DeepStream 3D Depth Camera App#
The deepstream-3d-depth-camera
sample application is provided at app/sample_apps/deepstream-3d-depth-camera for your reference. This example demonstrates two different pipelines which bring depth camera from 2D into 3D world.
The depth and color data capture component is produced by Intel® RealSense™ Depth Camera D435 series. For more details, see https://www.intelrealsense.com/depth-camera-d435/.
Prerequisites#
You must have the following development packages installed:
GStreamer-1.0
GStreamer-1.0 Base Plugins
GStreamer-1.0 gstrtspserver
X11 client-side library
libyaml-cpp-dev
RealSense SDK
To install these packages, execute the following command:
sudo apt-get install libgstreamer-plugins-base1.0-dev libgstreamer1.0-dev \ libgstrtspserver-1.0-dev libx11-dev libyaml-cpp-dev
Follow the RealSense SDK documentation to add RealSense public key and list of repositories. For x86, refer to IntelRealSense/librealsense. For Jetson platforms, refer to IntelRealSense/librealsense. You may use Ubuntu 20.04 source path into apt-repository to install dependencies.
sudo add-apt-repository "deb https://librealsense.intel.com/Debian/apt-repo bionic main" -u
Then install
librealsense2
package to build and test.sudo apt-get install librealsense2-utils librealsense2-dev
Make sure RealSense SDK version is not earlier than 2.48.
Plugin in Intel RealSense Depth D400 series USB camera. To verify the camera and upgrade firmware, run
realsense-viewer
and update from the UI. Navigate to the folder sources/apps/sample_apps/deepstream-3d-depth-camera.If you are running these commands inside deepstream container, make sure camera devices are mounted in the
docker run
command. For example:docker run --rm -it --gpus '"device=0"' --device /dev/video0 --device /dev/video1 --device /dev/video2 ...
Export
DISPLAY
environment to the correct display. for example,export DISPLAY=:0.0
Depth Color Capture to 2D Rendering Pipeline Overview#
This is the first pipeline from the depth capture to 2D based depthmap to direct rendering with linear colors configured by the user.
The pipeline is setup by ds_3d_realsense_depth_capture_render.yaml
. It has 2 components, ds3d::dataloader
for depth/color and datarender
for GLES 2D render.
ds3d::dataloader
loads custom liblibnvds_3d_dataloader_realsense.so
and creates a RealSense dataloader through thecreateRealsenseDataloader
function. This specific loader is configured for output streams of [color, depth]. Gst-appsrc connects the dataloader into the deepstream pipeline.name: realsense_dataloader type: ds3d::dataloader out_caps: ds3d/datamap custom_lib_path: libnvds_3d_dataloader_realsense.so custom_create_function: createRealsenseDataloader
ds3d::datarender
loads custom liblibnvds_3d_gl_datarender.so
and create a GLES render through thecreateDepthStreamDataRender
function. This specific loader is configured for 2D depth and color images. Gst-appsink connects the datarender into the deepstream pipeline.name: depth-render type: ds3d::datarender in_caps: ds3d/datamap custom_lib_path: libnvds_3d_gl_datarender.so custom_create_function: createDepthStreamDataRender
captures color and depth streams inds3d/datamap
, then delivers the data tods3d::datarender
componentdepth-render
Depth Color Capture to 3D Point Cloud Processing and Rendering#
The 2nd pipeline is from depth capture, 3D point cloud processing and alignment, to the 3D point cloud rendering with colors.
The 2nd pipeline is setup by the ds_3d_realsense_depth_to_point_cloud.yaml
. It has 3 components: ds3d::dataloader
for depth/color capture, ds3d::datafilter
for depth-to-point-cloud processing, and datarender
for GLES 3D points render.
ds3d::dataloader
is the same as the 1st pipeline for depth and color capture. It also outputs the intrinsic parameters of the color/depth sensors, and extrinsic parameters from depth to color sensor module.name: realsense_dataloader type: ds3d::dataloader out_caps: ds3d/datamap custom_lib_path: libnvds_3d_dataloader_realsense.so custom_create_function: createRealsenseDataloader
ds3d::datafilter
loads custom liblibnvds_3d_depth2point_datafilter.so
and creates a depth-to-3D-point processing filter through thecreateDepth2PointFilter
function. This specific filter generates the 3D point-cloud dataset from depth, and calculates a UV-coordinate map for correspondence between points and color position. It requires sensors’ intrinsic and extrinsic data fromdataloader
to make the alignment.name: point2cloud_datafilter type: ds3d::datafilter in_caps: ds3d/datamap out_caps: ds3d/datamap custom_lib_path: libnvds_3d_depth2point_datafilter.so custom_create_function: createDepth2PointFilter
ds3d::datafilter
is loaded by thenvds3dfilter
Gst-plugin which acceptsin_caps
as sink_caps andout_caps
as src_caps. It creates a customds3d::datafilter
instance and processess data asds3d/datamap
.ds3d::datarender
and create a GLES render through thecreatePointCloudDataRender
function . This specific loader is configured for 3D points and colors rendering. It also supports 3D scene rotation based on mouse-drag.name: point-render type: ds3d::datarender in_caps: ds3d/datamap custom_lib_path: libnvds_3d_gl_datarender.so custom_create_function: createPointCloudDataRender
captures color and depth streams along with the intrinsic and extrinsic parameters of the sensor inds3d/datamap
. It then delivers the data to the next componentpoint2cloud_datafilter
. This component generates 3D point-cloud data and UV coordination map into new output datads3d/datamap
. Finally, the data is delivered tods3d::datarender
componentpoint-render
for 3D rendering.
Inside the configuration files,
in_caps
andout_caps
correspond to Gstreamer’s sink_caps and src_caps.
Getting Started#
Run RealSense Camera for Depth Capture and 2D Rendering Examples#
Run the depth capture 2D render pipeline:
$ deepstream-3d-depth-camera -c ds_3d_realsense_depth_capture_render.yaml
This sets up a realsense dataloader.
It then streams ds3d/datamap to final the rendering component: depth-render.
The depth-render custom lib shall display the depth data and color data together in same window. Update
min_depth/max_depth
to remove foreground and background objects in the depth rendering. From RealSense specification, D435 Camera depth range is between0.3
and3
meters.
min_depth: 0.3 # in meters
max_depth: 2.0 # in meters
Update min_depth_color/min_depth_color [R, G, B] values to visualize color map of depth.
min_depth_color: [255, 128, 0] # RGB color value for mininum depth
max_depth_color: [0, 128, 255] # RGB color value for maximum depth
The other colors are linearly interpolated between ``min_depth_color`` and ``max_depth_color``
Run 3D Depth Capture, Point Cloud filter, and 3D Points Rendering Examples#
Run the depth capture and 3D processing pipeline:
$ deepstream-3d-depth-camera -c ds_3d_realsense_depth_to_point_cloud.yaml
This sets up a realsense dataloader (same as 2D depth). It then streams ds3d/datamap to the downstream datafilter component point2cloud_datafilter.
It streams ds3d/datamap to the
nvds3dfilter
Gst-plugin which loadspoint2cloud_datafilter
to convert 2D depth into 3D points. For more details onnvds3dfilter
Gst-plugin, See Gst-nvds3dfilter.name: point2cloud_datafilter type: ds3d::datafilter in_caps: ds3d/datamap out_caps: ds3d/datamap custom_lib_path: libnvds_3d_depth2point_datafilter.so custom_create_function: createDepth2PointFilter
Finally the data stream as ds3d/datamap is delivered to the render component
point-render
Fields of view_* are the eyes of the view position, similar to the OpenGL
gluLookAt()
.view_position: [0, 0, -1] # view position in xyz coordinates view_target: [0, 0, 1] # view target which is the direction pointing to view_up: [0, -1.0, 0] # view up direction
Fields of near/far/fov are the perspective range of the eye, similar to the OpenGL
gluPerspective()
.near: 0.01 # nearest points of perspective far: 10.0 # farmost points of perspective fov: 40.0 # FOV of perspective
DeepStream 3D Depth Camera App Configuration Specifications#
deepstream-3d-depth-camera [ds3d::userapp]
group settings#
The table below demonstrates the group settings for ds_3d_realsense_depth_to_point_cloud.yaml as an example.
Property |
Meaning |
Type and Range |
Example |
type |
Specify type ds3d::userapp |
Component type for user debug |
Must be type: ds3d::userapp |
name |
Indicate user-defined component name |
String |
enable_debug |
Indicate whether enable debug log |
Boolean |
enable_debug: False |
dump_depth |
Indicate file location to dump depth raw data |
String |
dump_depth: depth_uint16_640x480.bin |
dump_color |
Indicate file location to dump color raw data |
String |
dump_color: color_rgba_1920x1080.bin |
dump_points |
Indicate file location to dump 3D points raw data. datatype is Float and XYZ packed |
String |
dump_points: pointxyz.bin |
DS3D Custom Components Configuration Specifications#
See more details in the DS_3D supported custom components specifications section in the DeepStream-3D Custom Apps and Libs Tutorials.
Build application From Source#
Go to the folder sources/apps/sample_apps/deepstream-3d-depth-camera.
Run the following commands:
$ Set CUDA_VER in the MakeFile as per platform. For both Jetson & x86, CUDA_VER=12.2 $ make $ make install
Note
Check the source code for more details on how to load dataloader/datarender through
Gst-appsrc
andGst-appsink
. datafilter is loaded by thenvds3dfilter
Gst-plugin.
