Gst-nvds3dmixer#
The Gst-nvds3dmixer plugin is a customizable plugin which provides a custom library interface to load component ds3d::datamixer
nvds3dmixer mix buffers from N input pads into one output pad.
The Plugin is fully configured through YAML format content or file.
Gst-nvds3dmixer properties Specifications#
Properties |
Description |
Release |
config-content |
yaml config content |
DS 7.0 |
config-file |
yaml config file path |
DS 7.0 |
Custom library Interfaces#
The plugin parse the config file or content and set SinkCaps and SrcCaps. load a custom ds3d::datamixer
from custom_lib_path
. Create this datamixer by custom_create_function
Supported DS3D Data mixers#
SL |
Data mixer |
Data mixer custom library |
1 |
DS3D Data mixer. Mix buffers from N input pads into one output pad. |
Custom low level library: libnvds_3d_multisensor_mixer.so
Inputs and Outputs#
Inputs (support N input pads)
ds3d/datamap
Control parameters
config-file
config-content
Output
ds3d/datamap
sink_caps
parsed from config-file:
in_caps:
ds3d/datamap.
src_caps
out_caps:
ds3d/datamap.
Example Inputs X 2 and Output
Input at sink_0 |
Input at sink_1 |
Output |
GstBuffer with ds3d/datamap |
{kVideoBridge2dData:value1},
{kLidarXYZI:value1}, {kLidarXYZI:value2}, … |
{kVideoBridge2dData+0:value1},
Configuration file#
- Example:
name: multisensor_mixer type: ds3d::datamixer in_caps: ds3d/datamap out_caps: ds3d/datamap custom_lib_path: libnvds_3d_multisensor_mixer.so custom_create_function: createMultiSensorMixer config_body: #timeout in milliseconds; timeout: 50 #force_sync == true will force mixer to wait for buffers from ALL inputs force_sync: true
Video mixer configuration options#
config-key |
Description |
Example value |
timeout |
Default: 33 ms |
force_sync |
Mixer will wait for ALL inputs to produce output.
Default: false |
output_object2d_key |
The key name to use when generating datamap output. This key name will be used to save NvDsObjectMeta from NvDsBatchMeta as an array of ds3d::Object2DBbox. |
DS3D::Object2DBboxKey |
