Gst-nvvideoconvert#
This plugin performs video color format conversion. It accepts NVMM memory as well as RAW (memory allocated using calloc() or malloc() ), and provides NVMM or RAW memory at the output.
Inputs and Outputs#
Inputs
Gst Buffer batched buffer
NvDsBatchMeta
Format: (NVMM/RAW)
dGPU - NV12, I420, P010_10LE, BGRx, RGBA, GRAY8, RGB, BGR, Y444, Y444_10LE, Y444_12LE, BGR10A2_LE, UYVP, I420_12LE, RGB10A2_LE, GRAY16_LE, BGRA64_LE
Jetson - NV12, I420, P010_10LE, BGRx, RGBA, GRAY8, RGB, BGR, BGR10A2_LE, UYVP, UYVY, YUY2, YVYU, Y42B, I420_12LE, GRAY16_LE, BGRA64_LE
Output
Gst Buffer
NvDsBatchMeta
Format: (NVMM/RAW)
Note
For 12bit NV12 format, the input/output caps shows I420_12LE. But the data is handled as semiplanar 12 bit data. This is a workaround since gstreamer v1.16 does not have the particular caps for 12 bit NV12. Downstream component should process it considering as 12bit NV12 only.
Only NVMM memory support is added for I420_12LE, Y444_10LE and Y444_12LE formats.
For BGRA64_LE format, only conversions from or to UYVP/BGRA64_LE are supported.
Not all formats mentioned in the caps are directly supported on Jetson platforms. For example, conversions involving GRAY16_LE, BGR10A2_LE, RGB10A2_LE, BGRA64_LE, RGB, BGR, UYVP, I420_12_LE, YUV444, YUV444_10LE, YUV444_12LE etc. require ‘compute-hw=GPU’, ‘copy-hw=GPU’ and ‘nvbuf-memory-type=nvbuf-mem-cuda-device’ to be set as properties, because the default conversion engine VIC, in jetson, does not support these formats.
Features#
This plugin supports scaling and conversion for NVMM to NVMM, RAW to NVMM, and NVMM to RAW and RAW to RAW buffer type conversion. The plugin supports cropping of the input and output frames.
Gst Properties#
The following table describes the Gst properties of the Gst-nvvideoconvert plugin.
Gst-nvvideoconvert gst properties# Property
Meaning
Type and Range
Example Notes
nvbuf-memory-type
Type of memory to be allocated. For dGPU:
0 (nvbuf-mem-default): Default memory, cuda-device
1 (nvbuf-mem-cuda-pinned): Pinned/Host CUDA memory
2 (nvbuf-mem-cuda-device) Device CUDA memory
3 (nvbuf-mem-cuda-unified): Unified CUDA memory
For Jetson:
0 (nvbuf-mem-default): Default memory, surface array
4 (nvbuf-mem-surface-array): Surface array memory
enum GstNvVidConvBufMemoryType
src-crop
Pixel location: left:top:width:height of the input image which will be cropped and transformed into the output buffer. If the crop location is out of bound the values will be clamped to image boundaries of the input image. This property will be applied to all the input images in the batch
String
src-crop=”20:40:150:100”
dest-crop
Pixel location: left:top:width:height is the location in the output image where the input image will be transformed to. If the crop location is out of bound the values will be clamped to image boundaries of the output image. This property will be applied to all the output images in the batch
String
dest-crop=”20:40:150:100”
interpolation-method
Interpolation method:
0: Nearest
1: Bilinear
2: Algo-1 (GPU—Cubic, VIC—5 Tap)
3: Algo-2 (GPU—Super, VIC—10 Tap)
4: Algo-3 (GPU—LanzoS, VIC—Smart)
5: Algo-4 (GPU—Ignored, VIC—Nicest)
6: Default (GPU—Nearest, VIC—Nearest)
enum GstInterpolationMethod
interpolation-method=1 Default value is 6.
compute-hw
Type of computing hardware:
0: Default (GPU for gDPU, VIC for Jetson)
1: GPU
2: VIC
enum GstComputeHW
compute-hw=0 Default value is 0.
gpu-id
Device ID of GPU to use for format conversion
Integer, 0 to 4,294,967,295
gpu-id=0
output-buffers
Number of Output Buffers for the buffer pool
Unsigned integer, 1 to 4,294,967,295
output-buffers=4
bl-output
Flag applicable only for Jetson to output Block linear NVMM buffer for NV12 format. This is ignored for dGPU, Software memory (output buffer) and formats other than NV12
Boolean. Default: false
bl-output=1
flip-method
Type of rotation method. This flag is applicable for Jetson and GPU.
Flip method:
0: Identity (no rotation)
1: Rotate counter-clockwise 90 degrees
2: Rotate 180 degrees
3: Rotate clockwise 90 degrees
4: Rotate horizontally
5: Rotate across upper right/lower left diagonal
6: Rotate vertically
7: Rotate across upper left/lower right diagonal
enum GstNvDsVideoFlipMethod
flip-method=1 Default value is 0.
allow-odd-crop
Flag to allow the odd dimensions for source and destination crop rectangle
Boolean
allow-odd-crop=1 Default value is 1.
contiguous-buffers
Enable contiguous output buffers
Boolean
contiguous-buffers=1 Default value is 0.
disable-passthrough
Disable passthrough mode at init time
Boolean
disable-passthrough=1 Default value is 0.
copy-hw
Select hardware used for surface copies:
1: GPU
2: VIC
flags: readable, writable, controllable
enum GstNvCopyHWType
copy-hw=2 Default value is 1.
