Gst-nvjpegenc#
The Gst-nvjpegenc plugin encodes images on both dGPU and Jetson platforms. It is the preferred method for encoding JPEG images.
On the dGPU platform this plugin is based on the libnvjpeg
library, part of the CUDA toolkit. On Jetson it uses a platform-specific hardware accelerator.
The plugin accepts I420, RGB input on dGPU platform and I420, NV12 input on Jetson platform and produces JPEG encoded bitstream.
On Jetson platform nvjpegenc
can also accept SW RAW buffers in I420, YV12, GRAY8 formats.
This plugin is not available on (ARM + dGPU) platforms like arm-sbsa. Use nvimageenc plugin instead.
Inputs and Outputs#
Inputs
Gst Buffer in I420, RGB format (dGPU)
Gst Buffer in I420, NV12 format (Jetson)
Gst SW Buffer in I420, YV12, GRAY8 format (Jetson)
Control parameters
Enableperf (Jetson Only)
idct-method (Jetson Only)
quality (Both Jetson and dGPU)
OutputGray (dGPU only)
Output
Gst Buffer with encoded output in JPEG format
Features#
The following table summarizes the features of the Gst-nvjpegenc plugin.
Feature |
Description |
Release |
Supports JPEG Encode |
DS 6.3 |
Gst Properties#
The following table summarizes the Gst properties of the Gst-nvjpegenc plugin.
Property |
Meaning |
Type and Range |
Example and Notes |
Platforms |
quality |
quality value for encoding |
Integer, 0 to 100 |
Quality=90 |
dGPU, Jetson |
Enableperf |
Enable encode time measurement |
Boolean |
Enableperf=1 |
Jetson |
Idct-method |
IDCT algorithm to use |
Enum 0: iSlow 1: iFast 2: Float |
Idct-method=2 |
Jetson |
OutputGray |
Output JPEG image in GRAYSCALE, needs I420 INPUT |
Boolean |
OutputGray=1 |
dGPU |
