as history for smart record?
      • Can I record the video with bounding boxes and other information overlaid?
    • Triton
      • Can Jetson platform support the same features as dGPU for Triton plugin?
      • How to enable TensorRT optimization for Tensorflow and ONNX models?
      • How to tune GPU memory for Tensorflow models?
      • Why am I getting following warning when running deepstream app for first time?
      • How to handle operations not supported by Triton Inference Server?
      • Can Gst-nvinferserver support models across processes or containers?
      • Can users set different model repos when running multiple Triton models in single process?
      • What is the difference between DeepStream classification and Triton classification?
      • Why is max_batch_size: 0 used in some Triton model config files (samples/triton_model_repo/*/config.pbtxt)?
      • How to support Triton ensemble model?
      • Why am I getting error Could not get EGL display connection while running deepstream sample application?
      • Does Gst-nvinferserver support Triton multiple instance groups?
      • Can Gst-nvinferserver support inference on multiple GPUs?
      • What is batch-size differences for a single model in different config files (gie group in source, config_inferserver.., and Triton model’s config.pbtxt)?
      • Profiling using NVTX
Graph Composer
  • Overview
    • Concepts
      • GXF (Graph eXecution Format)
      • Graph
      • Node
      • Components
      • Codelets
      • Subgraph
      • System
      • Edges / Connection
      • Messages
      • Extension
      • Graph eXecution Engine (GXE)
    • Tools
      • Graph Composer
      • Registry
      • Container Builder
      • GXF Server
      • GXF CLI
    • Workflow
Platforms
  • Ubuntu 20.04 LTS (x86_64)
    • Features Supported
    • System Requirements
    • Install
  • Ubuntu 20.04 LTS (ARM64 Jetson)
    • Install
  • Windows 10 (x86_64)
Getting Started
  • Application Workflow
    • Launch Graph Composer
    • Sync Extensions
    • Create a Graph
    • Run Graph from Graph Composer
      • Local System
      • Remote System
    • Run Graph from Command line
    • Create Container Image from Graph Composer
      • Local System
      • Remote System (Windows)
    • DeepStream Application
  • Creating an AI Application
    • Launch Composer
    • Drag and Drop Components
    • Configure Components
    • Connect Components
    • Add GStreamer Scheduler
    • Count Number Of People
    • Save Graph
    • Use Multiple inputs
    • Runtime add/remove inputs
  • Reference graphs
    • Installing the reference graphs
    • deepstream-test1
      • Graph Files
      • Graph
      • Sample Output
    • deepstream-test2
      • Graph Files
      • Graph
      • Sample Output
    • deepstream-test3
      • Graph Files
      • Graph
      • Sample Output
    • deepstream-test4
      • Graph Files
      • Graph
      • Sample Output
    • deepstream-test5
      • Graph and related files
      • Graph
      • Sample Output
    • deepstream-runtime-src-add-del
      • Graph Files
      • Graph
      • Sample Output
    • deepstream-template-plugin
      • Graph Files
      • Graph
      • Sample Output
    • deepstream-app
      • Graph Files
    • deepstream-audio
      • Graph files
      • Graph
      • Sample Output
    • deepstream-triton
      • Graph
      • Sample Output
    • deepstream-camera
      • Graph
      • Sample Output
    • deepstream-action-recognition
      • Graph
      • Sample Output
    • deepstream-subgraph
      • Graph
      • Sample Output
    • deepstream-3d-camera
      • Graph
      • Sample Output
    • deepstream-ucx-test1
      • Graph
      • Sample Output
    • deepstream-ucx-test2
      • Graph
      • Sample Output
  • Development Workflow
    • Sync Extensions
      • Using commandline
      • Using Composer UI
    • Develop New Extension
      • Using commandline
        • Generate an extension for GXF Codelet
        • Generate an extension for GXF wrapper of GstElement
      • Using Composer UI
    • Create and test graph
  • Developing Extensions for DeepStream
    • Extension and component factory registration boilerplate
    • A simple DeepStream component
    • Implementation of INvDsInPlaceDataHandler
    • Controlling Properties
    • Triggering Actions
    • Handling signal callbacks
    • Implementation of an Configuration Provider component
  • DeepStream Components
    • Interfaces
      • Element - INvDsElement
      • I/Os - INvDsIO/INvDsInput/INvDsOutput
      • Connections - INvDsConnection
      • DeepStream Domain Component - INvDsComponent
      • Probe - INvDsProbe
      • Probe Callback Implementation - INvDsInPlaceDataHandler
      • Action - INvDsAction
      • Signal - INvDsSignal
      • Element Property Controller – INvDsPropertyController
      • Configurations – INvDsConfigComponent template and specializations
      • INvDsInferModelConfigComponent
      • INvDsVideoTemplatePluginConfigComponent / INvDsAudioTemplatePluginConfigComponent
    • Data Components
      • GstBufferHandle
      • NvBufSurfaceHandle
      • NvBufAudioHandle
      • NvDsBatchMetaHandle
    • Basic Components
      • I/Os
    • Connections
      • NvDsConnection
      • NvDsMultiSrcConnection
    • Probes
      • NvDsProbe
      • NvDsProbeConnector
      • NvDsScheduler
  • Overview
    • GXF Core
    • GXF Extensions
  • GXF Development Guide
    • Application Development Guide
      • LifeCycle of a Codelet
      • The GXF Scheduler
        • Greedy Scheduler
        • Multithread Scheduler
        • Epoch Scheduler
      • SchedulingTerms
        • PeriodicSchedulingTerm
        • CountSchedulingTerm
        • MessageAvailableSchedulingTerm
        • MultiMessageAvailableSchedulingTerm
        • BooleanSchedulingTerm
        • AsynchronousSchedulingTerm
        • DownstreamReceptiveSchedulingTerm
        • TargetTimeSchedulingTerm
        • ExpiringMessageAvailableSchedulingTerm
        • AND Combined
        • BTSchedulingTerm
      • Messages
        • Transmitter
        • Receiver
        • Transmitter Example
        • Receiver Example
      • Memory Management
    • Extensions Development Guide
      • Sample GXF Extension
  • Graph Execution Engine
    • 1. How to override the parameters that are specified in the graph file using command line options?
      • 1. Single graph file
      • 2. Multiple subgraph files
GXF Core APIs
  • GXF Core C APIs
    • Context
      • Create context
      • Create a context from a shared context
      • Destroy context
    • Extensions
      • Load Extensions from a file
      • Load Extension libraries
      • Load Metadata files
      • Register component
    • Graph Execution
      • Loads a list of entities from YAML file
      • Set the root folder for searching YAML files during loading
      • Loads a list of entities from YAML text
      • Activate all system components
      • Deactivate all System components
      • Starts the execution of the graph asynchronously
      • Interrupt the execution of the graph
      • Waits for the graph to complete execution
      • Runs all System components and waits for their completion
    • Entities
      • Create an entity
      • Activate an entity
      • Deactivate an entity
      • Destroy an entity
      • Find an entity
      • Find all entities
      • Increase reference count of an entity
      • Decrease reference count of an entity
      • Get status of an entity
      • Get state of an entity
      • Notify entity of an event
    • Components
      • Get component type identifier
      • Get component type name
      • Get component name
      • Get unique identifier of the entity of given component
      • Add a new component
      • Add component to entity interface
      • Find a component in an entity
      • Get type identifier for a component
      • Gets pointer to component
    • Primitive Parameters
      • 64-bit floating point
        • Set
        • Get
      • 64-bit signed integer
        • Set
        • Get
      • 64-bit unsigned integer
        • Set
        • Get
      • 32-bit signed integer
        • Set
        • Get
      • String parameter
        • Set
        • Get
      • Boolean
        • Set
        • Get
      • Handle
        • Set
        • Get
    • Vector Parameters
      • Set 1-D Vetor Parameters
      • Set 2-D Vetor Parameters
      • Get 1-D Vetor Parameters
      • Get 2-D Vetor Parameters
    • Information Queries
      • Get Meta Data about the GXF Runtime
      • Get description and list of components in loaded Extension
      • Get description and list of parameters of Component
      • Get parameter type description
      • Get flag type description
      • Get parameter description
      • Redirect logs to a file
    • Miscellaneous
      • Get string description of error
  • GXF Python APIs
    • Context
      • Create context
      • Destroy context
    • Extensions
    • Graph
    • Entities
      • Find an entity
    • Components
        • Set
        • Get
        • Set
        • Get
        • Set
        • Get
        • Set
        • Get
      • String parameter
        • Set
        • Get
      • Boolean
        • Set
        • Get
      • Handle
        • Set
        • Get
    • Vector Parameters
Extensions Manual
  • CudaExtension
    • Components
      • nvidia::gxf::CudaStream
      • nvidia::gxf::CudaStreamId
      • nvidia::gxf::CudaEvent
      • nvidia::gxf::CudaStreamPool
        • Parameters
      • nvidia::gxf::CudaStreamSync
        • Parameters
  • GXF Stream Sync
    • Signaler
    • Waiter
    • GxfStreamExtension
      • Components
        • nvidia::gxf::GxfStreamSync
    • GXF Stream Sync Workflow
      • At the Signaler codelet
      • At the Waiter Codelet
      • Example
  • StandardExtension
    • Interfaces
      • nvidia::gxf::Codelet
      • nvidia::gxf::Clock
      • nvidia::gxf::System
      • nvidia::gxf::Queue
      • nvidia::gxf::Router
      • nvidia::gxf::Transmitter
      • nvidia::gxf::Receiver
      • nvidia::gxf::Scheduler
      • nvidia::gxf::SchedulingTerm
      • nvidia::gxf::Allocator
      • nvidia::gxf::Monitor
    • Components
      • nvidia::gxf::RealtimeClock
        • Parameters
      • nvidia::gxf::ManualClock
        • Parameters
      • nvidia::gxf::SystemGroup
      • nvidia::gxf::MessageRouter
      • nvidia::gxf::RouterGroup
      • nvidia::gxf::DoubleBufferTransmitter
        • Parameters
      • nvidia::gxf::DoubleBufferReceiver
        • Parameters
      • nvidia::gxf::Connection
        • Parameters
      • nvidia::gxf::PeriodicSchedulingTerm
        • Parameters
      • nvidia::gxf::CountSchedulingTerm
        • Parameters
      • nvidia::gxf::TargetTimeSchedulingTerm
        • Parameters
      • nvidia::gxf::DownstreamReceptiveSchedulingTerm
        • Parameters
      • nvidia::gxf::MessageAvailableSchedulingTerm
        • Parameters
      • nvidia::gxf::MultiMessageAvailableSchedulingTerm
        • Parameters
      • nvidia::gxf::ExpiringMessageAvailableSchedulingTerm
        • Parameters
      • nvidia::gxf::BooleanSchedulingTerm
      • nvidia::gxf::AsynchronousSchedulingTerm
      • nvidia::gxf::GreedyScheduler
        • Parameters
      • nvidia::gxf::MultiThreadScheduler
        • Parameters
      • nvidia::gxf::BlockMemoryPool
        • Parameters
      • nvidia::gxf::UnboundedAllocator
        • Parameters
      • nvidia::gxf::Tensor
      • nvidia::gxf::Timestamp
      • nvidia::gxf::Metric
        • Parameters
      • nvidia::gxf::JobStatistics
        • Parameters
      • nvidia::gxf::Broadcast
        • Parameters
      • nvidia::gxf::Gather
        • Parameters
      • nvidia::gxf::TensorCopier
        • Parameters
      • nvidia::gxf::TimedThrottler
        • Parameters
      • nvidia::gxf::Vault
        • Parameters
      • nvidia::gxf::Subgraph
        • Parameters
      • nvidia::gxf::EndOfStream
      • nvidia::gxf::Synchronization
        • Parameters
      • signed char
      • unsigned char
      • short int
      • short unsigned int
      • int
      • unsigned int
      • long int
      • long unsigned int
      • float
      • double
      • bool
    • Python Bindings
      • Clock
      • Receiver
      • Transmitter
      • PrimitiveType
      • Shape
      • MemoryStorageType
      • Tensor
      • Allocator
  • Python Codelets
    • General Concepts
    • Implenting a Python Codelet
      • Implementing Class
      • Adding Python Codelet to the Graph
      • Accessing Parameters
      • Accessing other Components
  • NetworkExtension
    • Interfaces
    • Components
      • nvidia::gxf::TcpClient
        • Parameters
      • nvidia::gxf::TcpServer
        • Parameters
  • NvTritonExt
    • Components
      • nvidia::triton::TritonServer
        • Parameters
      • nvidia::triton::TritonInferencerInterface
      • nvidia::triton::TritonInferencerImpl
        • Parameters
      • nvidia::triton::TritonInferenceRequest
        • Parameters
      • nvidia::triton::TritonInferenceResponse
        • Parameters
      • nvidia::triton::TritonOptions
      • nvidia::triton::TritonRequestReceptiveSchedulingTerm
        • Parameters
  • SerializationExtension
    • Interfaces
      • nvidia::gxf::ComponentSerializer
    • Components
      • nvidia::gxf::EntityRecorder
        • Parameters
      • nvidia::gxf::EntityReplayer
        • Parameters
      • nvidia::gxf::StdComponentSerializer
        • Parameters
  • MultimediaExtension
    • Components
      • nvidia::gxf::AudioBuffer
      • nvidia::gxf::VideoBuffer
  • VideoEncoderExtension
    • Components
      • nvidia::gxf::VideoEncoderRequest
        • Parameters
      • nvidia::gxf::VideoEncoderResponse
        • Parameters
      • nvidia::gxf::VideoEncoderContext
        • Parameters
  • VideoDecoderExtension
    • Components
      • nvidia::gxf::VideoDecoderRequest
        • Parameters
      • nvidia::gxf::VideoDecoderResponse
        • Parameters
      • nvidia::gxf::VideoDecoderContext
        • Parameters
  • Behavior Trees
    • General Concept
    • Behavior Tree Codelets
      • Constant Behavior
      • Parallel Behavior
      • Repeat Behavior
      • Selector Behavior
      • Sequence Behavior
      • Switch Behavior
      • Timer Behavior
  • UCX Extension
    • Description
    • Requirements
    • Components
      • UcxContext
        • Parameters
      • UcxTransmitter
        • Parameters
      • UcxReceiver
        • Parameters
      • UcxComponentSerializer
        • Parameters
      • UcxEntitySerializer
        • Parameters
      • UcxSerializationBuffer
        • Parameters
    • Example
  • HttpExtension
    • Interfaces
      • nvidia::gxf::HttpClient
    • Components
      • nvidia::gxf::HttpServer
        • Parameters
      • nvidia::gxf::CppRestHttpClient
        • Parameters
  • GrpcExtension
    • Interfaces
    • Components
      • nvidia::gxf::GrpcServer
        • Parameters
  • NvDs3dProcessingExt
    • Components
      • nvidia::deepstream::NvDs3dSrc
        • Parameters
      • nvidia::deepstream::NvDs3dSink
        • Parameters
      • nvidia::deepstream::NvDs3dFilter
        • Parameters
      • nvidia::deepstream::NvDs3dDataDepthInfoLogger
        • Parameters
      • nvidia::deepstream::NvDs3dDataColorInfoLogger
        • Parameters
      • nvidia::deepstream::NvDs3dDataPointCloudInfoLogger
        • Parameters
  • NvDsActionRecognitionExt
    • Components
      • nvidia::deepstream::NvDsActionRecognition2D
        • Parameters
      • nvidia::deepstream::NvDsActionRecognition3D
        • Parameters
  • NvDsAnalyticsExt
    • Components
      • nvidia::deepstream::NvDsAnalytics
        • Parameters
  • NvDsBaseExt
    • Interfaces
      • nvidia::deepstream::INvDsKeyboardInput
    • Components
      • nvidia::deepstream::NvDsStaticOutput
      • nvidia::deepstream::NvDsDynamicOutput
      • nvidia::deepstream::NvDsOnRequestOutput
      • nvidia::deepstream::NvDsStaticInput
      • nvidia::deepstream::NvDsOnRequestInput
      • nvidia::deepstream::NvDsMultiOutput
      • nvidia::deepstream::NvDsProbeConnector
        • Parameters
      • nvidia::deepstream::NvDsConnection
        • Parameters
      • nvidia::deepstream::NvDsMultiSrcConnection
        • Parameters
      • nvidia::deepstream::NvDsKeyboardInput
      • nvidia::deepstream::NvDsScheduler
      • nvidia::deepstream::NvDsToGxfBridge
        • Parameters
      • nvidia::deepstream::NvGxfToDsBridge
        • Parameters
      • nvidia::deepstream::NvDsGxfObjectDataTranslator
      • nvidia::deepstream::NvDsGxfAudioClassificationDataTranslator
      • nvidia::deepstream::NvDsGxfOpticalFlowDataTranslator
      • nvidia::deepstream::NvDsGxfSegmentationDataTranslator
      • nvidia::deepstream::NvDsGxfInferTensorDataTranslator
      • nvidia::deepstream::NvDsQueue
        • Parameters
      • nvidia::deepstream::NvDsTee
        • Parameters
      • nvidia::deepstream::NvDsBufferSync
        • Parameters
  • NvDsBodyPose2D
    • Components
      • nvidia::BodyPose2D::PostProcess
        • Parameters
      • nvidia::BodyPose2D::BodyPose2dModel
        • Parameters
      • nvidia::BodyPose2D::NvDsGxfBodypose2dDataTranslator
  • NvDsCloudMsgExt
    • Components
      • nvidia::deepstream::NvDsMessage
      • nvidia::deepstream::NvDsMsgRelayTransmitter
      • nvidia::deepstream::NvDsMsgRelayReceiver
      • nvidia::deepstream::NvDsMsgBrokerC2DReceiver
        • Parameters
      • nvidia::deepstream::NvDsMsgBrokerD2CTransmitter
        • Parameters
        • Parameters
        • Parameters
      • nvidia::deepstream::NvDsMsgConverter
        • Parameters
      • nvidia::deepstream::NvDsMsgConvBroker
        • Parameters
  • NvDsConverterExt
    • Components
      • nvidia::deepstream::NvDsVideoConvert
        • Parameters
      • nvidia::deepstream::AudioConvert
        • Parameters
      • nvidia::deepstream::AudioResample
        • Parameters
  • NvDsDewarperExt
    • Components
      • nvidia::deepstream::NvDsAisleFilter
        • Parameters
      • nvidia::deepstream::NvDsBBoxFilter
        • Parameters
      • nvidia::deepstream::NvDsDewarper
        • Parameters
      • nvidia::deepstream::NvDsSpotChangeSignal
        • Parameters
  • NvDsEmotionExt
    • Components
      • nvidia::Emotion::NvDsEmotionTemplateLib
  • NvDsFacialLandmarks
    • Components
      • nvidia::FacialLandmarks::PostProcess
        • Parameters
      • nvidia::FacialLandmarks::PreProcess
        • Parameters
      • nvidia::FacialLandmarks::FacialLandmarksPgieModel
        • Parameters
      • nvidia::FacialLandmarks::FacialLandmarksSgieModel
        • Parameters
      • nvidia::FacialLandmarks::FacialLandmarksSgieModelV2
        • Parameters
      • nvidia::FacialLandmarks::NvDsGxfFacialLandmarksTranslator
  • NvDsGazeExt
    • Components
      • nvidia::Gaze::NvDsGazeTemplateLib
      • nvidia::Gaze::NvDsGxfGazeDataTranslator
  • NvDsGesture
    • Components
      • nvidia::Gesture::PreProcess
        • Parameters
      • nvidia::Gesture::GestureModel
        • Parameters
  • NvDsHeartRateExt
    • Components
      • nvidia::HeartRate::NvDsHeartRateTemplateLib
      • nvidia::HeartRate::NvDsGxfHeartRateDataTranslator
  • NvDsInferenceExt
    • Components
      • nvidia::deepstream::NvDsModelUpdatedSignal
      • nvidia::deepstream::NvDsInferVideoPropertyController
        • Parameters
      • nvidia::deepstream::NvDsAsr
        • Parameters
      • nvidia::deepstream::NvDsInferAudio
        • Parameters
      • nvidia::deepstream::NvDsPreProcess
        • Parameters
  • NvDsInferenceUtilsExt
    • Components
      • nvidia::deepstream::NvDsKittiDump
        • Parameters
      • nvidia::deepstream::NvDsFpsMeasurement
        • Parameters
      • nvidia::deepstream::NvDsLatencyMeasurement
        • Parameters
      • nvidia::deepstream::NvDsAudioClassificationPrint
        • Parameters
      • nvidia::deepstream::NvDsPerClassObjectCounting
        • Parameters
      • nvidia::deepstream::NvDsModelEngineWatchOTFTrigger
        • Parameters
      • nvidia::deepstream::NvDsRoiClassificationResultParse
        • Parameters
      • nvidia::deepstream::NvDsMetaDeserialize
        • Parameters
      • nvidia::deepstream::NvDsMetaSerialize
        • Parameters
  • NvDsInterfaceExt
    • Interfaces
      • nvidia::deepstream::INvDsElement
      • nvidia::deepstream::INvDsIO
      • nvidia::deepstream::INvDsInput
      • nvidia::deepstream::INvDsOutput
      • nvidia::deepstream::INvDsProbe
      • nvidia::deepstream::INvDsConnection
      • nvidia::deepstream::INvDsComponent
      • nvidia::deepstream::INvDsInPlaceDataHandler
      • nvidia::deepstream::INvDsAction
      • nvidia::deepstream::INvDsSignal
      • nvidia::deepstream::INvDsPropertyController
      • nvidia::deepstream::INvDsAudioTemplatePluginConfigComponent
      • nvidia::deepstream::INvDsVideoTemplatePluginConfigComponent
      • nvidia::deepstream::INvDsInferModelConfigComponent
      • nvidia::deepstream::INvDsGxfDataTranslator
    • Components
      • nvidia::deepstream::NvBufSurfaceHandle
      • nvidia::deepstream::NvBufAudioHandle
      • nvidia::deepstream::NvDsBatchMetaHandle
      • nvidia::deepstream::GstBufferHandle
  • NvDsMuxDemuxExt
    • Components
      • nvidia::deepstream::NvDsStreamDemux
        • Parameters
      • nvidia::deepstream::NvDsStreamMux
        • Parameters
      • nvidia::deepstream::NvDsStreamDemuxNew
        • Parameters
      • nvidia::deepstream::NvDsStreamMuxNew
        • Parameters
  • NvDsOpticalFlowExt
    • Components
      • nvidia::deepstream::NvDsOpticalFlow
        • Parameters
      • nvidia::deepstream::NvDsOpticalFlowVisual
        • Parameters
  • NvDsOutputSinkExt
    • Components
      • nvidia::deepstream::NvDsFakeSink
        • Parameters
      • nvidia::deepstream::NvDsFileOut
        • Parameters
      • nvidia::deepstream::NvDsVideoRendererPropertyController
        • Parameters
      • nvidia::deepstream::NvDsRtspOut
        • Parameters
      • nvidia::deepstream::XvImageSink
        • Parameters
      • nvidia::deepstream::AlsaAudioRenderer
        • Parameters
  • NvDsSampleExt
    • Components
      • nvidia::deepstream::NvDsSampleProbeMessageMetaCreation
        • Parameters
      • nvidia::deepstream::NvDsSampleSourceManipulator
        • Parameters
      • nvidia::deepstream::NvDsSampleVideoTemplateLib
        • Parameters
      • nvidia::deepstream::NvDsSampleAudioTemplateLib
        • Parameters
      • nvidia::deepstream::NvDsSampleC2DSmartRecordTrigger
        • Parameters
      • nvidia::deepstream::NvDsSampleD2C_SRMsgGenerator
        • Parameters
  • NvDsSampleModelsExt
    • Components
      • nvidia::deepstream::NvDsResnet10_4ClassDetectorModel
        • Parameters
      • nvidia::deepstream::NvDsSecondaryCarColorClassifierModel
        • Parameters
      • nvidia::deepstream::NvDsSecondaryCarMakeClassifierModel
        • Parameters
      • nvidia::deepstream::NvDsSecondaryVehicleTypeClassifierModel
        • Parameters
      • nvidia::deepstream::NvDsSonyCAudioClassifierModel
        • Parameters
      • nvidia::deepstream::NvDsCarDetector360dModel
        • Parameters
  • NvDsSourceExt
    • Components
      • nvidia::deepstream::NvDsSourceInfoLoader
        • Parameters
      • nvidia::deepstream::NvDsStartSrAction
      • nvidia::deepstream::NvDsStopSrAction
      • nvidia::deepstream::NvDsSrDoneSignal
      • nvidia::deepstream::NvDsSingleSrcInput
        • Parameters
      • nvidia::deepstream::NvDsSourceManipulationAction
      • nvidia::deepstream::NvDsMultiSourceSmartRecordAction
      • nvidia::deepstream::NvDsMultiSrcInput
        • Parameters
      • nvidia::deepstream::NvDsMultiSrcWarpedInput
        • Parameters
      • nvidia::deepstream::NvDsRecordAction
      • nvidia::deepstream::NvDsMultiSrcInputWithRecord
        • Parameters
      • nvidia::deepstream::NvDsCameraSrcInput
        • Parameters
      • nvidia::deepstream::VideoTestSrc
        • Parameters
      • nvidia::deepstream::AudioTestSrc
        • Parameters
      • nvidia::deepstream::AlsaAudioInput
        • Parameters
  • NvDsTemplateExt
    • Components
      • nvidia::deepstream::NvDsAudioTemplate
        • Parameters
      • nvidia::deepstream::NvDsVideoTemplate
        • Parameters
  • NvDsTrackerExt
    • Components
      • nvidia::deepstream::NvDsTracker
        • Parameters
  • NvDsTranscodeExt
    • Components
      • nvidia::deepstream::NvDsJpegDecoder
        • Parameters
      • nvidia::deepstream::NvDsVideoDecoder
        • Parameters
      • nvidia::deepstream::NvDsH264Encoder
        • Parameters
      • nvidia::deepstream::NvDsH265Encoder
        • Parameters
  • NvDsTritonExt
    • Components
      • nvidia::deepstream::NvDsTriton
        • Parameters
  • NvDsUcxExt
    • Components
      • nvidia::deepstream::NvDsUcxClientSink
        • Parameters
      • nvidia::deepstream::NvDsUcxClientSrc
        • Parameters
      • nvidia::deepstream::NvDsUcxServerSink
        • Parameters
      • nvidia::deepstream::NvDsUcxServerSrc
        • Parameters
  • NvDsUdpExt
    • Components
      • nvidia::deepstream::NvDsUdpSink
        • Parameters
      • nvidia::deepstream::NvDsUdpSrc
        • Parameters
  • NvDsVisualizationExt
    • Components
      • nvidia::deepstream::NvDsOSDPropertyController
        • Parameters
      • nvidia::deepstream::NvDsTiler
        • Parameters
      • nvidia::deepstream::NvDsSegVisual
        • Parameters
      • nvidia::deepstream::NvDsBlender
        • Parameters
      • nvidia::deepstream::NvDsTilerEventHandler
        • Parameters
Tools
  • Registry
    • Repository Manager
      • NVIDIA Cloud Repository
      • Local Workspace
    • Cache
    • Extension Registration
    • Installing graphs for deployment
  • Registry Command Line Interface
    • cache
    • repo
      • repo clean
      • repo list
      • repo info
      • repo sync
    • extn
      • extn add
      • extn sync
      • extn import
      • extn list
      • extn info
      • extn versions
      • extn variants
      • extn dependencies
    • comp
      • comp list
      • comp info
    • graph
      • graph install
  • Composer
    • User Interface
      • Menu Bar
        • File Menu
        • Edit Menu
        • Registry Menu
        • Graph Menu
        • Tools Menu
        • Window Menu
        • Help Menu
      • Context Menu
      • Toolbar
      • Component List
    • Create New Application
    • Open and Save Application Graphs
    • Compose an Application Graph
      • Finding the right component
      • Creating a Component Instance
      • Understanding the Component Handles
      • Linking and Unlinking components
      • Entity Node
      • Setting up a Connection from an Input to an Output
      • Changing the Component Properties
      • Editor Features
      • Subgraph
      • Backdrop
    • Extend a Graph
    • Run Graph
      • Options
    • Build Container Image
      • Options
    • Generate Gstreamer Extension
      • Options
    • Remote Access
      • Comparison of available options
    • Omniverse Streaming Client
      • Installation and Usage
      • Configuration
      • Server
      • Client
    • WebRTC streaming
      • Current Limitations:
    • Restrictions
    • Trouble Shooting
  • Container Builder
    • Prerequisites
    • Container Builder Features
    • Container Builder Tool Usage
    • Run Container Builder
    • Container Builder Configuration
    • A Basic Example of Container Builder Configuration
    • A Multi-Stage Example
    • Container builder main control section specification
    • Container dockerfile stage section specification
  • GXF Command Line Interface
    • stat
    • config
    • dump
FAQ Guide
  • FAQ
    • General
      • How to add new extension?
    • Registry
      • How can I know which extensions synchronized to registry cache correspond to a specific repository?
      • The registry failed to perform an operation and reported an error message. How can I get more information on why the operation failed?
      • How can I change the location of the registry logs?
    • Container Builder
      • In the main control section, why is the field container_builder required?
      • In the list of local_copy_files, if src is a folder, Any difference for dst ends with ‘/’ or not?
      • What happens if unsupported fields are added into each section of the YAML file?
      • During container builder installing graphs, sometimes there are unexpected errors happening while downloading manifests or extensions from registry. And once it happens, container builder may return errors again and again. How to clean and restart?
      • Regarding git source code compiling in compile_stage, Is it possible to compile source from HTTP archives?
      • Container builder fails to run with the following error:
    • Composer
      • What is the GPU requirement for running the Composer?
      • Can I run Composer on iGPU?
      • Why can’t I paste a component after copied one?
      • Why I cannot run WebSocket Streaming with Composer?
      • Unable to start the composer in deepstream development docker?
      • Unable to right-click in composer when run through ov-streaming?
      • Composer throws the error Registry Model update failed in the console
DeepStream API Guide
  • DeepStream API Guides
DeepStream Legal Information
  • DeepStream Legal Information
    • Notice
    • Trademarks
    • Copyright
DeepStream Feedback
  • Feedback form
    • Request Documentation Fix
DeepStream
  • Docs »
  • View page source
DeepStream Legal Information¶
Notice¶
ALL NVIDIA DESIGN SPECIFICATIONS, REFERENCE BOARDS, FILES, DRAWINGS, DIAGNOSTICS, LISTS, AND OTHER DOCUMENTS (TOGETHER AND SEPARATELY, ”MATERIALS”) ARE BEING PROVIDED ”AS IS.” NVIDIA MAKES NO WARRANTIES, EXPRESS, IMPLIED, STATUTORY, OR OTHERWISE WITH RESPECT TO THE MATERIALS, AND ALL EXPRESS OR IMPLIED CONDITIONS, REPRESENTATIONS AND WARRANTIES, INCLUDING ANY IMPLIED WARRANTY OR CONDITION OF TITLE, MERCHANTABILITY, SATISFACTORY QUALITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT, ARE HEREBY EXCLUDED TO THE MAXIMUM EXTENT PERMITTED BY LAW.
Information furnished is believed to be accurate and reliable. However, NVIDIA Corporation assumes no responsibility for the consequences of use of such information or for any infringement of patents or other rights of third parties that may result from its use. No license is granted by implication or otherwise under any patent or patent rights of NVIDIA Corporation. Specifications mentioned in this publication are subject to change without notice. This publication supersedes and replaces all information previously supplied. NVIDIA Corporation products are not authorized for use as critical components in life support devices or systems without express written approval of NVIDIA Corporation.
Trademarks¶
NVIDIA, the NVIDIA logo, CUDA, Jetson, Jetson Nano, NVIDIA AGX, Tegra, TensorRT, Tesla and Xavier are trademarks or registered trademarks of NVIDIA Corporation in the United States and other countries. Other company and product names may be trademarks of the respective companies with which they are associated. The Android robot is reproduced or modified from work created and shared by Google and is used according to terms described in the Creative Commons 3.0 Attribution License. HDMI, the HDMI logo, and High-Definition Multimedia Interface are trademarks or registered trademarks of HDMI Licensing LLC. ARM, AMBA, and ARM Powered are registered trademarks of ARM Limited. Cortex, MPCore and Mali are trademarks of ARM Limited. All other brands or product names are the property of their respective holders. ”ARM” is used to represent ARM Holdings plc; its operating company ARM Limited; and the regional subsidiaries ARM Inc.; ARM KK; ARM Korea Limited.; ARM Taiwan Limited; ARM France SAS; ARM Consulting (Shanghai) Co. Ltd.; ARM Germany GmbH; ARM Embedded Technologies Pvt. Ltd.; ARM Norway, AS and ARM Sweden AB.
Copyright¶
© 2021-2023 by NVIDIA CORPORATION & AFFILIATES. All rights reserved.
Next Previous
© Copyright 2023, NVIDIA. Last updated on Aug 09, 2023.
Built with Sphinx using a theme provided by Read the Docs.
