Sample Configurations and Streams¶
Contents of the package¶
This section provides information about included sample configs and streams.
samples: Directory containing sample configuration files, streams, and models to run the sample applications.
samples/configs/deepstream-app: Configuration files for the reference application:
source30_1080p_dec_infer-resnet_tiled_display_int8.txt: Demonstrates 30 stream decodes with primary inferencing. (For dGPU and Jetson AGX Xavier platforms only.)
source30_1080p_dec_infer-resnet_tiled_display_int8.yml: YAML based config file to demonstrate 30 stream decode with primary inferencing. (For dGPU and Jetson AGX Xavier platforms only.)
source4_1080p_dec_infer-resnet_tiled_display_int8.txt: Demonstrates four stream decodes with primary inferencing, object tracking, and three different secondary classifiers. (For dGPU and Jetson AGX Xavier platforms only.)
source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.yml: YAML based config file to demonstrate four stream decode with primary inferencing, object tracking, and three different secondary classifiers. (For dGPU and Jetson AGX Xavier platforms only.)
source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8_gpu1.txt: Demonstrates four stream decodes with primary inferencing, object tracking, and three different secondary classifiers on GPU 1 (for systems that have multiple GPU cards). For dGPU platforms only.
config_infer_primary.txt: Configures a nvinfer element as primary detector.
config_infer_primary.yml: YAML based config file to configure a nvinfer element as primary detector.
config_infer_secondary_carcolor.txt, config_infer_secondary_carmake.txt, config_infer_secondary_vehicletypes.txt: Configure a nvinfer element as secondary classifier.
config_infer_secondary_carcolor.yml,config_infer_secondary_carmake.yml, config_infer_secondary_vehicletypes.yml: YAML based config file to configure a nvinfer element as secondary classifier.
config_tracker_IOU.yml: Config file for IOU tracker.
config_tracker_NvSORT.yml: Config file for NvSORT tracker.
config_tracker_NvDeepSORT.yml: Config file for NvDeepSORT tracker.
config_tracker_NvDCF_accuracy.yml: Config file for NvDCF tracker for higher accuracy.
config_tracker_NvDCF_max_perf.yml: Config file for NvDCF tracker for max perf mode.
config_tracker_NvDCF_perf.yml: Config file for NvDCF tracker for perf mode.
config_preprocess.txt : Config file for using preprocess in PGIE mode.
config_preprocess_sgie.txt : Config file for using preprocess in SGIE mode.
source4_1080p_dec_preprocess_infer-resnet_preprocess_sgie_tiled_display_int8.txt : Demonstrates four stream decodes with preprocess plugin in PGIE mode followed by primary inferencing, preprocess plugin in SGIE mode, and three different secondary classifiers. (For dGPU and Jetson AGX Xavier platforms only.)
source30_1080p_dec_preprocess_infer-resnet_tiled_display_int8.txt : Demonstrates 30 stream decodes with preprocess plugin in PGIE mode followed by primary inferencing. (For dGPU and Jetson AGX Xavier platforms only.)
sources_30.csv: CSV file for 30 sources required in source30_1080p_dec_infer-resnet_tiled_display_int8.yml.
sources_4.csv: CSV file for 30 sources required in source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.yml.
source1_usb_dec_infer_resnet_int8.txt: Demonstrates one USB camera as input.
source1_csi_dec_infer_resnet_int8.txt: Demonstrates one CSI camera as input. (For Jetson only.)
source2_csi_usb_dec_infer_resnet_int8.txt: Demonstrates one CSI camera and one USB camera as inputs. (For Jetson only.)
source6_csi_dec_infer_resnet_int8.txt: Demonstrates six CSI cameras as inputs. (For Jetson only.)
source2_1080p_dec_infer-resnet_demux_int8.txt: Demonstrates demux mode for two sources.
config_mux_source4.txt, config_mux_source30.txt: Sample nvstreammux (new) config files. For more details see Section Mux Config Properties.
samples/configs/deepstream-app-triton: Configuration files for the reference application for inferencing using Triton Inference Server.
source30_1080p_dec_infer-resnet_tiled_display_int8.txt (30 Decode + Infer)
source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt (4 Decode + Infer + SGIE + Tracker)
source1_primary_classifier.txt (Single source + full frame classification)
source1_1080p_dec_infer_peoplesemsegnet_shuffle.txt (Single source + semantic segmentation)
source1_primary_detector_peoplenet_transformer.txt (Single source + full frame classification)
Note
Other classification models can be used by changing the ds-triton
nvinferserverconfig file in the[*-gie]group of application config file.
source1_primary_detector.txt (Single source + object detection using ssd)
Configuration files for ds-triton
nvinferserverelement in configs/deepstream-app-triton/config_infer_plan_engine_primary.txt (Primary Object Detector)
config_infer_secondary_plan_engine_carcolor.txt (Secondary Car Color Classifier)
config_infer_secondary_plan_engine_carmake.txt (Secondary Car Make Classifier)
config_infer_secondary_plan_engine_vehicletypes.txt (Secondary Vehicle Type Classifier)
config_infer_primary_classifier_densenet_onnx.txt (DenseNet-121 v1.2 classifier)
config_infer_primary_classifier_inception_graphdef_postprocessInTriton.txt (TensorFlow Inception v3 classifier - Post processing in Triton)
config_infer_primary_classifier_inception_graphdef_postprocessInDS.txt (TensorFlow Inception v3 classifier - Post processing in DeepStream)
config_infer_primary_detector_ssd_inception_v2_coco_2018_01_28.txt (TensorFlow SSD Inception V2 Object Detector)
config_infer_primary_classifier_mobilenet_v1_graphdef.txt (TensorFlow Mobilenet V1 classifier)
config_infer_primary_detector_ssd_mobilenet_v1_coco_2018_01_28.txt (TensorFlow Mobilenet V1 Object Detector)
samples/configs/deepstream-app-triton-grpc: Configuration files for the reference application for inferencing using Triton Inference Server gRPC
nvinferserverelement in configs/deepstream-app-triton-grpc/config_infer_plan_engine_primary.txt (Primary Object Detector)
NVIDIA TAO Toolkit pretrained Models:
samples/configs/tao_pretrained_models: Contains README.md to obtain configs and models for TAO toolkit.
samples: Directory containing sample configuration files, models, and streams to run the sample applications.
samples/streams: The following streams are provided with the DeepStream SDK:
Streams
Type of Stream
sample_1080p_h264.mp4
H264 containerized stream
sample_1080p_h265.mp4
H265 containerized stream
sample_720p.h264
H264 elementary stream
JPEG image
sample_720p_mjpeg.mp4
MJPEG containerized stream
sample_720p.mp4
Containerized stream
sample_cam5.mp4
H264 containerized stream (360D camera stream)
sample_cam6.mp4
JPEG image
Image for perspective projection in Dewarper
yoga.mp4
sample_qHD.mp4
Used for MaskRCNN
sample_qHD.h264
sample_push.mov
sample_ride_bike.mov
sample_run.mov
sample_walk.mov
fisheye_dist.mp4
sonyc_mixed_audio.wav
Audio bitstream
sample_office.mp4
pointcloud
Contains input files for lidar application
samples/models: The following sample models are provided with the SDK:
DeepStream Reference application
Model |
Model Type |
No. of Classes |
Resolution |
Primary Detector |
Resnet10 |
4 |
640 × 368 |
Secondary Car Color Classifier |
Resnet18 |
12 |
224 × 224 |
Secondary Car Make Classifier |
Resnet18 |
6 |
224 × 224 |
Secondary Vehicle Type Classifier |
Resnet18 |
20 |
224 × 224 |
Segmentation example
Model |
Model Type |
No. of Classes |
Resolution |
Industrial |
Resnet18 + UNet |
1 |
512 x 512 |
Semantic |
Resnet18 + UNet |
4 |
512 x 512 |
Instance |
Resnet50 + Maskrcnn |
2 |
1344 x 832 |
Scripts included along with package¶
The following scripts are included along with the sample applications package:
samples/ prepare_classification_test_video.sh: Downloads Imagenet test images and creates a video out of it to test with Classification models like TensorFlow Inception, ONNX DenseNet etc.
samples/ prepare_ds_triton_model_repo.sh: Prepare the Model repository for Triton Inference Server
Creates engine files for Caffe and UFF based models provided as part of SDK.
Downloads Model files for ONNX DenseNet , SSD Inception V2 Coco, Inception v3.
For additional information on the above models, refer to:
samples/ prepare_ds_triton_tao_model_repo.sh: Prepare the Model repository for Triton Tao Inference Server
Downloads Model files for Peoplenet Transformer, Peoplesemsegnet Shuffle, Facenet.
Create engine files for downloaded models.
uninstall.sh: Used to clean up previous DS installation.
