Python Sample Apps and Bindings Source Details#
Sample Application Source Details#
The following table shows the location of the Python sample applications under NVIDIA-AI-IOT/deepstream_python_apps.
Python sample application source details# Reference test application
Path inside the GitHub repo
Description
Simple test application 1
apps/deepstream-test1
Simple example of how to use DeepStream elements for a single H.264 stream: filesrc → decode → nvstreammux → nvinfer (primary detector) → nvdsosd → renderer.
Simple test application 2
apps/deepstream-test2
Simple example of how to use DeepStream elements for a single H.264 stream: filesrc → decode → nvstreammux → nvinfer (primary detector) → nvtracker → nvinfer (secondary classifier) → nvdsosd → renderer.
Simple test application 3
apps/deepstream-test3
Builds on deepstream-test1 (simple test application 1) to demonstrate how to:
Use multiple sources in the pipeline
Use a uridecodebin to accept any type of input (e.g. RTSP/File), any GStreamer supported container format, and any codec
Configure Gst-nvstreammux to generate a batch of frames and infer on it for better resource utilization
Extract the stream metadata, which contains useful information about the frames in the batched buffer
Simple test application 4
apps/deepstream-test4
Builds on deepstream-test1 for a single H.264 stream: filesrc, decode, nvstreammux, nvinfer, nvdsosd, renderer to demonstrate how to:
Use the Gst-nvmsgconv and Gst-nvmsgbroker plugins in the pipeline
Create NVDS_META_EVENT_MSG type metadata and attach it to the buffer
Use NVDS_META_EVENT_MSG for different types of objects, e.g. vehicle and person
Implement “copy” and “free” functions for use if metadata is extended through the extMsg field
USB camera source application
apps/deepstream-test1-usbcam
Simple test application 1 modified to process a single stream from a USB camera.
RTSP output application
apps/deepstream-test1-rtsp-out
Simple test application 1 modified to output visualization stream over RTSP.
Image data access application
apps/deepstream-imagedata-multistream
Builds on simple test application 3 to demonstrate how to:
Access decoded frames as NumPy arrays in the pipeline
Check detection confidence of detected objects (DBSCAN or NMS clustering required)
Modify frames and see the changes reflected downstream in the pipeline
Use OpenCV to annotate the frames and save them to file
Optical flow application
apps/deepstream-opticalflow
Demonstrates how to obtain opticalflow meta data and also demonstrates how to:
Access optical flow vectors as numpy array
Visualize optical flow using obtained flow vectors and OpenCV
Segmentation application
apps/deepstream-segmentation
Demonstrates how to obtain segmentation meta data and also demonstrates how to:
Acess segmentation masks as numpy array
Visualize segmentation using obtained masks and OpenCV
Analytics application
apps/deepstream-nvdsanalytics
Demonstrates how to use the nvdsanalytics plugin and obtain analytics metadata
Runtime source add/delete application
apps/runtime_source_add_delete
Demonstrates how to add and delete input sources at runtime
Face redaction application
apps/deepstream-imagedata-multistream-redaction
Demonstrates how to access image data and perform face redaction
RTSP input/output application
apps/deepstream-rtsp-in-rtsp-out
Multi-stream pipeline with RTSP input and output
Preprocess application
apps/deepstream-preprocess-test
Demonstrates how to use nvdspreprocess plugin and perform custom preprocessing on provided ROIs
Demuxer application
apps/deepstream-demux-multi-in-multi-out
Builds on deepstream-test3 to demonstrate how to use nvstreamdemux plugin to split batches and output separate buffer/streams.
CuPy application
apps/deepstream-imagedata-multistream-cupy
Demonstrates how to access GPU buffer in a multistream source as a CuPy array and modify images in place.
Segmask application
apps/deepstream-segmask
Demonstrates how to extract NvOSD_MaskParams from stream metadata and resize and binarize mask array for interpretable segmentation mask.
Custom binding application
apps/deepstream-custom-binding-test
Demonstrates how to use NvDsUserMeta to attach and extract custom data structure written in Python bindings to/from the buffer.
Python Bindings and Application Development#
This section provides details about DeepStream application development in Python. Python bindings are available here: NVIDIA-AI-IOT/deepstream_python_apps . Read more about Pyds API here.
Prerequisites#
Ubuntu 24.04
DeepStream SDK 8.0 or later
Python 3.12
Gst Python v1.24.1
If Gst python installation is missing on Jetson, follow the instructions in bindings readme.
Running Sample Applications#
Clone the
deepstream_python_appsrepo under<DeepStream ROOT>/sources:git clone https://github.com/NVIDIA-AI-IOT/deepstream_python_apps
This will create the following directory:
<DeepStream ROOT>/sources/deepstream_python_apps
The Python apps are under the
appsdirectory. Go into each app directory and follow instructions in the README.Note
The app configuration files contain relative paths for models.
Pipeline Construction#
DeepStream pipelines can be constructed using Gst Python, the GStreamer framework’s Python bindings. See sample applications main functions for pipeline construction examples.
MetaData Access#
DeepStream MetaData contains inference results and other information used in analytics. The MetaData is attached to the Gst Buffer received by each pipeline component. The metadata format is described in detail in the SDK MetaData documentation and API Guide.
The SDK MetaData library is developed in C/C++. Python bindings provide access to the MetaData from Python applications. Please find Python bindings source and packages at NVIDIA-AI-IOT/deepstream_python_apps.
Memory Management#
Memory for MetaData is shared by the Python and C/C++ code paths. For example, a MetaData item may be added by a probe function written in Python and needs to be accessed by a downstream plugin written in C/C++. The deepstream-test4 app contains such usage. The Python garbage collector does not have visibility into memory references in C/C++, and therefore cannot safely manage the lifetime of such shared memory. Because of this complication, Python access to MetaData memory is typically achieved via references without claiming ownership.
Allocations#
When MetaData objects are allocated in Python, an allocation function is provided by the bindings to ensure proper memory ownership of the object. If the constructor is used, the the object will be claimed by the garbage collector when its Python references terminate. However, the object will still need to be accessed by C/C++ code downstream, and therefore must persist beyond those Python references.
Example: To allocate an NvDsEventMsgMeta instance, use this:
msg_meta = pyds.alloc_nvds_event_msg_meta() *# get reference to allocated instance without claiming memory ownership*
NOT this:
msg_meta = NvDsEventMsgMeta() *# memory will be freed by the garbage collector when msg_meta goes out of scope in Python*
Allocators are available for the following structs:
NvDsVehicleObject: alloc_nvds_vehicle_object()NvDsPersonObject: alloc_nvds_person_object()NvDsFaceObject: alloc_nvds_face_object()NvDsEventMsgMeta: alloc_nvds_event_msg_meta()NvDsEvent: alloc_nvds_event()NvDsPayload: alloc_nvds_payload()Generic buffer: alloc_buffer(size)
String Access#
Some MetaData structures contain string fields. Sections below provide details on accessing them.
Setting String Fields#
Setting a string field results in the allocation of a string buffer in the underlying C++ code.
obj.type = "Type"
This will cause a memory buffer to be allocated, and the string “TYPE” will be copied into it. This memory is owned by the C code and will be freed later. To free the buffer in Python code, use:
pyds.free_buffer(obj.type)
Note
NvOSD_TextParams.display_text string now gets freed automatically when a new string is assigned.
Reading String Fields#
Directly reading a string field returns C address of the field in the form of an int, for example:
obj = pyds.NvDsVehicleObject.cast(data);
print(obj.type)
This will print an int representing the address of obj.type in C (which is a char*).
To retrieve the string value of this field, use pyds.get_string(), for example:
print(pyds.get_string(obj.type))
Casting#
Some MetaData instances are stored in GList form. To access the data in a GList node, the data field needs to be cast to the appropriate structure. This casting is done via cast() member function for the target type:
NvDsBatchMeta.cast
NvDsFrameMeta.cast
NvDsObjectMeta.cast
NvDsUserMeta.cast
NvDsClassifierMeta.cast
NvDsDisplayMeta.cast
NvDsLabelInfo.cast
NvDsEventMsgMeta.cast
NvDsPersonObject.cast
In version v0.5, standalone cast functions were provided. Those are now deprecated and superseded by the cast() functions above:
glist_get_nvds_batch_meta
glist_get_nvds_frame_meta
glist_get_nvds_object_meta
glist_get_nvds_user_meta
glist_get_nvds_classifier_meta
glist_get_nvds_display_meta
glist_get_nvds_label_info
glist_get_nvds_event_msg_meta
glist_get_nvds_vehicle_object
glist_get_nvds_person_object
Example:
l_frame = batch_meta.frame_meta_list
frame_meta = pyds.NvDsFrameMeta.cast(l_frame.data)
Callback Function Registration#
Custom MetaData added to NvDsUserMeta require custom copy and release functions. The MetaData library relies on these custom functions to perform deep-copy of the custom structure, and free allocated resources. These functions are registered as callback function pointers in the NvDsUserMeta structure. Callback functions are registered using these functions:
pyds.set_user_copyfunc(NvDsUserMeta_instance, copy_function)
pyds.set_user_releasefunc(NvDsUserMeta_instance, free_func)
Note
Callbacks need to be unregistered with the bindings library before the application exits. The bindings library currently keeps global references to the registered functions, and these cannot last beyond bindings library unload which happens at application exit. Use the following function to unregister all callbacks:
pyds.unset_callback_funcs()
See the deepstream-test4 sample application for an example of callback registration and deregistration.
Limitation: The bindings library currently only supports a single set of callback functions for each application. The last registered function will be used.
Optimizations and Utilities#
Python interpretation is generally slower than running compiled C/C++ code. To provide better performance, some operations are implemented in C and exposed via the bindings interface. This is currently experimental and will expand over time. The following optimized functions are available:
pyds.NvOSD_ColorParams.set(double red, double green, double blue, double alpha)This is a simple function that performs the same operations as the following:
txt_params.text_bg_clr.red = red txt_params.text_bg_clr.green = green txt_params.text_bg_clr.blue = blue txt_params.text_bg_clr.alpha = alpha
These are performed on each object in deepstream_test_4.py, causing the aggregate processing time to slow down the pipeline. Pushing this function into the C layer helps to increase performance.
generate_ts_rfc3339 (buffer, buffer_size)This function populates the input buffer with a timestamp generated according to RFC3339:
%Y-%m-%dT%H:%M:%S.nnnZ\0
Image Data Access#
Decoded images are accessible as NumPy arrays via the get_nvds_buf_surface function. This function is documented in the API Guide.
See the deepstream-imagedata-multistream sample application for an example of image data usage.
