Gst-nvvideotestsrc#
The Gst-nvvideotestsrc plugin uses CUDA to generate video test data in a variety of formats and patterns that is written directly to GPU output buffers using the video/x-raw(memory:NVMM) data type.
The plugin can also be used to input raw video and generate GPU buffers at the output. The plugin provides properties to introduce jitter in buffer latencies which can be used to simulate network conditions locally.
Note
The Gst-nvvideotestsrc plugin is currently only supported on X86.
Outputs#
This section summarizes the outputs of the Gst-nvvideotestsrc plugin.
  • Output
    • Gst Buffer with a test pattern
    • Video Format: NV12, I420, RGBA, UYVP, BGRA64_LE, RGB10A2_LE (NVMM)
  • Control parameters
    • gpu-id
    • animation-mode
    • memtype
    • blocksize
    • pattern
Gst Properties#
The following tables describes the Gst properties of the Gst-nvvideotestsrc plugin.
nvvideotestsrc plugin properties#
Property
Meaning
Type and Range
Example notes
animation-mode
For animating patterns, the counter that controls the animation.
Enum “GstNvVideoTestSrcAnimationMode” Default: 0, “frames”
(0): frames - Frame count
(1): wall-time - Wall clock time
(2): running-time - Running time
animation-mode=0
blocksize
Size in bytes to read per buffer (-1 = default)
Unsigned Integer. Range: 0 - 4294967295 Default: 4096
blocksize=4096
gpu-id
ID of the GPU where the buffers are allocated
Unsigned Integer. Range: 0 - 2147483647 Default: 0
gpu-id=0
num-buffers
Number of buffers to output before sending EOS (-1 = unlimited)
Integer. Range: -1 - 2147483647 Default: -1
num-buffers=300
pattern
Type of test pattern to generate
Enum “GstNvVideoTestSrcPattern” Default: 0, “smpte”
(0): smpte - SMPTE color bars
(1): mandelbrot - Mandelbrot set
(2): gradient - Gradient
pattern=1
memtype
Type of the memory used for the allocated buffers
Enum “NvBufSurfaceMemType” Default: 2, “Device CUDA memory”
(1): Host/Pinned CUDA memory - host
(2): Device CUDA memory - device
(3): Unified CUDA memory - unified
memtype=2
do-timestamp
Apply current stream time to buffers
Boolean. Default: false
do-timestamp=true
is-live
Whether to act as a live source. Introduces latency based on FPS setting on src caps
is-live=true
location
File location for raw video file input. When file location is not specified, pattern gets used.
String. Default: NULL
location=test.rgba
file-loop
Loop through the input file until num-buffers (if specified) or infinitely
file-loop=true
max-jitter
Maximum jitter (in milliseconds) that can be applied to each buffer. Only applicable when is-live=true. A random jitter ranging up to “max-jitter” gets applied to each buffer.
Integer, ≥0 Default: 0
max-jitter=100
fixed-jitter
List of fixed jitter values (in milliseconds). The list will be looped through for the entire sequence. Only applicable when is-live=true. If “fixed-jitter” is specified “max-jitter”(if specified) is ignored.
Semicolon delimited integer array. all values ≥0. Default: “”
fixed-jitter=30;40;100;0;0
horizontal-speed
Horizontal speed of the SMPTE pattern in pixels per frame. Positive values move to the left; negative to the right
Integer. Default: 0
horizontal-speed=1
How to test#
nvvideotestsrc is currently supported for X86 only. support with “Jetson + dGPU” is not yet enabled.
Run following reference gst-launch-1.0 pipeline on DGPU setup.
  1. Default SMPTE Pattern - 720p 60Hz
gst-launch-1.0 nvvideotestsrc ! queue ! nveglglessink -e
  1. Mandelbrot Pattern - 1080p 60Hz
    gst-launch-1.0 nvvideotestsrc pattern=mandelbrot ! 'video/x-raw(memory:NVMM), width=1920, height=1080, framerate=60/1' ! queue ! nveglglessink -e
  2. Gradient Pattern - 720p 60Hz
gst-launch-1.0 gst-launch-1.0 nvvideotestsrc pattern=2 ! queue ! nveglglessink -e
