Gst-nvjpegdec#
The Gst-nvjpegdec plugin decodes images on both dGPU and Jetson platforms. It is the preferred method for decoding JPEG images.
On the dGPU platform this plugin is based on the libnvjpeg
library, part of the CUDA toolkit. On Jetson it uses a platform-specific hardware accelerator.
The plugin uses an internal software parser to parse JPEG streams. Thus, there is no need to use a jpegparse
open source plugin separately to parse the encoded frame.
The plugin accepts a JPEG encoded bitstream and produces RGB output on the dGPU platform and produces I420 output on the Jetson platform. This plugin is not applicable
on (ARM + dGPU) platforms like arm-sbsa. Use nvimagedec plugin instead. OSS nvjpegdec plugin may be listed in these platforms, but don’t use that.
Inputs and Outputs#
Inputs
Elementary JPEG
Control parameters
gpu-id (dGPU only)
DeepStream (Jetson only)
Output
Gst Buffer with decoded output in RGB format for dGPU, and I420 format for Jetson
Features#
The following table summarizes the features of the Gst-nvjpegdec plugin.
Feature |
Description |
Release |
Supports JPEG Decode |
DS 4.0 |
Supports MJPEG Decode |
DS 4.0 |
Gst Properties#
The following table summarizes the Gst properties of the Gst-nvjpegdec plugin.
Property |
Meaning |
Type and Range |
Example and Notes |
Platforms |
gpu-id |
Device ID of GPU to use for decoding. |
Integer, 0 to 4,294,967,295 |
gpu-id=0 |
dGPU |
