Gst-nvimagedec#
The Gst-nvimagedec plugin decodes images on dGPU and (ARM + dGPU) platforms like arm-sbsa. This plugin is based on the libnvjpeg library which part of the CUDA toolkit. The plugin accepts a JPEG encoded bitstream and produces RGB output. jpegparse plugin should be used to parse the encoded frame before nvimagedec, since it does not have an internal bitstream parser.
Inputs and Outputs#
  • Inputs
    • Elementary JPEG
  • Control parameters
    • gpu-id
    • needs-pool
  • Output
    • Gst Buffer with decoded output in RGB format.
Features#
The following table summarizes the features of the Gst-nvimagedec plugin.
Gst-nvimagedec plugin features#
Feature
Description
Release
Supports toggling buffer pool
plugin can toggle output buffer pool based on use cases
DS 6.4
Gst Properties#
The following table summarizes the Gst properties of the Gst-nvimagedec plugin.
Gst-nvimagedec plugin gst properties#
Property
Meaning
Type and Range
Example and Notes
Platforms
gpu-id
Device ID of GPU to use for decoding.
Integer, 0 to 4,294,967,295
gpu-id=0
dGPU, ARM+dGPU
needs-pool
Enabling / Disabling output buffer pool
Boolean, 0 or 1
needs-pool=1
dGPU, ARM+dGPU
