Gst-nvds3dfilter#
The Gst-nvds3dfilter plugin is a customizable plugin which provides a custom library interface to load component ds3d::datafilter.
The Plugin is fully configured through YAML format content or file. sink_caps and src_caps is also configurable.
Gst-nvds3dfilter
Custom library Interfaces#
The plugin parse the config file or content and set SinkCaps and SrcCaps. load a custom ds3d::datafilter from custom_lib_path. Create this datafilter by custom_create_function.
See more details of ds3d::datafilter in DS3D Manual ds3d::datafilter- DS3D Custom DataFilter.
Inputs and Outputs#
  • Inputs
    • NvDs3DBuffer or
    • Metadata (NvDsBatchMeta) which has user meta NVDS_3D_DATAMAP_META_TYPE
  • Control parameters
    • config-file
    • config-content
  • Output
    • NvDs3DBuffer or
  • sink_caps
    • parsed from filed of in_caps: ds3d/datamap or any user specified in_caps:.
  • src_caps
    • parsed from filed of out_caps: ds3d/datamap or any user specified out_caps:.
Configuration file#
Example:
type: ds3d::datafilter
custom_lib_path: libnvds_tritoninferfilter.so
custom_create_function: createLidarInferenceFilter
config_body:
  in_streams: [color, depth]
Gst-nvds3dfilter properties Specifications#
Gst-nvds3dfilter Properties.#
Properties
Description
Release
config-content
yaml config content
DS 6.1
config-file
yaml config file path
DS 6.1
Supported DS3D filter custom libs#
These custom libs are part of DeepStream release package.
DS3D Data filter
Data filter custom library
Creating Instance Function
Description
Multi-Modal-triton-infer
Multi-modal sensor data inference library, see details in libnvds_tritoninferfilter Configuration Specifications
Data-alignment
libnvds_3d_alignment_datafilter.so
createLidarAlignmentFilter
lidar/camera Sensor Intrinsic and Extrinsic parameters and alignment
Depth-2-point-cloud
libnvds_3d_depth2point_datafilter.so
createDepth2PointFilter
Convert Image Depth data into 3D Point Cloud data, see details in Custom datafilter libnvds_3d_depth2point_datafilter Configuration Specifications
Custom ds3d::datafilter library: libnvds_3d_alignment_datafilter.so#
The input kLidarXYZI from ds3d/datamap buffer is converted into kLidarXYZIAligned. This is done by a series of transformations.
Transformations done inside the alignment filter are described below with the help of KITTI Data format and calibration data references.
Transformations#
Transform ID
Details
AL_TR_1
Euclidean transformation from lidar to reference camera.
Velodyne points convert to reference camera (cam0) coordinate. Output = matrixmultiply(Tr_velo_to_cam, input_lidar_point)
AL_TR_2
Note: AL_TR_2 is done on top of AL_TR_1.
Alignment filter expect users to set lidar_to_cam_extrisic with both Tr_velo_to_cam and R0_rect. Rotation to account for rectification for points in the reference camera. Output = matrixmultiply(matmul(R0_rect, Tr_velo_to_cam), input_lidar_point)
AL_TR_3
[Optional and is configured to ON/OFF with config: align_to_intrinsic]
Projective transformation from rectified reference camera frame (AL_TR2) to cam[2]. Note: Alignment filter expect users to set cam_intrinsic with P_rect[2]. Output = matrixmultiply(matmul(P_rect[2], R0_rect, Tr_velo_to_cam), input_lidar_point). Note: P_rect[2], R0_rect, Tr_velo_to_cam are all converted to 4X4 matrices.
In DeepStream world:
Transformations DeepStream vocab#
cam_intrinsic
P0 OR P_rect[0]
is a 3X4 matrix = matrix_multiply(R0_rect, Tr_velo_to_cam)
More info here: Alignment configuration Options.
Inputs and Outputs#
  • Inputs
    • ds3d/datamap
    • config-file
    • config-content
  • Output
    • ds3d/datamap
Configuration file#
Example:
link_to: ds3d_aligned_render
custom_lib_path: libnvds_3d_alignment_datafilter.so
custom_create_function: createLidarAlignmentFilter
config_body:
  cam_width: 1242
  cam_height: 375
  cam_intrinsic: [7.215377000000e+02, 0.000000000000e+00, 0.000000000000e+00, 0.000000000000e+00, 7.215377000000e+02, 0.000000000000e+00, 6.095593000000e+02, 1.728540000000e+02, 1.000000000000e+00, 4.485728000000e+01, 2.163791000000e-01, 2.745884000000e-03]
  #lidar_to_cam_extrisic is a 3X4 matrix = matrix_multiply(R0_rect, Tr_velo_to_cam);
  #lidar_to_cam_extrisic is in column major order
  #For more details on R0_rect and Tr_velo_to_cam, please check: https://github.com/lkk688/3DDepth/blob/main/README.md
  lidar_to_cam_extrisic: [2.34773698e-04, 1.04494074e-02, 9.99945389e-01, -9.99944155e-01, 1.05653536e-02, 1.24365378e-04, -1.05634778e-02, -9.99889574e-01, 1.04513030e-02, -2.79681694e-03, -7.51087914e-02, -2.72132796e-01]
  #cam input keys to ratain in the output datamap
  cam_input_keys: [DS3D::ColorFrame+1]
  #lidar input and output/aligned keys to retain in the output datamap
  #note: lidar_input_keys and lidar_aligned_keys map the same sensor data
  lidar_input_keys: [DS3D::LidarXYZI+0]
  lidar_aligned_keys: [DS3D::LidarAlignedXYZIKey]
  max_points: 2073600
  mem_pool_size: 32
  align_to_intrinsic: false
  lidar_element_size: 4
Configuration options#
Alignment config_body#
config-key
Description
Example value
cam_width
The width of camera image used for video input.
1242
cam_height
The height of camera image used for video input.
375
cam_intrinsic
Is a 3X4 matrix in column major.
Projective transformation from rectified reference camera frame to cam in use for video input.
More info here (see documentation for P_rect[i]; Note: we use P_rect[2] for the default config in ds3d_lidar_video_alignment_render.yaml).
[3X4] matrix in column major.
For more details on R0_rect and Tr_velo_to_cam, please check: lkk688/3DDepth
lidar_input_key
The keyname to use for lidar input from the input datamap buffer.
DS3D::LidarXYZI+0
lidar_aligned_key
The keyname to use for lidar output newly added by alignment filter into the output datamap buffer.
max_points
Maximum number of Lidar points in the input datamap at:
{lidar_input_key: points}.
2048000
mem_pool_size
Alignment filter maintains an internal pool.
This is the pool size the user want to allocate.
4
align_to_intrinsic
If true:
AL_TR_3 is done.
If false:
AL_TR_2 is done.
True
lidar_element_size
The size of output aligned lidar data points.
= 3 means XYZ = 4 means XYZI (I is the intensity) More details here.
4
Custom ds3d::datafilter library: libnvds_3d_depth2point_datafilter.so#
