Application Migration to DeepStream 8.0 from DeepStream 7.1#
Running DeepStream 7.1 compiled Apps in DeepStream 8.0#
To run the old app from DeepStream 7.1 in DeepStream 8.0, create symlinks of the libraries so the old application can find them.:
mkdir /opt/nvidia/deepstream/deepstream-7.1
mkdir /opt/nvidia/deepstream/deepstream-7.1/lib
ln -s /opt/nvidia/deepstream/deepstream-8.0/lib/* /opt/nvidia/deepstream/deepstream-7.1/lib/
Compiling DeepStream 7.1 Apps in DeepStream 8.0#
Before compiling DeepStream 7.1 applications in DeepStream 8.0, modify the Makefiles and set the NVDS_VERSION flag to 8.0.
There are two options to compile DeepStream 7.1 in DeepStream 8.0:
Option 1: Replace existing
sources/appsfrom DeepStream-8.0 and copy the entire`sources/appsdirectory from DeepStream-7.1.Option 2 : Individual applications in DeepStream SDK have dependency on sources under
apps-commondirectory. Ideally, to compile those applications, you must use the same version of apps-common. In case you want to use the latest version, you may need to adjust some application function calls because of a change in application function definitions.
Note
By default, OpenCV is deprecated in DeepStream 6.1. However, you can enable OpenCV in plugins such as nvinfer (nvdsinfer) and dsexample (gst-dsexample) by setting WITH_OPENCV=1 in the Makefile of these components. Refer to the component README for more instructions.
