Sample Configurations and Streams#
Contents of the package#
This section provides information about included sample configs and streams.
samples: Directory containing sample configuration files, streams, and models to run the sample applications.
samples/configs/deepstream-app: Configuration files for the reference application
The following table provides information about configuration files for the reference application in samples/configs/deepstream-app
directory.
Sample configs for the reference application in samples/configs/deepstream-app# Configuration File
Description
Platform
source30_1080p_dec_infer-resnet_tiled_display_int8.txt
Demonstrates 30 stream decodes with primary inferencing
For dGPU and Jetson AGX Orin platforms only.
source30_1080p_dec_infer-resnet_tiled_display_int8.yml
YAML based config file to demonstrate 30 stream decode with primary inferencingFor dGPU and Jetson AGX Orin platforms only.
source4_1080p_dec_infer-resnet_tiled_display_int8.txt
Demonstrates four stream decodes with primary inferencing, object tracking, and two different secondary classifiers
source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.yml
YAML based config file to demonstrate four stream decode with primary inferencing, object tracking, and two different secondary classifiers
source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8_gpu1.txt
Demonstrates four stream decodes with primary inferencing, object tracking, and two different secondary classifiers on GPU 1 (for systems that have multiple GPU cards)
For dGPU platforms only
config_infer_primary.txt
Configures a nvinfer element as primary detector
For dGPU and Jetson
config_infer_primary.yml
YAML based config file to configure a nvinfer element as primary detector
For dGPU and Jetson
config_infer_secondary_vehiclemake.txt, config_infer_secondary_vehicletypes.txt
Configure a nvinfer element as secondary classifier
For dGPU and Jetson
config_infer_secondary_vehiclemake.yml, config_infer_secondary_vehicletypes.yml
YAML based config file to configure a nvinfer element as secondary classifier
For dGPU and Jetson
config_tracker_IOU.yml
Config file for IOU tracker
For dGPU and Jetson
config_tracker_NvSORT.yml
Config file for NvSORT tracker
For dGPU and Jetson
config_tracker_NvDeepSORT.yml
Config file for NvDeepSORT tracker
For dGPU and Jetson
config_tracker_NvDCF_accuracy.yml
Config file for NvDCF tracker for higher accuracy
For dGPU and Jetson
config_tracker_NvDCF_max_perf.yml
Config file for NvDCF tracker for max perf mode
For dGPU and Jetson
config_tracker_NvDCF_perf.yml
Config file for NvDCF tracker for perf mode
For dGPU and Jetson
config_preprocess.txt
Config file for using preprocess in PGIE mode
For dGPU and Jetson
config_preprocess_sgie.txt
Config file for using preprocess in SGIE mode
For dGPU and Jetson
source4_1080p_dec_preprocess_infer-resnet_preprocess_sgie_tiled_display_int8.txt
Demonstrates four stream decodes with preprocess plugin in PGIE mode followed by primary inferencing, preprocess plugin in SGIE mode, and two different secondary classifiers
source30_1080p_dec_preprocess_infer-resnet_tiled_display_int8.txt
Demonstrates 30 stream decodes with preprocess plugin in PGIE mode followed by primary inferencing
sources_30.csv
CSV file for 30 sources required in source30_1080p_dec_infer-resnet_tiled_display_int8.yml
sources_4.csv
CSV file for 30 sources required in source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.yml
source1_usb_dec_infer_resnet_int8.txt
Demonstrates one USB camera as input
For dGPU and Jetson
source1_csi_dec_infer_resnet_int8.txt
Demonstrates one CSI camera as input
For Jetson only
source2_csi_usb_dec_infer_resnet_int8.txt
Demonstrates one CSI camera and one USB camera as inputs
For Jetson only
source6_csi_dec_infer_resnet_int8.txt
Demonstrates six CSI cameras as inputs
For Jetson only
source2_1080p_dec_infer-resnet_demux_int8.txt
Demonstrates demux mode for two sources
For dGPU and Jetson
config_mux_source4.txt, config_mux_source30.txt
Sample nvstreammux (new) config files. For more details see Section Mux Config Properties
For dGPU and Jetson
samples/configs/deepstream-app-triton: Configuration files for the reference application for inferencing using Triton Inference Server.
The following table provides information about configuration files for the reference application in samples/configs/deepstream-app-triton
directory.
Sample configs for the reference application for inferencing using Triton Inference Server in samples/configs/deepstream-app-triton# Configuration File
Description
30 Decode + Infer
source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
4 Decode + Infer + SGIE + Tracker
source1_primary_classifier.txt
Single source + full frame classification
source1_1080p_dec_infer_peoplesemsegnet_shuffle.txt
Single source + semantic segmentation
source1_primary_detector_peoplenet_transformer.txt
source1_primary_detector.txt
Single source + object detection using ssd
Note
Other classification models can be used by changing the ds-triton nvinferserver
config file in the [*-gie]
group of application config file.
Configuration files for ds-triton
nvinferserver
element in configs/deepstream-app-triton/. The following table provides information about configuration files for the reference application insamples/configs/deepstream-app-triton
directory.Sample configs for ds-triton nvinferserver
element in samples/configs/deepstream-app-triton#Configuration File
Description
config_infer_plan_engine_primary.txt
Primary Object Detector
config_infer_secondary_plan_engine_vehiclemake.txt
Secondary Vehicle Make Classifier
config_infer_secondary_plan_engine_vehicletypes.txt
Secondary Vehicle Type Classifier
config_infer_primary_classifier_densenet_onnx.txt
DenseNet-121 v1.2 classifier
config_infer_primary_classifier_inception_graphdef_postprocessInTriton.txt
TensorFlow Inception v3 classifier - Post processing in Triton
config_infer_primary_classifier_inception_graphdef_postprocessInDS.txt
TensorFlow Inception v3 classifier - Post processing in DeepStream
config_infer_primary_detector_ssd_inception_v2_coco_2018_01_28.txt
TensorFlow SSD Inception V2 Object Detector
config_infer_primary_classifier_mobilenet_v1_graphdef.txt
TensorFlow Mobilenet V1 classifier
config_infer_primary_detector_ssd_mobilenet_v1_coco_2018_01_28.txt
TensorFlow Mobilenet V1 Object Detector
samples/configs/deepstream-app-triton-grpc: Configuration files for the reference application for inferencing using Triton Inference Server gRPC
The following table provides information about configuration files for the reference application using Triton Inference Server gRPC in samples/configs/deepstream-app-triton-grpc
directory.
Sample configs for inferencing using Triton Inference Server gRPC in samples/configs/deepstream-app-triton-grpc# Configuration File
Description
30 Decode + Infer
nvinferserver
element in configs/deepstream-app-triton-grpc/. The following table provides information about configuration files for the reference application using Triton Inference Server nvinferserver insamples/configs/deepstream-app-triton-grpc
directory.Sample configs for inferencing using Triton Inference Server gRPC in samples/configs/deepstream-app-triton-grpc# Configuration File
Description
NVIDIA TAO Toolkit pretrained Models:
samples/configs/tao_pretrained_models: Contains README.md to obtain configs and models for TAO toolkit.
samples: Directory containing sample configuration files, models, and streams to run the sample applications.
samples/streams: The following streams are provided with the DeepStream SDK:
Streams
Type of Stream
sample_1080p_h264.mp4
H264 containerized stream
sample_1080p_h265.mp4
H265 containerized stream
sample_720p.h264
H264 elementary stream
JPEG image
sample_720p_mjpeg.mp4
MJPEG containerized stream
sample_720p.mp4
Containerized stream
sample_cam5.mp4
H264 containerized stream (360D camera stream)
sample_cam6.mp4
JPEG image
Image for perspective projection in Dewarper
yoga.mp4
sample_qHD.mp4
Used for MaskRCNN
sample_qHD.h264
sample_push.mov
sample_ride_bike.mov
sample_run.mov
sample_walk.mov
fisheye_dist.mp4
sonyc_mixed_audio.wav
Audio bitstream
sample_office.mp4
pointcloud
Contains input files for lidar application
samples/models: The following sample models are provided with the SDK:
DeepStream Reference application
Model |
Model Type |
No. of Classes |
Resolution |
Primary Detector |
Resnet18 |
4 |
960 × 544 |
Secondary Vehicle Make Classifier |
Resnet18 |
20 |
224 × 224 |
Secondary Vehicle Type Classifier |
Resnet18 |
6 |
224 × 224 |
Segmentation example
Model |
Model Type |
No. of Classes |
Resolution |
Industrial |
Resnet18 + UNet |
1 |
512 x 512 |
Semantic |
Resnet18 + UNet |
4 |
512 x 512 |
Instance |
Resnet50 + Maskrcnn |
2 |
1344 x 832 |
Scripts included along with package#
Note
The script
prepare_classification_test_video.sh
mentioned below requiresffmpeg
to be installed. Some of the low level codec libraries need to be re-installed along with ffmpeg.Use the following command to install/re-install ffmpeg:
apt-get install --reinstall libflac8 libmp3lame0 libxvidcore4 ffmpeg
The following scripts are included along with the sample applications package:
samples/ prepare_classification_test_video.sh: Downloads Imagenet test images and creates a video out of it to test with Classification models like TensorFlow Inception, ONNX DenseNet etc.
samples/ prepare_ds_triton_model_repo.sh: Prepare the Model repository for Triton Inference Server
Creates engine files for Caffe and UFF based models provided as part of SDK.
Downloads Model files for ONNX DenseNet , SSD Inception V2 Coco, Inception v3.
For additional information on the above models, refer to:
ONNX DenseNet - onnx/models
SSD Inception V2 Coco - tensorflow/models
Inception V3 - tensorflow/models
samples/ prepare_ds_triton_tao_model_repo.sh: Prepare the Model repository for Triton Tao Inference Server
Downloads Model files for Peoplenet Transformer, Peoplesemsegnet Shuffle, Facenet.
Create engine files for downloaded models.
uninstall.sh: Used to clean up previous DS installation.
